Polo 6R 1600 TDI Team
Re: Polo 6R 1600 TDI Team
Checked ..., this is always the same thing, the money.
If optionals are not included in the purchase/configuration of a car it is logical that everything is at the limit of what is possible.
off topic
Maybe now it can be understood better the reason why I always asked for the images of the fuse box, and the wires that reach the dimmer and light switch connectors to make the wiring/harnesses I had for sale. Also a car front image, to see the lights configuration, ...because all this of the optionals and the multiple configurations is not explained in any manual, only visible in the 6R itself. Even with the VIN it is not possible to have this information so specific, e.g... DRLs installed, OK, but what installation type?...
The great 6R, was and will be an unexpected gift for our hands. As I said on occasion, the perfect car to learn.
Thanks world crisis! :lol:
Turbodruk
Drives: Polo 6R 1600 TDI Team
Post by Turbodruk »
Hi Ciclo!
Thank you for all your codings. Here is an autoscan after I used your coding for the Central Electrics and the RLS.
Sunday,12,November,2017,18:56:39:51415
VCDS Version: 17.8.0.1 (x64)  HEX-V2 CB: 0.4407.4
Data version: 20170721 DS276.2
www.Ross-Tech.com
VIN: WVWZZZ6RZBY015008   License Plate:
Chassis Type: 6R-VW25 (7E0)
Scan: 01 03 04 08 09 10 15 17 19 25 2E 44 56 61 77 0B
VIN: WVWZZZ6RZBY015008   Mileage: 153480km-95368miles
56-Radio -- Status: OK 0000
77-Telephone -- Status: Malfunction 0010
Address 01: Engine (J623-CAYB)       Labels:. 03L-906-023-CAY.clb
   Part No SW: 03L 906 023 EP    HW: 03L 906 023 D
   Component: 1,6l R4 CR td H13 9970
   Revision: --H13---    Serial number:
   Coding: 00114034002401080000
   Shop #: WSC 124697 483 00190
   ASAM Dataset: EV_ECM16TDI02103L906023EP 003007
   ROD: EV_ECM16TDI02103L906023EP_003.rod
   VCID: 78A818B3A25FC6B763A-802C
Readiness: 1110 1000
Address 03: ABS Brakes (J104)       Labels:. 6R0-907-37x-ESP82.clb
   Part No SW: 6R0 907 379 AJ    HW: 6R0 907 379 AF
   Revision: --------
   Coding: 210228E3416E00B7842514E282D900521100
   Shop #: WSC 02069 000 00000
   VCID: 0654664BD86BA047616-8052
Address 08: Auto HVAC (J301)       Labels: 6R0-820-045-9AP.clb
   Part No SW: 6R0 820 045 J    HW: 6R0 820 045 J
   Component: Climatic       25 0660
   Revision: 00 11 25
   VCID: 3536D187F54DFBDFB8C-8060
1 Fault Found:
00457 - Control Module for Network (J519)
            013 - Check DTC Memory
                    Fault Status: 01101101
                    Fault Priority: 6
                    Fault Frequency: 1
                    Reset counter: 1
                    Mileage: 153487 km
                    Time Indication: 0
                    Date: 2017.11.12
                    Time: 18:53:43
   Revision: B9080001    Serial number: 0771 116170197
   Coding: 3CB029BF48A10000012805906C2B1ED15F80412F60840048200000030000
   Shop #: WSC 18752 008 00032
   VCID: 688848F3F27F5637F3A-803C
   Subsystem 1 - Part No: 1K0 955 559 AH  Labels: 1K0-955-559-AG.CLB
   Component: RLS 180510 05  54  0403
   Coding: 06302D
   Subsystem 2 - Part No SW: 6R0 959 801 R    HW: 6R0 959 801 R  Labels: 6R0-959-801.CLB
   Component: J386__TSG_FT  006 0912
   Serial number: KU0-KU020.05.1010960
   Coding: 48BC30
   Subsystem 3 - Part No SW: 6R0 959 802 T    HW: 6R0 959 802 T  Labels: 6R0-959-802.CLB
   Component: J387__TSG_BT  006 0912
   Serial number: KU0-KU018.05.1011444
   Coding: 48BC30
   Subsystem 4 - Part No SW: 5K0 959 542 C    HW: 5K0 959 542 C
   Component: E221__MFL-TAS  H31 0033
   Serial number: 0361915
   Coding: 020000
3 Faults Found:
02745 - Bulb for Daytime Running Light; Left
            010 - Open or Short to Plus
                    Fault Status: 01101010
                    Fault Priority: 3
                    Fault Frequency: 1
                    Reset counter: 1
                    Mileage: 153487 km
