Patil's T-roc 2020 1.5Tsi evo+Dsg7 RHD
patil
Re: Patil's T-roc 2020 1.5Tsi evo+Dsg7 RHD
Post by patil »
Rear door control module MQB LIN emulator installation in my T-roc: Unsuccessful/incompatible. :oops:
Why need a LIN emulator?
VW doesn't provide the rear door control modules in many of their budget to mid range cars to save cost. One of the many advantages of having rear door control modules is in retrofitting rear door warning/ exit lamps in OEM way.
For those who do not have rear door control modules like my T-roc, have to resort to an alternative way of wiring and installing the rear door warning lamps. I personally believe, using the rear door open ground wire of the rear door lock microswitch is not safe, but there is no alternative.
Here comes the role of a LIN emulators, conceptualized by one among many Russian wizards named Roman( HackR) from drive2 forum.
Links to his post about these emulators.
https://www.drive2.ru/l/619680906197613085/
https://www.drive2.ru/market/offers/1531579
As Roman explains in his post, his emulator bypasses the use of ground wire from door lock/unlock microswitch. Instead it uses LIN bus signal from door window motor and converts to regular analogue signal to control the rear door warning lamps. This is the main reason for me buying the emulators. There are also other advantages of the emulator, like it switches off the lamp after some time in case the door is opened for prolonged time. It also emulates the light off in a gradual fading effect similar to front door warning lamps do when doors are closed.
The connection is simple. Emulator has 5 pins, 3 input and 2 output to door warning lamps.
Wiring scheme from HackR ( Google translated)
I wired it accordingly:
But unfortunately, the lamp LEDs didn't light up when door was opened. Did multimeter check, there was almost nil output ( 1.5V instead of 12V) on pin5 of emulator.
The plausible reason given by Roman is that, these MQB LIN emulators are designed based on 5Q0 front door control modules of his Tiguan. But in my T-roc, 5Q4 front door control modules are installed from factory. Probably the bytes/ bits responsible for door open/ close in LIN communications are different in 5Q0 and 5Q4 modules. 🤷‍♂️
Back to square one again 🤭
I think, I will atleast try to use unused BCM pins to power up my rear door warning lamps, instead +30 from fusebox. I have received a informative document from dear master Ciclo to study about MQB lighting control adaptations of BCM... back to school again :mrgreen:
The original LED ceiling/dome lights and my old white LED footwell lights (LC72) have/had that fade-on/fade-off feature. I also had the old white LED footwell lights programmed to be ambient/auxiliary/hall/bus lights. As we all know, both lights also turn off after the preset/programmed time.
:arrow: viewtopic.php?p=573840#p573840 (use logic to achieve your goals).
I think for my fall 2024 project when I wire my rear door warning/exit lights "correctly" I'll program them like that, though the bus lights are not clear to me here.
I guess later, for my winter/Christmas 2024 project I'll program them to flash intermittently to live with excitement and hope for such a beautiful season. 🎄 🎄 ...😆
The great and only challenge for an ideal student is to find better Masters. :mrgreen:
patil
Post by patil »
ciclo wrote: Thu Sep 12, 2024 1:36 am
I don't think so :mrgreen:
Each unused pin in BCM's can be assigned to perform upto 50 different lighting functions is crazy!! :shock:
It's mind boggling how much BCM's have evolved over a decade. 😇
patil wrote: Sun Sep 15, 2024 8:39 pm Each unused pin in BCM's can be assigned to perform upto 50 different lighting functions is crazy!! :shock:
I think that rather than an evolution, it is about increasingly better "ordering" what was already known and what could be known in the future.
We humans, in our position of being able to change things (like gods), have good ideas, but we are a real disaster when it comes to organizing to be able to spread our ideas in a clear and concise way.
In any case, translations can sometimes lead to confusion.
I am absolutely sure that after so many years, DV52 knows with absolute certainty that they are 'exit' and not 'entry', it is logical that editing a PDF that is so old no longer makes sense. It has happened to me on many occasions. Translators are always to blame for everything. 😁
It is a good idea to keep things in the language of the creator.
It is always better to have an open and relaxed mind in order to achieve better goals.🧙‍♂️ Let's hope that no one presses a red button because the interpreter/translator or IA made a mistake in the translation... 💣🧨💥... we could disappear because of a simple thing like this.🐒🤭
patil
Post by patil »
Rear door exit/ warning lamps test using unused BCM pin : successful ✌️
I must thank dear Master Ciclo ♥️ for pushing me in the right path of en(light)enment. 😁
Previously tested white LED lamps as footwell lights viewtopic.php?p=598520#p598520
Using the same BCM pin t73a /72, commanded this pin to work as rear left door exit/ warning lamps by adjusting adaptations Leuchte30FR LC72.
