ciclo. Wife's Golf MK7.5 Ready2Go 1.0 TSI 6MT 200Nm/l 115HP. 🧙‍♂️
Locked
Re: ciclo. Wife's Golf MK7.5 Ready2Go 1.0 TSI 6MT 200Nm/l 115HP. First and Last pages UPDATED !!!
Golf 7.5 Wireless Charger with GSM/LTE Amplifier. Installation.
Previous information:
- viewtopic.php?p=587939#p587939
- viewtopic.php?p=587962#p587962
- viewtopic.php?p=588003#p588003
Rear area.
Route the wires to the front area parallel to the original wiring.
Note due to a question by email:
In the video of the RVC High installation you can see which trims/parts were removed to run the wires from the shark antenna to the GSM/LTE Amp:
https://www.youtube.com/watch?v=52lwjs4grZU
Front area.
Wiring for multi-color ambient light.
5F connections.
Wireless charger connections.
Fusebox.
4 fuses :arrow: viewtopic.php?p=574274#p574274
BCM.
Earth.
🍻 A couple of beers so I don't get depressed... 😆
VCDS coding.
Wireless charger + GSM/LTE Amplifier. "Discover Media"
5F
Coding:
Byte8 Bit4  AUX-IN connection ... disable
Byte15 Bit0  Telefhone baseplate installed ... enable
Byte15 Bit1  Telephone Antenna Baseplate installed ... enable
Byte15 Bit5  Wireless charging availability  ... enable (note: displays the LTE icon)
Result.
Wireless charging.
Aux-in off. LTE icon. Laptop connection.
It seems that in Discover Media it is not possible to display the Qi icon just to the right of the telephony signal level (I have tried to code some related things, but just wasted my time 😶).
Multicolor Ambient Light.
To be "Ambient" light it is enough, but NOT to illuminate objects clearly.
VCDS Autoscan
Saturday,05,February,2022,20:04:12:32438
VCDS Version: 21.9.0.2 (x64)  HEX-V2 CB: 0.4555.4
Data version: 20210903 DS330.0
www.Ross-Tech.com
VIN: WVWZZZAUZKPCICLOW   License Plate: WIRELESS CHARGER + GSM/LTE AMPLIFIER. OK!
Mileage: 41451km-25756mi   Repair Order:
Chassis Type: AU-VW37 (3Q0)
Scan: 01 03 08 09 10 13 15 17 19 29 39 3C 42 44 4B 52 5F 65 6C A5
          A9 D6 D7
VIN: WVWZZZAUZKPCICLOW   Mileage: 41451km-25756miles
29-Left Light -- Status: OK 0000
39-Right Light -- Status: OK 0000
42-Door Elect, Driver -- Status: OK 0000
4B-Multifunc. Module -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
A5-Frt Sens. Drv. Assist -- Status: OK 0000
A9-Struct. Borne Sound -- Status: OK 0000
D6-Light Ctrl Left 2 -- Status: OK 0000
D7-Light Ctrl Right 2 -- Status: OK 0000
Address 01: Engine (J623-DKRF)       Labels:. 04E-907-309-V1.clb
   Part No SW: 04C 906 025 L    HW: 04C 907 309 BB
   Component: R3 1.0l TFS   H20 6198
   Revision: D7H20000    CVN: 92B19492
   Coding: 01190032234415082000
   Shop #: WSC 00046 123 12345
   ASAM Dataset: EV_ECM10TFS01104C906025L 002003
   ROD: EV_ECM10TFS01104C906025L_002.rod
   VCID: 290F00D8897EC923D0F-807C
   VINID: 9E69EAAAA465A9B8000041051C011774D2
Readiness: 0110 0001
Address 03: ABS Brakes (J104)       Labels: 5Q0-907-379-IPB-V1.clb
   Part No SW: 5Q0 614 517 DD    HW: 5Q0 614 517 AC
   Component: ESC           H25 0424
   Revision: 00000000    Serial number: 51998000000173
   Coding: 01FA6AA114202170477B060560CA2580562884E26006A4733420F00A40AA430B00000012121212B835351919323200
   ASAM Dataset: EV_Brake1UDSContiMK100IPB 037009
   ROD: EV_Brake1UDSContiMK100IPB_037_VW37.rod
   VCID: 76B51BA40840D6DB8DD-8022
Address 08: Auto HVAC (E87)       Labels:| 5G0-907-044.clb
   Part No SW: 5NA 907 044 AJ    HW: 5NA 907 044 AJ
   Component: AC Automat    H50 1301
   Revision: 20K03000    Serial number: 00000A00202735
   Coding: 000200032001100D110500400010142A
   Shop #: WSC 12345 123 12345
   ASAM Dataset: EV_ACTouchPrehVW37X 001010
