I left the report open but Alex closed it. I cannot find the username. mcp.php?i=logs&mode=topic_logs&t=58703& ... 857cf8a641
Ok, then everything is fine.
Shishir wrote: Wed Sep 06, 2017 5:57 amHi akshay922,akshay922 wrote: Sat Sep 02, 2017 8:10 am Hi Ciclo/Graaja/Patil?Gannu
You are such an inspiration!
I'm located in India and contemplating the below headlights for my polo 6c:
http://www.vagtune.in/volkswagen/vw-lig ... 6rx-detail
I'm not sure if its worth the price, will it be plug and play and how are DRL's going to function and finally pro's and cons of buying this.
If anyone can shed some light on this, will be appreciated.
I would advise against this headlight unit from VagTune. I received very poor service from them(I am based out of Bangalore). In the end, swapped these headlights to OEM Valeos`. They are brighter than these headlights and are superior in quality.
Best,
Shishir
Sorry for the late reply Shishir.Shishir wrote: Wed Sep 06, 2017 5:57 am Hi Akshay,
1. Warranty depends on your relationship with your respective dealership. I am taking my chances. They claimed that my warranty would be void even on aftermarket Roots horn.![]()
2. Yes, it was plug and play
3. Yes
4. I did not get LED DRL activated but you can ask the installer for the same(they come on with headlights). Cornering lights were left untouched so they continue to work as they worked before.
5. You may contact German DNA for these headlights. You can find their contact details on Facebook and give my reference (Shishir, Grey GT TSI). They are based out of Bangalore.
On a side note, switching off of DRL when indicators are turned on, will not work because of BCM issue but it was not a deal breaker for me.
Best,
Shishir
I did talk to your reference for headlights in Banglore, turns out that he does custom coding and custom wires must be drawn from BCM.
Also, he did tell me he will have to cut and splice some wires which virtually cant be detected, "THIS ISNT PLUG AND PLAY" and he was exteremly confident that this wont cause warranty issues!!
Lastly, Once you do this modification and you want to go back to OEM you will have to get it done at his place, you cant do it at home or anywhere else, since his custom coding has to be changed.
I haven't forgotten this, but so far I've failed in my attempts to read eeprom from bcm with my vcp cable.firegrafik wrote: Sat Sep 16, 2017 3:25 pmI bought used 7E0937090B from T6 with LED headlights (but still haven't installed it). Anyway if someone could teach me how to read/write the EEPROM dump using VCP from that my BCM, and it could be possible to make any 7E0937090B to be compatible with LED headlights by writing that dump.iichel wrote: Sat Sep 16, 2017 9:51 am very interesting. i need to find a BCM 7E0 B with LED headlight support![]()
I couldn’t either [emoji848], closest I got was it started to do something and went crazy, interior lights flashed on/off cluster started beeping and lights flashing then eventually stopped [emoji15] ....... I didn’t try again [emoji23]iichel wrote:I haven't forgotten this, but so far I've failed in my attempts to read eeprom from bcm with my vcp cable.firegrafik wrote: Sat Sep 16, 2017 3:25 pmI bought used 7E0937090B from T6 with LED headlights (but still haven't installed it). Anyway if someone could teach me how to read/write the EEPROM dump using VCP from that my BCM, and it could be possible to make any 7E0937090B to be compatible with LED headlights by writing that dump.iichel wrote: Sat Sep 16, 2017 9:51 am very interesting. i need to find a BCM 7E0 B with LED headlight support![]()
I also tried it and it didn't work.iichel wrote: Fri Sep 22, 2017 3:55 pm .... but so far I've failed in my attempts to read eeprom from bcm with my vcp cable.
Direct TPMS
drive2 your dreams
Everything works like a charm.
My BlueGT IC: (It's not my new GTI IC)
Before
Address 17: Instruments (J285) Labels:| 5K0-920-xxx-17.clb
Part No SW: 6R0 920 870 C HW: 6R0 920 870 C
Component: KOMBI H05 0607
Coding: 140E01
Shop #: WSC 00788 219 00200
VCID: 3502C0673BC17907FE-8060
After
Part No SW: 6R0 920 870 F HW: 6R0 920 870 C
Component: KOMBI H05 0709
Coding: 140E01
VCID: 38F9CE663FC6630A0E-806C
Parts:
It can also be 7E0937090B.
http://www.ebay.es/itm/Nuevo-original-V ... 3641.l6368
Installation:
Sensors/valves
TPMS unit
Wiring
Editing Parameters:
You can use this editor
http://htmlpreview.github.io/?https://r ... rator.html
Or this editor
https://skodapilot.com/rdkseditor/
I have used both, but finally I used the RDKS editor from Skodapilot. Many thanks to its creator (a big hug).
