Seat Ibiza 6J, 2.0 TDI FR, Auto Lights Retrofit (BCM 88D)
Re: Seat Ibiza 6J, 2.0 TDI FR, Auto Lights Retrofit (BCM 88D)
I see. Perhaps it's better to focus on completing the retrofit of the BCM first.
Or you could check some things like whether the wiring is transmitting +12V to T73a/37 in auto setting.
MIH11MI6
Drives: 6J FR 2.0TFSI CDLJ AWD
Post by MIH11MI6 »
iichel wrote: Fri Dec 18, 2020 2:48 pm I see. Perhaps it's better to focus on completing the retrofit of the BCM first.
I can confirm 12v is being sent to the T37a/37 in auto :)
all other exterior lights work as intended, at the front?
MIH11MI6
Post by MIH11MI6 »
iichel wrote: Fri Dec 18, 2020 2:58 pm all other exterior lights work as intended, at the front?
Yes but not in auto light mode
If set to side lights only, just side lights are on.
if set to headlights on, then dipped beam comes on, when stalk is pressed or flashed, full beams come on
but nothing in auto mode by the looks of things, other than the side lights being permanently on
I see. I'll leave it to ciclo to have a look at your coding.
MIH11MI6
Post by MIH11MI6 »
iichel wrote: Fri Dec 18, 2020 3:08 pm I see. I'll leave it to ciclo to have a look at your coding.
okay, thanks for your help, i'll keep investigating but everything seems correct according to 7L6 wiring diagrams, so next step is check T6 stuff
MIH11MI6
Post by MIH11MI6 »
I have checked measuring block 29, which switches on and off when I turn the light switch from off to auto, so the BCM knows that the auto lights are working. It must be in the coding
i'm just guessing at this point, but you could have a look at byte 18 and try something like '61'.
3C8829EFC8F32500932000007E0B1EC80080610F60880000200000000000
MIH11MI6
Post by MIH11MI6 »
iichel wrote: Fri Dec 18, 2020 3:37 pm i'm just guessing at this point, but you could have a look at byte 18 and try something like '61'.
no Such luck :( still no change. Ciclo may be our only hope :cry:
MIH11MI6
Post by MIH11MI6 »
Hi iichel,
Been doing some digging around to try bridge the gap we are having, i'd like your opinion on the coding for byte 13.
Byte 13 according to your coding is 0B
3C8829EFC8F32500932000007E0B1EC8008061]0F60880000200000000000
From what i've found online (see below)
The coding matches currently for what is ticked in the image, however bit 7 is unchecked, surely this would affect the light sensor working, please let me know your thoughts :)
Matt
MIH11MI6
Post by MIH11MI6 »
I have also uploaded the T6 BCM pinout to the drive link i've previously shared, I have compared it to all the wiring I have done and it all seems okay, I must be missing something
Yes you're right.
3C8829EFC8F32500932006007E8B9EC81080610F60882000200000030000
MIH11MI6
Post by MIH11MI6 »
iichel wrote: Sat Dec 19, 2020 6:23 am Yes you're right.
Brill thanks, will check first thing when I get to the car
MIH11MI6
Post by MIH11MI6 »
Just tried it and realised... my vcds is saying coding accepted, but the bcm isn't storing the settings 🤦‍♂️ any idea why that could be? Possibly battery voltage?
MIH11MI6
Post by MIH11MI6 »
MIH11MI6 wrote: Sat Dec 19, 2020 9:29 am
Update
Was battery voltage, got it to accept long coding, e20 interior lighting now works. Side lights still on permanently though
Changed patch of auto lights from T17/16 To T17/5. Side lights now work as expected
