Posts: 7851 Joined: Sun Feb 24, 2013 10:20 am
Post
by ciclo » Wed May 17, 2017 8:55 pm
Testing Gateway codings.
Address 19: CAN Gateway (J533) Labels: None
Part No SW: 7E0 909 901 HW: 7E0 937 090
Component: GW-K-CAN TP20 H81 0744
Revision: B9081001
Coding: 0022
FB
Shop #: WSC 12345 123 12345
VCID: 682176FECFDE5BD515-803C
Nothing found for now
Wednesday,17,May,2017,13:50:33:06516
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 7 x64
VCDS Version: 17.1.3.0
Data version: 20170320 DS267.7
www.Ross-Tech.com
VIN: WVWZZZ6RZDY0CICLO License Plate: TESTING (GATEWAY)
Mileage: Repair Order:
Chassis Type: 6R (7E0)
Scan: 01 03 04 08 09 10 15 17 19 20 25 2E 37 44 55 56 77 0B
VIN: WVWZZZ6RZDY0CICLO Mileage:
56-Radio -- Status: OK 0000
Address 01: Engine (J623-CBZC) Labels: 03F-906-070-CBZ.clb
Part No SW: 03F 906 070 GD HW: 03F 907 309 AJ
Component: SIMOS10.22AH10 5466
Revision: --H10--- Serial number: 00000000000000
Coding: 001100D6202400080000
Shop #: WSC 00788 648 00255
ASAM Dataset: EV_ECM12TFS02103F906070GD 004007
ROD: EV_ECM12TFS02103F906070FP.rod
VCID: 6A2F6AF4FFC84FE7E5-803E
Readiness: 0110 0101
Address 03: ABS Brakes (J104) Labels: 6R0-907-37x-ESP82.clb
Part No SW: 6R0 907 379 BE HW: 6R0 907 379 AF
Revision: --------
Coding: 210228E3216D00B5842814EA84D300401700
Shop #: WSC 40308 002 104857
VCID: 02C73ACC53D0BF8F25-8056
Address 04: Steering Angle (G085) Labels: 6R0-959-654.clb
Serial number: 08021613470174
Coding: 01
Shop #: WSC 00000 000 00000
ROD: EV_LWSKLOVW25X.rod
VCID: 7E3B42302F2CC77345-802A
Part No SW: 6R0 907 044 H HW: 6R0 907 044 H
Component: Climatronic H11 0711
Revision: V0000000
VCID: 38F1D66E0FCE7B0595-806C
Address 09: Cent. Elect. (J519) Labels: 7E0-937-BCM-V1.clb
Part No SW: 7E0 937 090 B HW: 7E0 937 090
Component: BCM PQ25 Max4 H81 0744
Revision: B9081001 Serial number: 0982 320160060
Coding: 3CB02FBF48E12400B3380FD17CEB9FD0DAC067AF600D30D0220000030800
VCID: 2AEFEA34F788CFA7E5-807E
Component: RLHS 220816 0 42 0106
Coding: 0728DD
Subsystem 2 - Part No SW: 6R0 959 801 BD HW: 6R0 959 801 BD Labels: 6R0-959-801.CLB
Component: J386__TSG_FT 003 8612
Serial number: KU0KU003041440937042
Coding: 0200A3
Subsystem 3 - Part No SW: 6R0 959 802 BF HW: 6R0 959 802 BF Labels: 6R0-959-802.CLB
Component: J387__TSG_BT 003 8612
Serial number: KU0KU006031440656541
Coding: 1000AB
Component: DWA-Sensor 00 001 0103
Subsystem 5 - Part No: 1K8 951 605 B
Component: LIN BACKUP HO H11 9005
Subsystem 7 - Part No SW: 1K8 959 442 HW: 1K8 959 442
Component: E221__MFL-DC1 H03 0103
Serial number: 27140003142720054516
Coding: A4FFFF
Subsystem 8 - Part No SW: 6R0 959 811 G HW: 6R0 959 811 G
Component: J388__TSG_HL 008 1611
Serial number: KU0KU003051200017821
Coding: 18BC32
Subsystem 9 - Part No SW: 6R0 959 812 G HW: 6R0 959 812 G
Component: J389__TSG_HR 008 1611
Serial number: KU0KU010051200012315
Coding: 18BC32
Address 10: Park/Steer Assist (J446) Labels: 6R0-919-475.clb
Part No SW: 6R0 919 475 C HW: 7E0 919 475
Component: PARKHILFE 4K H11 0013
Revision: -------- Serial number: 47361212601014
Coding: 308001
ROD: EV_VW250ParkiAssis2.rod
VCID: 3EFBC2702FEC473345-806A
Address 15: Airbags (J234) Labels: 5K0-959-655.clb
Component: VW10Airbag01M H10 0020
Revision: -------- Serial number: 003GX01JKVVP
Coding: 00314D
Shop #: WSC 01383 785 00200
VCID: 4A0FAA947F280F87E5-801E
Serial number: 3575HRB405N1C4LI7929
Serial number: 3585HRB405B1D5MS8GS2
Serial number: 3515RRB405B17ABS901.