                    Time Indication: 0
                    Date: 2017.11.12
                    Time: 18:53:45
02746 - Bulb for Daytime Running Light; Right
                    Fault Priority: 3
                    Fault Frequency: 1
                    Reset counter: 1
                    Mileage: 153487 km
                    Time Indication: 0
                    Date: 2017.11.12
                    Time: 18:53:45
02195 - Dimmer Switch Instrument Panel & Switch Lighting (E20)
            008 - Implausible Signal
                    Fault Status: 01101000
                    Fault Priority: 3
                    Fault Frequency: 1
                    Reset counter: 1
                    Mileage: 153487 km
                    Time Indication: 0
                    Date: 2017.11.12
                    Time: 18:53:45
Address 10: Park/Steer Assist (J446)       Labels:| 6R0-919-475.clb
   Part No SW: 6R0 919 475     HW: 6R0 919 475
   Component: PARKHILFE 4K  H07 0008
   Revision: --------    Serial number: 71391012733298
   Coding: 100001
   ASAM Dataset: EV_VW250ParkiAssis2 S01006
   ROD: EV_VW250ParkiAssis2.rod
   VCID: 7BA207BF9369EDAF0E8-802E
   Part No SW: 6R0 959 655 C    HW: 6R0 959 655 C
   Component: VW10Airbag00L H09 0018
   Revision: --------    Serial number: 003DW00G103P
   Coding: 00304C
   VCID: 42DCBA5BB4035C670DE-8016
   Serial number: 3572SRB40000B8408ACB
   Serial number: 3582SRB40000B8185282
   Serial number: 3516GRB401R9OICD64ET
   Serial number: 3526GRB401T9OICCSB69
Address 17: Instruments (J285)       Labels:| 5K0-920-xxx-17.clb
   Part No SW: 6R0 920 870 A    HW: 6R0 920 870 A
   Component: KOMBI         H04 0709
   Coding: 540800
   Shop #: WSC 00788 648 00255
   VCID: 3332EF9FFBB9E5EF968-8066
   Revision: B9080001
   Coding: 002200
   Component: IMMO          H04 0709
   Serial number:
   Shop #: WSC 00000 000 00000
   VCID: 6A8C32FBECF36427E5E-803E
Address 2E: Media Player 3
Cannot be reached
   Part No: 6R0 423 156 B
   Coding: 11230
   Shop #: WSC 00788
   VCID: 2F3AE3EF1E51C10FF20-807A
Address 56: Radio (J0503)       Labels:. 5M0-035-1xx-56.clb
   Part No SW: 5K0 035 190 B    HW: 5K0 035 190 B
   Component: Radio RCD510  005 0236
   Revision: 00000001    Serial number: VWZ1Z3P0376022
   Coding: 01000401020001
   Shop #: WSC 00020 790 12345
   VCID: 24101CC34ED772571F2-8070
   Part No SW: 7E0 907 534     HW: 7E0 937 090
   Component: Batt.regelung H80 0736
   Coding: 030B1A5A
   Shop #: WSC 12345 123 12345
   Component: J367-BDM  H07 0125
   Serial number: 00000000002790237207
Address 77: Telephone (J412)       Labels:| 5N0-035-729.clb
   Part No SW: 5N0 035 729 A    HW: 5N0 035 729 A
   Component: TELEFON       H05 0315
   Revision: 1B001001    Serial number: 00007665485869
   Coding: 0810030080010110
   Shop #: WSC 00015 115 00001
   ASAM Dataset: EV_UHVUMI 001007
   ROD: EV_UHVUMI.rod
   VCID: 2E04FEEB109BC807F96-807A
2 Faults Found:
9457426 - Left audio channel for speech/telephone
          B104F 12 [009] - Short to GND
                    Fault Status: 00000001
                    Fault Priority: 4
                    Fault Frequency: 1
                    Reset counter: 1
                    Mileage: 153487 km
                    Date: 2017.11.12
                    Time: 18:53:45
9457170 - Right audio channel for speech/telephone
          B104E 12 [009] - Short to GND
                    Fault Priority: 4
                    Fault Frequency: 1
                    Reset counter: 1
                    Mileage: 153487 km
                    Date: 2017.11.12
                    Time: 18:53:45
End----(Elapsed Time: 01:31, VBatt start/end: 12.1V/12.1V. VIgn 12.0V)-----
There seems to be a new error in the auto HVAC, not sure what it means. Perhaps in the future I will know. :lol:
The H7 now work again with the light switch on "0", the rear lights are off, no problem at all.
