UK-POLOS.NET - THE VW Polo Forum • My high mileage GTI - Page 4
Page 4 of 8
Re: My high mileage GTI
Posted: Wed Apr 29, 2015 10:39 am
by Space
Somewhere in August my car has it's yearly MOT test. Then it's also time to replace the belts, waterpump, tensioner etc. I thought that maybe it's also a good moment to freshen up the cylinder head. Is it much additional work?
I want to replace the rear brake calipers. They have been revised twice, but they keep getting stuck. I have done this before on a Porsche 944 and noticed that when removing the brake hose from the caliper it starts dripping brake fluid. I thought this would create a vacuum so the dripping would stop, but it didn't. I was wondering if that also happens on this car, so I will take measures catching the fluid and protect the chassis.
Posted: Wed Apr 29, 2015 10:42 am
by alexperkins
Its a huge amount of work to take the head off - cams have to removed amongst many other components
My advice would be if its running well, dont touch it. The block itself is fairly low maintenance
Do the belts tensioners and waterpump and a good engine flush and oil change :)
When replacing the calipers, use a brake hose clamp to compress the brake hose and stop it leaking out
In order to create a vacuum the traditional way, you have to put a plastic bag over the top of the master cylinder, then screw the lid back on
Posted: Wed Apr 29, 2015 11:05 am
by Space
I can feel in the low RPMs it has lost some torque. May be leaky valves. I have no oil usage to speak of. It's no real drama and I have driven a car with bad head before for 40.000 miles without problem, only lack of torque and little hesitation now and then.
The problem I have with brake hose clamp is that it might damage the structural integrity without noticing. Maybe just be quick on changing it from one caliper to the new and clean the caliper before it kills the fresh red caliper paint :).
Posted: Wed Apr 29, 2015 11:07 am
by alexperkins
Plastic bag over the master cylinder with the lid screwed over the top will work just as well :)
Using proper brake hose clamps its very hard to damage the hoses anyway
Posted: Wed Apr 29, 2015 11:45 am
by Space
Thanks Alex. Will keep you posted. Perhaps put some pictures on here of the work and ofcourse the mysterious beige interior of the car :lol:
Posted: Wed Apr 29, 2015 12:01 pm
by alexperkins
Haha yes the mysterious beige interior :D
Posted: Thu Apr 30, 2015 3:52 pm
by Space
Is it easy to repair a rear brake caliper? I see there are repair sets available. I did porsche brakes before, but this is a different system. Handbrakes are different. How does that work on our GTIs?
Posted: Thu Apr 30, 2015 4:09 pm
by alexperkins
Not too difficult but theres a cranked spindle to remove due to the way the handbrakes work
My advice would be however to get a refurbed caliber. The handbrake mechanism is an ass to refit.
Posted: Thu Apr 30, 2015 5:35 pm
by Space
Posted: Thu Apr 30, 2015 5:36 pm
by alexperkins
I do indeed
Posted: Wed Jul 01, 2015 2:36 pm
by Space
Car is still leaking oil. Where could it leak? Seemed to be from the carter pan, but that one has a new seal.
Posted: Wed Jul 01, 2015 2:37 pm
by alexperkins
Have you had a good look underneath? Guessing the sump pan had a fluid gasket put on it as per spec
Posted: Wed Jul 01, 2015 3:16 pm
by Space
Yes that fluid gasket was replaced. Still find a 4 square inch oil spot every morning on the street. I wondered whereelse it could leak. Flywheel seal was dry and left in place.
Posted: Wed Jul 01, 2015 3:54 pm
by TRiBaL
Space wrote:Yes that fluid gasket was replaced. Still find a 4 square inch oil spot every morning on the street. I wondered whereelse it could leak. Flywheel seal was dry and left in place.
Check your oil pressure sensor for leaks
Posted: Wed Jul 01, 2015 3:58 pm
by alexperkins
Plenty of places - rocker cover, oil filter, crankcase breather, oil cooler. Theres a few to start you with
