What's wrong with 5 doors?whitegtipolo wrote:Love it needs lowering like mine way too high. Why 5door??
New Member
- Edi30
Re: New Member
Re: New Member
For some reason the dark wheels make it look higher, needs lows now. Stunning
- whitegtipolo
Re: New Member
Not saying looks bad just asking why he chose 5doors
- Edi30
Re: New Member
I know just having a bit of fun. If I didn't have the need for 5 doors I would have saved the money and gone for 3 doors. I do think that VW do a great job of making both models look great.whitegtipolo wrote:Not saying looks bad just asking why he chose 5doors
- Edi30
Re: New Member
Bennyboy, did you get your issues resolved?bennyboy wrote: 2 the headlights on there highest setting still is not high enough feels like i can only see about 30 feet infront of the car and the golf was about 50-60 foot so not to happy about that .
4 while out last night planted my right foot again and got the spped right upthere is a very loud droning noise as if there is a blown exhaust at the manifold but as soon as you lift off alittle it go's away, so im hoping its just the newness and it will quiet down once i have a few more miles on it .
sorry no pictures as to much driving and it was raining all day and night and now the car is mega dirty and still raining now.
- bennyboy
- Drives: old 6r GTI , now 6c GTI
Re: New Member
5 doors 1 of the reasons were easy access for passengers and for me going from a golf big boot that i often filled up,so going to the alot smaller polo the back seat will be getting used alot more.
and regarding the headlights its booked in on tuesday to check the light levels but i was told the bulbs are std so i will be after a lot brighter set so if you know of any that are a straight swap over let me know cheers
- Edi30
Re: New Member
If you want a straight swap for H7 bulbs I can recommend Xenon upgrades. I have replaced my std bulbs with Osram Nightbreakers which are claimed as being 90% brighter than std halogen. Philips also do some Xenons X-treme Power which I have in my golf but the Osrams are better. Ring also do Xenon max claiming 100% brighter but I have no experience of these. These Xenon upgrades are about £25 a pair and are well worth it.bennyboy wrote:5 doors 1 of the reasons were easy access for passengers and for me going from a golf big boot that i often filled up,so going to the alot smaller polo the back seat will be getting used alot more.
Failing that if you want to go brighter then you could try HID kits which are more expensive but again I have no experience of these so I will let the forum guys tell you about the available kits and costs etc.
- whitegtipolo
Re: New Member
I have fitted hid kit to mine I can help with any issues if you want to fit
- bennyboy
Re: New Member
Thanks alot for the offer but im not in any way mechanically minded, a bulb change is about all i can dowhitegtipolo wrote:I have fitted hid kit to mine I can help with any issues if you want to fit
- bennyboy
Re: New Member
just put in a nice new set of osram nightbreakers as recommended by edi30 Cheers
i fitted 1 and could see a big differance in brighness so done both headlights and im gonna head back out in a hour or 2 to check on the distance of the new bulbs , and im back to the dealers tomorrow to get the light level checked out as im still not happy even though i have them on the highest setting on the dash dial.
- Edi30
Re: New Member
What was the outcome of the trip to the dealer? Also how are you getting on with the new bulbs?
- bennyboy
Re: New Member
The bulbs are loads better thanks for the info
the dealers
firstly dont forget i had all ready changed to the osrams blubs the day befor , so the car went in and both headlights were way out the both needed adjusting up as i thought by quite alot as i stood and watched him do it and then he said that the beam brightness is adequate and then i told him that i had replaced them both and he seemed rather shocked so i just told him now imagine what i have been driving with for the last 2 weeks , near darkness + i also found 2 blach square blocks of sponge both in a bag and 1 in each wing both full of water so i pulled thm both out and asked what the hell there were and why they were in my wings he looked at me and said sound proofing
and at that point i nearly fell over followed by " how gullable do you think i am " i wasnt a happy customer that day.
but still love the car
so now with the new bulbs and the lights both adjusted its great even in the dark.
- Edi30
Re: New Member
Pleased the lights are sorted now. So has your dealer now finished the PDI?
- whitegtipolo
Re: New Member
I have them foam bits in behind the lights thought was standard
- Edi30
Re: New Member
No foam in mine might be worth asking the dealer if this should have been removed at the PDI, but it sounds odd to me. I have never had this in any of my VW's in the past.whitegtipolo wrote:I have them foam bits in behind the lights thought was standard
