The pin T73b/7 (58 terminal) can be used as a signal to the relay for permanent ambient lights.CNK wrote:Can you tell me more about this?ciclo wrote: it will have the pins you need for ambient lights permanents.
In your case to the existing wire.
In 7H0 BCM there were some pins in BCM black connector for this use, but I think they were eliminated. (I have to check)
