ABS coding.
Re: ABS coding.
Didn ou check the fuse for the steering angle sensor? Its one of the tiny ones
Macattack
- Drives: Polo 6R 1.2tdi
Re: ABS coding.
Hi no I’m not with the car at present but I will tomorrow. As I said earlier all was fine until loosing the code so presumed it was a coding issue.
Thank you for your advice.
Macattack
Re: ABS coding.
Hi sorry for delays in getting back to you. , I’ve checked fuses etc Double checked I entered the code you provided correctly
Still coming up with 00778 steering angle sensor. And 00493 ESP sensor unit.
Checking back in the history there is no faults related to this. Just engine running issue codes
Macattack
Re: ABS coding.
Hi when I try to connect to steering angle sensor it comes up with no communication. So am unable to give any info regarding steering angle readings
