iichel wrote: Mon Aug 27, 2018 9:27 pm Is the other connector, the T2, for your garage door remote control?
Nope ... some clues...
:lol:
Ah the laser guided machine guns. Not for road use.
The OSRAM LED lamps that I showed you is the only thing that is not for road use (only OFF road use). The rest of the installation is correct... someone will have to invent new rules for these NEW unknown lights. :lol:
The reason why I use these LED lamps is for the simple fact that they emit a perfect white light, they are not annoying at all for the vision.
Clarification: I absolutely agree with the ECE standards regarding the ilegal use of LED lamps in spotlights for standard bulbs.
headRest = +5hp ... :lol:
:lol:
Wednesday,29,August,2018,12:03:12:32438
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 7 x64
VCDS Version: 18.2.1.2 (x64)  HEX-V2 CB: 0.4411.4
Data version: 20180518 DS287.1
www.Ross-Tech.com
VIN: WVWZZZ6RZDY0CICLO   License Plate: BATTERY MONITORING (deep overhaul)
Mileage: 30260km-18802mi   Repair Order:
Chassis Type: 6R-VW25 (7E0)
Scan: 01 03 04 08 09 10 15 17 19 20 25 2E 37 44 55 56 61 65 77
VIN: WVWZZZ6RZDY0CICLO   Mileage: 30260km-18802miles
56-Radio -- Status: OK 0000
Address 01: Engine (J623-CBZC)       Labels:. 03F-906-070-CBZ.clb
   Part No SW: 03F 906 070 GD    HW: 03F 907 309 AJ
   Component: SIMOS10.22AH10 5466
   Revision: --H10---    Serial number: 00000000000000
   Coding: 001100D6202400080000
   Shop #: WSC 00788 648 00255
   ASAM Dataset: EV_ECM12TFS02103F906070GD 004007
   ROD: EV_ECM12TFS02103F906070FP.rod
   VCID: 6A8D3FD44CF80237CF3-803E
Readiness: 0110 0101
Address 03: ABS Brakes (J104)       Labels:. 6R0-907-37x-ESP82.clb
   Part No SW: 6R0 907 379 BE    HW: 6R0 907 379 AF
   Revision: --------
   Coding: 210228E3216D00B5842814EA84D300401700
   Shop #: WSC 40308 002 104857
   VCID: 025D77745448FA77673-8056
   Serial number: 08021613470174
   Coding: 01
   ROD: EV_LWSKLOVW25X.rod
   VCID: 7EA5038420709E9703B-802A
   Part No SW: 6R0 907 044 H    HW: 6R0 907 044 H
   Component: Climatronic   H11 0711
   Revision: V0000000
   VCID: 3829D59C425460A7897-806C
   Part No SW: 7E0 937 090 C    HW: 7E0 937 090 C
   Revision: B9082001    Serial number: 4000 122170091
   Coding: 3CB02FBF48E12400B3380F317CEB9FDC5AC0670F600D30D0200000030800
   VCID: 2B03FAD08302DB3FF45-807E
   Component: RLHS 220816 0  42  0106
   Coding: 0728DD
   Subsystem 2 - Part No SW: 6R0 959 801 BD    HW: 6R0 959 801 BD  Labels: 6R0-959-801.CLB
   Component: J386__TSG_FT  003 8612
   Serial number: KU0KU003041440937042
   Coding: 0200A3
   Subsystem 3 - Part No SW: 6R0 959 802 BF    HW: 6R0 959 802 BF  Labels: 6R0-959-802.CLB
   Component: J387__TSG_BT  003 8612
   Serial number: KU0KU006031440656541
   Coding: 1000A3
   Subsystem 5 - Part No: 1K8 951 605 B
   Component: LIN BACKUP HO  H11 9005
   Subsystem 7 - Part No SW: 1K8 959 442     HW: 1K8 959 442
   Component: E221__MFL-DC1  H03 0103
   Serial number: 27140003142720054516
   Coding: A4FFFF
   Subsystem 8 - Part No SW: 6R0 959 811 G    HW: 6R0 959 811 G
   Component: J388__TSG_HL  008 1611
   Serial number: KU0KU003051200017821
   Coding: 18BC32
   Subsystem 9 - Part No SW: 6R0 959 812 G    HW: 6R0 959 812 G
   Component: J389__TSG_HR  008 1611
   Serial number: KU0KU010051200012315
   Coding: 18BC32
   Part No SW: 7E0 919 475 AA    HW: 7N0 919 475
   Component: PARKHILFE 8K  H06 0212
   Revision: --------    Serial number: 28231708304294
   Coding: 308001
   Shop #: WSC 02739 790 50316
   ASAM Dataset: EV_VW75XParkAssis8K 001012
   VCID: 71BF28B8612EF1EF8E9-8024
   Component: VW10Airbag01M H10 0020
   Revision: --------    Serial number: 003GX01JKVVP
   Coding: 00314D
   Shop #: WSC 01383 785 00200
   ROD: EV_AirbaVW10BPAVW250.rod
   VCID: 4ACD9F542C38E237EF3-801E
   Serial number: 3575HRB405N1C4LI7929
   Serial number: 3585HRB405B1D5MS8GS2
   Serial number: 3515RRB405B17ABS901.
