Page 4 of 5
Re: Reverse Lamp and Camera disappeared after BCM max Upgrade
Posted: Sun Feb 23, 2020 3:36 am
by ciclo
New BCM coding
(7E0 BCM Max, Automatic lights + CH/LH, with Front Foglights and DRLs under BCM control, without LED plate lights :?:)
3CB82BBF08A10000013806B03CEB9ED95F80612F60842041200000020000
New RLS coding
0228DD
Zahari, this is the first BCM coding, any faults due to the lack of installation of some equipment or due to improper installation will be corrected, therefore do not worry and enjoy the achievements made so far. :)
Post a new Autoscan with the new codings so we know what to do.
Please make any comments you deem appropriate about the operation of the lights, it will help us solve any possible incident. Thank you.
Posted: Mon Feb 24, 2020 6:17 pm
by ZahariGeorgiev
Hello ciclo,
I code the BCM, and everything is back to normal finally!
But... i dint find where to recode RLS, can you provide some help?
Posted: Mon Feb 24, 2020 8:11 pm
by ciclo
Great! 8)
The RLS label is inside the BCM (09 Address), in the drop-down panel.
Read the VCDS coding in the installation guide for automatic lights, you have images with the drop-down panel in pg 18.
https://drive.google.com/file/d/0B2nv91 ... sp=sharing
Have you installed the fog lights and DRLs under BCM control?
Posted: Mon Feb 24, 2020 8:35 pm
by ZahariGeorgiev
The problem is: that i don't see RLS in the drop box menu..
Is it this one:
Posted: Mon Feb 24, 2020 9:37 pm
by iichel
No that is your MFL (Multi Funktion Lenkrad) = MFSW
The RLS is not in your first autoscan, correct? Is it installed correctly?
Posted: Tue Feb 25, 2020 2:10 am
by ciclo
iichel wrote: Mon Feb 24, 2020 9:37 pm No that is your MFL (Multi Funktion Lenkrad) = MFSW
+1
Zahari, if you want us to remain friends, post an autoscan every time you do a new installation. :lol:
Posting an Autoscan with the final results is the best gift you can give to me and other users.😊
Posted: Tue Feb 25, 2020 5:21 am
by ZahariGeorgiev
Today after work will gonna do again autoscan and post it here. Sry but yesterday dint have wi-fi to upload it.
Posted: Tue Feb 25, 2020 5:50 am
by ciclo
Don't worry, just kidding! when possible for you. :wink:
Posted: Tue Feb 25, 2020 6:00 pm
by ZahariGeorgiev
Tuesday,25,February,2020,15:31:13:35439
VCDS Version: 17.1.3.0
Data version: 20170220 DS267.3
www.Ross-Tech.com
VIN: WVWZZZ6RZBY004889   License Plate: M2016
Mileage: 154440km-95964mi   Repair Order:
Chassis Type: 6R (7E0)
Scan: 01 02 03 04 08 09 15 17 19 25 44 56 0B
VIN: WVWZZZ6RZBY004889   Mileage: 154440km-95964miles
25-Immobilizer -- Status: Malfunction 0010
56-Radio -- Status: Malfunction 1010
Address 01: Engine (J623-CAYB)       Labels: 03L-906-023-CAY.clb
   Part No SW: 03L 906 023 AH    HW: 03L 906 023 D
   Component: R4 1.6l TDI   H13 9979
   Revision: --H13---    Serial number:
   Coding: 00254016002400080000
   Shop #: WSC 124697 483 00190
   ASAM Dataset: EV_ECM16TDI02103L906023AH 003014
   ROD: EV_ECM16TDI02103L906023AH_003.rod
   VCID: 6C257124FF5950E9FD-8038
Readiness: 0 0 0 0 1
Address 02: Auto Trans
Cannot be reached
Address 03: ABS Brakes (J104)       Labels: 6R0-907-37x-ESP82.clb
   Part No SW: 6R0 907 379 AJ    HW: 6R0 907 379 AF
   Revision: --------
   Coding: 210228E3416D00B6842D14EA82DA00421300
   Shop #: WSC 02069 123 12345
   VCID: 06BB3D165B5FB4A30D-8052
   Part No SW: 6R0 907 044 H    HW: 6R0 907 044 H
   Component: Climatronic   H12 0812
   Revision: V0000000
   VCID: 38E9D9800745687D9D-806C
4 Faults Found:
01274 - Air Flow Flap Positioning Motor (V71)
            000 -  -  - Intermittent
                    Fault Status: 00100000
                    Fault Priority: 3
                    Fault Frequency: 1
                    Reset counter: 86
                    Mileage: 154430 km
                    Time Indication: 0
                    Date: 2014.07.18
                    Time: 15:25:32
01272 - Positioning Motor for Central Flap (V70)
                    Fault Priority: 3
                    Fault Frequency: 1
                    Reset counter: 86
                    Mileage: 154430 km
                    Time Indication: 0
                    Date: 2014.07.18
                    Time: 15:25:40
01271 - Positioning Motor for Temperature Flap (V68)
                    Fault Priority: 3
                    Fault Frequency: 1
