iichel wrote: Fri Dec 18, 2020 2:05 pm
i take my hat off to you sir
you'll have to excuse the mess that is the auto scan. the car is VERY stripped down right now
VCDS Version: Release 15.7.1 (x64) Running on Windows 10 x64
Data version: 20150904
www.Ross-Tech.com
Friday,18,December,2020,14:23:29:05031
Chassis Type: 6J (7E0)
Scan: 01 03 08 09 15 17 19 22 25 44 56
VIN: VSSZZZ6JZAR131492 Mileage: 162560km-101010miles
22-AWD -- Status: Cannot be reached 1100
44-Steering Assist -- Status: Not registered 0011
56-Radio -- Status: Cannot be reached 1100
Address 01: Engine (J623-CFHD) Labels: 03L-906-018-CFF.clb
Part No SW: 03L 906 018 CR HW: 03L 906 018 A
Component: R4 2.0l TDI H20 9979
Revision: 43H20--- Serial number:
Coding: 00190012042500080000
Shop #: WSC 12345 210 12345
ASAM Dataset: EV_ECM20TDI0110L3906018CR 003008
ROD: N/A
VCID: 7CF06CDFF7F8C0DE01-8028
No ASAM data for: "EV_ECM20TDI0110L3906018CR" (SE25)
13 Faults Found:
4527 - ROD - Unknown Error Code
- 00 [039]
Fault Status: 00000001
Fault Priority: 2
Fault Frequency: 1
Mileage: 162569 km
Date: 2020.12.18
Time: 00:11:42
4871 - ROD - Unknown Error Code
- 00 [039]
Fault Priority: 2
Fault Frequency: 1
Mileage: 162569 km
Date: 2020.12.18
Time: 00:11:42
4875 - ROD - Unknown Error Code
- 00 [039]
Fault Priority: 2
Fault Frequency: 1
Mileage: 162569 km
Date: 2020.12.18
Time: 00:12:03
5111 - ROD - Unknown Error Code
- 00 [039]
Fault Priority: 2
Fault Frequency: 1
Mileage: 162569 km
Date: 2020.12.18
Time: 00:11:46
5132 - ROD - Unknown Error Code
- 00 [167]
MIL ON - Not Confirmed - Tested Since Memory Clear
Fault Priority: 2
Fault Frequency: 1
Mileage: 162569 km
Date: 2020.12.18
Time: 00:11:41
5177 - ROD - Unknown Error Code
- 00 [167]
Fault Priority: 2
Fault Frequency: 1
Mileage: 162569 km
Date: 2020.12.18
Time: 00:11:41
4238 - ROD - Unknown Error Code
- 00 [039]
Fault Priority: 2
Fault Frequency: 1
Mileage: 162569 km
Date: 2020.12.18
Time: 00:11:42
4881 - ROD - Unknown Error Code
- 00 [039]
Fault Priority: 2
Fault Frequency: 1
Mileage: 162569 km
Date: 2020.12.18
Time: 00:11:42
4900 - ROD - Unknown Error Code
- 00 [039]
Fault Priority: 2
Fault Frequency: 1
Mileage: 162569 km
Date: 2020.12.18
Time: 00:11:42
5169 - ROD - Unknown Error Code
- 00 [167]
Fault Priority: 2
Fault Frequency: 1
Mileage: 162569 km
Date: 2020.12.18
Time: 00:11:42
5282 - ROD - Unknown Error Code
- 00 [039]
Fault Priority: 2
Fault Frequency: 1
Mileage: 162569 km
Date: 2020.12.18
Time: 00:11:42
5325 - ROD - Unknown Error Code
- 00 [167]
Fault Priority: 2
Fault Frequency: 1
Mileage: 162569 km
Date: 2020.12.18
Time: 00:11:42
4278 - ROD - Unknown Error Code
- 00 [167]
Fault Priority: 2
Fault Frequency: 1
Mileage: 162569 km
Date: 2020.12.18
Time: 00:11:42
Readiness: 0 0 0 0 1
Address 03: ABS Brakes (J104) Labels: 6R0-907-37x-ESP82.clb
