BCM Upgrade and not able to match the key
Hiroki
Drives: 6r Polo 1.2 TSI 2011
Re: BCM Upgrade and not able to match the key
Post by Hiroki »
ciclo wrote: Fri Nov 15, 2024 3:50 am Please do the following:
- Disconnect the negative battery terminal (30 sec).
- Reconnect it.
- Set the comfort function for all car windows with the window switch on the driver's door (auto up/down - one click).
- With VCDS, Clear All DTCs.
- New BCM coding:
3CB82FBF28FB2400B3380EB07CEB96D15FC0612F608C20D1200000020000
- Check for Faults.
- Autoscan, GW Inst list, Clear All DTCs. New Autoscan.
Check the LED function for the Anti-Theft Alarm.
still no luck sir
Friday,08,November,2024,12:01:59:38219
VCDS Version: 24.7.1.0 (x64) HEX-V2 CB: 0.4656.4
Data version: 20240919 DS356.3
www.Ross-Tech.com
VIN: WVWZZZ6RZBU037606 License Plate:
Mileage: 194790km-121036mi Repair Order:
Chassis Type: 6R-VW25 (7E0)
Scan: 01 02 03 04 08 09 10 15 17 19 25 44 56
VIN: WVWZZZ6RZBU037606 Mileage: 194790km-121036miles
56-Radio -- Status: OK 0000
Address 01: Engine (J623-CBZB) Labels:. 03F-906-070-CBZ.clb
Part No SW: 03F 906 070 BQ HW: 03F 906 070 D
Component: SIMOS10.20H02 9849
Revision: -------- Serial number: CVN: 949FC520
Coding: 002500F6202400080000
Shop #: WSC 12345 123 61029
ASAM Dataset: EV_ECM12TFS02103F906070BQ 003010
ROD: EV_ECM12TFS02103F906070BQ_003.rod
VCID: 72BDCB884426752A59F-8026
VINID: 9E69EAAAA1A2A929400C718018574E6D87
Readiness: 0110 0101
Address 02: Auto Trans
Cannot be reached
Address 03: ABS Brakes (J104) Labels:. 6R0-907-37x-ESP82.clb
Part No SW: 6R0 907 379 AJ HW: 6R0 907 379 AF
Revision: --------
Coding: 23022BE3417000B9C42BD4E282D700801200
Shop #: WSC 31414 790 31414
VCID: 06558758586E798A657-8052
Address 08: Auto HVAC (ÿÿÿÿÿ) Labels: 6R0-820-045-9AP.clb
Part No SW: 6R0 820 045 J HW: 6R0 820 045 J
Component: Climatic 25 0660
Revision: 00 11 25
VCID: 3537309475482212BCD-8060
Part No SW: 7E0 937 190 B HW: 7E0 937 190
Component: BCM PQ25 Max3 H81 0744
Revision: B8081001 Serial number: 0970 117220019
Coding: 3CB82FBF28FB2400B33806B07CEB96D15FC0612F608C20D1200000020000
Shop #: WSC 18752 008 00032
VCID: 2B0316ECA30C64E2DA9-807E
Component: RLHS 300518 0 50 0107
Coding: 008F77
Subsystem 2 - Part No SW: 6R0 959 802 S HW: 6R0 959 802 S Labels: 6R0-959-802.CLB
Component: J386__TSG_FT 006 0903
Serial number: KU0-KU025.08.1012517
Coding: 18BC34
Subsystem 3 - Part No SW: 6R0 959 801 AA HW: 6R0 959 801 AA Labels: 6R0-959-801.CLB
Component: J387__TSG_BT 006 0902
Serial number: KU0-KU024.08.1017757
Coding: 08BC34
Component: DWA-Sensor 00 001 0103
Component: LIN BACKUP HO H05 1501
Subsystem 7 - Part No SW: 1K8 959 442 HW: 1K8 959 442
Component: E221__MFL-MD9 H04 0103
Serial number: 27190003121620060022
Coding: A40000
Subsystem 8 - Part No SW: 6R0 959 811 F HW: 6R0 959 811 F
Component: J388__TSG_HL 006 0902
Serial number: KU0-KU001.09.1011977
Coding: 08BC32
Subsystem 9 - Part No SW: 6R0 959 812 F HW: 6R0 959 812 F
Component: J389__TSG_HR 006 0902
Serial number: KU0-KU016.08.1014939
Coding: 08BC32
Address 10: Park/Steer Assist (J446) Labels:* None
Part No SW: 6RD 919 475 A HW: 56D 919 475
Component: PARKHILFE 8K H02 0007
Revision: -------- Serial number: 57921435200072
Coding: 308103
ASAM Dataset: EV_EPHVA18VW250GPCS 001004
VCID: 50F96100EA6A673A8FB-8004
Part No SW: 6R0 959 655 L HW: 6R0 959 655 L
Component: VW10Airbag00R H09 0020
Revision: -------- Serial number: 003GY001DNMQ Dataset Number: v00305166R0 0001
Coding: 003052
ROD: EV_AirbaVW10BPAVW250.rod
VCID: 4BC3766C034C44E2FA9-801E
Serial number: 3572SRB40000C64551E5
Serial number: 3582SRB40000C4185A98
Serial number: 3515RRB405B6VQ8C3GB/
Serial number: 3525RRB40636UBV85G8-
5 Faults Found:
9437723 - Igniter for Passenger's Airbag
B1002 1B [10001001] - Resistance Too High
Fault Priority: 2
Fault Frequency: 1
Mileage: 194791 km
Date: 2024.11.08.