                    Reset counter: 86
                    Mileage: 154430 km
                    Time Indication: 0
                    Date: 2014.07.18
                    Time: 15:25:40
00710 - Defroster Flap Positioning Motor (V107)
                    Fault Priority: 3
                    Fault Frequency: 1
                    Reset counter: 86
                    Mileage: 154430 km
                    Time Indication: 0
                    Date: 2014.07.18
                    Time: 15:25:42
Address 09: Cent. Elect. (J519)       Labels: 7E0-937-BCM-V1.clb
   Revision: B9080001    Serial number: 0771 138160111
   Coding: 3CB82BBF48A10000013806B03CEB9ED95F80612F60842041200000020000
   Shop #: WSC 18752 008 00032
   VCID: 68197930C73548CD1D-803C
   Subsystem 1 - Part No SW: 6R0 959 801 R    HW: 6R0 959 801 R  Labels: 6R0-959-801.CLB
   Component: J386__TSG_FT  006 0903
   Serial number: KU0-KU011.05.1015140
   Coding: 18BC30
   Subsystem 2 - Part No SW: 6R0 959 802 T    HW: 6R0 959 802 T  Labels: 6R0-959-802.CLB
   Component: J387__TSG_BT  006 0902
   Serial number: KU0-KU017.05.1012733
   Coding: 08BC30
   Subsystem 3 - Part No SW: 1K8 959 442     HW: 1K8 959 442
   Component: E221__MFL-MD9  H04 0103
   Serial number: 29190000858580089166
   Coding: A40000
   Subsystem 4 - Part No SW: 6R0 959 811 F    HW: 6R0 959 811 F
   Component: J388__TSG_HL  006 0902
   Serial number: KU0-KU010.05.1012823
   Coding: 08BC32
   Subsystem 5 - Part No SW: 6R0 959 812 F    HW: 6R0 959 812 F
   Component: J389__TSG_HR  006 0902
   Serial number: KU0-KU007.05.1017524
   Coding: 08BC32
3 Faults Found:
01520 - Rain and Light Recognition Sensor (G397)
            004 - No Signal/Communication
                    Fault Status: 01100100
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 44
                    Mileage: 154399 km
                    Time Indication: 0
                    Date: 2014.07.17
                    Time: 21:51:33
02745 - Bulb for Daytime Running Light; Left
            010 - Open or Short to Plus
                    Fault Status: 01101010
                    Fault Priority: 3
                    Fault Frequency: 1
                    Reset counter: 44
                    Mileage: 154399 km
                    Time Indication: 0
                    Date: 2014.07.17
                    Time: 21:51:29
02746 - Bulb for Daytime Running Light; Right
                    Fault Priority: 3
                    Fault Frequency: 1
                    Reset counter: 44
                    Mileage: 154399 km
                    Time Indication: 0
                    Date: 2014.07.17
                    Time: 21:51:29
   Part No SW: 6R0 959 655 C    HW: 6R0 959 655 C
   Component: VW10Airbag008 H09 0018
   Revision: --------    Serial number: 003DW00FP4EK
   Coding: 003038
   VCID: 42FFC5A2278B2CC72D-8016
   Serial number: 3572SRB40000B7ACC10B
   Serial number: 3582SRB40000B7C92178
   Serial number: 3516GRB401P9OICCMBQI
   Serial number: 3526GRB401N9OICD7JTE
   Part No SW: 6JA 920 840 A    HW: 6JA 920 840 A
   Component: KOMBI         H16 0607
   Coding: 140801
   Shop #: WSC 73430 031 00217
   VCID: 39EEDF850B466A7C9D-806C
   Revision: B9080001
   Coding: 002200
1 Fault Found:
01304 - Radio
                    Fault Status: 00100100
                    Fault Priority: 2
                    Fault Frequency: 26
                    Reset counter: 88
                    Mileage: 154399 km
                    Time Indication: 0
                    Date: 2014.07.17
                    Time: 21:52:25
   Component: IMMO          H16 0607
   Serial number:
   Shop #: WSC 00000 000 00000
   VCID: 6A27752AC7435CDFED-803E
1 Fault Found:
9456681 - Key
          B104C 29 [008] - Implausible Signal
                    Fault Status: 00000001
                    Fault Priority: 6
                    Fault Frequency: 3
                    Mileage: 154399 km
                    Date: 2020.02.24
                    Time: 22:10:39
   Part No: 6R0 423 156 B
   Coding: 11230
   Shop #: WSC 00000
   VCID: 2FE0EB9B7728BE42C5-807A
Address 56: Radio
Cannot be reached
End-------------------------(Elapsed Time: 02:48)--------------------------
For Immobilizer fault: one of my key is broken. Already got 2 new (just have to learn them)
For CAN Gateway fault: my radio is aftermarket.