Part No SW: 6R0 907 379 R HW: 6R0 907 379 R
Component: ESP8.2i front H04 0002
Revision: --------
Coding: 130248DB837000B3C82912EBC1D300821700
Shop #: WSC 04941 000 00000
VCID: 4D96F11B10C2B956E6-8018
4 Faults Found:
00287 - ABS Wheel Speed Sensor; Rear Right (G44)
012 - Electrical Fault in Circuit
Fault Status: 11101100
Fault Priority: 0
Fault Frequency: 58
Reset counter: 88
Mileage: 162569 km
Time Indication: 0
Date: 2015.04.25
Time: 00:07:51
Hex Value: 0x0007
Hex Value: 0x0000
Hex Value: 0x10B1
Hex Value: 0x0992
Hex Value: 0x007F
Hex Value: 0x7F7F
Hex Value: 0x7F00
Hex Value: 0x0000
00290 - ABS Wheel Speed Sensor; Rear Left (G46)
Fault Priority: 0
Fault Frequency: 58
Reset counter: 88
Mileage: 162569 km
Time Indication: 0
Date: 2015.04.25
Time: 00:07:51
Hex Value: 0x0007
Hex Value: 0x0000
Hex Value: 0x10B1
Hex Value: 0x0892
Hex Value: 0x007F
Hex Value: 0x7F7F
Hex Value: 0x7F00
Hex Value: 0x0000
00283 - ABS Wheel Speed Sensor; Front Left (G47)
Fault Priority: 0
Fault Frequency: 19
Reset counter: 88
Mileage: 162569 km
Time Indication: 0
Date: 2015.05.11
Time: 00:01:53
Hex Value: 0x0007
Hex Value: 0x0000
Hex Value: 0x11B1
Hex Value: 0x0698
Hex Value: 0x00FF
Hex Value: 0x7F7F
Hex Value: 0x7F00
Hex Value: 0x0000
00285 - ABS Wheel Speed Sensor; Front Right (G45)
Fault Priority: 0
Fault Frequency: 19
Reset counter: 88
Mileage: 162569 km
Time Indication: 0
Date: 2015.05.11
Time: 00:01:53
Hex Value: 0x0007
Hex Value: 0x0000
Hex Value: 0x11B1
Hex Value: 0x0798
Hex Value: 0x00FF
Hex Value: 0x7F7F
Hex Value: 0x7F00
Hex Value: 0x0000
Part No SW: 6J0 820 043 A HW: 6J0 820 043 A
Component: Climatronic H07 0404
Revision: S0000000
VCID: 224C72A73DDC562E6B-8076
3 Faults Found:
01316 - ABS Control Module
013 - Check DTC Memory
Fault Status: 01101101
Fault Priority: 6
Fault Frequency: 1
Reset counter: 88
Mileage: 162569 km
Time Indication: 0
Date: 2015.05.11
Time: 00:11:42
00457 - Control Module for Network (J519)
Fault Priority: 6
Fault Frequency: 1
Reset counter: 88
Mileage: 162569 km
Time Indication: 0
Date: 2015.05.11
Time: 00:11:42
00797 - Sunlight Photo Sensor (G107)
010 - Open or Short to Plus
Fault Status: 01101010
Fault Priority: 3
Fault Frequency: 1
Reset counter: 88
Mileage: 162569 km
Time Indication: 0
Date: 2015.05.11
Time: 00:11:47
Address 09: Cent. Elect. (J519) Labels: None
Part No SW: 7E0 937 090 C HW: 7E0 937 090 C
Revision: B9082001 Serial number: 4000 300172843
Coding: 3C8829EFC8F32500932000007E0B1EC80080420F60880000200000000000
Shop #: WSC 02739 534 139556
VCID: 2B529F834A169766D8-807E
Subsystem 1 - Part No: 1K0 955 559 AH Labels: 1K0-955-559-AG.CLB
Component: RLS 140411 05 54 0403
Coding: 02242D
Subsystem 2 - Part No: 1K8 951 605
Component: LIN BACKUP HO H09 9002
10 Faults Found:
00329 - Control Circuit for Unlocking Rear Lid
011 - Open Circuit
Fault Status: 01101011
