Adam87
Drives: T5.2
Post by Adam87 »
ciclo wrote:Image :lol:
Now one of us has to buy [emoji85][emoji23]
...A, C, E, G etc = 315 Mhz frequency for key remote = NAR + india?
... (nothing), B, D, F, H etc = 434 MHz frequency for key remote = EU
don't buy it ;)
iichel, your explanation may be correct for 7H0 BCM, but not for 7E0 BCM.
As far as I know for 7E0:
433 MHz 7E0 937 090
315 MHz 7E0 937 190
However, it is always necessary to verify it in the ETKA to be totaly sure. :wink:
Intriguing
Bit15 Bit0 disabled = Mute and Push to-Talk functions work like a charm.
Bit15 Bit0 enabled = Both buttons do the Push-to-Talk function. WT* :?: :lol:
MFSW coding (VCDS Autoscan = first page)
Subsystem 7 - Part No SW: 1K8 959 442 HW: 1K8 959 442
Component: E221__MFL-DC1 H03 0103
Serial number: 27140003142720054516
Coding: A4FFFF ................. (same like Polo Sedan GT)
Will my MFSW coding be correct? I'll have to test 240000.
Will Byte15 Bit0 description totally correct? I'll have to install another MFSW with other different buttons to test it. (again)
etc... :mrgreen:
firegrafik
Drives: 6R 1,6MPI(CFNA) sedan
Post by firegrafik »
Old type MFSW like this
doesn't have Mute and Push-to-talk buttons simultaneously. Only one (left-side below) and the function of this button defines by 0 bit 15 Byte.
With new type MFSW with separate Mute and PtT buttons it is not so actual.
Sure firegrafik, but my BCM is very current. :wink:
I will try to find something new is this Bit0, btw :twisted: this Bit0 is activated from factory on the current Jetta.
for example, 2017 Jetta: http://forums.ross-tech.com/showthread. ... #post76816
Address 09: Cent. Elect. (J519) Labels: 7E0-937-BCM-V1.clb
Part No SW: 7E0 937 190 B HW: 7E0 937 190
Component: BCM PQ25 Max3 H81 0744
Coding: 7B994B9A08AB0B0008392080240884C54BC6722E600151F0B0A050032844
Subsystem 4 - Part No SW: 6C0 959 442 A HW: 6C0 959 442 A
Polo 6R with the MFS 6C0 959 442
Saturday,24,December,2016,08:55:23:49450
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 7 x64
VCDS Version: 16.8.0.3
Data version: 20161010 DS255
www.Ross-Tech.com
VIN:  License Plate: 24122016
Mileage: 1350km-838mi Repair Order:
Chassis Type: 60 (6RU)
Scan: 01 03 08 09 10 15 17 19 25 44 56
VIN:  Mileage: 1350km-838miles
56-Radio -- Status: OK 0000
Address 01: Engine (J623-CJLA) Labels: None
Part No SW: 03E 906 019 AQ HW: 03E 906 019 AQ
Component: SIMOS11.2 H04 1968
Revision: --H04--- Serial number:
Coding: 00110016032400000000
Shop #: WSC 01234 785 00200
ASAM Dataset: EV_ECM12MPI02103E906019AQ 001001
ROD: N/A
VCID: 73E5B5AADA7402DAAD-8026
No ASAM data for: "EV_ECM12MPI02103E906019AQ" (VW25)
Readiness: 0000 0100
Address 03: ABS Brakes (J104) Labels: Redir Fail!