Adaptation/parameter	RDID	Current value	Input	Unit
[VO]_Leuchte30FR LC72	$056E
  [LO]_Lasttyp 30	  	  [VO]_36 - LED Kleinleistung
  [LO]_Lampendefektbitposition 30	  	  0
  [LO]_Fehlerort mittleres Byte DTC-DFCC 30	  	  2
  [LO]_Lichtfunktion A 30	  	  [VO]_Tuerausstiegslicht hinten links
  [LO]_Lichtfunktion B 30	  	  [VO]_nicht aktiv
  [LO]_Dimmwert AB 30	  	  100
  [LO]_Lichtansteuerung HD AB 30	  	  [VO]_always
  [LO]_Lichtfunktion C 30	  	  [VO]_nicht aktiv
  [LO]_Lichtfunktion D 30	  	  [VO]_nicht aktiv
  [LO]_Dimmwert CD 30	  	  0
  [LO]_Dimming Direction CD 30	  	  [VO]_maximize
  [LO]_Lichtfunktion E 30	  	  [VO]_nicht aktiv
  [LO]_Lichtfunktion F 30	  	  [VO]_nicht aktiv
  [LO]_Dimmwert EF 30	  	  0
  [LO]_Dimming Direction EF 30	  	  [VO]_maximize
  [LO]_Lichtfunktion G 30	  	  [VO]_nicht aktiv
  [LO]_Lichtfunktion H 30	  	  [VO]_nicht aktiv
  [LO]_Dimmwert GH 30	  	  0
  [LO]_Dimming Direction GH 30	  	  [VO]_maximize
My observations:
The light goes off after few minutes simultaneously along with interior lights, when door is kept open. I played with adaptations to bring in slow fading effect when door is closed, but couldn't figure it out. We will need 2 unused BCM pins to control each of rear door exit/ warning lamps.
Finally, I achieved what I was aiming for, OEM way of controlling rear door warning lamps 8)
I will do rewiring of rear door warning/exit lamps at convenient time.
Emulators be damned 🙈
💥Super congratulations!💥, I am very glad to know that you have succeeded.👏
As I already told you by email, to finally earn your place in the Olympus of the Gods ⚡...🤭, I think you should 'search' with the search terms 'Tuer' and/or 'Interior_light_' in the Protocol Diagnostics of your 'Exceptional' TRoc.💎🚀 💖
Perhaps, with patience and using a good translator if necessary, you can find in all those 'highlighted' adaptation channels something related to the slow fading effect for these lights. I guess it should be activated in 'decimal value/percentaje' or 'active/not active' in one of those channels.
giannis20vt
Post by giannis20vt »
I am following this particular thread with great interest. Congratulations to both of you for the efforts and knowledge you offer us. Thank you very much.
I was interested in the specific part with the lighting of the doors on the way out. (door warning lamps)
I am thinking of using it for another reason (similar and of course related to lighting). More on my own thread so as not to spoil Patil's thread.
https://www.uk-polos.net/viewtopic.php? ... a&start=60
patil
Post by patil »
ciclo wrote: Tue Sep 17, 2024 3:11 am 🕉
Thank you so much for the kind words dear Master ☺️🙏
I am working on adaptations to successfully implement slow dimming effect, I will surely post if get a breakthrough 👍
@giannis20vt , thank you and you can ask/ post anything which you feel useful in my thread, no problem.
patil
Post by patil »
OEM frameless autodimming IRVM: Improvised to perfection🤓💯
Previously, I had modified the OEM frameless autodimming IRVM to fit in my T-roc. But the result was not perfect.viewtopic.php?p=605327#p605327
After carefully studying and taking measurements of the mirror ball- socket mounts of both my T-roc and new frameless mirror, I realised that, ball- socket mounts are almost identical.
I decided to buy a new frameless autodimming mirror with a different part number this time 3G0857511AD. Compared to previous frameless mirror 3G0 AC, the AD version supports sidemirror autodimming function as it has 2 additional pins. Though, AC version can also be modified in PCB by soldering 2 new wires to support side mirror autodimming. I know that, Octavia MK3 side mirrors did came with autodimming side view mirrors from the factory, they are perfect fit (1:1) for MK1 T-roc. If I get hold of those autodimming side mirrors, I will retrofit them, as new AD version frameless IRVM supports it. For now, blue tinted, heated and with integrated blinkers I got from AliExpress are doing great job 👍
This time I took a pragmatic approach. Decided to swap the stock T-roc IRVM mount with new frameless IRVM. For this, I had to dismantle both the mirrors completely 😁
With few expired credit/debit cards, heat gun and lot of patience, it is fairly easy job to dissemble the mirrors without damaging. Luckily, the ball-socket locking units of both mirrors turned out to be identical twins!👌
Stock T-roc IRVM completely dissambled:
New frameless IRVM dissambled
Comparison of lock mounts, both are similar except for the length. Top T-roc, bottom new frameless IRVM.
Replaced the lock mount of frameless IRVM with T-roc mount. Perfect swap👌
Final result: Comparison. Left, frameless IRVM with T-roc IRVM lock mount.
The result is very satisfying 😍 Everything is perfect, new frameless IRVM can be moved and adjustable freely like IRVM from factory✌️
Heartfelt thanks to dear friend Szymon for helping me to get new frameless IRVM🤗
patil
Post by patil »
Log # 26, 27, and 28.
#26 OEM wireless charging pad in storage compartment.
# 27 OEM Led DSG gear knob China version.
#28 OEM touch climatronic unit China version.
I got some free time out of my hectic work schedule. So decided to do all the above 3 retrofits at the same time, as they involve almost the same area/trims involved of the central console.
