Steering rack upgrade from PR-1N2 to PR-1N4
- Jay-Jay
- Drives: Polo 6R HL 1.2TSI 77kw, Audi S1 MY2018
Re: Steering rack upgrade from PR-1N2 to PR-1N4
Here it is:
ESP8.2i
J104
HW: 6R0907379AF H05
SW: 6R0907379AF 0005
Long coding:
210248E3437200BA842912E9C2D800421700
ESP8.2i
J104
HW: 6R0907379AF H05
Long coding:
Hm, that looks ok to me. You could try 210248E3417200BA842912E982D800421700 to remove the sports package option but i doubt it will make a difference.
I don't know if it's related and I don't know if I already mentioned it here or elsewhere, but when the front bushings were changed in an official workshop on our ex-9N3, the subframe was removed to do it more 'easily' (not indicated in the manuals to do this job), and then the wheels squeaked on every corner at just 20 km/h... they had not aligned the subframe.
- Jay-Jay
I've just tried the coding you suggested, but the problem is still there.iichel wrote: Sat Jun 08, 2024 1:57 pm Hm, that looks ok to me. You could try 210248E3417200BA842912E982D800421700 to remove the sports package option but i doubt it will make a difference.
Just out of curiosity: what does the sport package ABS coding mean? Does it affect somehow the way ESC works?
Btw: this morning I asked a mechanic friend to take a test drive together with me.
We test drove the car for about 2 hours over all the roads and turns where I was sure to replicate the ESP problem.
At first, he said it feels like an electronical problem. So, while he was driving I monitored wheel speed sensor and G85, G200 and G202 sensor values, but I didn't noticed any strange value, even when the ESP kicked-in abruptly.
Like me, he also noticed the problem is much more present when turning on the right than on the left.
He also noticed that there is wheel rubbing only on the front left wheel when taking turns on the right. It seems like there is more body rolling and suspension compression on the front left of the car. As I already said, I replaced almost everything: the struts and all the wishbones bushings are new, so they can't be the cause of that.
So, after a while, he asked to bring the car to my garage to have a quick look at the front left wheel, which seems where the problem comes from.
We lifted the car and the front left wheel has literally zero play.
He excluded any kind of mechanical problem related to the steering rack and to the ball joint.
Then, with the car lifted only on the left side, he asked me to turn the steering wheel and to quickly move it by little movements on the left and on the right, while looking inside the wheel arc to the suspension components. What he saw is that the antiroll bar seems to not only rotate up and down, but also to steangely move in a diagonal way, like if the rubber bushings have a bit of play, despite the fact they don't make any noise on the road.
So, in the end, he suggested me to precautionally replace them, preferrable with poly bushes and to test again the car.
When I did the steering rack replacement job, I centered the subframe with the proper VW centering pins... This is why I can't understand what is going on.ciclo wrote: Sun Jun 09, 2024 4:16 am I don't know if it's related and I don't know if I already mentioned it here or elsewhere, but when the front bushings were changed in an official workshop on our ex-9N3, the subframe was removed to do it more 'easily' (not indicated in the manuals to do this job), and then the wheels squeaked on every corner at just 20 km/h... they had not aligned the subframe.![]()
1 week after I brought the car to the wheel alligbmebt workshop and the measured values were pretty good. I remember there was just a slight difference of 0,4° in caster between the front left and the front right wheel. Camber was almost identical.
More than 1 month ago, I also installed front subframe rigid collars, which not only center the subframe, but also make it more rigid and eliminate the play the bolts have inside the subframe holes.
I'm really getting crazy. All seems ok, but it is definetely not when on the road.
i'm guessing the steering angle of the wheels is different between what the ESP expects based on steering angle sensor
so G85 angle of i.e. 180 degrees would be a certain movement in the rack, that results in the movement of the steering arm by 1 cm. then the wheel makes an 10 degree angle. wheel rotation difference shows, lateral acceleration has a value.
with the 1N1 it might be 1 cm of steering arm, with 1N4 it's maybe 0.8cm. I guess this is where the ESP says 'something ain't right' because the values don't show as expected and tolerances are violated
it probably is a coding thing, that's why i suggested sports mode in ESP coding. i'm sorry it didn't help.
- Jay-Jay
That would make sense.
You don't have to be sorry. I'm graetful to you for your help.
So I'd need to understand what I have to modify in the ABS coding.
If some other ideas come to your mind, I'm open to make new tries.