Fault Priority: 2
Fault Frequency: 1
Reset counter: 88
Mileage: 162569 km
Time Indication: 0
Date: 2015.05.11
Time: 00:11:43
00975 - Heated Rear Window (Z1)
011 - Open Circuit
Fault Priority: 3
Fault Frequency: 1
Reset counter: 88
Mileage: 162569 km
Time Indication: 0
Date: 2015.05.11
Time: 00:11:44
00920 - Heated Outside Mirrors; Driver Side (Z4) / Passenger Side (Z5)
011 - Open Circuit
Fault Priority: 3
Fault Frequency: 1
Reset counter: 88
Mileage: 162569 km
Time Indication: 0
Date: 2015.05.11
Time: 00:11:44
03156 - Sensor for Anti-Theft System (G578)
004 - No Signal/Communication
Fault Status: 01100100
Fault Priority: 2
Fault Frequency: 1
Reset counter: 88
Mileage: 162569 km
Time Indication: 0
Date: 2015.05.11
Time: 00:11:47
01332 - Door Control Module; Passenger Side (J387)
Fault Priority: 2
Fault Frequency: 1
Reset counter: 88
Mileage: 162569 km
Time Indication: 0
Date: 2015.05.11
Time: 00:11:47
01331 - Door Control Module; Driver Side (J386)
Fault Priority: 2
Fault Frequency: 1
Reset counter: 88
Mileage: 162569 km
Time Indication: 0
Date: 2015.05.11
Time: 00:11:47
03591 - Control Circuit for Horn
011 - Open Circuit
Fault Priority: 3
Fault Frequency: 1
Reset counter: 88
Mileage: 162569 km
Time Indication: 0
Date: 2015.05.11
Time: 00:11:45
01504 - Bulb for License-Plate Light (X)
Fault Priority: 3
Fault Frequency: 1
Reset counter: 88
Mileage: 162569 km
Time Indication: 0
Date: 2015.05.11
Time: 00:11:43
02195 - Dimmer Switch Instrument Panel & Switch Lighting (E20)
008 - Implausible Signal
Fault Status: 01101000
Fault Priority: 3
Fault Frequency: 1
Reset counter: 88
Mileage: 162569 km
Time Indication: 0
Date: 2015.05.11
Time: 00:11:43
04194 - Unknown Error Code
002 - Lower Limit Exceeded
Fault Status: 01100010
Fault Priority: 3
Fault Frequency: 1
Reset counter: 88
Mileage: 162569 km
Time Indication: 0
Date: 2015.05.11
Time: 00:11:43
Address 15: Airbags (J234) Labels: 5K0-959-655.clb
Part No SW: 6R0 959 655 H HW: 6R0 959 655 H
Component: VW10AirbagA03 H08 0018
Revision: -------- Serial number: 003EQ0000M7T
Coding: 003033
Shop #: WSC 06401 785 00200
ROD: EV_AirbaVW10BPAVW250_SE25.rod
VCID: 479AC333FEBE5306DC-8012
Crash sensor for side airbag; driver side:
Serial number: 3496GRB402JD1BPUPREW
Crash sensor for side airbag; front passenger side:
Serial number: 3506GRB402JD1BPV4J9Y
8 Faults Found:
9437210 - Igniter for Driver's Airbag
B1000 1A [137] - Resistance Too Low
9437723 - Igniter for Passenger's Airbag
B1002 1B [137] - Resistance Too High
Fault Priority: 2
Fault Frequency: 1
Mileage: 162569 km
Date: 2020.12.18
Time: 00:11:46
9440000 - Driver's side; side-airbag igniter
B100B 00 [000] - -
Intermittent - Not Confirmed - Tested Since Memory Clear
0000 - Internal Control Module Memory Check Sum Error
B2000 00 [000] - -
Fault Priority: 1