   ROD: EV_ACTouchPrehVW37X_VW37.rod
   VCID: 074B66607FAADF53E6B-8052
   Air quality sensor:
Address 09: Cent. Elect. (J519)       Labels:. 5Q0-937-08X-V2.clb
   Part No SW: 5Q0 937 084 DH    HW: 5Q0 937 084 CG
   Component: BCM MQBAB H   H40 0312
   Serial number: 72007150025702
   Coding: 000000000000000000000000000000000000000000000000000000000000
   ASAM Dataset: EV_BCMMQB 020001
   ROD: EV_BCMBOSCH_020.rod
   VCID: 015F7878518EE163A8F-8054
   Wiper motor control module:
   Subsystem 1 - Part No SW: 5G1 955 119 A    HW: 5G1 955 119 A  Labels: 5QX-955-119-V1.CLB
   Component: WWS    180621  043  0551
   Serial number:         180705074106
   Coding: 0F4DFD
   Rain/Light Recognition Sensor:
   Subsystem 2 - Part No SW: 5Q0 955 547 B    HW: 5Q0 955 547 B  Labels: 5Q0-955-547.CLB
   Component: RLHS  052  0107
   Serial number: S5Y20M05D14H05M53S24
   Coding: 06A8DD
   Anti-theft alarm system sensor:
   Subsystem 3 - Part No SW: 5Q0 951 172     HW: 5Q0 951 172
   Component: Sensor, DWA  005  0316
   Serial number: 000000000ZY191251XZQ
   Alarm horn:
   Subsystem 4 - Part No SW: 5QD 951 605     HW: 5QD 951 605
   Component: Sirene, DWA  005  0313
   Serial number: 00002854456462182207
   Steering Column Switch:
   Subsystem 5 - Part No SW: 5Q1 953 507     HW: 5Q1 953 549
   Component: J527 SMLS MQB  004  0060
   Serial number: 00000002081804401346
Address 10: Park/Steer Assist (J791)       Labels:| 5Q0-919-298.clb
   Part No SW: 5QA 919 298 D    HW: 5QA 919 298 A
   Component: PLA 3.0 12KH07 0050
   Serial number: 000308417318277
   Coding: 0271167841
   ASAM Dataset: EV_EPHVA2CAU3700000 009041
   ROD: EV_EPHVA2CAU3700000.rod
   VCID: 51FF8838C16ED1E378F-8004
Address 13: Auto Dist. Reg (J428)       Labels:* None
   Part No SW: 5Q0 907 572 S    HW: 3QF 907 572 A
   Component: ACC BOSCH MQB H11 0780
   Coding: 2B056FE35DFFC728979D81A461400600000000000010000004
   ASAM Dataset: EV_ACCBOSCHVW416 003015
   ROD: EV_ACCBOSCHVW416_003_VW37.rod
   VCID: 47CBA6603F2A1F5326B-8012
Address 15: Airbags (J234)       Labels:| 5Q0-959-655.clb
   Part No SW: 5Q0 959 655 BJ    HW: 5Q0 959 655 BJ
   Component: AirbagVW21    006 0339
   Serial number: 003VWR4F1CUQ
   Coding: 98CCC000000000005C0000CF000800000065
   Shop #: WSC 00028 028 00064
   ASAM Dataset: EV_AirbaVW20SMEVW37X 002160
   ROD: EV_AirbaVW20SMEVW37X_VW37.rod
   VCID: 094F605869BEA923F0F-805C
   Left seat belt tensioner:
   Subsystem 1 - Part No SW: 5G0 980 945 B    HW: 5G0 980 945 B
   Component: BeltPretRevFL  H37 0350
   Serial number: 34169667E30071820325
   Coding: 333135
   Right seat belt tensioner:
   Subsystem 2 - Part No SW: 5G0 980 946 B    HW: 5G0 980 946 B
   Component: BeltPretRevFR  H37 0350
   Serial number: 34169668E31071830145
   Coding: 333135
   Subsystem 3 - Part No SW: -----------    HW: 480 002 307 18
   Component: SideSensor_Df  001 0887
   Serial number: 35700000000F8745C23S
   Coding: 2D2D2D
   Subsystem 4 - Part No SW: -----------    HW: 480 002 807 18
   Component: SideSensor_Pf  001 0887
   Serial number: 358000000000EC18233G
   Coding: 2D2D2D
   Subsystem 5 - Part No SW: -----------    HW: 480 403 107 18
   Component: SideSensor_Dr  003 6149
   Serial number: 3510001A729FD154210-
   Coding: 2D2D2D
   Subsystem 6 - Part No SW: -----------    HW: 480 403 107 18
   Component: SideSensor_Pr  003 6149
   Serial number: 3520001A929FD1515577
   Coding: 2D2D2D
   Subsystem 7 - Part No SW: -----------    HW: 480 402 306 18
   Component: FrontSensor_D  003 6149
   Serial number: 3550001A326704A3C63.