Part No SW: 6R0 907 379 BP HW: 6R0 907 379 AQ
Component: ABS9.0 front H01 0003
Serial number: --------------
Coding: 60DD2763212B18C20618E46B845818000000
Shop #: WSC 00000 000 08192
ASAM Dataset: EV_Brake1ABS90BOSCH 003017
ROD: EV_Brake1ABS90BOSCH_VW25.rod
VCID: 0D11C352DC90742ADB-8058
Part No SW: 6R0 907 044 Q HW: 6R0 907 044 Q
Component: Climatronic H12 0615
Revision: V0000000
VCID: 41892F62D848E04AEF-8014
Address 09: Cent. Elect. (J519) Labels: 6R0-937-08x-09.clb
Part No SW: 6RU 937 086 M HW: 6RU 937 086
Component: BCM IM M+4 H40 0432
Revision: BY040001 Serial number: 0200 078160167
Coding: 3AB02BFF48A30000013800006D0B169000C0414F60AC0000200000000000
Shop #: WSC 01070 002 104857
VCID: 6BD5ADCA8A44DA1A65-803E
Subsystem 1 - Part No: 5K7 955 559 B
Component: RLS 311215 03 37 0059
Coding: 0728DD
Subsystem 2 - Part No SW: 6R0 959 802 EF HW: 6R0 959 802 EF Labels: 6R0-959-802.CLB
Component: J386__TSG_FT 020 2551
Serial number: 13202848160111221608
Coding: 350000
Subsystem 3 - Part No SW: 6R0 959 801 ED HW: 6R0 959 801 ED Labels: 6R0-959-801.CLB
Component: J387__TSG_BT 020 2551
Serial number: 13202849160107223746
Coding: 040000
Subsystem 4 - Part No SW: 6C0 959 442 HW: 6C0 959 442
Serial number: 0111607164000748AB2B
Coding: 240000
Subsystem 5 - Part No SW: 6R0 959 811 S HW: 6R0 959 811 S
Component: J388__TSG_HL 019 1552
Serial number: 13102728160108150857
Subsystem 6 - Part No SW: 6R0 959 812 S HW: 6R0 959 812 S
Component: J389__TSG_HR 019 1552
Serial number: 13202729160111111032
Address 10: Park/Steer Assist (J446) Labels: 7E0-919-475.clb
Part No SW: 7E0 919 475 K HW: 1Q0 919 475
Component: PARKHILFE 4K H03 0106
Revision: -------- Serial number: 35821404004439
Coding: 308001
Shop #: WSC 12345 123 12345
ASAM Dataset: EV_VW75XParkAssis4K 001004
ROD: EV_VW75XParkAssis4K.rod
VCID: 3A7B588EBD9EB392AE-806E
Address 15: Airbags (J234) Labels: 5K0-959-655.clb
Part No SW: 6R0 959 655 J HW: 6R0 959 655 J
Revision: -------- Serial number: 003GW013KE03
Coding: 003036
VCID: 49993742E878280A37-801C
Address 17: Instruments (J285) Labels: 5K0-920-xxx-17.clb
Part No SW: 6RF 920 861 B HW: 6RF 920 861 B
Component: KOMBI H01 0215
Coding: 1108000000
Shop #: WSC 12345 123 08192
ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A05729
ROD: EV_Kombi_UDS_VDD_RM09_VW25.rod
VCID: 4A9B084EED7E23123E-801E
Address 19: CAN Gateway (J533) Labels: None
Part No SW: 6RU 909 901 HW: 6RU 937 086
Component: GW-K-CAN TP20 H40 0432
Revision: BY040001
Coding: 002200
VCID: 1939A7021058988A47-804C
Address 25: Immobilizer (J334) Labels: 5K0-920-xxx-25.clb
Component: IMMO H01 0215
Serial number:
Shop #: WSC 00000 000 00000
VCID: 6ADBA8CE8DBEC3121E-803E
Address 44: Steering Assist (J500) Labels: 1Sx-909-144-44.clb
Part No SW: 1S2 909 144 P HW: 1S2 909 144 P
Component: EPS_ECU H61 1702
Coding: 0001000000000000
ROD: EV_SteerAssisNSK_VW12.rod
VCID: 41892F62D048E04AEF-8014
Address 56: Radio (J503) Labels: User\6RF-035-187.clb
Part No SW: 6RF 035 187 HW: 6RF 035 187
Component: Radio 013 0116
Revision: -------- Serial number: VWZGZ1S0840292
Coding: 00000440000002
VCID: 0603FC7EB1E607729A-8052
End-------------------------(Elapsed Time: 02:23)--------------------------
Thanks iichel, it seems to me that the first ones were sold in India and Russia (2014-2015)
Yes this one is from India too
Adam87
Drives: T5.2
Post by Adam87 »
When I installed my T6 MFSW I'm sure my menu buttons didn't work correctly until I checked this box
I'll have to double check
Very interesting Adam (please, check all buttons, no hurry) by the way, is a beautiful image. 8)
Adam87
Drives: T5.2
Post by Adam87 »
Thank you [emoji41][emoji4],
Well I just tried in un-checking the box and it seems I made the whole thing up [emoji23] I makes no difference (I don't have the speech button working yet as I need to alter the mic wiring to the radio)
Ok, thanks Adam, I hope to have some time this weekend (Sunday) to do several tests that I have pending.
diskoboy
Drives: 1.6 TDI BMT
Post by diskoboy »
I need the part no for the climatronic control unit with black/white background/text.
Please help :)
BTW - the new Discovery Media is sooo cool ;)
App connect and everything :)
Locked