Log #26 OEM wireless charging pad(5NA980611, rated 5w).
Previous information with wiring scheme here viewtopic.php?p=598872#p598872
How to dismantle central console trim in T-roc is here( applicable to all 3 mentioned  retrofits) viewtopic.php?p=597689#p597689
Pictures/details of installation:
1. 12v +30 from the additional fuse box I made
2. GND to near by GND point
3. 5F control unit quadlock grey connector 12pin t12/5 &11
4. BCM t73a/14 "C" connector( optional) - I connected it, this connection has a specific function, I found out by doing tests. This connection allows the phone to continue charging even when ignition is turned off. The charging stops only when the driver door is opened/ car is locked.
5. Coding:  Enable Byte15, bit5 in 5F using experimental yellow screen.
Bought a new charging rubber mat for RHD 2GB863328B9B9. For LHD 2GA863328C9B9
Charging also works with stock mat, but the mat for wireless charging is designed thoughtfully. The new mat has a wide central deeper recess for correct alignment of the phone over the charging pad. On the back side, new honeycomb pattern of the mat allows heat dissipation more efficiently 👌 I have observed a  noticeable reduction of phone heating with the new mat.
# 27 ?OEM Led DSG gear knob China version.
I bought this from a reputed AliExpress seller. She assured me that it is OEM China version and not cheap replicas sold everywhere on AliExpress. I took her words with a pinch of salt and purchased it. For the price of 70$, the quality, the fit and finish is very good, I have no complaints.
I prefer to have a dual display of gears selection both in knob and base panel. The Chinese version doesn't have the problem of electronic conflict when you install a LED gear knob while retaining the base gear indicator panel. The Original EU version LED knob will not work correctly if the knob is installed while retaining the base gear indicator panel. Some letters on both the led knob and base panel don't illuminate correctly.
I have solved this problem with OEM led gear knob in Polo. Details here viewtopic.php?p=589334#p589334
The fonts are slightly thinner in Chinese version compared to OE version. But the colour rendering is perfect and works well. No errors in scan✅
#28 OEM touch climatronic unit China version ( 17G907044AN)
A previous attempt to install touch climatronic with a frame bought from AliExpress was unsuccessful. The touch climatronic frames for T-roc sold in AliExpress are for LHD only. Details here viewtopic.php?p=602253#p602253
As I mentioned previously, for RHD T-roc we need a frame with part number 2GB863099B. Unfortunately, this part is not sold separately! It's a part of a larger ridiculously expensive central console trim 2GB863042B.
Fortunately, I found the RHD central console trim with frame for touch climatronic unit on EBay UK for a fraction of the price. But the seller wasn't willing to ship to India. I tormented dear iichel to get it.😁 The trim made a long and arduous journey from UK-NL-IND.
Finally got it undamaged and in perfect condition like brand new.. glossy 🖤
I liked the glossy black trim so much so that, for a change, I decided to install the trim as is rather than transferring the climatronic frame to my stock limestone grey trim☺️
The climatronic frame is plastic welded to central console trim, but with gentle hands and correct tools it is possible to dismantle the frame without damaging it.
Basic settings and coding/adaptations transfer:
1. Transferred the 08 HVAC coding from old to new unit
2. Basic settings of flap motors went on fine.
3. Basic settings of AC compressor didn't start, got an error
I had to follow the steps provided by Ross -tech shared by dear master Ciclo in his post here viewtopic.php?p=575072#p575072 http://wiki.ross-tech.com/wiki/index.ph ... 9_Climatic
On 3rd attempt, it was successful!
I did all the checks on new unit and everything is working correctly ✌️ Though I felt it wasn't necessary, I did transfer all the adaptations of old unit. Everything was ok.