   Coding: 2D2D2D
Address 17: Instruments (J285)       Labels:| 5G0-920-XXX-17.clb-SRI3
   Part No SW: 5G1 920 791 B    HW: 5G1 920 791 B
   Component: KOMBI         404 4191
   Coding: 07A532806E8C000801887A0F5401000080000000
   Shop #: WSC 00200 935 01530
   ASAM Dataset: EV_DashBoardVDDMQBAB 009058
   ROD: EV_DashBoardVDDMQBAB_009_VW26.rod
   VCID: 2B03FAD08382DB33223-807E
Address 19: CAN Gateway (J533)       Labels:| 3Q0-907-530-V1.clb
   Part No SW: 3Q0 907 530 AC    HW: 3Q0 907 530 C
   Component: GW MQB High   521 5388
   Serial number: 09012020001767
   Coding: 030100047F085700DB0002FE080F00010001070000000000000000000000
   GVL: 014E3C100000000040CC80000002480000000000000200000000000000000000
   ASAM Dataset: EV_GatewNF 013026
   ROD: EV_GatewNF_VW37.rod
   VCID: 70B92DBC6A24F8EB571-8024
   Generator:
   Component: 4-01-02-01-04
   Multifunction steering wheel control module:
   Subsystem 2 - Part No SW: 5G0 959 442 AB    HW: 5G0 959 442 AB  Labels: 3C8-959-537.CLB
   Component: E221__MFL-MD9  H18 0052
   Serial number: 39190002063230049307
   Coding: 2CFFFF
   Subsystem 3 - Part No SW: 5Q0 915 181 K    HW: 5Q0 915 181 K
   Component: J367-BDMHella  H10 9070
   Serial number: 9353818504
Address 29: Left Light (J1018)       Labels: 8V0-907-399.clb
   Part No SW: 8V0 907 399 D    HW: 8V0 907 399 D
   Component: LCM_MLBevoH08 0014
   ASAM Dataset: EV_LCMLeftHELLAAU736 001012
   ROD: EV_LCMLeftHELLAAU736_VW37.rod
Address 39: Right Light (J1023)       Labels: 8V0-907-399.clb
   ASAM Dataset: EV_LCMRightHELLAAU736 001012
Address 3C: Lane Change (J1086)       Labels:| 5Q0-907-686.clb
   Component: HRE_Master    H12 0081
   Serial number: 0519386082
   Coding: 02011103
   ROD: EV_HREntryHella_VW37.rod
   VCID: 3D27C4886DF645838C7-8068
   Lane change assistance control module 2:
   Subsystem 1 - Part No SW: 5Q0 907 685 C    HW: 5Q0 907 685 C
   Component: HRE_Slave  H12 0081
   Serial number: 0519601132
   Coding: 020111
Address 42: Door Elect, Driver (J386)       Labels:| 5QX-959-X93-42.clb
   Part No SW: 5Q4 959 593 F    HW: 5Q4 959 593 F
   Component: TSG FS        006 0246
   Serial number: 0000305474246
   Coding: 00150220D000048000001001
   Shop #: WSC 00020 999 12345
   ASAM Dataset: EV_DCU2DriveSideMAXHCONT 001005
   ROD: EV_DCU2DriveSideMAXHCONT_VW37.rod
   VCID: 48C9A55C3234102B2F1-801C
   Rear Driver Side Door Control Module:
   Subsystem 1 - Part No SW: 5Q4 959 811 F    HW: 5Q4 959 811 F  Labels: 5QX-959-81X-V1.CLB
   Component: Fond FHSG DRV  010 0004
   Serial number: 00000000000009798407
   Coding: 010000
Address 44: Steering Assist (J500)       Labels:| 5Q0-909-144.clb
   Part No SW: 5Q0 909 144 AA    HW: 5Q0 909 144 AA
   Component: EPS_MQB_ZFLS  131 1081
   Coding: 931F0000
   Shop #: WSC 12345 102 209715
   ASAM Dataset: EV_SteerAssisMQB 015157
   ROD: EV_SteerAssisMQB_015.rod
   VCID: 73B322B01B32C3F3AA3-8026
Address 4B: Multifunc. Module (J745)       Labels:| 3Q0-907-338-V2.clb
   Part No SW: 3Q0 907 338 E    HW: 3Q0 907 338 E
   Component: FCM MQB Low   003 0367
   Serial number: 01081930001280
   Coding: 00000005090016C200205F03020000000000000000000000000000000000
   ASAM Dataset: EV_MultiModulContiVW48X 003003
   ROD: EV_MultiModulContiVW48X_003_VW27.rod
   VCID: 372BD6A04FCA6FD356B-8062
Address 52: Door Elect, Pass. (J387)       Labels:| 5QX-959-X92-52.clb
   Part No SW: 5Q4 959 592 F    HW: 5Q4 959 592 F
   Component: TSG BFS       006 0246
   Serial number: 0000336638884
   Coding: 00150220DE00048000001001
   Shop #: WSC 00028 028 00068
   ASAM Dataset: EV_DCU2PasseSideMAXHCONT 001005
   ROD: EV_DCU2PasseSideMAXHCONT_VW37.rod
   Rear Passenger Door Control Module:
   Subsystem 1 - Part No SW: 5Q4 959 812 F    HW: 5Q4 959 812 F  Labels: 5QX-959-81X-V1.CLB
   Component: Fond FHSG PSG  010 0004
   Serial number: 00000000000009846262
   Coding: 090000
   Part No SW: 3Q0 035 874 C    HW: 3Q0 035 874 C
   Component: MU-S-ND-ER    853 0891
   Serial number:
