UK-POLOS.NET - THE VW Polo Forum • autolights - Page 5
Page 5 of 5
Re: autolights
Posted: Thu Nov 21, 2013 6:43 pm
by joelburbidge
with regards to taking the kufatec wire out of pin 6 into pin 7 do i then put the original wire back into pin 6?
Re: autolights
Posted: Fri Nov 22, 2013 10:25 pm
by Mart!n-GTI-DK
Here is what I did instead of the foglight.
Re: autolights
Posted: Fri Nov 22, 2013 11:23 pm
by ciclo
wow... excellent Mart!n. :wink:
joelburbidge. Have you been able to solve something from wiring?
Re: autolights
Posted: Sun Nov 24, 2013 2:29 pm
by joelburbidge
Not had chance to yet
Re: autolights
Posted: Mon Nov 25, 2013 8:14 am
by ciclo
edit... bad link
Re: autolights
Posted: Wed Jan 08, 2014 5:42 pm
by joelburbidge
ciclo with response to your last pm all is working apart from the full beam i am correct saying that full beam in your diagram is pin 2 of the 2 pin coupling?
Re: autolights
Posted: Thu Jan 09, 2014 10:08 am
by ciclo
As you know my English is very bad and sometimes it's hard for me to understand the questions.
Please copy the diagram and notes on the diagram your question. I do not want to answer without knowing exactly what you mean.
Please.
I'm hoping that everything will work properly in your BlueGT and you show here.
Automode...full beam
pin 2 (T10)---> pin 37 BCM......pin 1 BCM----> input relay......output relay---->pin 2 coupling---->pin 4 (T17)
Re: autolights
Posted: Fri Mar 07, 2014 11:02 am
by ciclo
Finally, all problems solved with automatic lights for vw polo 6R, here:
http://www.uk-polos.net/view ... 20#p474658