Serial number: 3525RRB405B181TUDPKC
Address 17: Instruments (J285) Labels: 5K0-920-xxx-17.clb
Part No SW: 6R0 920 870 C HW: 6R0 920 870 C
Component: KOMBI H05 0607
Coding: 140E01
Shop #: WSC 00233 219 91226
VCID: 35F2D0570BD189708D-8060
Revision: B9081001
Coding: 0022FB
Address 20: High Beam Assist. (J844) Labels: 8S0-857-511.clb
Part No SW: 7E0 857 511 G HW: 7E0 857 511 E
Component: FLA H10 0003
Revision: AA001001
Coding: 0404001C00000000000000
Shop #: WSC 03607 002 104857
VCID: 2EEBE240EFBCA743C5-807A
Address 25: Immobilizer (J334) Labels: 5K0-920-xxx-25.clb
Component: IMMO H05 0607
Address 2E: Media Player 3 (J650) Labels: 5N0-035-342.lbl
Part No SW: 5N0 035 342 F HW: 5N0 035 342 F
Component: SG EXT.PLAYER H18 0530
Revision: A1001003 Serial number: 7662584630
Coding: 010100
Address 37: Navigation (J0506) Labels: 1T0-035-680.clb
Part No SW: 1T0 035 680 L HW: 1T0 035 680 C
Component: RNS-MID H06 5218
Revision: AB001001 Serial number: VWZ6Z7L7654213
Coding: 04000442040000A10001
VCID: 37F0D46D0BCB7D029D-8062
Subsystem 1 - Part No: 1T0 919 859 B
Component: EU West V14 8477
Part No: 6R0 423 156 B
Component: LenkhilfeTRW V277
Coding: 11221
Shop #: WSC 00788
VCID: 2FE8E4457FB3AD4ADD-807A
Address 55: Headlight Range (J431) Labels: 6R0-907-357.clb
Part No SW: 6R0 907 357 HW: 6R0 907 357
Component: LWR-ECU H02 0070
Revision: -------- Serial number: --------------
Coding: 0112000001000000
VCID: 7730542D030BFD429D-8022
Address 56: Radio (J0506) Labels: 1T0-035-680.clb
Address 77: Telephone (J412) Labels: 7P6-035-730.clb
Part No SW: 7P6 035 730 L HW: 7P6 035 730 L
Component: TELEFON H15 3200
Revision: 1B001001 Serial number: 00007664158506
Coding: 0501000000010110
ASAM Dataset: EV_UHVNA 002720
ROD: EV_UHVNA_002.rod
VCID: 3BFCCC7933FF551E7D-806E
End-------------------------(Elapsed Time: 04:19)--------------------------
Post
by ciclo » Fri May 19, 2017 9:22 am
I think now it's harder to navigate through the forum with the upgrade. Maybe it's a personal feeling or lack of knowledge.
Some times I used to see/navigate through the forum without login, and now my browser (chrome) warns me that
it is not a secure site due to the scripts (videos). I have to give the appropriate permissions
every time I view a page that it contains videos to be able to see them.
I guess this will happen to many people without login and this limits the use of the forum widely.
The first page of my topic is an example.
CNK
Posts: 620 Joined: Mon Apr 06, 2015 10:18 pm
Drives: 6R
Post
by CNK » Fri May 19, 2017 9:35 am
It's because youtube BB Code uses http instead of https:
for images with http you can use proxy (I don't know if it's possible in phpBB, I'm owner of XenForo
Posts: 14866 Joined: Sat Nov 11, 2006 5:29 pm
Post
by alexperkins » Fri May 19, 2017 11:00 am
Ive fixed the Youtube issue. All videos are now in HTTPS
Post
by ciclo » Fri May 19, 2017 11:15 am
alexperkins wrote: ↑ Fri May 19, 2017 11:00 am
Excellent. Thanks for all the great work you do.