   Coding: 02731001FF0000004111000100880A231F0507E401200400CF
   ASAM Dataset: EV_MUStd4CDELP 001001
   ROD: EV_MUStd4CDELP_VW26.rod
   VCID: 323DE7B4A4A88AFB615-8066
   Display and control head 1 for information electronics:
   Subsystem 1 - Part No SW: 5G6 919 605 B    HW: 5G6 919 605 B
   Component: ABT_Std-2_Nav  H52 8130
   Serial number: VWZ6ZHV2691212
   Data carrier:
   Subsystem 2 - Part No SW: 5NA 919 866 CA    HW: -----------
   Component: ECE AS 22/23  --- 1810
   Part No SW: 5Q0 907 273 B    HW: 5Q0 907 273
   Component: RDKBERU30     H04 0009
   Serial number: 30000000250801
   ASAM Dataset: EV_RDKBERU30 006001
   ROD: EV_RDKBERU30_006_VW37.rod
   VCID: 3431E1AC5EBC84CB739-8060
Address 6C: Back-up Cam. (J772)       Labels:| 5Q0-980-556.clb
   Part No SW: 5Q0 980 556 B    HW: 5Q0 980 556 B
   Component: RVC Compact   H18 0231
   Coding: 01844201C600201F000060
   ASAM Dataset: EV_CamSysRVRVCPANAMQBAB 006009
   ROD: EV_CamSysRVRVCPANAMQBAB.rod
   VCID: 392FD09879DE79A3A0F-806C
Address A5: Frt Sens. Drv. Assist (R242)       Labels:| 3Q0-980-65X-A5.clb
   Part No SW: 3Q0 980 654 L    HW: 3Q0 980 654 A
   Component: MQB_B_MFK     H10 0610
   Serial number: 28011912K23389
   Coding: 000307000000040100221354C156A90094000E33004000
   ASAM Dataset: EV_MFKBoschMQBB 002041
   ROD: EV_MFKBoschMQBB_002.rod
   VCID: 40D9BD7C1A04286BE71-8014
Address A9: Struct. Borne Sound (J869)       Labels: 4H0-907-159.clb
   Part No SW: 5F0 907 159     HW: 4H0 907 159 A
   Component: SAS-GEN 2     H07 Z001
   Serial number: 181027201414
   ASAM Dataset: EV_SoundActuaGen2AU64X 003010
   ROD: EV_SoundActuaGen2AU64X.rod
   VCID: 6A8D3FD44CF8023B195-803E
Address D6: Light Ctrl Left 2 (A31)       Labels: 7PP-941-572.clb
   Part No SW: 7P5 941 572 A    HW: 7P5 941 572 A
   Component: LED1L         H06 0002
   ASAM Dataset: EV_LEDMinMaxL_KEBODAVW481 001003
   ROD: EV_LEDMinMaxL_KEBODAVW481.rod
Address D7: Light Ctrl Right 2 (A27)       Labels: 7PP-941-572.clb
   Component: LED1R         H06 0002
   ASAM Dataset: EV_LEDMinMaxR_KEBODAVW481 001003
   ROD: EV_LEDMinMaxRKEBODVW481.rod
End----------(Elapsed Time: 01:28, VBatt start/end: 13.3V/13.3V)-----------
Edit. 28th March.
LTE amplifier + Qi are great for making Wi-Fi connections with the smartphone as a hotspot for "multiple" devices.
Everything works at lightning speed. 💪
I guess it will work a lot of better for 5G networks.
I think that this is the true intention of the amplifier. It is not for better coverage in distant or lost places far from civilization.
Fantastic!!! I already have my Eiffel Tower.
https://www.youtube.com/watch?v=6f7pgA0riU8 🤭
:arrow: viewtopic.php?p=587667#p587667
... if you remember.
:arrow: viewtopic.php?p=579233#p579233 , previous info, previous info, previous info ... hmm ... those who use the wonderful smartphone or finger devices to view the information will have a very difficult time.
Tip: throw the f smartphone 🐵 in the trash and use the smartlaptop 👨‍🎓. 😁
Think that in a not too distant future the dimension of the screen will be the entire visual spectrum that you will have in front of your eyes.😲
https://www.youtube.com/watch?v=r18IwJ0SS30
USB C-type for rear charging. With nice and successful ambient LED lights (58d).
Previous info:
- viewtopic.php?p=588693#p588693
- viewtopic.php?p=574733#p574733
Previous info:
- viewtopic.php?p=582082#p582082
https://www.youtube.com/watch?v=YVkUvmD ... 3HY&t=108s
T16. Original Stalks and Ring.
👨‍❤️‍👨 These two are in love (SW/HW), referring to the fact that today is Valentine's Day. :)
T14. New Stalks and Ring.
1 of 5. Testing processes will begin at the end of next week.
https://www.youtube.com/watch?v=dzTAPY4uEYE
Discover Media MIB 2.5 Delphi Firmware Update. From 0891 to 0879.
💎Original Video :arrow: :arrow: :arrow: : https://www.youtube.com/embed/IzD2aqnko ... autoplay=1
:arrow: https://www.drive2.ru/l/592358317125313617/
As explained in D2 thread, it's an upgrade, not a downgrade.