Do you want me to snap some pics of my wiring looms inside the car? (Dimmer switch loom, light switch loom, fuse box)
I was first thinking of retrofitting the DRL's beside the fog lamps, but taking into consideration I want to do the 6C LED headlight retrofit, it's probably better to wait for that, as I'll get LED DRL's.
Thanks again!
Turbodruk wrote: Sun Nov 12, 2017 6:00 pm The H7 now work again with the light switch on "0", the rear lights are off, no problem at all.
Well, this has become very interesting, extraordinarily interesting.
About the specific legal questions and manufacture dates for each country I prefer not to comment anything because in the end we would all be right or not ...
Now at this moment you have activated the DRLs (TFL = Tagfahrlicht) and deactivated the "Dauerfahrlicht" -> permanent/continuous operating light.
(I write it in this way so that others can understand it).
https://en.pons.com/translate/wyhlidal- ... rfahrlicht :?: (I think it's no right)
https://en.pons.com/translate?q=Tagfahr ... en&in=&lf= :wink: :lol:
The question now is to find out why we get the two faults in the automatic scan for the DRLs. For this it would be necessary to change the BCM coding again to find the correct way to activate the DRLs (TFL) in your 6R Bluemotion. (original/factory wiring like a 6R with 7H0 BCM Max but without separate DRLs)
I think I know how to do it.
I'm going to study the BCM coding in detail and now I'm back ... :)
Try this:
3CB029BF48A10000012805906C2B1ED15B80412F60840048200000030000
and we will have managed to activate your DRLs (TFL) and deactivate your "Dauerfahrlicht" in the correct way.
Revision: 00 11 25
1 Fault Found:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 1
Mileage: 153487 km
Time Indication: 0
Date: 2017.11.12
Time: 18:53:43
Thanks again!
climatronic error 00457 - Control Module for Network (J519) is solved by setting adaptation channel 1 of the HVAC to value 1
... this is what iichel discovered.
Turbodruk wrote: Sun Nov 12, 2017 6:00 pm Do you want me to snap some pics of my wiring looms inside the car? (Dimmer switch loom, light switch loom, fuse box)
It would be perfect :wink: , besides necessary for future installations. (6C LEDs headlights)
In this way, for example:
viewtopic.php?f=56&t=69121#p515584
viewtopic.php?f=56&t=69121#p515598
viewtopic.php?f=56&t=69121#p515618
Turbodruk wrote: Sun Nov 12, 2017 6:00 pm I was first thinking of retrofitting the DRL's beside the fog lamps, but taking into consideration I want to do the 6C LED headlight retrofit, it's probably better to wait for that, as I'll get LED DRL's.
Completely agree with you.
ciclo wrote: Sun Nov 12, 2017 7:41 am iichel can/could include this wire in your wiring for automatic lights. I would do it . :lol:
t73b/4 to t10au/10 is present
iichel wrote: Mon Nov 13, 2017 1:36 pm
t10au :?:
T10au - 10 pin connector for automatic headlights :lol:
iichel wrote: Mon Nov 13, 2017 2:01 pm T10au - 10 pin connector for automatic headlights :lol:
That is not correct iichel, the wire 0.5 mm2 (T10au/10) to which you refer is for the backlighting of the light switch and has to come from T6/5 Dimmer connector (output). Already present in any 6R (T17/17).
And the new wire we refer is to feed the Dimmer through T6/3 pin (input), this in turn will feed all the interior lighting of switches, including the light switch.
This wire has to come from T73b/4 in this case, and must be 1.0mm2 thickness (mandatory).
Therefore, it is necessary to install a new wire in the Turbodruk 6R from T6/3 Dimmer connector to T73b/4 BCM white connector so that the 7E0 BCM that we are installing works correctly (apart of your new wiring for automatic lights).
This new wire is part of the necessary adjustments to adapt the new 7E0 BCM in Turbodruk 6R.
I understand you ciclo, don't worry.
There is two T10's. The T10 replacing T17 and the T10 for the light switch. I refer to the T10 replacing T17 where T10/10 is vacant in normal auto light wiring.
you refer to T10 for the light switch where T10/10 is grey/blue for terminal 58d.
I think were are talking about two different T10's
Turbodruk
Post by Turbodruk »
Hello !
I set the new coding, the faults of the DRL's are gone, ciclo and iichel are magicians. :lol:
The HVAC faults are still there, it doesn't really bother me. I think it's because I've got cheap climatic, not fancy pantsy climatronic.