Old unit:
New unit:
Autoscan:
Saturday,19,October,2024,20:49:13:09269
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 11 x64
VCDS Version: 24.7.0.0 (x64)  HEX-V2 CB: 0.4643.4
Data version: 20240715 DS356.3
www.Ross-Tech.com
VIN: WVGZZZA1ZLVtriple-roc   License Plate:
Chassis Type: A1-VW27 (3Q0)
Scan: 01 02 03 05 08 09 10 13 15 17 19 2B 3C 42 44 4B 52 5F 65 6D
          75 A5 BB BC CA D6 D7
VIN: WVGZZZA1ZLVtriple-roc   Mileage: 59681km-37084miles
05-Acc/Start Auth. -- Status: OK 0000
2B-Steer. Col. Lock -- Status: OK 0000
42-Door Elect, Driver -- Status: OK 0000
4B-Multifunc. Module -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
6D-Trunk Elect. -- Status: OK 0000
75-Telematics -- Status: OK 0000
A5-Frt Sens. Drv. Assist -- Status: OK 0000
BB-Door Rear Drv -- Status: OK 0000
BC-Door Rear Pass -- Status: OK 0000
CA-Sunroof -- Status: OK 0000
D6-Light Ctrl Left 2 -- Status: OK 0000
D7-Light Ctrl Right 2 -- Status: OK 0000
Address 01: Engine (J623-DPCA)       Labels:. 04E-907-309-V1.clb
   Part No SW: 05E 906 018 AT    HW: 05E 907 309 H
   Component: R4 1.5l TFS   H20 9640
   Revision: 8AH20000    CVN: 5E8A0C2D
   Coding: 0125003223641D0830000000000000000000000000000000
   Shop #: WSC 00020 043 00000
   ASAM Dataset: EV_ECM15TFS01105E906018AT 003003
   ROD: EV_ECM15TFS01105E906018AT_003_VW27.rod
   VCID: 77A8E2A6DF4F07E26E9-8022
   VINID: 9E65EAAAA441A9C9801C720314E84F2DE4
Readiness: 1010 0001
Address 02: Auto Trans (J743)       Labels: 0CW-927-769.clb
   Part No SW: 0CW 300 050 J    HW: 0AM 927 769 E
   Component: GSG DQ200G2_M H05 1911
   Revision: 00005009    Serial number: CU501911185682 CVN: ABB5E1C0
   Coding: 0014
   Shop #: WSC 17734 418 534600
   ASAM Dataset: EV_TCMDQ200021 001001
   ROD: EV_TCMDQ200021.rod
   VCID: 3C223D8AA6E9E4BA43B-8068
Address 03: ABS Brakes (J104)       Labels: 5Q0-907-379-IPB-V1.clb
   Part No SW: 5Q0 614 517 DK    HW: 5Q0 614 517 BN
   Component: ESC           H35 0113
   Revision: 00000000    Serial number: 63139000003538
   Coding: 46FA8A7D90272473477F060362C82562510924E26046A4733822F00A52A24B0B00000523525212121035351919323200
   Shop #: WSC 00000 000 00000
   ASAM Dataset: EV_Brake1UDSContiMK100IPB 049012
   ROD: EV_Brake1UDSContiMK100IPB_049_VW27.rod
   VCID: 7DA4F08EFD732DB2345-8028
Address 05: Acc/Start Auth. (J518)       Labels:| User\5Q0-959-435.lbl
   Part No SW: 3Q0 959 435 N    HW: 3Q0 959 435 N
   Component: VWKESSYMQB    037 1307
   Revision: 00037000    Serial number: 0534174099 Dataset Number: V03935301VA 0001
   Coding: 1F20200723
   Shop #: WSC 00046 000 00000
   ASAM Dataset: EV_KessyHellaMQBAB 004052
   ROD: EV_KessyHellaMQBAB.rod
   VCID: 45D4586ED523A5722C5-8010
   Rear lid opener control module:
   Subsystem 1 - Part No SW: 3GD 962 243 D    HW: 3GD 962 243 D
   Component: GEB.F.Heckoef  H17 0908
   Serial number: 05086671
Address 08: Auto HVAC (E87)       Labels:. 5G0-907-044.clb
   Part No SW: 17G 907 044 AN    HW: 17G 907 044 AN
   Component: AC Automat    H11 1501
   Revision: 20K07000    Serial number: 00000A00811480
   Coding: 061200242001100D1105004012101836
   Shop #: WSC 12345 123 12345
   ASAM Dataset: EV_ACTouchPrehVW37X 001010
   ROD: N/A
   VCID: 76B6EFA2D8457EEA75F-8022
No ASAM data for: "EV_ACTouchPrehVW37X" (VW27)
Address 09: Cent. Elect. (J519)       Labels:. 5Q0-937-08X-V2.clb
   Part No SW: 5Q0 937 084 EC    HW: 5Q0 937 084 EC
   Component: BCM MQBAB H   H44 0511
   Serial number: B2701012207200 Dataset Number: V03935394NB 0001
   Coding: 000000000000000000000000000000000000000000000000000000000000
   ASAM Dataset: EV_BCMMQB 022001
   ROD: EV_BCMBOSCH_022_VW26.rod
   Rain/Light Recognition Sensor:
   Subsystem 1 - Part No SW: 5Q0 955 547 C    HW: 5Q0 955 547 C  Labels: 5Q0-955-547.CLB
   Component: RLHS  051 0206
   Serial number: S6Y19M10D15H05M19S28
   Coding: 0018DD
   Anti-theft alarm system sensor:
   Subsystem 2 - Part No SW: 5Q0 951 172     HW: 5Q0 951 172