Honestly, I wouldn't want to find myself obligated to put back my old PR-1N2 steering rack.
could you post an adapmap of your abs controller please?
- Jay-Jay
Here it is:
At this point, I wonder what's the function of the last digit in the Steering coding ("0" for PR-1N2 and "1" for PR-1N4). I thought it makes the ABS unit knows what kind of steering rack is installed, but maybe it only affects the steering fluid pressure and the steering feeling.
SW:6R0-907-379-AF HW:6R0-907-379-AF --- ABS Brakes --- SA: 40168
Component:ESP8.2i front H05 0005, Coding:210248E3417200BA842912E982D800421700
Sunday,09,June,2024,17:03:12:00009
VCDS Version: Release 21.9.0 (x64) Data version: 20210903 DS330.0
VCID: 020B3F0F990F189957-8056
Channel Field 1 Field 2 Field 3 Field 4
1 0 Adaptation Tire Pressure Enabled N/A
2 ERROR: Channel 02 Not Available
3 ERROR: Channel 03 Not Available
4 ERROR: Channel 04 Not Available
5 ERROR: Channel 05 Not Available
6 ERROR: Channel 06 Not Available
7 ERROR: Security access required
8 ERROR: Channel 08 Not Available
9 2 Value large N/A N/A
10 ERROR: Security access required
11 ERROR: Channel 11 Not Available
12 ERROR: Channel 12 Not Available
13 ERROR: Channel 13 Not Available
14 ERROR: Channel 14 Not Available
15 ERROR: Channel 15 Not Available
16 ERROR: Channel 16 Not Available
17 ERROR: Channel 17 Not Available
18 ERROR: Channel 18 Not Available
19 ERROR: Channel 19 Not Available
20 ERROR: Channel 20 Not Available
21 1 Value center N/A N/A
22 ERROR: Channel 22 Not Available
23 ERROR: Channel 23 Not Available
24 ERROR: Channel 24 Not Available
25 ERROR: Channel 25 Not Available
26 ERROR: Channel 26 Not Available
27 ERROR: Channel 27 Not Available
28 ERROR: Channel 28 Not Available
29 ERROR: Channel 29 Not Available
30 ERROR: Channel 30 Not Available
31 ERROR: Channel 31 Not Available
32 ERROR: Channel 32 Not Available
33 ERROR: Channel 33 Not Available
34 ERROR: Channel 34 Not Available
35 1 Function ON N/A N/A
36 2 Value Strong N/A N/A
37 ERROR: Channel 37 Not Available
38 ERROR: Channel 38 Not Available
39 ERROR: Channel 39 Not Available
40 ERROR: Channel 40 Not Available
41 ERROR: Channel 41 Not Available
42 ERROR: Channel 42 Not Available
43 ERROR: Channel 43 Not Available
44 ERROR: Channel 44 Not Available
45 ERROR: Channel 45 Not Available
46 ERROR: Channel 46 Not Available
47 ERROR: Channel 47 Not Available
48 ERROR: Channel 48 Not Available
49 ERROR: Channel 49 Not Available
50 ERROR: Channel 50 Not Available
51 1 Function Enabled N/A N/A
52 ERROR: Channel 52 Not Available
53 ERROR: Channel 53 Not Available
54 ERROR: Channel 54 Not Available
55 ERROR: Channel 55 Not Available
56 ERROR: Channel 56 Not Available
57 ERROR: Channel 57 Not Available
58 1 Value center N/A N/A
59 ERROR: Channel 59 Not Available
60 ERROR: Channel 60 Not Available
61 ERROR: Channel 61 Not Available
62 ERROR: Channel 62 Not Available
63 ERROR: Channel 63 Not Available
64 ERROR: Channel 64 Not Available
65 ERROR: Channel 65 Not Available
66 ERROR: Channel 66 Not Available
67 ERROR: Channel 67 Not Available
68 ERROR: Channel 68 Not Available
69 ERROR: Channel 69 Not Available
70 ERROR: Channel 70 Not Available
71 ERROR: Channel 71 Not Available
72 ERROR: Channel 72 Not Available
73 1 Function ON N/A N/A
74 ERROR: Channel 74 Not Available
75 ERROR: Channel 75 Not Available
76 ERROR: Channel 76 Not Available
77 ERROR: Channel 77 Not Available
78 ERROR: Channel 78 Not Available
79 ERROR: Channel 79 Not Available
80 ERROR: Security access required
81 ERROR: Channel 81 Not Available
82 ERROR: Channel 82 Not Available
83 ERROR: Channel 83 Not Available
84 ERROR: Channel 84 Not Available
85 ERROR: Channel 85 Not Available
86 ERROR: Channel 86 Not Available
