Welcome Cosmonaut21
In theory it cannot be removed ... However,
don't try this:
Image :mrgreen:
read here:
http://www.polovw.it/foro/viewtopic.php ... 36#p629115
I hope it helps you.
:arrow: Bachecco :wink:
ciclo wrote:Help. No hurry. :lol:
Picture from 6R WRC fusebox (SB) :?:
Please. :lol:
i guess he wants to remove the trim. it's not a sepereate part but part of the dashboard. it is melted into the dashboard, you'll need to say, drill or melt it out.
i wouldn't recommend to do this.
Please. :lol:
--> sit and wait
http://www.polo6rfreunde.de/index.php/T ... -Polo-WRC/
CNK
Drives: 6R
Post by CNK »
ciclo wrote:Welcome Cosmonaut21
don't try this:
Image :mrgreen:
Hey, this is possible, but it's easier when dashboard is removed:
https://www.drive2.com/l/458574964937720895/ ;)
iichel wrote: I see. I have some money available for a T6 BCM. Any recommendations on the right Z-code?
There are so many, high window rear door, mechancally locking tailgate etc etc. i don't know it anymore, too many options :oops:
The only one I know for sure is 8T1 :mrgreen:
7E0937090B ZTZ
This one will meet all your expectations.
434 Mhz
Led Headlights
HBA
Side Assist
RDK (if it is possible with the Amarok system) :)
CCS, ACC... :lol:
Interface for external use.
Etc...
Highline, Executive... :mrgreen:
If you also want to install comfort tailgate: Z-code = 07W
It would be difficult (compatible parts) to install in our tiny 6R, but not impossible. :lol:
Gracias señor ciclo!
The guys on the Polo6R FReunde forum posted 2 fuse boxes of the WRC ;)
iichel wrote:The guys on the Polo6R FReunde forum posted 2 fuse boxes of the WRC ;)
My sincere thanks to all three.
Elsawin and Erwin (last update) are a little joke about the WRC diagrams. I suppose to hide some information ... :lol:
I suppose that:
As for 31 fuse
As for S1, S2 fuses
And precisely the 87 terminal was the reason I asked for the images, due to other incongruities in other diagrams about the +15 terminal related with other systems... (I have to do some tests to be able to continue talking... :lol: )
Image :)
Are you planning to retrofit the 2.0 TFSI by any chance?
No, my 1.2 TSI 90HP engine is perfect for me.
It has an awesome acceleration 0-65 km/h ...
mine is even faster 65 km/h - 0 kmh :mrgreen:
rain closing:
09 address -> Coding.4 Byte 6 bit — rain closing active 8 byte 0 bit — rain light sensor installed 14 Byte 1 bit — rain sensor functions active,Subunit RLS coding0 Byte 2 bit Rain closing active
source: http://www.polo6rfreunde.de/index.php/T ... post400693
i haven't tried it yet
Thanks iichel. :wink: But... what's new in that coding? I have that codification for three years and in my 6R does not work ... I do not want it to work.
iichel, did you get the Assistants menu in your MFA when you installed the Lane Assist?
I was reviewing this Autoscan and I remembered your 7E0 Lane Assist.
hmm... what would happen if you test with your last BCM Bytes (26,27,28,29) :?: :mrgreen: ... 50 03 28 04 (faster will be all HEX at the same time 50032804 copy-paste).
hmm... Gateway in your case 042201 :?:
Please, report VCDS faults. :lol:
BTW, the solution for badufay (VWVortex)... to disable the DRL wink with turn signal. (Byte23 Bit7 = unmarked)
7B994BBE08AB0F0008392080240894C54BC6722E60015170B0A050032844
To display the oil temperature in the MFD+ (MFA, MFI - High, plus) the oil temp sensor is required and enable it in the MFD+ menu.
Locked