   Component: Sensor, DWA  005 0316
   Serial number: 000000000ZY192950M1T
   Alarm horn:
   Subsystem 3 - Part No SW: 5Q0 951 605 B    HW: 5Q0 951 605 B
   Component: Sirene, DWA  004 0007
   Serial number: 00000000000000754028
   Steering Column Switch:
   Subsystem 4 - Part No SW: 5Q1 953 521 Q    HW: 5Q1 953 569
   Component: Lenks.Modul  H03 0170
   Serial number: 0100221120190C400340
Address 10: Park/Steer Assist (J791)       Labels:| 5Q0-919-298.clb
   Part No SW: 5QA 919 298 K    HW: 5QA 919 298 A
   Component: PLA 3.0 12K   H08 0073
   Serial number: 000150057322125 Dataset Number: V03935342EN 0001
   Coding: 8379167851
   ASAM Dataset: EV_EPHVA2CAU3700000 009055
   ROD: EV_EPHVA2CAU3700000_010_VW37.rod
   VCID: 58EA811A3291289A473-800C
Address 13: Auto Dist. Reg (J428)       Labels:| 2Q0-907-572.clb
   Part No SW: 2Q0 907 572 AB    HW: 2Q0 907 572 B
   Component: ACCCONTIMQB   H03 0397
   Dataset Number: V03935376DS 0001
   Coding: 300C47435CFF8748949C812483578700000000000000000004
   Shop #: WSC 00046 123 12345
   ASAM Dataset: EV_ACCMRRCONTIVW376 003018
   ROD: EV_ACCMRRCONTIVW376_003_VW27.rod
   VCID: 74B2D5AACE396CFA4BB-8020
Address 15: Airbags (J234)       Labels:| 5Q0-959-655.clb
   Part No SW: 3Q0 959 655 CM    HW: 3Q0 959 655 CM
   Component: Airbag VW21   006 0720
   Revision: --------    Serial number: 003Z2PPMRKF2 Dataset Number: V03935298UN 0001
   Coding: 88CCC0C0000000005C5400CF008840000065
   Shop #: WSC 00020 999 00000
   ASAM Dataset: EV_AirbaVW21TS6VW48X 001014
   ROD: EV_AirbaVW21TS6VW48X_VW27.rod
   VCID: 0B40AE56B3C713023A1-805E
   Subsystem 1 - Part No SW: -----------    HW: 454 002 910 19
   Component: SideSensor_Df  008 0887
   Serial number: 357000000004A1316142
   Coding: 2D2D2D
   Subsystem 2 - Part No SW: -----------    HW: 454 002 810 19
   Component: SideSensor_Pf  008 0887
   Serial number: 35800000000C98B8424V
   Coding: 2D2D2D
   Subsystem 3 - Part No SW: -----------    HW: 454 802 210 19
   Component: SideSensor_Dr  301 0148
   Serial number: 35100A0CB121A000000D
   Coding: 2D2D2D
   Subsystem 4 - Part No SW: -----------    HW: 454 802 510 19
   Component: SideSensor_Pr  301 0148
   Serial number: 35200E4A8381A000000P
   Coding: 2D2D2D
   Subsystem 5 - Part No SW: -----------    HW: 454 802 310 19
   Component: FrontSensor_D  304 0149
   Serial number: 35500964D2C1A000000R
   Coding: 2D2D2D
Address 17: Instruments (J285)       Labels:| 5G0-920-XXX-17.clb-SRI3
   Part No SW: 17A 920 790 B    HW: 17A 920 790 B
   Component: KOMBI         503 4310
   Coding: 65FC00986E88080C0188770F1801000000000906
   ASAM Dataset: EV_DashBoardVDDMQBA0 001042
   ROD: EV_DashBoardVDDMQBA0_001_VW27.rod
   VCID: 2616FFE248654E6A05F-8072
Address 19: CAN Gateway (J533)       Labels:| 3Q0-907-530-V1.clb
   Part No SW: 3Q0 907 530 AC    HW: 3Q0 907 530 C
   Component: GW MQB High   442 4388
   Revision: --------    Serial number: 0000427114 Dataset Number: V03935301GP 0001
   Coding: 030100046F08560003100258180F00010001070000000000000000000000
   GVL: 014E3C000800060040CC80008000C80010000000000200000000000000000000
   ASAM Dataset: EV_GatewNF 013026
   ROD: EV_GatewNF_VW27.rod
   VCID: 70BAD9BABA2150DAAF3-8024
   Generator:
   Component: 5-01-14-01-04
   Multifunction steering wheel control module:
   Subsystem 2 - Part No SW: 1EA 959 442 D    HW: 1EA 959 442 D
   Component: MFL  H03 0219
   Serial number: 17038312100192202040
   Coding: 2D0900
   Subsystem 3 - Part No SW: 5Q0 915 181 K    HW: 5Q0 915 181 K
   Component: J367-BDMHella  H10 9070
   Serial number: 3250843205
Address 2B: Steer. Col. Lock (J764)       Labels:| 1EA-905-861.clb
   Part No SW: 2Q0 905 861 A    HW: 2Q0 905 861 A
   Component: ELV-MQBB      H08 0021
   Serial number: 19000332474005
   Coding: 0800000000000000
   ASAM Dataset: EV_ELVMarqMQBA0 002002
   ROD: EV_ELVMarqMQBA0_VW27.rod
   VCID: 313C1CBE71AB19D2E0D-8064
Address 3C: Lane Change (J1086)       Labels:* Redir Fail!
   Part No SW: 2Q0 907 686 B    HW: 2Q0 907 686 B
   Component: HRE3_Kl15_Mst H06 0150
   Serial number: 14520011985865  Dataset Number: V03935308HF 0001
   Coding: 92A54640
   ASAM Dataset: EV_HREntryHellaGen3Kl15 002001
   ROD: EV_HREntryHellaGen3Kl15_002_VW27.rod
   VCID: 392C249EA9DBD19258D-806C
   Lane change assistance control module 2:
   Subsystem 1 - Part No SW: 2Q0 907 685 B    HW: 2Q0 907 685 B
   Component: HRE3_Kl15_Slv  H06 0150
   Serial number: 14520011913860
Address 42: Door Elect, Driver (J386)       Labels:| 5QX-959-X93-42.clb
   Part No SW: 5Q4 959 593 K    HW: 5Q4 959 593 K
   Component: TSG FS        007 0485
   Serial number: 0000397175085  Dataset Number: V03935313VT 0001
   Coding: 00151A20D001028000001000
   ASAM Dataset: EV_DCU2DriveSideMAXHCONT 001005
   ROD: EV_DCU2DriveSideMAXHCONT_VW27.rod
   VCID: 4DC4604E0D535D32E45-8018
   Rear Driver Side Door Control Module:
   Subsystem 1 - Part No SW: 5Q0 959 408     HW: 5Q0 959 164   Labels: 5QX-959-81X-V1.CLB
   Component: FOND_FHSG_DRV  007 0010
   Serial number: 00000000000036110727
   Coding: 1D0000
Address 44: Steering Assist (J500)       Labels:| 5Q0-909-144.clb
   Part No SW: 5Q0 909 144 AB    HW: 5Q0 909 144 AA
   Component: EPS_MQB_ZFLS  131 1082
   Dataset Number: V03935312TK 0001
   Coding: 171F0000
   Shop #: WSC 00020 999 12345
   ASAM Dataset: EV_SteerAssisMQB 015157
   ROD: EV_SteerAssisMQB_015.rod
Address 4B: Multifunc. Module (J745)       Labels:| 3Q0-907-338-V2.clb
   Part No SW: 3Q0 907 338 E    HW: 3Q0 907 338 E
   Component: FCM MQB Low   003 0367
   Serial number: 17111910522941 Dataset Number: V03935304ZR 0001
   Coding: 000000070900204600000900000000000000000000000000000000000000
   ASAM Dataset: EV_MultiModulContiVW48X 003003
   ROD: EV_MultiModulContiVW48X_003.rod
   VCID: 372822A69FCFC7E2AE9-8062
Address 52: Door Elect, Pass. (J387)       Labels:| 5QX-959-X92-52.clb
   Part No SW: 5Q4 959 592 K    HW: 5Q4 959 592 K
   Component: TSG BFS       007 0485
   Serial number: 0000396858048  Dataset Number: V03935313WJ 0001
   Coding: 00151020DC01028000001000
   ASAM Dataset: EV_DCU2PasseSideMAXHCONT 001005
   ROD: EV_DCU2PasseSideMAXHCONT_VW27.rod
   VCID: 4CC26D4AF649543AF3B-8018
   Rear Passenger Door Control Module:
   Subsystem 1 - Part No SW: 5Q0 959 407     HW: 5Q0 959 163   Labels: 5QX-959-81X-V1.CLB
   Component: FOND_FHSG_PSG  007 0010
   Serial number: 00000000000036011483
   Coding: 050000
   Part No SW: 3Q0 035 864 C    HW: 3Q0 035 864 C
   Component: MU-S-N-ER     854 0879
   Serial number:                Dataset Number: 5G0CV1v____ 0001
   Coding: 02720601BE0000004111000100080A201F0500F601200000C6
   ASAM Dataset: EV_MUStd4CDELP 001001
   ROD: EV_MUStd4CDELP_VW27.rod
   Display and control head 1 for information electronics:
   Subsystem 1 - Part No SW: 5G6 919 605 B    HW: 5G6 919 605 B
   Component: ABT_Std-2_Nav  361 8214
   Serial number: VWZ6ZHX1471458
   Data carrier:
   Subsystem 2 - Part No SW: 5NA 919 866 FH    HW: -----------
   Component: MRM2 2024/25  --- 2210
   Part No SW: 5Q0 907 273 B    HW: 5Q0 907 273
   Component: RDKBERU30     H04 0009
   Serial number: 30000000255241 Dataset Number: RDKS_TinyQ_ 1017
   ASAM Dataset: EV_RDKBERU30 006001
   ROD: EV_RDKBERU30_005.rod
   VCID: 343215AA8EB92CFA8BB-8060
Address 6D: Trunk Elect. (J605)       Labels:| 5Q0-959-107.clb
   Part No SW: 5Q0 959 107 T    HW: 5Q0 959 107 C
   Component: HDSG-Modul    H12 0271
   Revision: --------    Serial number: PLG01908160021 Dataset Number: V03935301SX 0001
   Coding: 1C28
   ASAM Dataset: EV_DeckLidCONTIAU736 001017
   ROD: EV_DeckLidCONTIAU736_VW27.rod
   VCID: 49CC545EF93B4112C8D-801C
Address 75: Telematics (J949)       Labels:| 5QE-035-285.clb
   Part No SW: 5NA 035 284 C    HW: 5NA 035 284 C
   Component: OCULowMQBLGE  H19 0825
   Revision: --------    Dataset Number: V03935298KU 0001
   Coding: 02720601EA16380D3F1CBE000045400382E608
   ASAM Dataset: EV_OCULowMQBLGE 004049
   ROD: EV_OCULowMQBLGE_004_VW27.rod
   VCID: 3D24308EBDF3EDB2745-8068
Address A5: Frt Sens. Drv. Assist (R242)       Labels:| 3Q0-980-65X-A5.clb
   Part No SW: 3Q0 980 654 L    HW: 3Q0 980 654 A
   Component: MQB_B_MFK     H12 0610