87 ERROR: Channel 87 Not Available
88 1 Function ON N/A N/A
89 ERROR: Security access required
90 ERROR: Security access required
91 ERROR: Channel 91 Not Available
92 ERROR: Channel 92 Not Available
93 ERROR: Channel 93 Not Available
94 ERROR: Channel 94 Not Available
95 ERROR: Channel 95 Not Available
96 ERROR: Channel 96 Not Available
97 ERROR: Channel 97 Not Available
98 ERROR: Channel 98 Not Available
99 0 Value N/A N/A
100 ERROR: Channel 100 Not Available
101 ERROR: Channel 101 Not Available
102 ERROR: Channel 102 Not Available
103 ERROR: Channel 103 Not Available
104 ERROR: Channel 104 Not Available
105 ERROR: Channel 105 Not Available
106 ERROR: Channel 106 Not Available
107 ERROR: Channel 107 Not Available
108 ERROR: Channel 108 Not Available
109 ERROR: Channel 109 Not Available
110 ERROR: Channel 110 Not Available
111 ERROR: Channel 111 Not Available
112 ERROR: Channel 112 Not Available
113 ERROR: Channel 113 Not Available
114 ERROR: Channel 114 Not Available
115 ERROR: Channel 115 Not Available
116 ERROR: Channel 116 Not Available
117 ERROR: Channel 117 Not Available
118 ERROR: Channel 118 Not Available
119 ERROR: Channel 119 Not Available
120 ERROR: Channel 120 Not Available
121 ERROR: Channel 121 Not Available
122 ERROR: Channel 122 Not Available
123 ERROR: Channel 123 Not Available
124 ERROR: Channel 124 Not Available
125 ERROR: Channel 125 Not Available
126 ERROR: Channel 126 Not Available
127 ERROR: Channel 127 Not Available
128 ERROR: Channel 128 Not Available
129 ERROR: Channel 129 Not Available
130 ERROR: Channel 130 Not Available
131 ERROR: Channel 131 Not Available
132 ERROR: Channel 132 Not Available
133 ERROR: Channel 133 Not Available
134 ERROR: Channel 134 Not Available
135 ERROR: Channel 135 Not Available
136 ERROR: Channel 136 Not Available
137 ERROR: Channel 137 Not Available
138 ERROR: Channel 138 Not Available
139 ERROR: Channel 139 Not Available
140 ERROR: Channel 140 Not Available
141 ERROR: Channel 141 Not Available
142 ERROR: Channel 142 Not Available
143 ERROR: Channel 143 Not Available
144 ERROR: Channel 144 Not Available
145 ERROR: Channel 145 Not Available
146 ERROR: Channel 146 Not Available
147 ERROR: Channel 147 Not Available
148 ERROR: Channel 148 Not Available
149 ERROR: Channel 149 Not Available
150 ERROR: Channel 150 Not Available
151 ERROR: Channel 151 Not Available
152 ERROR: Channel 152 Not Available
153 ERROR: Channel 153 Not Available
154 ERROR: Channel 154 Not Available
155 ERROR: Channel 155 Not Available
156 ERROR: Channel 156 Not Available
157 ERROR: Channel 157 Not Available
158 ERROR: Channel 158 Not Available
159 ERROR: Channel 159 Not Available
160 ERROR: Channel 160 Not Available
161 ERROR: Channel 161 Not Available
162 ERROR: Channel 162 Not Available
163 ERROR: Channel 163 Not Available
164 ERROR: Channel 164 Not Available
165 ERROR: Channel 165 Not Available
166 ERROR: Channel 166 Not Available
167 ERROR: Channel 167 Not Available
168 ERROR: Channel 168 Not Available
169 ERROR: Channel 169 Not Available
170 ERROR: Channel 170 Not Available
171 ERROR: Channel 171 Not Available
172 ERROR: Channel 172 Not Available
173 ERROR: Channel 173 Not Available
174 ERROR: Channel 174 Not Available
175 ERROR: Channel 175 Not Available
176 ERROR: Channel 176 Not Available
177 ERROR: Channel 177 Not Available
178 ERROR: Channel 178 Not Available
179 ERROR: Channel 179 Not Available
180 ERROR: Channel 180 Not Available
181 ERROR: Channel 181 Not Available
182 ERROR: Channel 182 Not Available
183 ERROR: Channel 183 Not Available
184 ERROR: Channel 184 Not Available
185 ERROR: Channel 185 Not Available
186 ERROR: Channel 186 Not Available
187 ERROR: Channel 187 Not Available
188 ERROR: Channel 188 Not Available