For Bulb for Daytime Running Light fault: I remove original bulb, because my new aftermarket r-line body kit, don't have holes in the fog lights for the DRL... :(
For Rain and Light Recognition Sensor fault: That's why it didn't appear in drop box menu..I buy wiring kit from kufatec - https://www.kufatec.com/en/volkswagen/v ... mber=38994, connect as on the diagram, rear view mirror is working. The sensor is: 5Q0955559B.
For Auto HVAC faults: i really don't have any idea what is going on.
Also don't know why cant reach Auto Trans
Posted: Tue Feb 25, 2020 6:30 pm
by iichel
RLS is the wrong part, you need a 5K7 rain sensor i.e. 5K7955559C
Posted: Tue Feb 25, 2020 7:50 pm
by ciclo
ZahariGeorgiev wrote: Tue Feb 25, 2020 6:00 pm
www.Ross-Tech.com
Cannot be reached
   Revision: --------
   Revision: V0000000
4 Faults Found:
                    Fault Priority: 3
                    Fault Frequency: 1
                    Reset counter: 86
                    Mileage: 154430 km
                    Time Indication: 0
                    Date: 2014.07.18
                    Time: 15:25:32
                    Fault Priority: 3
                    Fault Frequency: 1
                    Reset counter: 86
                    Mileage: 154430 km
                    Time Indication: 0
                    Date: 2014.07.18
                    Time: 15:25:40
                    Fault Priority: 3
                    Fault Frequency: 1
                    Reset counter: 86
                    Mileage: 154430 km
                    Time Indication: 0
                    Date: 2014.07.18
                    Time: 15:25:40
                    Fault Priority: 3
                    Fault Frequency: 1
                    Reset counter: 86
                    Mileage: 154430 km
                    Time Indication: 0
                    Date: 2014.07.18
                    Time: 15:25:42
   Coding: 18BC30
   Coding: 08BC30
   Coding: A40000
   Coding: 08BC32
   Coding: 08BC32
3 Faults Found:
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 44
                    Mileage: 154399 km
                    Time Indication: 0
                    Date: 2014.07.17
                    Time: 21:51:33
                    Fault Priority: 3
                    Fault Frequency: 1
                    Reset counter: 44
                    Mileage: 154399 km
                    Time Indication: 0
                    Date: 2014.07.17
                    Time: 21:51:29
                    Fault Priority: 3
                    Fault Frequency: 1
                    Reset counter: 44
                    Mileage: 154399 km
                    Time Indication: 0
                    Date: 2014.07.17
                    Time: 21:51:29
   Coding: 003038
   Coding: 140801
   Revision: B9080001
   Coding: 002200
1 Fault Found:
01304 - Radio
                    Fault Priority: 2
                    Fault Frequency: 26
                    Reset counter: 88
                    Mileage: 154399 km
                    Time Indication: 0
                    Date: 2014.07.17
                    Time: 21:52:25
   Serial number:
1 Fault Found:
9456681 - Key
                    Fault Priority: 6
                    Fault Frequency: 3
                    Mileage: 154399 km
                    Date: 2020.02.24
                    Time: 22:10:39
   Coding: 11230
   Shop #: WSC 00000
Address 56: Radio
Cannot be reached
You have to do the following:
1- Install the RLS for PQ25 indicated by iichel.
2- New BCM coding
3CB82BBF08A10000013806B07CEB9ED95F80612F60842001200000020000
3- Autoscan -> Gateway installation list -> Clear all DTCs -> Start (new autoscan).
Post the new autoscan.
Climatronic faults are intermittent, they will be cleared.
About the faults of DRLs, Key and Radio (+ Gateway) what you already know.
Your DSG gearbox can be read, but by selecting the '6R' model (search or drop-down panel), not by selecting 'Auto-detect (CAN only)'.
Posted: Wed Feb 26, 2020 3:16 am
by ZahariGeorgiev
Thanks again guys!
Today will order new sensor - 5K7955559, and everything else is clear what should i do :)
Will post results when i am ready.
Posted: Fri Feb 28, 2020 8:09 am
by ZahariGeorgiev
Till i am waiting for the new RLS, i try to fix problem with my key, and I bought one used remote key from Golf 7. The problem is that when i change the flip key blade with new one, that new one was terrible and the key couldn't unfold. So is there any OEM blades or some high quality aftermarket?
Posted: Fri Feb 28, 2020 10:46 am
by ag69
Did your original keys are/were as same as this key fob?
Posted: Fri Feb 28, 2020 11:25 am
by ZahariGeorgiev
Nope, they are not the same.
It is like this one:
