T73b/
18 can powertrain low = T20a/6
19 can powertrain high = T20a/16
20 can convenience high
21 can convenience low
22 can diag low = T20a/9 = T16b/14
23 can diag high = T20a/19 = T16b/6
24 LIN to G578, G213, J245, A209 = T20a/12
54 Can dash high = T20a/8
57 Can dash low = T20a/18
If you can communicate to the BCM, i'd say you'd also have to be able to communicate with devices on the CAN convenience line, these wirings should be there in your BCM 088D
In the Polo 6R, the gateway is T20a
The diagnistic interface is T16b
- Drives: T5
Ok steady progress at last........! Thanks again for your pin outs.
With the CAN gateway disconnected and wires run direct to the BCM, the CANBUS is back up and able to view each module, apart from the stereo, which I believe occupies
J553
T20B/10 - Can Low
T20B/20 - Can High
Do you know where these would have to be connected to on the BCM?
J553
T20B/10 - Can Low
T20B/20 - Can High
In think that this is can convenience and not necessary
- Drives: T5
Thanks for the info, I have linked up the stereo canbus wires with the convenience canbus in the BCM, and voila, the stereo is now recognised and works, so those wires were required it turns out. With the canbus disconnected, the stereo does not switch on with the ignition and asks for the radio code ![☺️](//cdn.jsdelivr.net/gh/twitter/twemoji@latest/assets/svg/263a.svg)
Good job. Verify everything works correctly (including instrument lights)
- Drives: T5
Thanks again for your help. Everything is back up and running. Have been for a short drive this evening, and all functions seem to be good ![👍🏻](//cdn.jsdelivr.net/gh/twitter/twemoji@latest/assets/svg/1f44d-1f3fb.svg)
- Drives: VW t5.1 GP bitdi 4motion
Thanks for this Adam87Adam87 wrote: ↑Sun Mar 08, 2020 11:55 am If it helps the left headlight is part of the bumper loom, when I retrofitted xenon headlights I replaced the bumper loom (I was also adding from PDC which is part of that loom) then you will only need to run the extra wires to the coupling point behind the right headlight and also gives you a new plug for the left headlight
![Very Happy :D](./images/smilies/icon_biggrin.gif)
I suppose the old wiring loom from the bumper could come in handy for "parts".
This is taking me an age to get done as I need the van for work pretty much 24hrs a day, (firefighter) it was not possible to have it out of use for 2-3 days or so while I carried this out and also juggled child care and school transport etc.
But now the schools are off and my other half is working from home, I now have the use of her VW UP to get me to work.
Hope to get stuck into it soon.
- Drives: T5
Could I just ask a quick question?
I have installed factory xenon headlights to my T5, and coded the van to allow them to “work” for the moment. I have replaced the original headlight T10 connectors with T14 and transferred the pins for a seamless install (I didn’t want to use a harness)
Now, the van already has a 10 pin connector from factory for the light switch.
How much does the retrofit wiring differ from the 17 pin connector looms that you guys have made?
Cheers!
Cheers!
- Drives: T5
If there is still anybody monitoring this thread, I need to find a way to code the DRL’s to dim whilst the sidelights and headlights are on. I have wired them up to the specified schematics on this thread, and work correctly apart from dim.
Any help will be appreciated!
Can you post a scan please?
- Drives: T5
- Drives: T5
Of course, it looks a bit of a mess ![Sad :(](./images/smilies/icon_sad.gif)
56-Radio -- Status: OK 0000
5F-Information Electr. -- Status: Not registered 0011
61-Battery Regul. -- Status: Malfunction 0010
77-Telephone -- Status: Not registered 0001
Address 01: Engine (J623-CAAA) Labels:. 03L-906-022-CAA.clb
Part No SW: 03L 906 019 ES HW: 03L 907 309 L
Component: R4 2,0L EDC H36 3988
Revision: 22H36--- Serial number: 00000000000000
Coding: 01114012232401080000
Shop #: WSC 47712 001 1048576
ASAM Dataset: EV_ECM20TDI01103L906019ES 003008
ROD: EV_ECM20TDI01103L906019DC_003.rod
VCID: 005980D64A88056B532-8054
2 Faults Found:
7144 - Please Check DTC Memory in CAN Gateway (J533)
U1008 00 [108] - -
[Diagnostic interface for data busRead out DTC]
Fault Status: 00000001
Fault Priority: 2
Fault Frequency: 4
Mileage: 215624 km
Date: 2020.05.04
Time: 09:27:54
Engine speed: 992.00 /min
Normed load value: 22.0 %
Vehicle speed: 13 km/h
Coolant temperature: 19 °C
Intake air temperature: 16 °C
Ambient air pressure: 1020 mbar
Voltage terminal 30: 14.140 V
ACC target acceleration: 0.000 m/s²
ACC control module received status-Bits 0-7: 00000110
