Upgrade Bulbs
Enty
Drives: Candy 6R
Re: Upgrade Bulbs
Post by Enty »
NMavs wrote:Aye over blackburn way :D I know of it haha. And yeah, honestly dead easy. I dont think some people realise that the headlights come out so easy lol. The only fidily bit is the stupid metal clips that hold the bulb inside the headlamp, but am sure you'll figure it out :-) haha
Woop! lol
I do miss the old place!
Also, don't suppose you got any idea how to get the plastic thing off the inside of the boot lid do ya?
NMavs
Re: Upgrade Bulbs
Post by NMavs »
haha. Erm, i havent had the one of this car, but my old 9n3 gti if i remember rightly had around 6 torx screws, and tight retainer clips holding it on. Just remove as many torx screws you can find, look inside the moulded handle on the inside of the boot as well, there'll be two screws up inside there. Then pull on it as hard as you can, because it'll be really tight. Hope that helps you lol :D
craig200588
Re: Upgrade Bulbs
Post by craig200588 »
Hey, Im needing some serious upgraded bulb-age. The standard bulbs are pure p!sh and cant see anything in the dark! I want bright white likes with as little yellow as possible, but I'm a total thicko when it comes to bulbs so if you kind folk could point me in the right direction! Not really wanting to spend a load, £30 or £35 tops!. cheeeeeers!!
AJ_7
Re: Upgrade Bulbs
Post by AJ_7 »
craig200588 wrote:Hey, Im needing some serious upgraded bulb-age. The standard bulbs are pure p!sh and cant see anything in the dark! I want bright white likes with as little yellow as possible, but I'm a total thicko when it comes to bulbs so if you kind folk could point me in the right direction! Not really wanting to spend a load, £30 or £35 tops!. cheeeeeers!!
I've installed Phillips Blue Vision Ultra. The name is quite decieving, they're very white with a very slight tinge of blue. If you read earlier in this thread I put a link up and a discount code for hids4u. All in all, 2 headlight and 2 sidelight bulbs (which come free) came to £19 delivered.
Failing that, a few other people go for the Osram Nightbreakers :)
