CNK
Drives: 6R
Post by CNK »
rdasadia wrote:Yes , as you said it, GT in India are indeed 6r. I have HW 6R0 907 379 BH. I do have latest vcds ver. Let me try ur suggested coding. Any chance of installing direct TPMS , the one which uses the antenna & four sensors?
This is TPMS Premium aka TPMS High, you need latest BCM to this mod.
ZZZhuk has got this in his Polo 6R Sedan: https://www.drive2.ru/l/461592849478059310/
rdasadia
Drives: Polo GT 1.2TSI DSG 6R 2016
Post by rdasadia »
Hi!! I have already upgraded my BCM to 6R0937088F. Will this do for high TPMS
rdasadia wrote: 6R0937088F. Will this do for high TPMS
No.
rdasadia wrote: Hi!! I have already upgraded my BCM to 6R0937088F
OMG! Please, please, please,... can you show me an autoscan with your new BCM installed? :lol:
Thanks in adavance.
firegrafik
Drives: 6R 1,6MPI(CFNA) sedan
Post by firegrafik »
No.
Thanks in adavance.
One Polo sedan owner about 2 years ago installed 6R0937088F instead of 6R0937085. The interesting thing - it worked. Engine started, cluster worked correct etc. :lol: But the owner asked for help why he cannot connect Vcds to the car. I was shocked.
firegrafik
Yes, yes. There is no CAN -diagnostic pins because this BCM does not consist gateway. With this BCM should be separate gateway control unit.
CNK
Drives: 6R
Post by CNK »
This BCM is only on Polos with Start/Stop system:
http://wiki.ross-tech.com/wiki/index.ph ... tting_(6R)
Basis+
Part Numbers: ***-937-084-***
Medium+
Part Numbers: ***-937-085-***
Supported Features (like Basis+ and additonally): Central Locking, Anti-Theft-System, Outside Mirror Heating, Seat Heating
Medium++
Part Numbers: ***-937-086-***
Supported Features (like Medium+ and additonally): Remote Control
High+
Part Numbers: ***-937-087-***
Supported Features (like Medium++ and additonally): Cruise Control System (CCS), Anti-Theft-System LIN-Databus (for Alarm Horn)
Reku (Recuperation)
Part Numbers: ***-937-088-***
Supported Features (like High+ and additonally): Start/Stop System (with Recuperation)
Licht (Lighting)
Part Numbers: ***-937-089-***
Supported Features (like High+ and additonally): Lighting Functions (LED DRL, Bi-Xenon etc.)
One guy from Poland was trying to retrofit 88D but without success.. (no CAN communication). But he didn't have an external gateway from BlueMotion 6R.
Start stop:
088B/D/F needs an external gateway.
This is found in the Polo 1.2 TDI Bluemotion
This one also supports bi-xenon, auto light etc.
7H0 937 090/090B does not need an external gateway
This is found in the Polo Blue GT 1.4 TSI ACT and the 1.6TDI with start/stop
rdasadia
Post by rdasadia »
No.
Thanks in adavance.
Okkk!!...there goes my money. Didnt know this was for 6c with seperate CAN. Fortunately had not installed it. @Ciclo which bcm should I buy?
First you must show us an autoscan with your original BCM. Your question requires it.
However, I think that the best option would be 7E0937090B, as you know, to install it on your GT imply some adjustments in the original wiring. Bear in mind that the Direct TPMS (High) has not yet been tested on the POLO 6R through CAN lines powertrain.
Your best bet or my recommendation is talk to firegrafik for the BCM purchase.
JayW
Post by JayW »
Im asking you cos i know you will know it! Whats the part number for the lower chin/valance for the rline front bumper? Its the black bit that sticks out.
peza2309
Drives: 2015 1.2 TSI POLO 6C
Post by peza2309 »
Hi, I'm fairly new to all this but looking to start somewhere and this car looks gorgeous :D
Was wondering where you can find all these parts especially bits like the r line grille and bumpers?
Own a new 1.2 tsi 6c and parts are hard to come by I find
JayW wrote:Im asking you cos i know you will know it! Whats the part number for the lower chin/valance for the rline front bumper? Its the black bit that sticks out.
6R0805915F :wink:
peza2309 wrote:Hi, I'm fairly new to all this but looking to start somewhere and this car looks gorgeous :D
Hello, welcome. :wink:
:arrow: If you learn to use these links will solve many of your questions.
In the first page of my topic there are many info but remember that you have a Polo 6C and, although it is similar to a 6R they are not the same car. Keep it in mind.
6R --- 2009-2014
6C --- 2015->
Locked