More info:
viewtopic.php?f=56&t=58703&start=2835#p516356
viewtopic.php?f=56&t=58703&p=517343#p517336
viewtopic.php?f=56&t=58703&start=3390#p521807 Thank you very much to both!
viewtopic.php?f=56&t=58703&start=3450#p522430
viewtopic.php?f=56&t=58703&start=3630#p524720
Thanks again to all for your participation in this adventure.
Of course, even without Gra_high on my 6R.
drive2 your dreams
Before
Coding: 140E01
After
Coding: 140E01
Saturday,23,September,2017,20:27:05:06516
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 7 x64
VCDS Version: 17.8.0.1
Data version: 20170721 DS276.2
www.Ross-Tech.com
VIN: WVWZZZ6RZDY0CICLO License Plate: Direct TPMS OK!!
Mileage: 27970km-17379mi Repair Order:
Chassis Type: 6R-VW25 (7E0)
Scan: 01 03 04 08 09 10 15 17 19 20 25 2E 37 44 55 56 65 77 0B
VIN: WVWZZZ6RZDY0CICLO Mileage: 27970km-17379miles
56-Radio -- Status: OK 0000
Address 01: Engine (J623-CBZC) Labels:. 03F-906-070-CBZ.clb
Part No SW: 03F 906 070 GD HW: 03F 907 309 AJ
Component: SIMOS10.22AH10 5466
Revision: --H10--- Serial number: 00000000000000
Coding: 001100D6202400080000
Shop #: WSC 00788 648 00255
ASAM Dataset: EV_ECM12TFS02103F906070GD 004007
ROD: EV_ECM12TFS02103F906070FP.rod
VCID: 6A37620CF7C037E89E-803E
Readiness: 0110 0101
Address 03: ABS Brakes (J104) Labels:. 6R0-907-37x-ESP82.clb
Part No SW: 6R0 907 379 BE HW: 6R0 907 379 AF
Revision: --------
Coding: 210228E3216D00B5842814EA84D300401700
Shop #: WSC 40308 002 104857
VCID: 02CF32C45BC8A7905E-8056
Serial number: 08021613470174
Coding: 01
ROD: EV_LWSKLOVW25X_VW25.rod
VCID: 7E433A482724CF7C3E-802A
Part No SW: 6R0 907 044 H HW: 6R0 907 044 H
Component: Climatronic H11 0711
Revision: V0000000
VCID: 38F9CE6637C6630A0E-806C
Part No SW: 7E0 937 090 C HW: 7E0 937 090 C
Revision: B9082001 Serial number: 4000 122170091
Coding: 3CB02FBF48E32400B3380F916CEB9FDCDAC0672F600D30D0200000030800
VCID: 2BF4E441E387BDB196-807E
Component: RLHS 220816 0 42 0106
Coding: 0728DD
Subsystem 2 - Part No SW: 6R0 959 801 BD HW: 6R0 959 801 BD Labels: 6R0-959-801.CLB
Component: J386__TSG_FT 003 8612
Serial number: KU0KU003041440937042
Coding: 0200A3
Subsystem 3 - Part No SW: 6R0 959 802 BF HW: 6R0 959 802 BF Labels: 6R0-959-802.CLB
Component: J387__TSG_BT 003 8612
Serial number: KU0KU006031440656541
Coding: 1000AB
Component: DWA-Sensor 00 001 0103
Subsystem 5 - Part No: 1K8 951 605 B
Component: LIN BACKUP HO H11 9005
Subsystem 7 - Part No SW: 1K8 959 442 HW: 1K8 959 442
Component: E221__MFL-DC1 H03 0103
Serial number: 27140003142720054516
Coding: A4FFFF
Subsystem 8 - Part No SW: 6R0 959 811 G HW: 6R0 959 811 G
Component: J388__TSG_HL 008 1611
Serial number: KU0KU003051200017821
Coding: 18BC32
Subsystem 9 - Part No SW: 6R0 959 812 G HW: 6R0 959 812 G
Component: J389__TSG_HR 008 1611
Serial number: KU0KU010051200012315
Coding: 18BC32
Address 10: Park/Steer Assist (J446) Labels:| 6R0-919-475.clb
Part No SW: 6R0 919 475 C HW: 7E0 919 475
Component: PARKHILFE 4K H11 0013
Revision: -------- Serial number: 47361212601014
Coding: 308001
ROD: EV_VW250ParkiAssis2.rod
VCID: 3E03BA8827E44F3C3E-806A
Component: VW10Airbag01M H10 0020
Revision: -------- Serial number: 003GX01JKVVP
Coding: 00314D
Shop #: WSC 01383 785 00200
VCID: 4A17A2AC7720F7889E-801E
Serial number: 3575HRB405N1C4LI7929
Serial number: 3585HRB405B1D5MS8GS2
Serial number: 3515RRB405B17ABS901.