   Serial number: 3525RRB405B181TUDPKC
   Part No SW: 6RD 920 870 A    HW: 6RD 920 870 A
   Component: KOMBI         H04 0805
   Coding: 140E01
   Shop #: WSC 00233 572 00000
   VCID: 47CBA6603F2A1F5FF0D-8012
   Part No SW: 7E0 909 901     HW: 7E0 937 090 C
   Revision: B9082001
   Coding: 002200
   VCID: 688945DC52743027D97-803C
   Revision: AA001001
   Coding: 0404001C00000000000000
   Shop #: WSC 03607 002 104857
   VCID: 2E05F3C4B090AE17D3B-807A
   Component: IMMO          H04 0805
   Shop #: WSC 00000 000 00000
   ROD: EV_Immo_UDS_VDD_RM09.rod
   Part No SW: 5N0 035 342 F    HW: 5N0 035 342 F
   Component: SG EXT.PLAYER H18 0530
   Revision: A1001003    Serial number: 7662584630
   Coding: 010100
   VCID: 2A0DFFD48CF8C2370F3-807E
Address 37: Navigation (J0506)       Labels:. 1T0-035-680.clb
   Part No SW: 1T0 035 680 L    HW: 1T0 035 680 C
   Component: RNS-MID       H06 5274
   Revision: AB001001    Serial number: VWZ6Z7L7654213
   Coding: 04000442040000A10001
   Shop #: WSC 12345 123 12345
   VCID: 372BD6A04F4A6FDF80D-8062
   Subsystem 1 - Part No: 1T0 919 859 B
   Component: EU West V15  8515
   Part No: 6R0 423 156 B
   Coding: 11250
   Shop #: WSC 00788
   VCID: 2F3BEEC0BE5AA71FD8D-807A
   Revision: --------    Serial number: --------------
   Coding: 0112000001000000
   VCID: 77AB16A00F4AAFDF40D-8022
Address 56: Radio (J0506)       Labels:. 1T0-035-680.clb
   Part No SW: 7E0 907 534     HW: 7E0 937 090 C
   Component: Batt.regelung H82 0752
   Coding: 02200864
   Subsystem 1 - Part No SW: 6C0 915 181 B    HW: 6C0 915 181 B
   Component: J367-BDM  H08 0270
   Serial number: 53337D48375881021946
   Serial number: 40000000050821
   ROD: EV_RDKBERU30_005.rod
   VCID: 372BD6A04FCA6FDF80D-8062
Address 77: Telephone (J412)       Labels:| 7P6-035-730.clb
   Part No SW: 7P6 035 730 L    HW: 7P6 035 730 L
   Component: TELEFON       H15 3200
   Revision: 1B001001    Serial number: 00007664158506
   Coding: 0501000000010110
   ASAM Dataset: EV_UHVNA 002720
   ROD: EV_UHVNA_002.rod
   VCID: 3B23CA9073E24BBF645-806E
End----------(Elapsed Time: 02:07, VBatt start/end: 13.4V/13.4V)-----------
8)
:lol:
EdgardoRodriguez
Drives: other
Post by EdgardoRodriguez »
What can you Tell us about battery regulator enabled ? Any pros/cons ?
:arrow: https://uk-polos.net/viewtopic.php?f=56 ... 68#p538668 ... :arrow: https://www.drive2.ru/l/457363852879727312/
Pros: It's what I intend to find out.
At a first contact... some interesting values in the measurement blocks (with VCDS).
Cons: By the moment, the weight added to the total weight of the car ... a few grams. :lol:
I'll do my research with two different types of ground wires. (6C0 and 7E0 :mrgreen:)
ciclo wrote: Thu Aug 30, 2018 8:48 pm Image
They will provide security and lighting just when you need them most.
dust
Drives: VW POLO Bluegt 150 DSG
Post by dust »
Amazing build! So much knowledge & information!!
ORiOn
Drives: Polo BlueGT / Audi S5
Post by ORiOn »
Are you adding corner light to the bumper(anti-fog light) to? As a plus from the one already on the headlight? :D
dust wrote: Fri Aug 31, 2018 12:44 pm Amazing build! So much knowledge & information!!
Thank you very much and welcome!
(note: I've already read your thread ... now I'm on vacation)
ORiOn wrote: Fri Aug 31, 2018 3:25 pm Are you adding corner light to the bumper(anti-fog light) to? As a plus from the one already on the headlight? :D
Nope... :lol:
stay tunned
(results)
Locked