189 ERROR: Channel 189 Not Available
190 ERROR: Channel 190 Not Available
191 ERROR: Channel 191 Not Available
192 ERROR: Channel 192 Not Available
193 ERROR: Channel 193 Not Available
194 ERROR: Channel 194 Not Available
195 ERROR: Channel 195 Not Available
196 ERROR: Channel 196 Not Available
197 ERROR: Channel 197 Not Available
198 ERROR: Channel 198 Not Available
199 ERROR: Channel 199 Not Available
200 ERROR: Channel 200 Not Available
201 ERROR: Channel 201 Not Available
202 ERROR: Channel 202 Not Available
203 ERROR: Channel 203 Not Available
204 ERROR: Channel 204 Not Available
205 ERROR: Channel 205 Not Available
206 ERROR: Channel 206 Not Available
207 ERROR: Channel 207 Not Available
208 ERROR: Channel 208 Not Available
209 ERROR: Channel 209 Not Available
210 ERROR: Channel 210 Not Available
211 ERROR: Channel 211 Not Available
212 ERROR: Channel 212 Not Available
213 ERROR: Channel 213 Not Available
214 ERROR: Channel 214 Not Available
215 ERROR: Channel 215 Not Available
216 ERROR: Channel 216 Not Available
217 ERROR: Channel 217 Not Available
218 ERROR: Channel 218 Not Available
219 ERROR: Channel 219 Not Available
220 ERROR: Channel 220 Not Available
221 ERROR: Channel 221 Not Available
222 ERROR: Channel 222 Not Available
223 ERROR: Channel 223 Not Available
224 ERROR: Channel 224 Not Available
225 ERROR: Channel 225 Not Available
226 ERROR: Channel 226 Not Available
227 ERROR: Channel 227 Not Available
228 ERROR: Channel 228 Not Available
229 ERROR: Channel 229 Not Available
230 ERROR: Channel 230 Not Available
231 ERROR: Channel 231 Not Available
232 ERROR: Channel 232 Not Available
233 ERROR: Channel 233 Not Available
234 ERROR: Channel 234 Not Available
235 ERROR: Channel 235 Not Available
236 ERROR: Channel 236 Not Available
237 ERROR: Channel 237 Not Available
238 ERROR: Channel 238 Not Available
239 ERROR: Channel 239 Not Available
240 ERROR: Channel 240 Not Available
241 ERROR: Channel 241 Not Available
242 ERROR: Channel 242 Not Available
243 ERROR: Channel 243 Not Available
244 ERROR: Channel 244 Not Available
245 ERROR: Channel 245 Not Available
246 ERROR: Channel 246 Not Available
247 ERROR: Channel 247 Not Available
248 ERROR: Channel 248 Not Available
249 ERROR: Channel 249 Not Available
250 ERROR: Channel 250 Not Available
251 ERROR: Channel 251 Not Available
252 ERROR: Channel 252 Not Available
253 ERROR: Channel 253 Not Available
254 ERROR: Channel 254 Not Available
255 ERROR: Channel 255 Not Available
- Jay-Jay
Well, while waiting for the new front antiroll bar poly bushes to arrive to me and hoping for a ABS Unit coding solution, tonight I casually did some Google searches in english, which in the end opened my mind.
It seems like upgrading to a quick steering rack was a popular upgrade, especially on Golf mk4 platform. People used to install Golf 4 R32 or Audi TT mk1 rack, which is shorter than the one factory installed on normal mk4 platfrom's cars.
Not all the cars from that generation had ESP factory installed. Some of them only had ASR.
Well, the owners who installed the quick steering rack on their cars with ESP, immediately experienced my same identical problem!!!
Simply Google "vw quick rack esp problem" and you'll find many forums talking about this.
ABS unit installed on those cars were much less complex (software speaking) than ABS unit installed on my Polo 6R. Despite that, I haven't found anywhere the trace of somebody who has found a defintive solution to this problem.
It seems like the only possible solutions are two:
- completely disable the ESP (wich is impossible on Bosch 8.2i ABS Unit and I would never always drive a car without ESP);
- put back a PR-1N2 steering rack.
