Thanks CNK. So I will keep looking for someone who can do this other than the VW workshop. Hope I find someone soonCNK wrote:Hey graaja, I gave my instrument cluster to my mate who deals with VAG automotive electronics. He have a special software for this and don't need any security code.
Support from local VW workshop told me, that instrument cluster which I ordered won't work in my Polo..
graaja
- Drives: Polo GT TSi
firegrafik
- Drives: 6R 1,6MPI(CFNA) sedan
Simon, some time ago I saw there is hacked Discover Media appeared for sale, without Component Protection. In this case it will work with current instrument cluster.CNK wrote:
So you bought new unit? Composition Media and Discover Media has got Copmponent Protection. In Poland unlocking this protection costs about 1000 PLN..![]()
6C instrument cluster doesn't fit to 6R, it's impossible:
I have the same IC like ciclo (Polo 6R BlueGT with maxi dot screen/MFA+), but as I remember @iichel has got instrument cluster from VW Amarok.
Edit: iichel overtook me again
In Russia such headunit is possible to buy for 50000RUB (approx. 800EUR)
https://www.drive2.ru/o/b/465672862250828867/
But for now it has only navigation and Bluetooth unlocked. They are working on Carplay, Android connect, Mirrorlink to be unlocked also.
- CNK
- Drives: 6R
Ok, thanks for infofiregrafik wrote:Simon, some time ago I saw there is hacked Discover Media appeared for sale, without Component Protection. In this case it will work with current instrument cluster.CNK wrote:
I don't need CarPlay because I don't use apples (only eat them
But MirrorLink and Android connect should work on the radio for so much money
Hi ciclo,
I need the wiring harness for polo max BCM.
How do I get in touch with you.
Welcome vishyvichvishyvich wrote:Hi ciclo,
I apologize for my delay in replying.
This is the informative topic dedicated to the sale of my wiring looms. Maybe you might be interested in reading it. Maybe you'll be able to make your own wiring.
I do not have time to make more wiring looms right now. I really sorry. I have a great demand.
My recommendation if you need my help:
Open a new topic in this forum and provide all the necessary information.
Perhaps, someday, I could have enough time to help you with this. (coding, etc... FREE)
Latest examples:
viewtopic.php?f=56&t=69603
viewtopic.php?f=56&t=69121
I really appreciate your interest in my wiring looms. Thank you.
Discovery Media with PDC and Golf 6 camera
New Mod: RLHS (6R non Bluemotion
Volkswagen. Humidity sensor.
A special sensor system in conjunction with the control algorithms in the Climatronic reduces misting-up of the windows and enhances climatic comfort by managing the humidity levels inside the car.
From the data delivered by the humidity and temperature sensor in the base of the interior mirror, the Climatronic control unit calculates the dew point temperature of the air – that is, the temperature at which the air humidity would condense. An infrared sensor remotely measures the radiated heat on the windscreen, and calculates the window temperature. To prevent the windows from misting up, Climatronic regulates the volume of air projected on to the windscreen and, with the compressor switched on, also the air humidity inside the car. Relative humidity based on interior temperature can also be kept at a pleasant level.
VCDS
BCM--> Byte8 Bit5 enabled
Address 09: Cent. Elect. (J519) Labels: 7E0-937-BCM-V1.clb
Part No SW: 7E0 937 090 B HW: 7E0 937 090
Component: BCM PQ25 Max4 H81 0744
Revision: B9081001 Serial number: 0982 320160060
Coding: 3CB02FBF48E12400B3380FD1FCEB9FD0DAC067AF600D30D0200000030800
Shop #: WSC 12345 123 12345
VCID: 2A27B27C0FD0875FAD-807E
Component: RLHS 220816 0 42 0106
Coding: 0728DD
Autoscan
Works like a charm.
I have tested all the automatic functions I had previously (all, many), lights, wipers (just today it was raining
), etc ... and maybe it's a personal sensation, but I think all these functions have also improved in regards to the sensor sensitivity.
Previous sensor:
Subsystem 1 - Part No: 5K7 955 559 B Labels: 5K7-955-559.CLB
Component: RLS 110215 03 37 0059
Coding: 0728DD
The humidity sensor function will have to be observed over time ...