CNK
Drives: 6R
Post
by CNK » Fri May 19, 2017 11:18 am
Great! But why wrap block has got only 850px width?
Post
by alexperkins » Fri May 19, 2017 11:20 am
blame phpBB lol
They decided to make it a standard for an 850px wide forum
Ive just done some tweaking and got rid of that 'feature'
Dave v
Posts: 12 Joined: Fri Jun 19, 2015 7:05 am
Drives: 6n2
Post
by Dave v » Mon May 22, 2017 2:33 pm
Hi there
I've previously posted around the wiring for a 090 BCM on a T5.1, was following Adam's progress through the wiring diagrams and guidance from Ciclo.
I was advised and then planned to start a new thread, but not sure what section to place it in as not a Polo?
Anyhow, I'll chance my luck to see if Ciclo or anyone else maybe able to assist, read that Adam sorted Xenon's on he's T5.
I've replaced the BCM previously and wired the lights as per Elsa/the guide, eg all fed from the BCM- Everything has been working fine for some time.
I've recently purchased a set of Bi Xenons and adaptor plugs (T10-T14). When first fitted nothing worked, so I checked and re- wired the adapter plugs as below:
Pins 1-4 Not used currently as auto range control is in future plans
Pin 5 - Negative
Pin 6 - Dipped beam/Xenons
Pin 7 - Negative
Pin 8 - High Beam
Pin 9 - Indicator
Pin 10 - T73b/6
Pin 11 - High beam/for shutter control
Pin 12 - To TFL/DRL
All's working fine apart from the LED DRL's, full scan below
69-Trailer -- Status: OK 0000
Address 01: Engine (J623-CAAC) Labels: 03L-906-022-CAA.clb
Part No SW: 03L 906 022 CH HW: 03L 907 309 K
Component: R4 2,0L EDC X31 9126
Revision: 26X31--- Serial number: 00000000000000
Coding: 01194012231400080000
Shop #: WSC 92521 052 00000
ASAM Dataset: EV_ECM20TDI01103L906022CH 002012
ROD: EV_ECM20TDI01103L906022CH_002.rod
VCID: 6DD1A8F5BC7F942914-8038
Readiness: 0 0 0 0 1
Address 03: ABS Brakes (-----) Labels: 7E0-907-37x-MK25AXT.clb
Part No SW: 7E0 907 379 E HW: 7E0 907 379 E
Component: ESP MK25A XT H43 0103
Revision: 00H43001
Coding: 508724AD89A50A9824A89171A96710
Shop #: WSC 02736 790 49152
VCID: 34677D9197D505E11B-8060
Address 04: Steering Angle Labels:
VCID: 55A1E015ACEF3CE9CC-956C
Address 08: Auto HVAC (J301) Labels: 7E5-907-047.clb
Part No SW: 7E5 907 047 BG HW: 7E5 907 047 BG
Component: Climatic-T5 H20 0506
Revision: 00001012
Coding: 0000000002
Shop #: WSC 02736 790 50316
ROD: EV_ClimaticT5.rod
VCID: 75E18095D42F5CE9EC-8020
Address 09: Cent. Elect. (J519) Labels: 7H0-937-08x-09.clb
Part No SW: 7H0 937 090 HW: 7H0 937 090
Component: BCM PQ25 Max4 H72 0708
Revision: B9072001 Serial number: 0531 053120030
Coding: B8A020380E212021002800803C2B8450F00066FF60060040300000000000
VCID: 6BD5A6ED8A6B9A190A-803E
Subsystem 1 - Part No SW: 7E0 959 801 C HW: 7E0 959 801 C Labels: 7E0-959-801.CLB
Component: J386__TSG_FT 003 0304
Coding: 050000
Subsystem 2 - Part No SW: 7E0 959 802 C HW: 7E0 959 802 C Labels: 7E0-959-802.CLB
Component: J387__TSG_BT 003 0308
Coding: 040000
Subsystem 3 - Part No SW: 5K0 959 542 C HW: 5K0 959 542 C Labels: 3C8-959-537.CLB
Component: E221__MFL-TAS H31 0037
Serial number: 0912947
Coding: 820000
Part No SW: 7E0 959 655 A HW: 7E0 959 655 A
