- RekinPoznan
- Drives: 6R
Hello
New here... great mods very impressiv
I installed today, xenon headlights am looking for the best way to keep the wiring harness to the controller range Xenon can someone something to help.
The second issue is very short wires from the connectors t73a and t73b very hard to get to the cable beam.
Best Regards Chriss
Best Regards Chriss
Hello, thanks for your comments.
Where have you purchased the wiring? links, images, etc... more info means more and better help.
- Mart!n-GTI-DK
- Drives: '14 Polo BlueGT
This picture is of a Mk5 Golf GTI. And those (number 12) is not used on a Polo.Bachecco wrote:Hi ciclo, you can take a photo of the skirt's adaptator. Number 12 in the picture.
Because I'm trying to figure out how to install side skirts. Thanks
- RekinPoznan
- Drives: 6R
ciclo wrote:Hello, thanks for your comments.
Thank you for your answer, the beam did the same on the basis of ELSA,with auto leveling system, found on earlier modifications of your cable gland for the coolant reservoir unless that road is good.
I wish I could help you better, but I do not understand what you want (your English is very difficult for me, please write what you want in Polish).
However, read the next links, perhaps help you.
viewtopic.php?f=56&t=68178#p509214
https://drive.google.com/folderview?id= ... =drive_web
viewtopic.php?f=62&t=67799#p505742
viewtopic.php?f=56&t=68034&hilit=washer+system
viewtopic.php?f=56&t=67705
Monday,02,May,2016,12:00:36:06516
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 7 x64
VCDS Version: 15.7.4.1
Data version: 20160216
www.Ross-Tech.com
VIN: WVWZZZ6RZDY0CICLO License Plate:
Mileage: Repair Order:
Chassis Type: 6R (7E0)
Scan: 01 03 08 09 10 15 17 19 20 25 2E 37 44 55 56 77 0B
VIN: WVWZZZ6RZDY0CICLO Mileage:
56-Radio -- Status: OK 0000
Address 01: Engine (J623-CBZC) Labels: 03F-906-070-CBZ.clb
Part No SW: 03F 906 070 GD HW: 03F 907 309 AJ
Component: SIMOS10.22AH10 2686
Revision: --H10--- Serial number: 00000000000000
Coding: 001100D6202400080000
Shop #: WSC 00788 648 00255
ASAM Dataset: EV_ECM12TFS02103F906070GD 004004
ROD: EV_ECM12TFS02103F906070FJ.rod
VCID: 6AD7C2AC97609770CA-803E
Readiness: 0110 0101
Address 03: ABS Brakes (J104) Labels: 6R0-907-37x-ESP82.clb
Part No SW: 6R0 907 379 BE HW: 6R0 907 379 AF
Revision: --------
Coding: 210228E3216D00B5842814EA84D300401700
Shop #: WSC 40308 002 104857
VCID: 026F9264FB6807480A-8056
Part No SW: 6R0 907 044 H HW: 6R0 907 044 H
Component: Climatronic H11 0711
Revision: V0000000
VCID: 38992E06D766C3D25A-806C
Address 09: Cent. Elect. (J519) Labels: 7E0-937-BCM-V1.clb
Part No SW: 7E0 937 090 HW: 7E0 937 090
Component: BCM PQ25 Max4 H80 0733
Revision: B9080001 Serial number: 0771 100150209
Coding: 3CB02FBF48E1240093380E916CEB97D0DAC0672F600D30D0200000030800
Shop #: WSC 03607 002 104857
VCID: 68C9CE969776A302DA-803C
Subsystem 1 - Part No: 5K7 955 559 B
Component: RLS 110215 03 37 0059
Coding: 0714DD
Subsystem 2 - Part No SW: 6R0 959 801 BD HW: 6R0 959 801 BD Labels: 6R0-959-801.CLB
Component: J386__TSG_FT 003 8612
Coding: 0200A3
Subsystem 3 - Part No SW: 6R0 959 802 BF HW: 6R0 959 802 BF Labels: 6R0-959-802.CLB
Component: J387__TSG_BT 003 8612
Coding: 1000AB
Component: DWA-Sensor 00 001 0103
Subsystem 5 - Part No: 1K8 951 605 B
Component: LIN BACKUP HO H11 9005
Subsystem 7 - Part No SW: 1K8 959 442 HW: 1K8 959 442
Component: E221__MFL-DC1 H03 0103
Coding: A4FFFF
Subsystem 8 - Part No SW: 6R0 959 811 G HW: 6R0 959 811 G
Component: J388__TSG_HL 008 1611
Coding: 18BC32
Subsystem 9 - Part No SW: 6R0 959 812 G HW: 6R0 959 812 G
Component: J389__TSG_HR 008 1611
Coding: 18BC32
Address 10: Park/Steer Assist (J446) Labels: 6R0-919-475.clb
Part No SW: 6R0 919 475 C HW: 7E0 919 475
Component: PARKHILFE 4K H11 0013
Revision: -------- Serial number: 47361212601014
Coding: 308001
ROD: EV_VW250ParkiAssis2.rod
VCID: 3EA31A28C784AF242A-806A
Address 15: Airbags (J234) Labels: 5K0-959-655.clb
Component: VW10Airbag01M H10 0020
Revision: -------- Serial number: 003GX01JKVVP
Coding: 00314D
Shop #: WSC 01383 785 00200
ROD: EV_AirbaVW10BPAVW250_SE25.rod
VCID: 4AB7024C17C05750CA-801E
Crash sensor for side airbag; driver side:
Serial number: 3575HRB405N1C4LI7929
Crash sensor for side airbag; front passenger side:
Serial number: 3585HRB405B1D5MS8GS2
Crash sensor for side airbag; rear; driver side:
Serial number: 3515RRB405B17ABS901.
