Suprised to find this is the only picture I have of them fitted.
Cars also in the workshop today have all the bushes replaced with superpro ones,
Then tomorrow I'm off to have the car remapped by Shark Performance, Cant wait for this!
260-275 for a stage 1?! I'd be lucky!!!! I know what you meant..6N2 GTI 00 wrote:Very Nice JackBrembo's look boss!
Let us know how you get on with the Re-map
Stage 1 it should pull anything between 260-275bhp and 280-300lbs ft of torque
I would ask Shark to ensure it stays below 300 lbs ft because that's the limit of the OEM Clutch & Flywheel
The brembo calipers are from an Alfa Romeo Brera 2.2 2006 onwards. They use a 305mm disc on the Brera but work fine on a 312mm disc. They then have a custom bracket so they can be used on the Fabia.Gtiandy wrote:What brembos are they if you don't mind me asking?
I'm trying to find a set that will fit under my 16" wheels and they look like they have plenty of clearance under those 17"s.
Andy
