Page 3 of 5
Re: How to fix the 6N2 ABS Signal Outside Specifications Fault
Posted: Thu Apr 18, 2019 10:55 am
by alexperkins
Frank, havent received any PM from you. You only have 6 posts which is why it probably doesnt work. Get past 10 and youll be able to PM me
Posted: Thu Apr 18, 2019 10:17 pm
by Polofrank
OK thanks Alex, have been tearing my hair out with the rear wiper too.
Supplied a direct battery current to the motor and it works fine . The other "power" wire is the self parking supply and that works fine too, but having had a little fiddle with trying to get power through from the relay area under the dash, it seems there must be another break in that wire somewhere, ( other than the one I found within the rubber boot in the hatch boot lid area )
Managed to bust a few fuses so have had to give up on the plan for the time being. I can see you wringing your hands at the amateurish antics !
Ref the ABS, I have bought a spare second hand pump complete with electronics , so had hoped to send that to you for inspection and for you to work your magic on it ?
Posted: Thu Apr 18, 2019 10:36 pm
by alexperkins
You may have more than one break
Do some multimeter testing to see if it’s an earthing fault or a positive feed fault
Sure, get to 10 messages and PM me and we can get that sorted
Posted: Thu May 30, 2019 8:09 pm
by zodiac1973
Thanks so much for this very useful information , ive had this problem on my gti and fixed it today in work, you are a legend
Posted: Thu Aug 01, 2019 2:17 pm
by Enos
Just wanted to express my gratitude to @alexperkins and everyone else who contributed to this thread.
I successfully fixed the issue on my 2001 Polo 6N2 with the same procedure as the one mentioned in the OP post.
Here is the picture of bad solder joint resulting in "Signal out of specification" error code:
http://prntscr.com/omzpo5
Posted: Sat Aug 31, 2019 11:08 am
by Polofrank
Hi Alex, still have the ABS problem but seem unable to send you a PM, any chance of finding some other way to communicate as this whole business is driving me crazy!
Posted: Sat Aug 31, 2019 8:30 pm
by Polofrank
Got your reply ok now and a PM sent. Old unit is split and wondering if one of the multipins in the bigger plug is causing a problem as the third one in from the top left shows no signs of scratching caused by being plugged into the female receptor. If thats not making a contact could that possibly be where the problem lies?
download/file.php?mode=view&id=3382
Posted: Sat Aug 31, 2019 8:49 pm
by Polofrank
Sorry, one more question about splitting the unit. Mine seems to have a set of small clips all around the controller so is it not possible to open it by prising the 13 little clips open all at once ?
download/file.php?mode=view&id=3383
Posted: Sat Aug 31, 2019 9:05 pm
by alexperkins
Will come back to you tomorrow or Monday. Chaos here as we’re moving house
Posted: Sat Aug 31, 2019 9:50 pm
by Polofrank
OK, many thanks
Posted: Mon Sep 02, 2019 2:18 pm
by alexperkins
Yes, but very gently. Those clips will VERY easily snap off due to the type of plastic they use
Posted: Mon Oct 07, 2019 8:39 pm
by vas.bak
Hello Alex
I am vasilis from Athens Greece
I was fix it my pump fault by folowing your instructions I weld the two conectors inside the abs modul.
But works perfect for one day.. and the second day start an other problem..
And light on again and in low speed under 20km and my foot on brake pedal
until the car stops and the pedal kicks me ..
I connect vcds and the fault I read is left front sensor problem... I change with a new one But starts again..
I was check the abs rotor... is clean and in perfect condition.
Please help me if you know what is this?
Posted: Fri Oct 11, 2019 3:30 pm
by vas.bak
Hello
Have a fix solution
Posted: Sat Oct 19, 2019 9:40 am
by vas.bak
Hello Alex
You don't see my post
Or
You don't know the solution for my problem
Posted: Wed Oct 23, 2019 8:51 pm
by vas.bak
Hello mates
Someone have solution at my ABS problem?