Here are some photo's from my wiring system:
And last but not least, a fresh autscan. The faults of the microphone is still there, I haven't got time to look what's going on behind the radio. No rush. :)
Tuesday,14,November,2017,18:47:21:51415
www.Ross-Tech.com
VIN: WVWZZZ6RZBY015008   Mileage: 153610km-95448miles
   Revision: --------
   Revision: 00 11 25
1 Fault Found:
                    Fault Priority: 6
                    Fault Frequency: 1
                    Reset counter: 5
                    Mileage: 153613 km
                    Time Indication: 0
                    Date: 2017.11.14
                    Time: 18:43:52
   Coding: 3CB029BF48A10000012805906C2B1ED15B80412F60840048200000030000
   Coding: 06302D
   Coding: 48BC30
   Coding: 48BC30
   Coding: 020000
1 Fault Found:
                    Fault Priority: 3
                    Fault Frequency: 1
                    Reset counter: 5
                    Mileage: 153613 km
                    Time Indication: 0
                    Date: 2017.11.14
                    Time: 18:43:55
   Coding: 100001
   Coding: 00304C
   Coding: 540800
   Revision: B9080001
   Coding: 002200
   Serial number:
Cannot be reached
   Coding: 11230
   Shop #: WSC 00788
   Coding: 030B1A5A
   ROD: EV_UHVUMI.rod
2 Faults Found:
                    Fault Priority: 4
                    Fault Frequency: 1
                    Reset counter: 5
                    Mileage: 153613 km
                    Date: 2017.11.14
                    Time: 18:43:55
                    Fault Priority: 4
                    Fault Frequency: 1
                    Reset counter: 5
                    Mileage: 153613 km
                    Date: 2017.11.14
                    Time: 18:43:55
End----------(Elapsed Time: 01:31, VBatt start/end: 12.3V/12.3V)-----------
Thanks to all people that are willing to spend their time helping and inspiring others. :D
Cheers.
Thanks for this report. Excellent. 8)
We have achieved something unprecedented in your/a special* 6R Bluemotion.
(We = you and me)
ciclo wrote: Mon Nov 13, 2017 7:23 am Try this:
* special due to:
- from 6R0937088 to 7E0937090 BCM
- from external GW to internal GW (BCM).
- without separate DRLs from factory.
- wiring configuration.
Now I would like to know why VW (there will be good reasons for this) sold these 6R Bluemotion with activated "Dauerfahrlicht" instead of TFL ...
(Driving with parking lights is strictly prohibited except in the Scandinavian countries)
With "Dauerfahrlicht" they may say that in the front are TFL, but in the rear are the parking lights. :|
In my humble opinion I think the rear parking/side lights should not be lit under any circumstance with enough sunlight and good weather conditions.. If they are activated they mitigate the brake lights effect.
I have observed this circumstance in the place where I live (a place with lots of sunlight) in those that have the Scandinavian lights activated to simulate daytime running lights.
The rest of faults:
BCM (as I explained to you)
Waiting for you to install the new wire (T6/3 -> T73b/4) to solve:
Therefore this is solved.
Climatic
Maybe it's related to the previous fault you still have in the BCM (above).
Media Player and Telephone
This/your unit is unknown to me, but I'm sure it's easy to solve. Search for online coding and check the installation (wiring).
Turbodruk
Post by Turbodruk »
Hey ciclo!
I've already installed the wiring you mentioned. The radio works perfectly, and so does the Bluetooth etc. I used an original VW microphone which I plugged into the wiring harness of this kit. When installing the cables for the 7E0 BCM, I think I unplugged the microphone without knowing. This is probably the reason why the faults are there in VCDS. Thank you for your concerns. :)
Greets.
Perfect, another thing solved.
We are very close to having a perfect Autoscan with everything Ok, and a block of improvements achieved. :wink:
The best is yet to come... :)
Turbodruk
Post by Turbodruk »
Next up after making a clean autoscan is the installment of the 6C LED headlights. I want to do a step by step install, to avoid having problems interfering with one another. I think this is a chronological order:
Install 6C headlights with wiring looms for a 6R with halogen headlights
Install LWR (automatic height adjustment)
Install SWRA (headlight washer units) with R-Line bumper
I do have start stop system. Would this be a problem for the 6C LED?
Some good news (probably?)
My dad is looking into buying a T6 California with LED headlights and ACC. If all goes through, I can provide an autoscan. Are you guys interested in such an autoscan?