   Serial number: 15111915K10993 Dataset Number: V03935315JQ 0001
   Coding: 000207060000040100021356C156890088000E20002000
   ASAM Dataset: EV_MFKBoschMQBB 002041
   ROD: EV_MFKBoschMQBB_002.rod
   VCID: 40DA497ACA01805A1F3-8014
Address CA: Sunroof (J245)       Labels:| 4M0-907-594.clb
   Part No SW: 4K0 907 594 AC    HW: 4K0 907 594
   Component: SAD_STG_1     006 0002
   Dataset Number: V03935280ME 0001
   Coding: 508040727602
   ASAM Dataset: EV_SunRoofCONTIAU736 009011
   ROD: EV_SunRoofCONTIAU736_009_VW27.rod
   VCID: 75B4E8AEC54375F27C5-8020
Address D6: Light Ctrl Left 2 (A31)       Labels: 7P5-941-591.clb
   Part No SW: 7P5 941 591 AH    HW: 7P5 941 591 A
   Component: LED1L         H07 0009
   ASAM Dataset: EV_LED_PLUS_L_KEBODAVW416 001003
   ROD: EV_LED_PLUS_L_KEBODAVW416.rod
   VCID: 025E8372848D524A497-8056
Address D7: Light Ctrl Right 2 (A27)       Labels: 7P5-941-591.clb
   Component: LED1R         H07 0009
   ASAM Dataset: EV_LED_PLUS_R_KEBODAVW416 001003
   ROD: EV_LED_PLUS_R_KEBODAVW416_VW27.rod
End----(Elapsed Time: 01:43, VBatt start/end: 11.9V/11.9V. VIgn 11.9V)-----
My observations:
The new touch panel looks modern and adds premiumness to cabin. Touch buttons sensitivity is sharp and works well. The sensitivity of touch can be adjusted in adaptations. I rarely touch the climatronic unit once set at desired temperatures, so the new touch panel shouldn't be of distraction to me.
I also found few deficiencies in the new unit. The Max AC button is missing on the new unit, it is very useful in hot countries like mine to get instant full AC on the push of a button. Sync button is also missing, instead a clean air option is available. Sync is now available in the AC menu display of MIB, though I don't use it much ( EU version has sync instead of clean air) . Another bug I found was when you press Menu option in touch display, AC menu appears in MIB, and press menu again, AC menu doesn't close on MIB  and goes back to the previous display. This wasn't the case with the old unit, I found it slightly annoying in the new unit.
Overall I am very satisfied with the results of all three retrofits. 🥰
Another beautiful, ambitious and challenging project is taking shape in the background with divine enlightenment from the top🤭😁
patil
Post by patil »
Happy Diwali ( festival of lights.. victory of light over darkness) to everyone ✨🪔🎇 🤗
Let there be light to guide us in the soak of darkness 🔦💡
TEST: PR-QQ9/ BCM-LINbus✨🔅✅
Still a lot of work to be done to be successful 🧑‍🔧
Thanks!! Happy Diwali to all of you.🌏🕯
Good luck with those dome lights via LIN. I seem to remember that Slavik successfully installed them on his Super Golf.
F1gur471v3ly 5p34k1ng?
7H15 M3554G3 53RV35 7O PR0V3 H0W 0UR M1ND5 C4N D0 4M4Z1NG 7H1NG5! 1MPR3551V3 7H1NG5! 1N 7H3 B3G1NN1NG 17 WA5 H4RD BU7 N0W, 0N 7H15 LIN3 Y0UR M1ND 1S R34D1NG 17 4U70M471C4LLY W17H 0U7 3V3N 7H1NK1NG 4B0U7 17, B3 PROUD! 0NLY C3R741N P30PL3 C4N R3AD 7H15.😄
patil
Post by patil »
Updates:
1. A5 assistant camera: Traffic Jam Assist (TJA) + 60 seconds interval to take control of the steering wheel when ACC is on.
VCP file management system has a custom dataset for T-roc A5 assistant camera 3Q0980654L which activates TJA and 60sec interval to take control of steering wheel ( from factory 15sec). I flashed it.
Both features worked as intended right away, I didn't have to do any coding/ adaptation changes in concerned control units.
In TJA, car moves automatically if stop is less than 3 sec, if more than 3 sec stop then asks to press gas pedal to move. Lane assist works from 0km/hr in TJA mode with DSG and available from minimum cruise speed 30km/hr in ACC mode. Previously lane assist was available only from 65km/hr.
Honestly speaking, Lane assist in 3Q0 "L" version factory assistant camera in my T-roc works decently under ideal road conditions ( which is rare in my country)
With more speed( 90km/hr and above), less accurately it holds to the lane in long curves. It likes straight roads and hates curves. Adaptive lane guidance really helps lane assist to hold the lane consistently.
I plan to upgrade from 3Q0 to 2Q0 camera for travel assist. More about it later.