Previous info
VCDS
Coding: 0728DD
Autoscan
Monday,27,March,2017,17:31:53:06516
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 7 x64
VCDS Version: 17.1.3.0
Data version: 20170320 DS267.7
www.Ross-Tech.com
VIN: WVWZZZ6RZDY0CICLO License Plate: RLHS OK
Mileage: Repair Order:
Chassis Type: 6R (7E0)
Scan: 01 03 04 08 09 10 15 17 19 20 25 2E 37 44 55 56 77 0B
VIN: WVWZZZ6RZDY0CICLO Mileage:
56-Radio -- Status: OK 0000
Address 01: Engine (J623-CBZC) Labels: 03F-906-070-CBZ.clb
Part No SW: 03F 906 070 GD HW: 03F 907 309 AJ
Component: SIMOS10.22AH10 5466
Revision: --H10--- Serial number: 00000000000000
Coding: 001100D6202400080000
Shop #: WSC 00788 648 00255
ASAM Dataset: EV_ECM12TFS02103F906070GD 004007
ROD: EV_ECM12TFS02103F906070FP.rod
VCID: 6A67323C0710079FAD-803E
Readiness: 0110 0101
Address 03: ABS Brakes (J104) Labels: 6R0-907-37x-ESP82.clb
Part No SW: 6R0 907 379 BE HW: 6R0 907 379 AF
Revision: --------
Coding: 210228E3216D00B5842814EA84D300401700
Shop #: WSC 40308 002 104857
VCID: 02FF02F46B187747ED-8056
Address 04: Steering Angle (G085) Labels: 6R0-959-654.clb
Serial number: 08021613470174
Coding: 01
Shop #: WSC 00000 000 00000
ROD: EV_LWSKLOVW25X.rod
VCID: 7E730A7877749F2B0D-802A
Part No SW: 6R0 907 044 H HW: 6R0 907 044 H
Component: Climatronic H11 0711
Revision: V0000000
VCID: 38299E964716333D5D-806C
Coding: 0728DD
Subsystem 2 - Part No SW: 6R0 959 801 BD HW: 6R0 959 801 BD Labels: 6R0-959-801.CLB
Component: J386__TSG_FT 003 8612
Serial number: KU0KU003041440937042
Coding: 0200A3
Subsystem 3 - Part No SW: 6R0 959 802 BF HW: 6R0 959 802 BF Labels: 6R0-959-802.CLB
Component: J387__TSG_BT 003 8612
Serial number: KU0KU006031440656541
Coding: 1000AB
Component: DWA-Sensor 00 001 0103
Subsystem 5 - Part No: 1K8 951 605 B
Component: LIN BACKUP HO H11 9005
Subsystem 7 - Part No SW: 1K8 959 442 HW: 1K8 959 442
Component: E221__MFL-DC1 H03 0103
Serial number: 27140003142720054516
Coding: A4FFFF
Subsystem 8 - Part No SW: 6R0 959 811 G HW: 6R0 959 811 G
Component: J388__TSG_HL 008 1611
Serial number: KU0KU003051200017821
Coding: 18BC32
Subsystem 9 - Part No SW: 6R0 959 812 G HW: 6R0 959 812 G
Component: J389__TSG_HR 008 1611
Serial number: KU0KU010051200012315
Coding: 18BC32
Address 10: Park/Steer Assist (J446) Labels: 6R0-919-475.clb
Part No SW: 6R0 919 475 C HW: 7E0 919 475
Component: PARKHILFE 4K H11 0013
Revision: -------- Serial number: 47361212601014
Coding: 308001
ROD: EV_VW250ParkiAssis2.rod
VCID: 3E338AB877341FEB0D-806A
Address 15: Airbags (J234) Labels: 5K0-959-655.clb
Component: VW10Airbag01M H10 0020
Revision: -------- Serial number: 003GX01JKVVP
Coding: 00314D
Shop #: WSC 01383 785 00200
VCID: 4A4772DC8770C7BFAD-801E
Serial number: 3575HRB405N1C4LI7929
Serial number: 3585HRB405B1D5MS8GS2
Serial number: 3515RRB405B17ABS901.