A million thanks to Borntotilt and Slavik.💎🤗
Update!! February 27, 2022
Some time ago I detected that with FW 0891 a fault was hung in the diagnosis if DAB stations were not detected, which makes no sense if the DAB+ system is properly installed.
With the new FW 0879 this is also solved... perfect!!!🧙‍♂️
Autoscan
(diagnosis checked in several places and several times by turning ignition switch off/on)
Sunday,27,February,2022,12:46:02:32438
www.Ross-Tech.com
VIN: WVWZZZAUZKPCICLOW   License Plate: DAB+ OK!!! (Solution = 5F = 0879 FW)
Mileage: 41669km-25891mi   Repair Order:
          A9 D6 D7
VIN: WVWZZZAUZKPCICLOW   Mileage: 41669km-25891miles
Readiness: 0000 0000
   Coding: 000200032001100D1105004C0018542A
   Air quality sensor:
   Coding: 0F4DFD
   Coding: 06A8DD
   Alarm horn:
   Subsystem 5 - Part No SW: 5Q1 953 507 GA    HW: 5Q1 953 549 F
   Component: J527 SMLS MQB  005  0080
   Serial number: 00000015072008490816
   Coding: 0271167841
   Coding: 2B057FE35DFFC728979F81A461400600000000000010000004
   Coding: 333135
   Coding: 333135
   Coding: 2D2D2D
   Coding: 2D2D2D
   Coding: 2D2D2D
   Coding: 2D2D2D
   Coding: 2D2D2D
   Coding: 030900047F085700DB0002FE080F00010001070000000000000000000000
   Generator:
   Subsystem 2 - Part No SW: 1EA 959 442 A    HW: 1EA 959 442 A
   Component: MFL  H03 0217
   Serial number: 17038312063192001134
   Coding: 8E0900
   Coding: 02011103
   Coding: 020111
   Coding: 010000
   Coding: 931F0000
   Coding: 090000
   Component: MU-S-ND-ER    853 0879
   Serial number:
   Coding: 02731001FF0000004111010100880A231F0507E401200400CF
   Data carrier:
End----------(Elapsed Time: 01:28, VBatt start/end: 12.6V/12.7V)-----------
https://www.youtube.com/watch?v=ciIMuYkrU7I&t=64s ... 😁
Control unit for steering wheel contact detection (J1158). (3G0959542)
Test conditions:
With 3Q0 camera.
... with VCDS ...
As expected, from the information provided by Slavik in his D2 thread, the steering wheel contact recognition unit does not work in these conditions, but it is necessary to code its presence because the GW LIN detects the installation of new components.
It's reported in the diagnosis... once coded, the fault disappears after Clear All DTCs.
I will also test a new 3G0959542A unit with a higher SW under similar conditions (3Q0 - Assistants),
but will do so with the Top Sport steering wheel and capacitive buttons. :arrow: viewtopic.php?p=588143#p588143
Before, I will post the info about the Heated MFSW.😍
Golf 7.5 Heated MFSW retrofitted-installed. (1 of 5)
Previous info:
- Read the previous page, this page and what will come...
💎Original Video :arrow: :arrow: :arrow: : https://www.youtube.com/embed/KlyBDxrrz ... autoplay=1
Coding.
19 GW
Adaptation
[VO]_Multi_function_steering_wheel_control_module Coding Value:
[LN]_Tiptronic:	[VN]_not installed
[LN]_Temp Sensor:	[VN]_installed
[LN]_variant:	[VN]_ACC-High
[LO]_clamp behaviour:	[VN]_active with clamp 58
[LN]_Heated_steering_wheel_button:	[VN]_active
[LO]_FoD ACC:	[VN]_automatic
[LO]_FoD Travel Assist:	[VN]_automatic
[LN]_Wake_up_ability_signal_horn:	[VN]_active
[LN]_Switch_speed_limiter:	[VN]_active
[LO]_Kombi_02_gueltig:	[VN]_not active
[LN]_double_stage_support:	[VN]_not active
[LN]_Platform:	[VN]_MQB
08 CLIMATRONIC
Coding
[LN]_steering wheel heater:	[VN]_installed
[LN]_Heated_steering_wheel_steps:	[VO]_mehrstufig
[LN]_Frequency_shift:	[VN]_Not_activated
[LN]_Blower display during auto mode:	[VN]_activated
[LN]_Blower_characteristic:	[VN]_Setup_normal
[LN]_Temperature_setup:	[VN]_Normal_setup
[LN]_fresh_air_blower_front:	[VN]_According to function preconditions
[LN]_Reinforced_overshoot_heating_mode:	[VN]_Not_activated
[LN]_Heated_steering_wheel_automatic_mode:	[VO]_Aussentemperatur
[LN]_Compressor_start_reduction:	[VN]_activated
[LN]_Seat_Heating_rear:	[VN]_not installed
[LN]_Reduction of window misting outside at high humidity:	[VN]_close over characteristic
[LN]_Blower_logic_manual_adjustment:	[VN]_Blower stage, absolut
[LO]_Heated_steering_wheel_version:	[VO]_LRH_Gen_2
19 GW
Coding
Subsystem - 001 Identification:
Subsystem number	49
System designation	E221__MFL-TTZ
Software version	0009
Hardware version	H03
VW/Audi part number	30D959442C
Coding	-
Subsystem - 006 Read coding: Multi Function Steering Wheel Control Module
Byte00:
1010 1110 ($AE)
Byte01:
0000 1100 ($0C)
Byte02:
0000 0000 ($00)
Note: 2E0C00 before adaptation/coding. Origin.
