Hello Александрfiregrafik wrote: Mon Jan 15, 2018 4:46 am Hello Szymon!
Could you please write the PR-codes of your current brakes front and rear separately.
Also, have you checked, does your current axle have the holes for mounting the disk brake supports?
In front I need to change wheels bearing housing to these:
because I want to install 310mm disks.
6Q0407255S - wheel bearing housing, left
6Q0407256S - wheel bearing housing, right
(PR-1ZC PR-1ZD PR-1ZR PR-1LN)
