Restoring lost abs long code with new vcds hex v2 pro
Re: Restoring lost abs long code with new vcds hex v2 pro
Try this one: 530244E3416E00B6CA2722EB82D500821100
Glen
- Drives: Vw polo 6r 1600tdi
it's rejecting this one as well. the problem I have with this car is that the original abs pump was not responding to vcds, so I dont have the original abs long code.
Hm, maybe try:
510244E3416E00B68A2722EB82D500821100
Glen
it's still rejecting all the abs long codes. It's one of those sedan models that's assembled in India, I don't know if they use different coding there.
Glen
I am going to try all over again from the first code you provided. on each attempt I re- enter the security access code and even clear the fault codes. I am following the same procedures that I performed on the other car and which accepted the coding.
Now you can see why this is not my favourite job. Many attemps for a coding that we may never find. And it's literally taking many hours
Try this one too:
630244E3416E00B6C62722EB82D500821100
Try this one too:
Glen
now I know, I hope I never have to go through this again, or have to bother you. I owe you for your time. I am going to try this one now.
Glen
Also rejected. I am beginning to wonder if it has something to do with part numbers .the original abs pump that was in the car, part number was 6RU614517A I have replaced with the exact matching number of the hatch back model I have, which is 6R0614517AF. I should have asked you to source one for me and code it that side.
No it should not matter. ESP8.2i is ESP8.2i, no matter what the part number is. There are several pumps that work.
I give up for now I'm out of ideas.
Glen
thanks for all your time. If you happen to come up with a solution please let me know, and if there is any way I can compensate you for your time, please let me know. I will keep trying those codes and see what happens. I am even having second thoughts about going to help the other mechanic with that m60ec1. You provided me with a code that was accepted ,its just a few refinements and some other codes which you have already provided me with that I need to try, but after today I dont know . enjoy what ever Is left of the rest of your day.
ESP8.2i Front
Polo 6R sedan
RHD
288mm/200mm front discs rear drums
Manual transmission
CLNA 1.6 TDI 105hp engine
VIN WVWZZZ60ZDT014294
230244E3416E00B6C42722EB82D500821100 rejected
530244E3416E00B6CA2722EB82D500821100 rejected
510244E3416E00B68A2722EB82D500821100 rejected
630244E3416E00B6C62722EB82D500821100 rejected
one last try:
630244C2416E00B6C62722EB82D500821100
Polo 6R sedan
RHD
Manual transmission
one last try:
Glen
thanks, I will go try it right away.
Glen
rejected. i am also giving up for now. i am going to look for headache pills.
Yep, well, if I take this as a refence:
230248E3417000BBC42612E582D800821100
This is the code that makes your 1st polo work.
same engine. same gearbox. so we know that is OK.
230244E3417000BBC42622E582D800821100 change to 288mm front brakes 200mm rear brakes
230244E3416E00B6C42722EB82D500821100 accomodate for VIN
630244E3416E00B6C62722EB82D500821100 some attempt to make Polo Sedan RHD work.
This is the best I can do based on the information I have
Some things you can try:
630224E3416E00B6C62712EB82D500821100
Polo 6R Sedan RHD: http://forums.ross-tech.com/showthread. ... #post38702
Glen
thanks, I will go back and try it. I can't give up, for me it's not an option. if I dont come right, what would it cost for you to find a used one in Europe and code it there before shipping?
