Page 4 of 15
Re: 6R 1.6TDI 90HP CAYB
Posted: Fri Feb 06, 2015 10:34 pm
by Ugabista
Regarding the error I have in Climatic (08), i did do some more tests and I came across this discrepancy in values in the third frame, will be normal?
Address 08: Auto HVAC (J301) Labels: 6R0-820-045.clb
Part No SW: 6R0 820 045 E HW: 6R0 820 045 E
Component: Climatic 24 0600
Revision: 00 10 24
VCID: 306FF64B63D6889E243-8065
1 Fault Found:
16372 - Control Module; Unspecified Internal Error
014 - Defective
Fault Status: 01101110
Fault Priority: 1
Fault Frequency: 1
Reset counter: 255
Mileage: 31090 km
Time Indication: 0
Date: 2013.14.04
Time: 21:04:20
May be related? Where to locate this sensor or does the panel Climatic?
Posted: Wed Feb 11, 2015 10:08 pm
by Ugabista
Nobody knows or no ideia:?:
I would be very grateful if someone could make a print to climatic module (08), entering the field 7 Measuring Blocks to check the value that appears in the third field as the picture shown above.
Posted: Tue Feb 17, 2015 7:58 pm
by Ugabista
6R0 035 501C
Posted: Thu Feb 19, 2015 11:14 am
by sambir
Car looks good. Where did you get your camera? and is it easy to fit on the rns 315?
Posted: Thu Feb 19, 2015 8:12 pm
by Ugabista
sambir wrote:Car looks good. Where did you get your camera? and is it easy to fit on the rns 315?
I bought here:
http://www.aliexpress.com/item/Flip-Cam ... 71049.html
It's plug&play with the RNS315 and RNS510, but you need an adapter, drilling is diferente in the trunk, in my case I bought the adapter to the
Ciclo and recommend.
See the DIY by
Ciclo.
https://drive.google.com/file/d/0B2nv91 ... JUSlU/edit
Posted: Thu Mar 19, 2015 10:26 pm
by Ugabista
1K8419091
This is compatible with my Polo?
Plug & Play or need someting more?
[emoji57]
Posted: Wed Mar 25, 2015 11:20 pm
by Ugabista
Ugabista wrote:1K8419091
[emoji57]
Anyone can help me
Posted: Thu Mar 26, 2015 7:35 am
by Mart!n-GTI-DK
part number does not exist. Are you sure your not missing a few numbers or letters in it?
And what is it suppose to be?
Posted: Thu Mar 26, 2015 12:31 pm
by alexperkins
Mart!n-GTI-DK wrote:part number does not exist. Are you sure your not missing a few numbers or letters in it?
Looks to be this
http://www.carsystems.pl/vw-multifuncti ... id485.html
Posted: Thu Mar 26, 2015 12:43 pm
by ciclo
[emoji57]
I see you have activated MFSW (VCDS), so it is plug and play.
No need to do this:
http://www.uk-polos.net/view ... 71#p421709
Posted: Thu Mar 26, 2015 5:19 pm
by Ugabista
Hello, the part number appears to be this or it can be added at the end of the letter A
It is a steering wheel
Hi, Yes that's right
ciclo wrote:Ugabista wrote:1K8419091
[emoji57]
No need to do this:
Thank you friend 'encyclopedia'
Re: 6R 1.6TDI 90HP CAYB 2009
Posted: Wed Apr 08, 2015 12:39 pm
by Ugabista
Hello guys,
i was thinking to change my BCM, can I make a direct replacement and put a 7H0 937 090 B or other latest for example ?
Thanks in advance
Posted: Thu Apr 16, 2015 5:04 pm
by Ugabista
i need help, I have searched and can not find a USB extension equal to this. I wanted to make an extension of the MEDIA-IN interface for the console and once a site of USA saw this extension, but with sizes and custom house is almost the price of a new car.
If anyone knows where I can find, the goal here please link.
I am very grateful.
Posted: Thu Apr 16, 2015 6:29 pm
by Ugabista
The idea is connected to the MEDIA-IN this way ...
Posted: Wed Apr 22, 2015 7:50 pm
by Ugabista
Nobody knows where this adapter or sell
