Hiya mate e of the bay http://www.ebay.co.uk/itm/S25-1156-P21W ... _855wt_922 it shows the silver bulbs in his posting an i had a bit of a to do with him. As he sends of the red housing type even though he shows silver hence why i stripped it off
Are you gonna strip the red off? If so i used wet and dry 400 grit, then 800 grit then 1200 grit, in the lovers i used my dremmel with a thin brass wheel. Then finished off with autosol
CANDYMAN wrote:Are you gonna strip the red off? If so i used wet and dry 400 grit, then 800 grit then 1200 grit, in the lovers i used my dremmel with a thin brass wheel. Then finished off with autosol
So i thought i would post some photos of the led boot light bulb i bought on e-bay! It is a 30 led canbus safe led, you get 2 in the packet.
Here are some pics of the little bad boys
Effectively there are 12 led's facing the lens i will take some night shots later
Im thinking of getting 2 of these and fit them to the flat part of the central front interior light then plug the adapter in where the bulb normally goes have measured and they will fit great just need to join the wiring together.