Small clip to demonstrate 60sec interval to take over steering warning:
https://youtu.be/UcWoQTa-u_8?si=18o9_M4rzbNFnQeU
2. Updated 65 TPMS firmware from 5Q0 "B to "F"
Existing dataset is not erased after flashing. I also changed the dataset with different psi settings for testing purposes. The tolerance limit to trigger low pressure warning is 3psi/0.2bar in "B " version. I think it will be the same with F version also.
patil
Post by patil »
Log#29
Retrofit: New top R version MK8 capacitive touch steering wheel+ steering wheel heating 😎👌✌️
I will start with the end result🤓
Sometime ago, I posted the pictures of new top version  MK8 touch steering wheel  I had bought.viewtopic.php?p=605477#p605477
Previously, I had replaced the factory installed steering wheel with MK8 touch with ACC+ assistant buttons+ heating button. Activated only ACC and left steering wheel heating retrofit for future.
viewtopic.php?p=600396#p600396
After removing the previous MK8 steering wheel+ airbag, it was time to replace the stock slipring with one which supports steering wheel heating.
Old and new slipring:
New slipring with 5Q1 pnp adapter(16pin to 14pin) from AliExpress. I got new 14 pin connector for new slipring but didn't use it, instead I used adapter from Ali, saves time and hassle free.
14pin connector needed for new slipring
Repining scheme for 5Q1 sliprings with heating support. Google translated, credits to respective owner from Drive2
Few installation pictures:
Better to remove slipring lock at last, to avoid damaging ribbon cable inadvertently and to maintain it's factory alignment.
Connecting the steering wheel heating connector to slipring
Power supply and GND connection
Coding the new steering wheel and steering wheel heating.
GW adaptation:
HVAC 08 coding for steering wheel heating:
New KLR unit need to be coded in GW 19
Enable byte1, bit3
New steering wheel and KLR unit recognised in ODIS
Before:
   Coding: 2D0900
Now:
   Subsystem 2 - Part No SW: 1EA 959 442 F    HW: 1EA 959 442 F
   Serial number: 17038315111572401137
   Coding: 8E0900
 Before:
 Now:
   Subsystem 4 - Part No SW: 5Q1 953 521 KS    HW: 5Q1 953 569 K
   Component: Lenks.Modul  H24 0190
   Serial number: 05000405202300100730
Latest autoscan:
Thursday,14,November,2024,01:00:44:09269
VCDS Version: 24.7.1.0 (x64)  HEX-V2 CB: 0.4643.4
Data version: 20240919 DS356.3
www.Ross-Tech.com
VIN: WVGZZZA1ZLVT-roc   License Plate:
VIN: WVGZZZA1ZLVT-roc   Mileage: 61426km-38168miles
   VCID: 77A8E2A6DF4F07E26E1-8022
Readiness: 0000 0000
   Coding: 0014
   VCID: 3C223D8AA6E9E4BA433-8068
   VCID: 7DA4F08EFD732DB234D-8028
   Coding: 1F20200723
   VCID: 45D4586ED523A5722CD-8010
   Coding: 061200242001100D1105004C12145836
   ROD: N/A
   VCID: 76B6EFA2D8457EEA757-8022
   Coding: 0018DD
   Alarm horn:
   Coding: 8379167851
   VCID: 58EA811A3291289A47B-800C
   VCID: 74B2D5AACE396CFA4B3-8020
   VCID: 0B40AE56B3C713023A9-805E
   Coding: 2D2D2D
   Coding: 2D2D2D
   Coding: 2D2D2D
   Coding: 2D2D2D
   Coding: 2D2D2D
   VCID: 2616FFE248654E6A057-8072
   Coding: 030900046F08560003100258180F00010001070000000000000000000000
   VCID: 70BAD9BABA2150DAAFB-8024
   Generator:
   Coding: 8F0F00
   VCID: 313C1CBE71AB19D2E05-8064
   Coding: 92A54640
   VCID: 392C249EA9DBD192585-806C
   VCID: 4DC4604E0D535D32E4D-8018
   Coding: 1D0000
   Coding: 171F0000
   VCID: 372822A69FCFC7E2AE1-8062
   VCID: 4CC26D4AF649543AF33-8018
   Coding: 050000
   Data carrier:
   Part No SW: 5Q0 907 273 F    HW: 5Q0 907 273
   Serial number: 30000000255241 Dataset Number: rdkseditor  0204
   VCID: 382A219A92D1C89AA7B-806C
   Coding: 1C28
   VCID: 49CC545EF93B4112C85-801C
   VCID: 3D24308EBDF3EDB274D-8068
   VCID: 40DA497ACA01805A1FB-8014
   VCID: 75B4E8AEC54375F27CD-8020
   VCID: 025E8372848D524A49F-8056
End----------(Elapsed Time: 01:46, VBatt start/end: 12.7V/12.7V)-----------
The results
Let me say something.. final impressions😁
The new top R version MK8 capacitive touch steering wheel is damn gorgeous with blue stitch and blue R button. R button stands out both day and night.💙 I liked the long ninja paddle shifters🤭 and feel smooth and premium to touch and operate👌 I must admit, the new R steering wheel is crown jewel of my all retrofits 👑
I have activated TA button just for completeness, pressing it doesn't do anything.I know 2Q0 camera is needed.
Steering wheel heating was like cherry on the cake 🍰 First time ever I experienced the heated steering wheel in cold winter weather.. loved it 😋
I've paid for the whole steering wheel, I am gonna make whole thing work 😜😁
Supreme illustration of your new toys.💎
Thank you so much!