Time: 20:17:22
9440027 - Driver's side; side-airbag igniter
B100B 1B [10001001] - Resistance Too High
Fault Priority: 2
Fault Frequency: 1
Mileage: 194791 km
Date: 2024.11.08.
Time: 20:17:22
9446677 - Redundant signal path for airbag shut-off; passenger side
B1025 15 [10001001] - Open or Short to Plus
Fault Priority: 2
Fault Frequency: 1
Mileage: 194791 km
Date: 2024.11.08.
Time: 20:17:20
9445397 - Key switch for deactivation of passenger-side airbag
B1020 15 [10001001] - Open or Short to Plus
Fault Priority: 2
Fault Frequency: 1
Mileage: 194791 km
Date: 2024.11.08.
Time: 20:17:20
9442836 - Front Passenger's Airbag Disabled Indicator Lamp
B1016 14 [10001001] - Open or Short to Ground
Fault Priority: 2
Fault Frequency: 1
Mileage: 194791 km
Date: 2024.11.08.
Time: 20:17:20
Part No SW: 6R0 920 860 F HW: 6R0 920 860 F
Component: KOMBI H04 0304
Coding: 240A00
ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A04086
VCID: 372B3A9C6FC4D002AE1-8062
Part No SW: 7E0 909 901 HW: 7E0 937 190
Component: GW-K-CAN TP20 H81 0744
Revision: B8081001
Coding: 002300
VCID: 6889A9E0727A8FFAF7B-803C
Component: IMMO H04 0304
Serial number:
VCID: 6A8DD3E86CF6BDEAE1F-803E
Part No: 6R0 423 156 B
Component: LenkhilfeTRW V277
Coding: 11230
Shop #: WSC 31414
VCID: 2F3B02FC9E5418C2F61-807A
1 Fault Found:
01317 - Control Module in Instrument Cluster (J285)
49-10 - No Communications - Intermittent
Part No SW: 6RD 035 187 B HW: 6RD 035 187 B
Component: Radio 534 5614
Revision: -------- Serial number: VWZZZ4H6239179
Coding: 1F000440040001
VCID: 46D5475818AEB98A257-8012
End----------(Elapsed Time: 01:45, VBatt start/end: 13.1V/13.4V)-----------
Hiroki
Post by Hiroki »
Hi sir, I figured out the situation. The led is working now. I believed when I re-install the door card, I might have forgotten to plug back in the led. My sincere apologies for wasting your time when I could have do my homework.
Great!
No worries, glad to help you.
The owner's manual tells you how the anti-theft alarm LED works in case you need it.
Hiroki
Post by Hiroki »
Thank you sir, the rain is stopping me to get back to my car. Thanks for all the help.
I am thinking of upgrading the Maxidot Cluster. I’m sure my dealer will not help me at all. Will u to you be able to code for me please? I’m thinking of buying this from AliExpress
“ I just found this on AliExpress: $821.77 | For VW POLO 6R Maxidot Speed Meter Mechanical Instrument 6RD 920 870 A 6RD920870A
https://a.aliexpress.com/_mrHd95V
Kindly advise.
You should have no problem replacing the old instrument panel with a BRAND NEW instrument panel at any VW dealer, they will be happy to charge you for the stated labor time for this replacement.
Don't forget to give them all the keys/remotes assigned to your car for a satisfactory replacement.
If you buy a second-hand one, I will tell you by PM who you should contact to code it. It would be necessary to send him the old instrument panel and the keys/remotes 'to Europe', 100% trustworthy in security issues, 'the best guy' in these matters.
I think in your case, it is better to buy a new one and have the dealer do the replacement. The one you indicate is perfect for your TSI.
Hiroki
Post by Hiroki »
Thank you sir, I will try to talk with the local dealer and will come back to you.
Being in your situation a few years ago, I seem to recall that the VW dealer charged me half an hour of labor to adapt the instrument panel, at a reasonable price for any pocket.
I went with the upper cover of the steering column and the two screws that hold the instrument panel already removed.🤭 It was only necessary to disconnect the old one and connect the new one.
The actual work took about 2-5 minutes with the VAS. Everything OK! 8)
