I installed maxidot cluster, changed BCM from 087M to 087AD, installed sensors ,tpms module wired and coded.
TPMS display failed to appear on cluster
VCDS autoscan shows tyre pressure status ok. The tpms module detects the sensor position, current pressure under measured values in address 65 but fails to display on cluster.
Here is the latest autoscan after tpms installation.
Tuesday,25,June,2019,04:13:51:09269
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 7 x64
VCDS Version: 19.6.0.2 (x64) HEX-V2 CB: 0.4505.4
Data version: 20190529 DS308.0
www.Ross-Tech.com
VIN: MEXL15606GT048293 License Plate:
Chassis Type: 60-VW25 (6R0)
Scan: 01 02 03 04 08 09 10 15 17 19 25 44 56 65
VIN: MEXL15606GT048293 Mileage: 42600km-26470miles
56-Radio -- Status: OK 0000
Address 01: Engine (J623-CBZB) Labels:. 03F-906-070-CBZ.clb
Part No SW: 03F 906 070 KC HW: 03F 907 309 AJ
Component: SIMOS10.22AH10 6270
Revision: --H10--- Serial number: 00000000000000
Coding: 00250056232400080000
Shop #: WSC 53863 002 1048576
ASAM Dataset: EV_ECM12TFS02103F906070KC 004006
ROD: EV_ECM12TFS02103F906070FP.rod
VCID: 6D84C0CEAD13BD3F117-8038
Readiness: 0110 0101
Part No SW: 0AM 300 065 N HW: 0AM 927 769 D
Component: GSG DSG AG7 431 6502
Revision: 00043014 Serial number: CU501508317273
Coding: 0000020
Shop #: WSC 01260 002 1048576
VCID: 3A2E3B92A05DDA87C45-806E
Part No SW: 6R0 907 379 BN HW: 6R0 907 379 AS
Component: ESP9.0i front H03 0001
Serial number: --------------
Coding: 62DD2463422703C8461624724254C0800908
Shop #: WSC 29230 002 1048576
VCID: 0B40AE56B3C7130FAF3-805E
Serial number: 10051504650275
Coding: 01
Shop #: WSC 00000 000 00000
ROD: EV_LWSKLOVW25X.rod
VCID: 7EA6F782F07536A7B8D-802A
Part No SW: 6R0 907 044 Q HW: 6R0 907 044 Q
Component: Climatronic H12 0615
Revision: V0000000
VCID: 41DC4C7EC18B895F85F-8014
Part No SW: 6R0 937 087 AD HW: 6R0 937 087 AD
Component: BCM PQ25 H+4 H42 0452
Revision: BF042001 Serial number: 5400 033190412
Coding: 3AB02BFF08A10000003800C07C2B9490F0C041FF608C0000200000000000
Shop #: WSC 12345 123 12345
VCID: 7F580A86F7FF3FAFB3B-802A
Subsystem 1 - Part No SW: 6R0 959 802 BH HW: 6R0 959 802 BH Labels: 6R0-959-802.CLB
Component: J386__TSG_FT 003 8612
Serial number: KU0KU015041441050460
Coding: 1400B3
Subsystem 2 - Part No SW: 6R0 959 801 BC HW: 6R0 959 801 BC Labels: 6R0-959-801.CLB
Component: J387__TSG_BT 003 8612
Serial number: KU0KU014041441047765
Coding: 0400B3
Subsystem 3 - Part No SW: 6C0 959 442 HW: 6C0 959 442
Component: E221__MFL-TAT H04 0019
Serial number: 1971517275001536AB2B
Coding: 240000
Subsystem 4 - Part No SW: 6R0 959 811 L HW: 6R0 959 811 L
Component: ------------- 006 5550
Serial number: 13102580150623202239
Coding: 020000
Subsystem 5 - Part No SW: 6R0 959 812 L HW: 6R0 959 812 L
Serial number: 13202581150812164218
Coding: 020000
2 Faults Found:
011 - Open Circuit
Fault Status: 01101011
Fault Priority: 2
Fault Frequency: 1
Reset counter: 0
Mileage: 42603 km
Time Indication: 0
Date: 2019.06.25
Time: 00:35:38
03432 - Activation of Right Parking Light
011 - Open Circuit
Fault Priority: 2
Fault Frequency: 1
Reset counter: 0
Mileage: 42603 km
Time Indication: 0
Date: 2019.06.25
Time: 00:35:38
Address 10: Park/Steer Assist (J446) Labels:| 7E0-919-475.clb
Part No SW: 7E0 919 475 J HW: 7N0 919 475
Component: PARKHILFE 8K H06 0105
Revision: -------- Serial number: 28261224902578
Coding: 108101
Shop #: WSC 02756 790 50316
VCID: 392C249EA9DBD19FCDF-806C
Part No SW: 6R0 959 655 J HW: 6R0 959 655 J
Revision: -------- Serial number: 003GW0118WCJ
Coding: 003036
Shop #: WSC 01234 785 00200
ROD: EV_AirbaVW10BPAVW250.rod
VCID: 49CC545EF93B411F5DF-801C
Part No SW: 6RD 920 870 A HW: 6RD 920 870 A
Component: KOMBI H05 0805
Coding: 140C01
Shop #: WSC 00046 123 12345
VCID: 47C85266EF2FB76F4BB-8012
Address 19: CAN Gateway (J533) Labels: None
Part No SW: 6R0 909 901 HW: 6R0 937 087 AD
Component: GW-K-CAN TP20 H42 0452
Revision: BF042001
Coding: 002300
VCID: 74B2D5AACEB96CF7DE9-8020
Component: IMMO H05 0805
ROD: EV_Immo_UDS_VDD_RM09.rod
VCID: 6A8ECBD29CFDAA07745-803E
Address 44: Steering Assist (J500) Labels:| 1Sx-909-144-44.clb
Part No SW: 1S2 909 144 P HW: 1S2 909 144 P
Component: EPS_ECU H61 1702
Coding: 0001000000000000
ROD: EV_SteerAssisNSK_014.rod
VCID: 41DC4C7EC10B895F85F-8014
Part No SW: 6RD 035 187 A HW: 6RD 035 187 A
Component: MIB2-S-R-CN 025 0210
Revision: -----001 Serial number: 01855GD0000318
Coding: 00000440010001
Shop #: WSC 00081 790 00118
VCID: 45D4586ED5A3A57FB97-8010
Address 65: Tire Pressure (J502) Labels: 3AA-907-273.clb
Part No SW: 3AA 907 273 F HW: 5Q0 907 273
Component: RDKBERU30 H04 0011
Serial number: 40000000058983
ROD: EV_RDKBERU30_005.rod
VCID: 372822A69FCFC7EF3BB-8062
End----------(Elapsed Time: 01:10, VBatt start/end: 13.7V/13.8V)-----------
I wonder what am I missing