- The coding automatically changed to the one shown above (AE0C00) as the adaptations/codings were introduced in 19 and 08.
If you have a Golf 7.5 from before July 2018 you must code in different places.🤭
Options in case of activating the automatic mode.
It can always be activated manually in any case.
Autoscan
Friday,25,February,2022,11:48:54:32438
www.Ross-Tech.com
VIN: WVWZZZAUZKPCICLOW   License Plate: HEATED MFSW OK!
Mileage: 41566km-25827mi   Repair Order:
          A9 D6 D7
VIN: WVWZZZAUZKPCICLOW   Mileage: 41566km-25827miles
Readiness: 0100 0000
   Air quality sensor:
   Coding: 0F4DFD
   Coding: 06A8DD
   Alarm horn:
   Coding: 0271167841
   Coding: 333135
   Coding: 333135
   Coding: 2D2D2D
   Coding: 2D2D2D
   Coding: 2D2D2D
   Coding: 2D2D2D
   Coding: 2D2D2D
   Generator:
   Subsystem 2 - Part No SW: 30D 959 442 C    HW: 30D 959 442 C
   Component: E221__MFL-TTZ  H03 0009
   Serial number: 14011020200010000582
   Coding: AE0C00
   Coding: 02011103
   Coding: 020111
   Coding: 010000
   Coding: 931F0000
   Coding: 090000
   Serial number:
   Data carrier:
End----------(Elapsed Time: 01:29, VBatt start/end: 12.8V/12.8V)-----------
Coding: AE0C00
Note: the VCDS GW label should be enhanced to show the steering wheel contact recognition unit (as shown in ODIS). 😉
https://www.youtube.com/embed/2FVLzxPjm ... autoplay=1
Golf 7.5 Top Sport Heated MFSW retrofitted-installed. (2 of 5)
Previous info:
- Please read the previous page, this one, and what will come ...
Test conditions:
- 3Q0 camera + Assistants.
💎Original Video :arrow: :arrow: :arrow: : https://www.youtube.com/embed/jslet9yj7 ... autoplay=1
Before posting the relevant info, I want to state again that when I bought this Top Sport steering wheel it did not come with the steering wheel contact recognition unit, it was installed later.
Coding.
19 GW
Adaptation
[LO]_clamp behaviour:	[VN]_active with clamp 15 on
[LO]_FoD ACC:	[VN]_activated
[LN]_Wake_up_ability_signal_horn:	[VN]_not active
08 CLIMATRONIC
Coding
19 GW
Coding
Subsystem number	49
System designation	MFL
Software version	0217
VW/Audi part number	1EA959442A
Coding	-
Byte00:
1000 1110 ($8E)
Byte01:
0000 1001 ($09)
Byte02:
0000 0000 ($00)
Note:
- The coding automatically changed to the one shown above (8E0900) as the adaptations/codings were introduced in 19 and 08.
Autoscan
Sunday,27,February,2022,12:18:24:32438
www.Ross-Tech.com
VIN: WVWZZZAUZKPCICLOW   License Plate: TOP SPORT HEATED MFSW OK!
Mileage: 41668km-25891mi   Repair Order:
          A9 D6 D7
VIN: WVWZZZAUZKPCICLOW   Mileage: 41668km-25891miles
   Air quality sensor:
   Coding: 0F4DFD
   Coding: 06A8DD
   Alarm horn:
   Coding: 0271167841
   Coding: 333135
   Coding: 333135
   Coding: 2D2D2D
   Coding: 2D2D2D
   Coding: 2D2D2D
   Coding: 2D2D2D
   Coding: 2D2D2D
   Generator:
   Coding: 8E0900
   Coding: 02011103
   Coding: 020111
   Coding: 010000
   Coding: 931F0000
   Coding: 090000
   Serial number:
   Data carrier:
End----------(Elapsed Time: 01:30, VBatt start/end: 12.6V/12.7V)-----------
As expected the new steering wheel contact recognition unit does not work either, it is still necessary to shake the steering wheel. All this will change when installing the 2Q0 camera. 😊
https://www.youtube.com/watch?v=vx7otAibacw
Ok, time to reflect:
1- The wireless charger is great.
2- The GSM/LTE amplifier works correctly as long as a minimum level of the required signals are received. Perfect for garages or walled places. It does its job.
If you travel with your car to places where there are no repeater antennas, I am afraid that the amplifier will not be of any use.
3- The MIB 2.5 DM Delphi firmware update is a must if you are in the same situation. It works much better.👍
I have updated the post with an issue related to DAB+ that had my unit. :arrow: viewtopic.php?p=589440#p589440
4- I like both steering wheels, both the Passat 8.5 Standard and the Top Sport R-line that I have tuned to R. The Heated steering wheel in both cases is great, it's worth it.
