chisyelamos1
Drives: 6c 1.4tdi
Re: RE: Re: ciclo's Polo. R-line 1.2 TSI 90hp 119gr.
Post by chisyelamos1 »
ciclo wrote:Hi guys, the thing I'll write below it is with the best of my intentions (as ever with all humility). Why do I say this? As you can see, this topic is read in many places in the world so we should try be accurate and must think what would be the best for the rest of readers/users. (their spent money and the achieved results with full success)
All of you know you are very special people to me.
firegrafik wrote: Ciclo's way will allow to return the wiring to stock at any moment.
And make an easy repair for any malfunctioning when someone does not have extensive knowledge about electrical repairs. It is not your case firegrafik :wink:, but it could be the case of many people. (from my experience)
firegrafik wrote: Rapid owner finished his retrofit
https://translate.googleusercontent.com ... jG95taHauw
Many thanks, good info 8). Autoscan :?:
benzinkopf wrote: Either way, its working! I'm now searching for best place to source all the terminal kontakt n wiring.
e.g: viewtopic.php?f=10&t=42713#p466570
Hmm (if you want) ... the same proposal I made to cmoret. (but they are different installations)
Why I write 'if you want'? Because I do not want to take away anyone the big satisfaction of doing it by oneself.
iichel wrote:HBA is possible without MFA+ but the normal cluster with the segment display does not have an incidator for HBA.
The Scirocco 1K8 mirror could work on the polo 6r foot, but it's not ideal.
the mirror should be on the instrument cluster CAN network. however the coding and diagnosis is done over the powertrain can.
this results in the mirror not showing up in autoscans, and the can gateway is not happy about it.
Therefore, Instrument cluster with MFA+ (for your own safety) and 7E0 mirror are mandatory for 6R. :wink: (we do too many tests [emoji38])
chisyelamos1 wrote:Hi, I've put LED lights in the front parking light (halogen headlight) and gives me error, is there any option VAGCOM? Thank you
EN: I wish I could help you, but the BCM PQ26 is unknown for me. I'm sorry.
SP: No sabes cuanto me gustaría poder ayudarte con el tema de los LEDs en las luces de posición, pero el Polo 6C es diferente al 6R en temas eléctricos y no parece haber mucha información o experiencia sobre estos asuntos para el 6C. Tendrás que indagar en los foros del Golf VII, por que las BCM aunque no sean iguales se configuran de forma similar. (poniendo de tu parte en el uso del VCDS como hiciste para los antiniebla :wink:)
Gracias.
Al final lo conseguí con mucha paciencia.
[emoji16]
Enviado desde mi LG-H815 mediante Tapatalk
benzinkopf, your installation to 7E0 BCM Max would be a combination between this installation and this one.
Please, send me by email the same images as in the first installation. Thank you. :wink:
diskoboy
Drives: 1.6 TDI BMT
Post by diskoboy »
ciclo wrote:Thank you very much from my heart.Image
15 pages, this image is intentionally small.
because you can look this process here
Should this also be used on a 2011 Polo 6R 1.6 TDI with retrofitted xenon and your auto-light switch?
Hi diskoboy, as can be seen this installation (process) is for a VW Transporter T5.2 (7L3) non Bluemotion, so that the full installation for your 6R BMT with external Gateway would be different.
Many parts of your current installation (with automatic lights) can be used, but first you have to carry all signals from your external Gateway to the 7E0 BCM (Internal Gateway)
iichel did this process (installation) under my recommendation to get that HBA system was recognized through IC CAN-lines. (in case you want detailed information about it)
Elsawin or Erwin would solve all your doubts about the pin assignment and correspondence. (External Gateway & other units to new 7E0 BCM)
After that, follow this diagram. IIRC w/o Front foglights in your case. :wink:
Ambient Lights with 7E0 installation (diagram only). Dedicated to CNK and others who asked me... :lol:
:arrow: Click here to enlarge
CNK
Drives: 6R
Post by CNK »
ciclo wrote:Ambient Lights with 7E0 installation (diagram only). Dedicated to CNK and others who asked me... :lol:
Wow Image very thanks!
This mod will be very hard to me (I think it would be one of the most difficult retrofits in my 6R) :arrow: as you know, I'm afraid about my windshield... :oops:
Image Image Image
I read that a lot of people broken the windshield in mk5 when they tried to remove rear mirror..
It's my current mirror:
Image Image
I saw that guitar string is best tool to remove adhesive plate.
Does anyone have experience in removing it? :roll:
He has done very well this mod: https://next.drive2.ru/l/452853381304680815/ Image
And similar:
https://next.drive2.ru/l/6622827/
https://next.drive2.ru/l/10527865/
http://www.vw-golfclub.ru/forum/showthread.php?t=52858
http://forums.vwvortex.com/showthread.p ... iew-Mirror
https://www.vwgolfv.pl/viewtopic.php?f=52&t=5174
CNK wrote: Wow Image very thanks!
All in one. :wink:
The possibilities are endless with switch, potentiometer -Dimmer-, LEDs colors, etc...
Now I think it is integrated into the infotainment systems - Luxury Cars - and managed from the touch screen.
Thanks for such extensive information about interior mirror. Good job!
Also:
Removing interior mirror
To remove my retaining plate (RLS) from the windscreen I used a cheap cord to tie plants (metal-plastic) to avoid damage on the ceramic paint and glass.
Two gloves and patience. :)
peter_dk25, soon we will need one of these.
:lol:
benzinkopf
Drives: 1.2TSI 105HP DSG7
Post by benzinkopf »
ciclo wrote:peter_dk25, soon we will need one of these.
i want one too. pls start with ACC in 6R. hahaha
peter_dk25
Drives: Blue GT
Post by peter_dk25 »
ciclo wrote:peter_dk25, soon we will need one of these. :lol:
Cool! A very special version of GRA-HIGH will be needed for this driver :-)
it will be a magical GRA_High... like mine... :lol:
chisyelamos1
Drives: 6c 1.4tdi
Re: RE: Re: New Member. R-line 1.2 TSI 90hp 119gr.
ciclo wrote:New Mod:
-Voltmeter
Please thoroughly read description.
http://www.ebay.com/itm/DC-3-00-32V-Dig ... 20f2f70d37
http://www.ebay.com/itm/5-PCS-LOT-0-36- ... 1e96eb8a70
Store: http://stores.ebay.com/jennyear
Enlarge the hole on the bottom side and the left side according to the measures of the links. OEM hole is 23x16 mm.
Wiring from lighter socket.
The lighting is good. It is seen perfect for day and night.
Hello ciclo
Sorry for asking such an old topic.
How the hole plug is removed? and as the 12-volt socket is removed?
Esp. Como se quita la tapa que tiene el agujero? Y la toma de mechero? Lo he intentado y se mueve todo jejeje no vaya que lo parta.
the safest way is to remove the centre console completely. Sounds more extreme than it is...
remove the handbrake cover, gearknob base, armrest, radio and clima decors and the middle console.
Then you can remove the centre tunnel. it's about 15 minutes of work.
The dealer has a special tool for it
CNK
Drives: 6R
Post by CNK »
All in one. :wink:
Going back to our last conversation...
...can anyone confirm, that windshield from Polo 6RU Sedan fit to Polo 6R Hatchback? :lol:
chisyelamos1 wrote: Hello ciclo
iichel wrote:the safest way is to remove the centre console completely. Sounds more extreme than it is...
+1 :wink: (said by iichel)
http://workshop-manuals.com/volkswagen/ ... er_socket/
http://workshop-manuals.com/volkswagen/ ... n_bulbl28/
Locked