Fault Frequency: 254
Reset counter: 0
Mileage: 0 km
Date: 2000.00.00
Time: 00:00:00
B2000 00 [000] - -
Fault Priority: 1
Reset counter: 0
Mileage: 0 km
Date: 2000.00.00
Time: 00:00:00
B2000 00 [000] - -
Fault Priority: 1
Reset counter: 0
Mileage: 0 km
Date: 2000.00.00
Time: 00:00:00
B2000 00 [000] - -
Fault Priority: 1
Reset counter: 0
Mileage: 0 km
Date: 2000.00.00
Time: 00:00:00
B2000 00 [000] - -
Fault Priority: 1
Reset counter: 0
Mileage: 0 km
Date: 2000.00.00
Time: 00:00:00
Address 17: Instruments (J285) Labels: 5K0-920-xxx-17.clb
Part No SW: 6J0 920 901 C HW: 6J0 920 901 C
Component: KOMBI H08 0110
Coding: 410800
Shop #: WSC 06403 785 00200
ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A04040
ROD: EV_Kombi_UDS_VDD_RM09_SE25.rod
VCID: 2858608F53E0BC7E35-807C
2 Faults Found:
13637376 - Please Check Fault Codes in Control Module for ABS Brakes
U1017 00 [009] - -
Fault Priority: 6
Fault Frequency: 1
Reset counter: 88
Mileage: 162569 km
Date: 2020.12.18
Time: 00:11:40
12653568 - Function Restricted due to Missing Message(s)
U1111 00 [009] - -
Fault Priority: 6
Fault Frequency: 1
Reset counter: 88
Mileage: 162569 km
Date: 2020.12.18
Time: 00:11:40
Address 19: CAN Gateway (J533) Labels: None
Part No SW: 7E0 909 901 HW: 7E0 937 090 C
Revision: B9082001
Coding: 042307
VCID: 68D8208F9B607C7EF5-803C
3 Faults Found:
000 - -
Fault Status: 01100000
Fault Priority: 2
Fault Frequency: 1
Reset counter: 255
Mileage: 162569 km
Time Indication: 0
Date: 2015.05.11
Time: 00:11:42
01324 - Control Module for All Wheel Drive (J492)
Fault Priority: 2
Fault Frequency: 1
Reset counter: 88
Mileage: 162569 km
Time Indication: 0
Date: 2015.05.11
Time: 00:11:43
01304 - Radio
Fault Priority: 2
Fault Frequency: 1
Reset counter: 88
Mileage: 162569 km
Time Indication: 0
Date: 2015.05.11
Time: 00:11:47
Address 22: AWD Labels: 1K0-907-554.lbl
Part No: 1K0 907 554 F
Component: Haldex 4Motion 0115
Coding: 0000001
Shop #: WSC 00000 000 00000
VCID: 306888EFA330F4BEED-8064
4 Faults Found:
01314 - Engine Control Module
00778 - Steering Angle Sensor (G85)
01317 - Control Module in Instrument Cluster (J285)
Address 25: Immobilizer (J334) Labels: 5K0-920-xxx-25.clb
Component: IMMO H08 0110
Serial number:
ASAM Dataset: EV_Immo_UDS_VDD_RM09 A03004
ROD: EV_Immo_UDS_VDD_RM09_SE25.rod
Part No: 6R0 423 156 B
Component: LenkhilfeTRW V277
Coding: 11221
Shop #: WSC 06403
VCID: 2F6A8B93EA0EEB46F4-807A
2 Faults Found:
49-10 - No Communications - Intermittent
79-00 - Please Check Fault Codes
Address 56: Radio
Cannot be reached
End-------------------------(Elapsed Time: 02:10)--------------------------
Unfortunately the coding you provided didnt solve the auto light or the interior light issue
I just checked the auto lights feed (T17/12 - T73a/37) and with auto lights on, it is permanent 12V all the time