Component: VW10Airbag00Y H05 0011
Revision: -------- Serial number: 003E5000CS7Q
Coding: 000000000000000000000000000000003059
ASAM Dataset: EV_AirbaVW10BPAVN750 A01001
ROD: EV_AirbaVW10BPAVN750.rod
VCID: 34677D919FD505E11B-8060
Part No SW: 7E0 920 970 E HW: 7E0 920 970 E
Component: KOMBI H04 0305
Coding: 160A00
ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A04113
ROD: EV_Kombi_UDS_VDD_RM09_VN35.rod
VCID: 2C5765F147E55D2143-8078
Address 19: CAN Gateway (J533) Labels: 6N0-909-901-6R.clb
Part No SW: 6N0 909 901 HW: 7H0 937 090
Component: GW-K-CAN TP20 H72 0708
Revision: B9072001
Coding: 042300
VCID: 70EFB181A34D79C13F-8024
Component: IMMO H04 0305
Serial number:
VCID: 6ADBA3E98D91831171-803E
Address 56: Radio (J503) Labels: 1K0-035-1xx-56.lbl
Part No SW: 5M0 035 186 AA HW: 5M0 035 186 AA
Component: Radio RCD310 013 0036
Revision: 00000000 Serial number: VWZ1Z2I6830021
Coding: 0500020002
Shop #: WSC 02736 790 00000
1 Fault Found:
03138 - Input AUX IN
011 - Open Circuit
Fault Status: 01101011
Fault Priority: 5
Fault Frequency: 1
Reset counter: 86
Mileage: 145936 km
Time Indication: 0
Date: 2017.05.21
Time: 11:00:03
Address 69: Trailer (J345) Labels: 1K0-907-383-V2.clb
Part No SW: 1K0 907 383 F HW: 1K0 907 383 F
Component: ConWysTrailer H07 0100
Revision: 3A001001 Serial number: 00000132425721
Coding: 0100000100000000
Shop #: WSC 00007 223 174336
VCID: 306F718163CD39C17F-8064
Address 0B: Sec. Air Heating Labels:
End-------------------------(Elapsed Time: 02:12)--------------------------
The side lights, T10/10 from the original isn't connected to anything- should it be?
Any help would be very much appreciated.
Posts: 6420 Joined: Fri Nov 14, 2014 2:14 pm
Post
by iichel » Mon May 22, 2017 3:35 pm
Hm, I cannot quickly check the coding, but these wires need to be ok:
T14/12 left to T73b/5
T14/12 right to T73b/6
T73b/11, check presence of a wire. There needs to be a +30 (constant 12V) to T73b/11. MIght already be present if you have static cornering lights...
Dave v
Drives: 6n2
Post
by Dave v » Mon May 22, 2017 4:59 pm
iichel wrote: ↑ Mon May 22, 2017 3:35 pm
Thanks for the reply.
I've checked and double checked Elsa:
T14/12 left to T73b/3
T14/10 left to T73b/5
T14/12 right to T73a/5
T14/10 right to T73b/6
Any idea if I'm checking the wrong version to have the above differences?
T14/11 also give the impression it's a switched live with the main beam, although can just try connecting to +30
Post
by iichel » Mon May 22, 2017 5:01 pm
T73b/11, not T14/11...
Dave v
Drives: 6n2
Post
by Dave v » Mon May 22, 2017 5:42 pm
iichel wrote: ↑ Mon May 22, 2017 5:01 pm
Sorry, somehow miss read that.
I'll check- thanks for you help.
Dave v
Drives: 6n2
Post
by Dave v » Mon May 22, 2017 8:06 pm
Tried connecting T73b/11 to +30, DRL's/LED's still not functioning.
Anything else I should check?
Post
by ciclo » Mon May 22, 2017 9:26 pm
Hi Dave v. (welcome)
At a quick glance. It's a coding problem, I'll tell you the BCM coding tomorrow.
Dave v
Drives: 6n2
Post
by Dave v » Mon May 22, 2017 11:10 pm
ciclo wrote: ↑ Mon May 22, 2017 9:26 pm
Thanks Ciclo, appreciated.
