A borescope you say... well aren’t those cool little things!?wolfie wrote: Tue May 25, 2021 6:44 pm One thing thing that may be worth a go is use a cheapo borescope to get in behind the panel. Cheapo ones that you plug into your phone can be had for under £20. Stand alone around £40. Doesn't necessarily mean you will be able to get at it of fix it. But at least you might spot where it's sneaking in.
Standing water in front passenger footwell - Mk9 6C 1L Polo Match
nick7wilson
- Drives: Mk9 6C 1L Polo Match
Re: Standing water in front passenger footwell - Mk9 6C 1L Polo Match
nick7wilson
Hey RUM4MO, looks like it’s probably one of these options that you initially suggested...
Should I simply spray all the seams with a sealer?
On the righthand-side of the windscreen, the rubber trim is not fixed properly against the bottom edge of the windscreen - but it is fixed properly on the bottom lefthand-side and middle.RUM4MO wrote: Fri Feb 19, 2021 7:31 pm Or, has the windscreen ever been replaced and so not sealed properly.
The mechanic has noticed it’s had a replacement wing at some point and suggested the same as you - maybe the seam sealer has not been done correctly.RUM4MO wrote: Fri Feb 19, 2021 7:31 pm Or has there been any crash damage repair on that side and panel seam sealer not been done correctly.
wolfie
Cavity wax might be worth a go as it has a degree of creep into cracks and such. The Bilt Hamber stuff is supposed to be pretty good. All going to be a bit hit and miss unless you can isolate the source of the leak.
https://www.bilthamber.com/corrosion-pr ... /dynax-s50
Cavity wax wont stop water intrusion