Crash sensor for side airbag; rear; passenger side:
Serial number: 3525RRB405B181TUDPKC
Address 17: Instruments (J285) Labels: 5K0-920-xxx-17.clb
Part No SW: 6R0 920 870 C HW: 6R0 920 870 C
Component: KOMBI H05 0607
Coding: 140E01
Shop #: WSC 00233 572 91226
ROD: EV_Kombi_UDS_VDD_RM09_SK35.rod
VCID: 359A280FA369D1E772-8060
Address 19: CAN Gateway (J533) Labels: None
Part No SW: 7E0 909 901 HW: 7E0 937 090
Component: GW-K-CAN TP20 H80 0733
Revision: B9080001
Coding: 002200
Address 20: High Beam Assist. (J844) Labels: 8S0-857-511.clb
Part No SW: 7E0 857 511 G HW: 7E0 857 511 E
Component: FLA H10 0003
Revision: AA001001
Coding: 0404001C00000000000000
VCID: 2E933AF887540F94AA-807A
Address 25: Immobilizer (J334) Labels: 5K0-920-xxx-25.clb
Component: IMMO H05 0607
Shop #: WSC 00000 000 00000
ROD: EV_Immo_UDS_VDD_RM09_SE25.rod
Address 2E: Media Player 3 (J650) Labels: 5N0-035-342.lbl
Part No SW: 5N0 035 342 F HW: 5N0 035 342 F
Component: SG EXT.PLAYER H18 0530
Revision: A1001003 Serial number: 7662584630
Coding: 010100
VCID: 2A9742EC9F2017B0CA-807E
Address 37: Navigation (J0506) Labels: 1T0-035-680.clb
Part No SW: 1T0 035 680 L HW: 1T0 035 680 C
Component: RNS-MID H06 5218
Revision: AB001001 Serial number: VWZ6Z7L7654213
Coding: 04000442040000A10001
Shop #: WSC 12345 123 12345
VCID: 37982C05D363C5D562-8062
Subsystem 1 - Part No: 1T0 919 859 B
Component: EU West V13 8348
Part No: 6R0 423 156 B
Component: LenkhilfeTRW V277
Coding: 11250
Shop #: WSC 00788
VCID: 2F903CFD274BF58DA2-807A
Address 55: Headlight Range (J431) Labels: 6R0-907-357.clb
Part No SW: 6R0 907 357 HW: 6R0 907 357
Component: LWR-ECU H02 0070
Revision: -------- Serial number: --------------
Coding: 0112000001000000
VCID: 77D8ACC5DBA3459562-8022
Address 56: Radio (J0506) Labels: 1T0-035-680.clb
Address 77: Telephone (J412) Labels: 7P6-035-730.clb
Part No SW: 7P6 035 730 L HW: 7P6 035 730 L
Component: TELEFON H15 3200
Revision: 1B001001 Serial number: 00007664158506
Coding: 0501000000010110
ASAM Dataset: EV_UHVNA 002720
ROD: EV_UHVNA.rod
VCID: 3BA42411CB97BD3942-806E
End-------------------------(Elapsed Time: 03:20)--------------------------
ok ok you have the recent VCDS too :p
and you also have this 0B adress at the top of your autoscan
I return to the previous state with all OK, all works like a charm. Some changes in some units.
sometimes, you must take 2 steps back to go 1 forward.
firegrafik
- Drives: 6R 1,6MPI(CFNA) sedan
I have this 0B adress too on my autoscan. It appeared after I had upgraded my VCDS version to the latest version.iichel wrote:ok ok you have the recent VCDS too :p
BCM PQ25
Question
If you active Byte21 Bit4 the direction indicators work correctly but the warning indicator lights on the instrument cluster flashes quickly, also it is detected a fault in the lights on the instrument cluster by yellow warning light on rpm sphere.
To me it means that there is too much consumption in the direction indicators with standard bulbs.
Does this mean that if LED bulbs are installed on blinkers and you active Byte21 Bit4 everything will work correctly?
Does anyone with LED bulbs for blinkers would do the test?
I did the test, and no good result (front only, rear only, left only, right only or all together)
Many thanks iichel, you're the best.
Perhaps the Byte21 Bit4 is for VW T5 which they have additional blinkers on the roof, and when it is activated (in 6R) what is really detecting is low power consumption.
And this leads me to have a new idea...
What do you think? ... original parts and perfect coding in case of faults ...
The low consumption I think is correct.
I will try to fix some wiring loom together with some extra power users. Let's see what that byte is doing.
The extra indicators, I'm not sure about it. It would be quite easy to do, change the fog light units to OEM fog units with DRL.
Then change the P21W for a orange light (maybe a P21W LED with orange color?). But it is very pricy, since new fog lights are around 75 euros per piece.
And I'm not so sure about the looks. I don't super like it, I think. Some French cars already have it, and I'm always looking for the blinker light. All the way down there
I guess it would be like this (similar) but without DRL.
I like the idea because the additional blinkers would be more outward and they wouldn't be influenced by illunination of headlights (as in the case of xenon).
Anyway it is just an idea...