Serial number: 3525RRB405B181TUDPKC
Coding: 140E01
Part No SW: 7E0 909 901 HW: 7E0 937 090 C
Revision: B9082001
Coding: 002200
VCID: 68296EF6F7D643DA8E-803C
Address 20: High Beam Assist. (J844) Labels:. 8S0-857-511.clb
Part No SW: 7E0 857 511 G HW: 7E0 857 511 E
Component: FLA H10 0003
Revision: AA001001
Coding: 0404001C00000000000000
Shop #: WSC 03607 002 104857
ROD: N/A
VCID: 2EF3DA58E7B4AF4CBE-807A
No ASAM data for: "EV_HighBeamAssisAU316" (VW25)
Component: IMMO H05 0709
Shop #: WSC 00000 000 00000
Address 2E: Media Player 3 (J650) Labels:. 5N0-035-342.lbl
Part No SW: 5N0 035 342 F HW: 5N0 035 342 F
Component: SG EXT.PLAYER H18 0530
Revision: A1001003 Serial number: 7662584630
Coding: 010100
VCID: 2AF7E24CFF80B7A89E-807E
Address 37: Navigation (J0506) Labels:. 1T0-035-680.clb
Part No SW: 1T0 035 680 L HW: 1T0 035 680 C
Component: RNS-MID H06 5218
Revision: AB001001 Serial number: VWZ6Z7L7654213
Coding: 04000442040000A10001
Shop #: WSC 12345 123 12345
VCID: 37F8CC6533C3650DF6-8062
Subsystem 1 - Part No: 1T0 919 859 B
Component: EU West V14 8477
Part No: 6R0 423 156 B
Component: LenkhilfeTRW V277
Coding: 11221
Shop #: WSC 00788
VCID: 2FF0DC5D87AB9555B6-807A
Address 55: Headlight Range (J431) Labels:. 6R0-907-357.clb
Part No SW: 6R0 907 357 HW: 6R0 907 357
Component: LWR-ECU H02 0070
Revision: -------- Serial number: --------------
Coding: 0112000001000000
VCID: 77384C253B03E54DF6-8022
Address 56: Radio (J0506) Labels:. 1T0-035-680.clb
Address 65: Tire Pressure (J502) Labels: 3AA-907-273.clb
Part No SW: 3AA 907 273 F HW: 5Q0 907 273
Component: RDKBERU30 H04 0011
Serial number: 40000000050821
ROD: EV_RDKBERU30.rod
VCID: 37F8CC653BC3650DF6-8062
Address 77: Telephone (J412) Labels:| 7P6-035-730.clb
Part No SW: 7P6 035 730 L HW: 7P6 035 730 L
Component: TELEFON H15 3200
Revision: 1B001001 Serial number: 00007664158506
Coding: 0501000000010110
ASAM Dataset: EV_UHVNA 002720
ROD: EV_UHVNA_002.rod
VCID: 3B04C4712BF75D2116-806E
End-------------------------(Elapsed Time: 04:27)--------------------------
Parts:
Installation:
Sensors/valves
TPMS unit
Wiring
Editing Parameters:
Or this editor
More info:
it's not october 11 yet. that means you figured it out with your original cluster?
firegrafik
- Drives: 6R 1,6MPI(CFNA) sedan
Congratulations, Fernando! Great work!
Exactly iichel.iichel wrote: Sun Sep 24, 2017 10:49 am it's not october 11 yet. that means you figured it out with your original cluster?
On October 11, more ...
Many thanks firegrafik, were 00:14:09 very exciting minutes with the VCP ...
(left bottom corner of image)
Everything was perfect, no hassle. In case you want to do it.
- ag69
- Drives: 1.2TSi 77Kw 7DSG
Speechless.
smg_shardul
- Drives: Polo 6R
Excellent work Fernando...[emoji1303]
Scotty_boy vw
Hi Ciclo I'm new on here and was wondering if you could help me with my retro fit of folding mirrors to my 6c polo.
I will be adding the extra wiring thats needed but what I'm really looking to do is add the folding on remote if it can be done?
was wondering if you could help me with this please.
regards
scott
Pm me please
regards
scott
Pm me please
Maybe a stupid question, but I'm wondering two things...
1) Why does everyone want to be helped by ciclo? I know he's probably the best, by some distance, but there are other people here too that know a thing or two. And he's a bit busy (celebrating holidays and stuff).
2) Why does everyone want to be helped by PM? The point of a forum is to share stuff in public. The reason why this topic is probably one of the most popular in Polo history is because everything is explained in detail, in a public way. Everyone can read, everyone can add.
Scotty_boy vw
The reason i asked ciclo is because he has done this mod so i was hoping he could help although if someone else can help with this then that would be great also.....iichel wrote: Mon Sep 25, 2017 7:51 pm Maybe a stupid question, but I'm wondering two things...
The reason i asked to be pm'd is so his build thread would not be clogged up with things like this happening!!!!!
scott