Serial number: 3525RRB405B181TUDPKC
Address 17: Instruments (J285) Labels: 5K0-920-xxx-17.clb
Part No SW: 6R0 920 870 C HW: 6R0 920 870 C
Component: KOMBI H05 0607
Coding: 140E01
Shop #: WSC 00233 572 91226
VCID: 352A989F5319412875-8060
Address 19: CAN Gateway (J533) Labels: None
Part No SW: 7E0 909 901 HW: 7E0 937 090
Component: GW-K-CAN TP20 H81 0744
Revision: B9081001
Coding: 002200
VCID: 68593E2607E6138DDD-803C
Address 20: High Beam Assist. (J844) Labels: 8S0-857-511.clb
Part No SW: 7E0 857 511 G HW: 7E0 857 511 E
Component: FLA H10 0003
Revision: AA001001
Coding: 0404001C00000000000000
Shop #: WSC 03607 002 104857
VCID: 2E23AA8837C47F7B8D-807A
Address 25: Immobilizer (J334) Labels: 5K0-920-xxx-25.clb
Component: IMMO H05 0607
Address 2E: Media Player 3 (J650) Labels: 5N0-035-342.lbl
Part No SW: 5N0 035 342 F HW: 5N0 035 342 F
Component: SG EXT.PLAYER H18 0530
Revision: A1001003 Serial number: 7662584630
Coding: 010100
Address 37: Navigation (J0506) Labels: 1T0-035-680.clb
Part No SW: 1T0 035 680 L HW: 1T0 035 680 C
Component: RNS-MID H06 5218
Revision: AB001001 Serial number: VWZ6Z7L7654213
Coding: 04000442040000A10001
VCID: 37289C954313353A45-8062
Subsystem 1 - Part No: 1T0 919 859 B
Component: EU West V14 8477
Part No: 6R0 423 156 B
Component: LenkhilfeTRW V277
Coding: 11221
Shop #: WSC 00788
VCID: 2F20AC8DB7FB650285-807A
Address 55: Headlight Range (J431) Labels: 6R0-907-357.clb
Part No SW: 6R0 907 357 HW: 6R0 907 357
Component: LWR-ECU H02 0070
Revision: -------- Serial number: --------------
Coding: 0112000001000000
VCID: 77681C554B53B57A45-8022
Address 56: Radio (J0506) Labels: 1T0-035-680.clb
Address 77: Telephone (J412) Labels: 7P6-035-730.clb
Part No SW: 7P6 035 730 L HW: 7P6 035 730 L
Component: TELEFON H15 3200
Revision: 1B001001 Serial number: 00007664158506
Coding: 0501000000010110
ASAM Dataset: EV_UHVNA 002720
ROD: EV_UHVNA_002.rod
VCID: 3B3494A17B072DD625-806E
End-------------------------(Elapsed Time: 04:21)--------------------------
Previous sensor:
Coding: 0728DD
Previous info
Info-sale
5Q0955547B RLHS for sale. New unused. Latest model. Genuine! (only one for sale)
Rain, Light and Humidity sensor.
Latest software, for POLO 6C, GOLF VII (restyling included), and other last VW models ...
Component: RLHS 250117 0 42 0105
Info: Not compatible with POLO 6R. (PQ25 platform)
Link to the sale.
peter_dk25
- Drives: Blue GT
Peter, your BlueGT already has a humidity sensor.
.. this model: viewtopic.php?f=56&t=58703&start=3120#p518088
In any case, if you need something ... just ask me.
wrecksigge
- Drives: 2012 Polo GTI
Hey Ciclo! As the Guru of VW polos i know you answer alot of questions and that you cant help everyone. But if you got the time, maybe you could just take a look in my thread about LED foglights and tell me what you think. Would appriciate it very muchciclo wrote:Peter, your BlueGT already has a humidity sensor.![]()
Cheers!
peter_dk25
- Drives: Blue GT
What a relief - Thanks x 2, Fernandociclo wrote:Peter, your BlueGT already has a humidity sensor.![]()
We stay in touch
Of course ... from the beginning, without you, all this would not have been so much fun.peter_dk25 wrote:We stay in touch
Do you remember your folding mirrors? ... it was absolutely fascinating (the worries and the whole process - Holger
I can never forget all those good moments.
peter_dk25
- Drives: Blue GT
Ditto - Fernando - I remember it well
And the mirrors are still working perfect!
patil
Master Namaste
Does these window controller modules support auto folding of mirrors with remote key?
Subsystem 1 - Part No SW: 6R0 959 802 CC HW: 6R0 959 802 CC Labels: 6R0-959-802.CLB
Component: ------------- 007 5551
Coding: 050000
Subsystem 2 - Part No SW: 6R0 959 801 BT HW: 6R0 959 801 BT Labels: 6R0-959-801.CLB
Coding: 050000
Coding: 050000
Coding: 050000