The dimensions are correct in both cases, much better than the previous generation of steering wheels.
I don't hate capacitive buttons, they feel good, they are eye-catching and pretty, you get a vibration feeback when pressed, but you need a little learning to press in the right place, it's easy to press inadvertently or make mistakes. Without a doubt it's easier with normal buttons, ... but capacitive ones are prettier. :lol:
I don't know how to interpret that the capacitive Climatronic is great and the capacitive buttons on the MFSW are not so great, I suppose it depends on the personal use that is made of them, ...I use the buttons on the steering wheel with high frequency...
https://www.youtube.com/watch?v=g6t8g6ka4W0
As soon as possible, I will start with the tests with the Travel Assist buttons, it will not be something immediate, there are still a few weeks to go until the end of the winter calendar (where I live) and the start of Formula 1.😍
VCDS 22.3.0
...and on the other side too. (W7💎)
👌 8) Thanks!!
Golf 7.5 6MT. TJA-EA (pACC) "30kmh".
- Partial activation of TJA and EA with manual gearbox. Lane Assist from 30Km/h instead of 60km/h.✅
-10zt :arrow: https://www.drive2.ru/l/553563973484544368/ Thank you!!
More comfortable. Worth it!
💎Original Video :arrow: :arrow: :arrow: : https://www.youtube.com/embed/kqMgELGJP ... autoplay=1
Well, I wanted to test it out before removing the 3Q0 camera and installing the 2Q0 (for Travel Assist and J1158 unit).
The video also shows how I still have to shake the steering wheel due to the really annoying warnings to take the steering wheel. I guess with the new steering wheel contact recognition unit I won't have these imprecise "warnings".
In my case and according to the video there are approximately 20 seconds between warnings. I always held the steering wheel with my hand... in a sweet/smooth/light way... 🤭
Anyone can drive a VW Golf... not just the usual Superman/woman gripping the steering wheel like she's/he's holding a ....
Applied coding:
Lane keeping "30kmh". Manual Gearbox. 3Q0 camera. pACC.
CODING
03: ABS
Byte29 Bit5 ... enable > (already coded in my case)
13: Auto Dist. Reg
[LO]_Emergency_Assist:	[VN]_installed > (already coded in my case)
[LO]_Traffic_jam_dependent_linear_tracking:	[VN]_deactivated  ...> activated
[LO]_Emergency_Assist:	[VO]_EA_Variant_1 ...> EA_Variant_2
Autoscan.
Wednesday,02,March,2022,11:10:48:32438
VCDS Version: 22.3.0.1 (x64)  HEX-V2 CB: 0.4613.4
Data version: 20220225 DS336.1
www.Ross-Tech.com
VIN: WVWZZZAUZKPCICLOW   License Plate: TJA/EA ACTIVATED. LA 30KMH OK!
Mileage: 41810km-25979mi   Repair Order:
          A9 D6 D7
VIN: WVWZZZAUZKPCICLOW   Mileage: 41810km-25979miles
   VCID: 290F00D8897EC923B8C-807C
Readiness: 1110 0001
   VCID: 76B51BA40840D6DBE5E-8022
   VCID: 074B66607FAADF538E8-8052
   Air quality sensor:
   ROD: EV_BCMBOSCH_020_VW37.rod
   VCID: 015F7878518EE163C0C-8054
   Coding: 0F4DFD
   Coding: 06A8DD
   Alarm horn:
   Coding: 0271167841
   VCID: 51FF8838C16ED1E310C-8004
Address 13: Auto Dist. Reg (J428)       Labels:| 5Q0-907-572-V2.clb
   Coding: 2B0D7FE35DFFC728979F81A461400600000000000010000004
   VCID: 47CBA6603F2A1F534E8-8012
   VCID: 094F605869BEA92398C-805C
   Coding: 333135
   Coding: 333135
   Coding: 2D2D2D
   Coding: 2D2D2D
   Coding: 2D2D2D
   Coding: 2D2D2D
   Coding: 2D2D2D
   VCID: 2B03FAD08382DB334A0-807E
   VCID: 70B92DBC6A24F8EB3F2-8024
   Generator:
   Coding: 8E0900
   Coding: 02011103
   VCID: 3D27C4886DF64583E44-8068
   Coding: 020111
   VCID: 48C9A55C3234102B472-801C
   Coding: 010000
   Coding: 931F0000
   VCID: 73B322B01B32C3F3C20-8026
   ROD: EV_MultiModulContiVW48X_003.rod
   VCID: 372BD6A04FCA6FD33E8-8062
   Coding: 090000
   Serial number:
   VCID: 323DE7B4A4A88AFB096-8066
   Data carrier:
   VCID: 3431E1AC5EBC84CB1BA-8060
   VCID: 392FD09879DE79A3C8C-806C
   Coding: 000307000000040100221354C156A90098000E33004000
   VCID: 40D9BD7C1A04286B8F2-8014
   VCID: 6A8D3FD44CF8023B716-803E
End----------(Elapsed Time: 01:30, VBatt start/end: 12.6V/12.6V)-----------
Note:
In my case it was not necessary to parameterize the A5 camera (3Q0) with the VCP zdc file.
https://www.youtube.com/watch?v=m6s2SOS ... RDMM&t=40s
T14. New stalks and slip ring with the Assistants button.
