Alarm help
antonio_king
Post by antonio_king »
hey MR_TOAD... great topic!
I have a mk4 and Toad Ai606 alarm. Was wondering what cable should use from the alarm to get the horn going off with the alarm? and to what colour cable and where should I connect it to?
Cheers!
markoff
Alarm Help
Post by markoff »
Good day Mr Toad,
I have, in the past, added a home made immobiliser to my cars (old cars and not Polos) by interrupting the 12v feed to the HT coil and taking this to a switch which I hide in the car somewhere. If the switch is open, no 12 v to coil so no HT and the sparkplugs cannot spark. This has saved my own car three times and my wife and daughter's cars at least once each. We have found that most alarm companies tend to put their override switches in the same place or in places the car thieves know about.
However, a family friend has asked me to fit this type of switch in her VW Polo 2007 model (1.4). But the engine is a lot more modern than the old types mentioned above and, although I can obviously trace the spark plug leads back to what I assume is an electronic distributor, I cannot find anything that looks like the old traditional HT coil.
Is there an HT coil in the new Polo? and where is it? If there is, is it safe to install one of my switches? If there is no traditional HT coil, is there some where that I can interrupt a voltage line which will achieve the same result?
Best Regards
Mark
MR_TOAD
Re: Alarm Help
Post by MR_TOAD »
markoff wrote:Good day Mr Toad,
Best Regards
Mark
Hi Mate
Dont go into ignition wires on new cars can upset ecu's put lights on and alsorts
Best is cut fuel pump wire or relay and ad relay in to switch
safest way
Ian
MR_TOAD
Post by MR_TOAD »
antonio_king wrote:hey MR_TOAD... great topic!
Cheers!
AI606 will have a short brown wire coming out
this give small pos feed when alarm is going off enough to run a relay to give power to horn
Ian
corky
Post by corky »
Hey Mr Toad,
i have a 6n 16v polo with central locking + immobilizer, the locking distance seems very poor (about 4ft!) and somewhat weak. i was going to change the batteries on the remote, but after reading a post where someone had a similar problem, they changed the batteries and it packed in all together - id rather avoid this! i was wondering if you knew if the poor locking distance was normal or if there is anything i can do to increase it - shy of fitting a whole new alarm etc.
cheers,
sam.
MR_TOAD
Post by MR_TOAD »
corky wrote:Hey Mr Toad,
cheers,
sam.
Hi Sam
What alarm is it you have ?
Ian
corky
Post by corky »
Mr Toad wrote:Hi Sam
Ian
Hi Ian,
It is a Logic 850/950 lock, immobilizer and alarm system -
Also, the boot no longer operates with the remote and has to be unlocked/locked manually. Any ideas?
Thanks again.
Sam
MR_TOAD
Post by MR_TOAD »
Sorry not dealt with them
but 90% of alarms as long as the battery is change quick a s poss then no problems should occur
Regards Ian
Ian
Hi Ian,
Thanks again.
Sam
corky
Post by corky »
cool cool man not to worry, thanks for the help dude.
take it easy,
sam.
antonio_king
Cheers!
Ian
Superb, don't suppose you know what cable to connect the brown one to?
ian1989
central locking on after market alarm
Post by ian1989 »
i got a 1996 polo 6n i just bought a new alarm but im having trouble locating my common line for my locking compresor could you please tell me what one it is as im loosing the will to live with it thanks ian
MR_TOAD
Post by MR_TOAD »
CDL 1: RED/BLUE OR GREY/RED-O/S/F DOOR HARNESS TEST!
CDL 2: GREEN/RED OR GREY/BLACK-O/S/F DOOR HARNESS TEST!
try them its neg operated
Ian
ian1989
Post by ian1989 »
hi there its me again i just tried them wires you said one of them is making it lock but not unlock and the othe is making it unlock and not lock were do i go from here thanks ian
MR_TOAD
Post by MR_TOAD »
ring me tomoro on 07774446402
Ian
ian1989
Post by ian1989 »
ok mate it will have to be bout 5:30 if thats ok cos im working thanks ian