My car has a tons of suspension upgrades. Bilstein B14 coilovers, poly bushes, Polo R WRC front sway bar, Whiteline rear anti-roll bar, GTI rear axle beam.
In the case iichel or some other guru would not appear with a magical ABS coding or other solutions (ie. replacing the ABS unit with a GTI one), after what I discovered I think I'll be ok with putting back the PR-1N2 steering rack.
I use my Polo as a daily car and I can't keep it like this.
Last day I was driving with a friend sitted on the passenger seat and suddenly while taking a turn on the right, the ESP kicked-in very strongly. It scared the ass out of him and it made me feel extremely embarassed. Luckily I know my car and all the mods I did make it handle tremendously better compared to how it did out of factory, so I wouldn't say this ESP problem can be considered a safety problem in my case. But I just can't keep it like this.
And it's a pity, because the steering feel is amazing: quick, precise, a bit heavier and more connected to the wheels.
I would say it feels even better than my Audi S1's steering feel.
But I'm sure all of you who are reading this would agree with me that if there's no solution, it's better to put back the old steering rack.
I will update this topic with the front sway bar poly bushes results, and if there won't be any improvement (like I expect at this point), I will further update the topic with final results after putting back the PR-1N2 steering rack.
Just a quick question, at this point.
My old Pr-1N2 steering rack has about 210.000km on its shoulders. It's old. I don't think it makes sense to install it back. Maybe it's better to buy a new TRW brand one.
There are two steering racks made by TRW:
- JRP 1130 (which has the G250 compatibility)
- JRP 1228 (which doesn't have the G250 sensor compatibility)
ETKA indicates there are two PR-1N2 steering racks:
- 6R1423055D (the one originally factory installed on my Polo), which has the G250 sensor hole;
- 6R1423055K, which doesn't have the G250 sensor hole.
It's easy to associate OEM part numbers with TRW part numbers.
I know my ABS unit only uses G85 sensor for reading the steering angle, so theorically it shouldn't make any difference which one I'd install.
But my concern regards the possibility that the two above mentioned racks might also have a slightly different steering ratio, which potentially could lend me to face the same issue I am having right now.
So, for not having the risk to have again this issue, I'd go for the TRW JRP1130 steering rack, and I'd just put the G250 sensor in its hole, without wiring it to the steering pump's unit.
What do you think?
What do you think?
Install it exactly the same as before, that is, exactly what ETKA indicates for your 6R, don't let budgets confuse you.
Thanks for all the info/study.
- Jay-Jay
Luckily the price is almost identical between the two racks.
BTW, as last try, in the next days I'll search for Polo GTIs and Audi A1s with Bosch 8.2i ABS unit and I'll scan them with VCDS. (My mum had a 2011 Audi A1 till 2 years ago... If only I had already scanned it...).
Hopefully there's something different in the ABS Adaptations channels and I can make the same modification on my ABS unit.
Fingers crossed.
If someone casually has an adapmap of a Bosch 8.2i unit installed on a car with PR-1N4 rack, I would be very greatfull if he could post it on here.
In the end, I'll give myself a time limit of 1 or 2 weeks for finding an ABS coding solution. Expired that time, I'll buy a new PR-1N2 steering rack and install it.
Fingers crossed.
I think there should be a solution in the software, it's all just coding and adaptation. It's very likely in the ABS coding.
check your instagram inbox for a coding sheet for esp8.2i, don't share
- Jay-Jay
Hi to everybody,
just a few quick updates.
I replaced the front swaybar bushings, but it didn't fix the problem.
Then, my focus switched to the ABS coding.
I really have to thank iichel who is giving me a huge support in this.
Our intention has been to make my ABS long-coding the same of a Polo GTI, because it's the only Polo version with Bosch 8.2i ABS unit and 1N4 steering rack.
After having tried many coding combinations (the most of them weren't accepted by my ABS unit), I decided to swap my old ABS unit (HW: AF, SW: AF) with a newer one which has the latest 8.2i firmware version available (HW: AF, SW: BE).
The job was pretty straight forward and less difficult than I expected.
This allowed me to further modify the ABS long-coding, by inserting the value for GTI engine (Byte 15: "41"), which my old ABS unit didn't accept.
So, now my ABS unit is coded for GTI engine, brakes and suspensions. Unfortunately this didn't fix the ESP problem.
To really make the ABS coding 100% like a Polo GTI I should also modify Byte 6 and Byte 14 with Polo GTI values ("02 - 40"), but unexpectedly this unit doesn't accept those values.