Active brake system error status-Bits 0-7: 00000000
Status of ACC/CCS acceleration interface-Bits 0-7: 00000000
Acceleration: -0.197 m/s²
Engine status: COENG_RUNNING
Cruise Control System (CCS): status-Bits 0-7: 00101100
4985 - Cylinder 2 Glow Plug Circuit (Q11)
P0672 00 [101] - Electrical Fault
Fault Priority: 2
Fault Frequency: 1
Mileage: 215623 km
Date: 2020.05.04
Time: 09:26:49
Engine speed: 925.00 /min
Normed load value: 44.3 %
Vehicle speed: 0 km/h
Coolant temperature: 13 °C
Intake air temperature: 13 °C
Voltage terminal 30: 13.960 V
Electric auxiliary heater: shut-off conditions-Bits 0-7: 00000000
Electric auxiliary heater: relay activation-Bits 0-7: 00000000
Preheat time: 1500 ms
Glow status-Bits 0-7: 00000000
Glow status-Bits 0-7: 10110000
Glow cycles above temperature threshold-Bits 0-7: 00000000
Glow cycles above temperature threshold-Bits 0-7: 00000111
Glow cycles below temperature threshold-Bits 0-7: 00000000
Glow cycles below temperature threshold-Bits 0-7: 00000110
Outside air temperature: 13.5 °C
Readiness: 0 0 0 0 1
Address 03: ABS Brakes (-----) Labels: 7E0-907-37x-MK25AXT.clb
Part No SW: 7E0 907 379 J HW: 7E0 907 379 E
Component: ESP MK25A XT H43 0109
Revision: 00H43001
Coding: 508724AD89A60A9724A7917AA96490
Shop #: WSC 02736 790 49152
VCID: 392F2D32695294A354C-806C
Address 08: Auto HVAC (J301) Labels:| 7E5-907-047.clb
Part No SW: 7E5 907 047 BC HW: 7E5 907 047 BC
Component: Climatic-T5 H19 0404
Revision: 00001009
Coding: 0000000003
Shop #: WSC 02736 790 50316
ROD: EV_ClimaT5Basis.rod
VCID: 71BFD51271221CE3ACC-8024
1 Fault Found:
13701936 - Function Restriction due to Faults in Other Modules
U1113 00 [008] - -
[Steuergerät für Bordnetz - bitte Fehlerspeicher auslesen]
Fault Priority: 6
Fault Frequency: 16
Reset counter: 164
Mileage: 215623 km
Date: 2020.05.04
Time: 03:01:21
Part No SW: 7E0 937 090 B HW: 7E0 937 090
Component: BCM PQ25 Max4 H81 0744
Revision: B9081001 Serial number: 0982 018170606
Coding: A0A0303A0E61242392284F702F6B8C55D680660F60871940300000000000
Shop #: WSC 02737 534 856573
VCID: 2A0D027E9CF42F3B2D6-807E
Subsystem 1 - Part No SW: 7E0 959 801 B HW: 7E0 959 801 B Labels: 7E0-959-80X-V1.CLB
Component: J386__TSG_FT 002 3311
Coding: 410000
Subsystem 2 - Part No SW: 7E0 959 802 B HW: 7E0 959 802 B Labels: 7E0-959-80X-V1.CLB
Component: J387__TSG_BT 002 3311
Coding: 410000
Subsystem 3 - Part No: 7E1 951 172
Component: DWA-Sensor 00 001 0104
Subsystem 4 - Part No: 1K0 951 605 C
Component: LIN BACKUP HO H05 1501
Subsystem 5 - Part No: 7E1 951 172
Address 10: Park/Steer Assist (J446) Labels:| 7E0-919-475.clb
Part No SW: 7E0 919 475 D HW: 7E0 919 475
Component: PARKHILFE 4K H11 0013
Revision: -------- Serial number: 47361206000548
Coding: 108001
ASAM Dataset: EV_VW75XParkAssis4K A01006
ROD: EV_VW75XParkAssis4K_A01_VN75.rod
VCID: 33331F1A4BBE6EF39E0-8066
Part No SW: 7E0 959 655 B HW: 7E0 959 655 B
Component: VW10Airbag009 H07 0013
Revision: -------- Serial number: 003HL00B1NC2
Coding: 000000000000000000000000000000003039
Shop #: WSC 02734 790 50316
ROD: EV_AirbaVW10BPAVN750.rod
VCID: 3537210245CA70C3B04-8060
Part No SW: 7E0 920 970 E HW: 7E0 920 970 E
Component: KOMBI H04 0305
Coding: 760A01
ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A04113
VCID: 2C0104669680310BDFA-8078
Part No SW: 7E0 909 901 HW: 7E0 937 090
Component: GW-K-CAN TP20 H81 0744
Revision: B9081001
Coding: 042307
VCID: 6889B8764278DD2BFB2-803C
2 Faults Found:
000 - -
Fault Status: 01100000
Fault Priority: 2
Fault Frequency: 2
Reset counter: 255
Mileage: 215623 km
Time Indication: 0
Date: 2014.09.25
Time: 02:43:38
03406 - Control Module for Battery Monitoring
Fault Status: 00100100
Fault Priority: 2
Fault Frequency: 19
Reset counter: 165
Mileage: 215623 km
Time Indication: 0
Date: 2014.09.25
Time: 03:20:22
Component: IMMO H04 0305
Serial number:
Shop #: WSC 00000 000 00000
ROD: EV_Immo_UDS_VDD_RM09_VW31.rod
VCID: 6A8DC27E5CF4EF3BED6-803E
End----(Elapsed Time: 01:38, VBatt start/end: 11.8V/11.8V. VIgn 11.8V)-----
09 BCMIbanezuv777 wrote:If there is still anybody monitoring this thread, I need to find a way to code the DRL’s to dim whilst the sidelights and headlights are on. I have wired them up to the specified schematics on this thread, and work correctly apart from dim.
Byte 23 bit 5 when unticked DRLs switch OFF when parking lights are ON
- Drives: T5
I have changed the coding over byte 23 bit 5 and this has no effect on the function of the DRL’s.
Is there a way to adjust the PWM voltage whilst the sidelights / headlights are on as per OEM?
try this please:
A0A0303A0E61242392284F702F6B8C55D680660F60871140300000000000