In my case, it is necessary to install them before installing and testing the multifunction steering wheels with "Travel Assist button", which replaces the "Assistants button".
The Assistants button migrates to the stalks to continue having the Assists systems Menu available in the AID.
07/2018 -->
They are the yellow and blue wires on the left side.
Its presence must be coded in BCM adaptations (or 16 Address <---07/2018):
- ODIS.
[LN]_Buttons for driver assistance systems: [VN]_not installed ... to installed.
- VCDS.
ENG153728-MAS00242-LIN-SMLS_konfig_2-Driver assistance systems button,not installed ,2 ... to installed.
Installation of stalks is described here :arrow: viewtopic.php?p=589175#p589175
https://www.youtube.com/watch?v=cJ4cYA7sWRE
Golf 7.5 Heated MFSW retrofitted-installed with TA button + Assistants button on Stalk. (3 of 5)
It is the same MFSW as -1 of 5- but with Travel Assist button, Assistants button on Stalk and R-line logo.
💎Original Video :arrow: :arrow: :arrow: : https://www.youtube.com/embed/JCTh2QCzS ... autoplay=1
Coding:
Notes regarding the coding of the multifunction buttons on the steering wheel (Golf 7.5):
1- When you code the multifunction buttons in the GW adaptations (ODIS,VCDS,ect), the coding (Binary-HEX) automatically changes.
2- Avoid coding in long coding with the tedious scientific push method.
3- Byte0 Bit0 enabled = DSG , Byte0 Bit7 enabled = Heated MFSW. ...so... 🧠
Autoscan:
Friday,04,March,2022,13:56:05:32438
www.Ross-Tech.com
VIN: WVWZZZAUZKPCICLOW   License Plate: MFSW W TA BUTT + STALKS W ASS BUTT 😄k!
Mileage: 41925km-26050mi   Repair Order:
          A9 D6 D7
VIN: WVWZZZAUZKPCICLOW   Mileage: 41925km-26050miles
   Air quality sensor:
   Coding: 0F4DFD
   Coding: 06A8DD
   Alarm horn:
   Subsystem 5 - Part No SW: 5Q1 953 507 GB    HW: 5Q1 953 549 F
   Serial number: 00000023032104400679
   Coding: 0271167841
   Coding: 2B0D7FE35DFFC728979F81A461400680000000000010000004
   Coding: 333135
   Coding: 333135
   Coding: 2D2D2D
   Coding: 2D2D2D
   Coding: 2D2D2D
   Coding: 2D2D2D
   Coding: 2D2D2D
   Generator:
   Subsystem 2 - Part No SW: 3G0 959 442 K    HW: 3G0 959 442 K  Labels: 3C8-959-537.CLB
   Component: E221__MFL-PR6  H06 0110
   Serial number: PR6-0440036133190478
   Coding: AE8C00
   Coding: 02011103
   Coding: 020111
   Coding: 010000
   Coding: 931F0000
   Coding: 090000
   Serial number:
   Data carrier:
End----------(Elapsed Time: 01:30, VBatt start/end: 13.3V/13.4V)-----------
Until the 2Q0 camera is installed, the Travel Assist and the steering wheel contact recognition unit do not work, even if there are no faults in the diagnosis and everything works correctly.
Golf 7.5 Top Sport Heated MFSW retrofitted-installed. TA button + Assistants button on Stalk. (4 of 5)
💎Original Video :arrow: :arrow: :arrow: : https://www.youtube.com/embed/RLXdgzwsu ... autoplay=1
:wink:
Coding.
:wink:
Autoscan.
Monday,07,March,2022,09:33:37:32438
www.Ross-Tech.com
VIN: WVWZZZAUZKPCICLO   License Plate: TOP SPORT HEATED MFSW TA + ASS ON STALK
Mileage: 41958km-26071mi   Repair Order:
          A9 D6 D7
VIN: WVWZZZAUZKPCICLO   Mileage: 41958km-26071miles
Readiness: 0010 0000
   Air quality sensor:
   Coding: 0F4DFD
   Coding: 06A8DD
   Alarm horn:
   Coding: 0271167841
   Coding: 333135
   Coding: 333135
   Coding: 2D2D2D
   Coding: 2D2D2D
   Coding: 2D2D2D
   Coding: 2D2D2D
   Coding: 2D2D2D
   Generator:
   Subsystem 2 - Part No SW: 1EA 959 442 B    HW: 1EA 959 442 B
   Serial number: 17036218081502000064
   Coding: AE2F00
   Coding: 02011103
   Coding: 020111
   Coding: 010000
   Coding: 931F0000
   Coding: 090000
   Serial number:
   Data carrier:
Edit. April 8, 2022: Still no 2Q0 camera, but this will be the MFSW that will really make everything work great.
My Winter project 2021/22 has been successfully completed in this last post on this page.✅
My exciting Spring project 2022 begins on the next page... the reason for "(5🖐 of 5🖐)" on the next page.🤭
https://www.youtube.com/watch?v=5-gTgJ7xilA&t=44s
Locked