Maybe it needs TCU to be installed... maybe BE firmware is not for Polo GTI (AK or BC could be the correct ones?)... or maybe I am missing something else. Who knows...
Cars with Bosch 8.2i ABS unit and 1N4 steering rack exist, so there must be a way to make ESP work correctly.
I could always upgrade to Bosch 9.0i ABS unit, which also supports ESC deactivation, but I want to keep this option for later, only if all the other tries to maintain the 8.2i Unit won't bring me to a definitive fix.
Anyway, does anybody know if these ABS units have parametrization?
I mean: is it possible to write specific parametrizations file with ODIS?
My suspect is that, regardless of the ABS unit firmware version (which plays an important role as well), of the long-coding and of the Adaptations channels, there might be also parameters which differ from car to car depending on what parametrizations file has been flashed from factory.
Do you think it might be possible with ABS units from this era?
_______________________________________
Corious fact: the new 'BE' ABS unit firmware version accepts the coding for 288/232 brake discs even with byte 15 coded for CBZB engine and Byte 4/Byte 12 coded for Manual transmission
In the while, I am also investigating about possible defects of mechanical components.
I ordered all these new parts:
- inner and outer tie rods, specific for PR-1N4 steering rack;
- ball joints;
- sway bar links;
- front wheel bearings (rear ones have just been replaced together with the GTI rear axle beam).
These same parts currently installed on my car have more than 100.000km, so I want to think I'll replace them for preventive maintenance as well.
Last week I brought my car again to the workshop to check the wheels alignment.
Toe-in has been properly aligned, but I noticed two things:
- camber on front left wheel is -0,75°, while on the right front wheel it is -1,10°. This is a difference of 0,35°. In the past the value was about -1,2° on both sides. Considering the struts and top mounts are new and the height has been adjusted the same on both front wheels, the difference in camber values makes me think the front subframe might not be properly transversally centered to the chassis of the car, despite I installed front subframe rigid collars, which in theory should perfectly center it.
- front wheels caster value is 5,2° and it's the same on both sides. This makes me think the front subframe is properly longitudinally centered to the chassis of the car.
By looking inside the wheel arch, I notice the distance between the rear side of the front subframe and the cassis of the car is a bit larger than it used to be before replacing the steering rack. So, to me it looks like the subframe is positioned further forward than it was before.
Do you think this could cause my ESP problem?
Any suggestion on what else to do/check, is really much appreciated.
- ball joints;
- sway bar links;
- Jay-Jay
Hi everybody, I have an important update.
In the end I decided to upgrade to Bosch 9.0i ABS unit. Between all the firmwares available, I choose the BG version, which is the same installed on Polo R WRC.
This work required me to modify the position of some wires inside the ABS unit connector.
Then, after many tries, I have been able to insert the ABS coding specific for Polo R WRC brakes/transmission/drivetrain/engine.
I test drove the car on the problematic turns and I can finally say the ESP now works perfectly. It doesn't kick-in abruptly for no reasons anymore and it works even better than when I didn't have this ESP problem before replacing the steering rack.
On spirited driving over roads with a lot of turns, I feel like the car is much more precise and stable. The more I speed up and the more the chassis feels rigid/stiff.
Even the steering weight feels a bit heavier and more direct and precise, even if I didn't change anything in the steering assist coding.
Thanks to the new ABS coding, brakes work much better too, especially the ABS kicks-in later and in a less intrusive/more sporty way.
In the end, I am extremely happy and satisfied.
I can't not thank enough iichel who supported me and tolerated me and the bad luck which always haunts me
So, to really give an end to this topic, I would say that to make a good work, it is also necessary to code the ABS unit also for Audi A1/Polo GTI/WRC drivetrain, which is stored in Byte 6 (and its mirror byte) of the ABS coding.
If tour ABS unit firmware doesn't support that specific coding for those 2 bytes in combination with brakes/transmission/engine bytes consequentially modified, you need to replace your ABS unit with one which has a firmware which support that coding combination, otherwise you risk to have the ESP problem I experienced, which kills all the fun.
P.S. now I can completely disable ESC with the button on the dashboard:
https://youtu.be/bTB0geG5G5s
Hard, long and creative experience, your tenacity has paid off, thank you very much for sharing it with all of us! You can finally enjoy your improvements.
If you want, please take some time to test it carefully and then return to provide us with a new report, I think it will be greatly appreciated by all of us.
Thank you!!
Thank you!!
