Page 3 of 3
Re: Rocker cover painting
Posted: Thu Jun 02, 2011 10:44 am
by alexperkins
Depends who powder coats it. Probs around £50 ish inc the prep work
Removing the rocker cover on these engines is a bugger
You have to take the cambelt off and remove the camshaft sprockets before you can remove it.
Posted: Thu Jun 02, 2011 11:00 am
by Verity
poop £50s quite a bit....but what i thought it would be
yeah i was all bummed out about that when i first wanted to get it painted. and found out it wasnt a screw off screw on jobbie.
id get the tech who did my cambelt to do it for a peperoni pizza
Posted: Thu Jun 02, 2011 12:22 pm
by red6n2
Oh the joys of being female :-/
Posted: Thu Jun 02, 2011 12:59 pm
by Verity
Haha the joys if having a boyfriend who works at VW
Posted: Thu Jun 02, 2011 2:16 pm
by red6n2
Ha ha the head tech at my vw took a keen interest in my car but when I had starting trouble and he told me it was my immobiliser which I knew it wasn't as the car started when cold first time Everytime and wanted to charge me £90 just to look at it I started to shy away from my newly found vw friend it was soon discovered by mr Perkins to be my engine temp sensor had gone changed that myself £35 done not had a problem since. And when I bought it I saw Brian head tech and he said it defiantly wouldn't fix it. Ha... vw 0 alex Perkins 1
Posted: Thu Jun 02, 2011 2:23 pm
by alexperkins
Posted: Mon Jun 06, 2011 7:23 pm
by tombarrack
Again, sorry to bring up an old topic, but I'm having a serious nightmare with the re-paint of my cover. I've given it a brushed on coat of halfords heat resistant paint, and left it for 48 hours to cure as per the instructions. However, after driving it today and having a quick gander at it, the top layer seems to have all blistered up into a leather effect under the heat? Is this normal? Will it settle to flat again after cooling? I'm getting pretty sick of my poor attempt at DIY - considering getting it removed and professionally sprayed whilst I get my cambelt done?
Posted: Mon Jun 06, 2011 9:28 pm
by Trottagti
Did you remove the red original paint???
Did you follow the instructions 100%
Most of the heat paints need heat when applying to cure the paint, if you want a 100% good diy job use the vht crinkle paint as it's ment to be used the way your trying now dude....
If it's blistered then that's a sign of it getting to hit to quickly and to thick. That's why I said DON'T brush it as this happens buddy.....
Posted: Mon Jun 06, 2011 9:37 pm
by tombarrack
Cheers man. Yeah I did. I didn't nitromorse it (because I was afraid) but i took it back to the metal using a variety of sandpapers & drill brushes. I'm guessing it's probably just too thick then if it's wrinkled everywhere. Thanks for the heads up with the crinkle paint - although I'm technically after a smooth finish?
If i take it back off again, and use something like this:
http://www.halfords.com/webapp/wcs/stor ... 65495#dtab
do you reckon I'd have better luck?
Presumably I'd have to mask up the entire bay if I was painting on the car?
Posted: Mon Jun 06, 2011 9:44 pm
by Trottagti
Yeah that looks ok stuff mate but i would go for a proper brand like vht mate there on eBay...
Look them up they do like loads of colors mate so go crazy ha....
