Locked
rmps
Drives: Polo 1.2 TDI Highline 75hp (6R)
Post by rmps »
Hola Ciclo!
Firstly I would like to congratulate you on your amazing car mods, it's an inspiration!
I've some questions about your automatic lights mod:
It seems that you used repair wires (000979009E) to connect to the new 10-pins light switch housing (8E0971980), despite the fact that the old 17-pins light switch housing (1J0972999) uses different cross-section wires.
How about the connections to the BCM (pins 1 and 37) and to the relay housing (4H0937529), which wires did you use?
It seems that I can use the same repair wire to connect to the BCM, and the repair wire 000979023E to connect to relays pins 1 and 2... for pins 3 and 5 couldn't find anything.
Could you please help?
Thank you and feliz navidad!
Hi rmps. Festas Felizes! Eu aprecio o seu comentário. :wink:
To tell you exactly what kind of wires you need, I have to know what is the "model year" of your Polo.
Tell me the tenth letter of your VIN: http://www.uk-polos.net/view ... 09#p478942
In the diagram that I share with everyone :lol: , you can see the thickness of the cross section of the wires, look on the final page of this installation guide.
https://drive.google.com/file/d/0B2nv91 ... edit?pli=1
BCM:
Pin 1: http://www.a4-freunde.com/attachment.ph ... 1353&stc=1
Pin 37: http://www.a4-freunde.com/attachment.ph ... 1415539780
Repair wires OEM that go to adapter relays 4H0937529 are not sold on VW because they have different contact pins at each end, so I can not say an exact reference.
In any case, for 4H0937529 you need this type of contact pin (depending on the thickness of the cross section of the cable): http://www.a4-freunde.com/attachment.ph ... 1415009194 , http://www.a4-freunde.com/attachment.ph ... 1416146148
On this website you have the references of the contact pins: http://www.a4-freunde.com/showwiki.php? ... zu+gehoert
I guess you know that I sell the wirings for automatic lights. http://www.uk-polos.net/view ... 09#p478298
By the questions you ask me about wiring automatic lights, my recommendation as a friend (not as seller) and due to the extensive experience with other users in this forum and many other forums around the world, you would make a good decision if you buy the wiring for automatic lights I sell.
-The car lights are very important for your safety.
-You will save lots of time and especially money.
-All wirings automatic lights that I sold, work perfectly... forever.
benzinkopf
Drives: 1.2TSI 105HP DSG7
Post by benzinkopf »
PM me Ciclo. I want the wiring as well!
I do not provide technical support for this: http://www.uk-polos.net/view ... 95#p483697
I apologize, it's too long to explain.
The installation guide is correct.
rmps
Post by rmps »
Muchas gracias, Fernado!
ciclo wrote: To tell you exactly what kind of wires you need, I have to know what is the "model year" of your Polo.
It's a C - MY2012. With original xenon lights and rain/light sensor.
ciclo wrote: In the diagram that I share with everyone :lol: , you can see the thickness of the cross section of the wires, look on the final page of this installation guide.
That's the diagram I'm talking about. For instance, you have a 0.5 mm^2 cross-section wire from pin #4 of the new 10-pin light switch housing (8E0971980) conecting to pin #1 of the original 17-pin light switch housing (1J0972999), despite the fact that the original wire connecting to it have 2.5 mm^2...
Both with 0.5 mm^2, I suppose. I didn't find any schematics with those connections...
ciclo wrote: I guess you know that I sell the wirings for automatic lights. http://www.uk-polos.net/view ... 09#p478298
Unfortunately, when I bought all the parts (except wires) I didn't know about your kit. I saw a similiar diagram in the french Polo 6R forum before I found this one.
I did built a plastic connector to the original 17-pin light switch housing (1J0972999) - something like the rear end of the original light switch, so that I don't have to remove any wires.
Best regards,
Rui Saraiva
Hi Rul,
With your permission:
Let's take this issue as an example of the hundreds of messages I get on my email requesting information about automatic lights wiring, but this time so that it can be read to everyone.
1- Model Year.
Your POLO 6R is "C", then your first mistake is that you bought the wrong adapter relays (4H0937529). Consequently, also the contact pins or wire repair.
The right for your model year is 8E0937527 for a perfect installation (OEM).
2- Cross-section wires.
-This is the most important part of the whole manufacturing process of the wiring. It is not correct any wiring purchased at any store, it must be specific to automotive.
Not all cables have the same technical specifications even if they have the same dimensions. You will prevent your car is on fire due to excessive heat in the wires.
-From (old pin1) 2.5mm2 to (new pin4) 0.5 mm2:
The new light switch is electronic and all light switching processes are controlled by the BCM or relays, so it is not necessary that electrical consumption go through the light switch.
3- Electrical diagram of the French forum is incomplete, it comes from a diagram of the German forum (Master2b) that is not entirely correct.
-I had to correct so that all lights work correctly in all POLO 6R with different BCM.
-VCDS coding from French forum is not valid for all POLO 6R. :wink:
Lest anyone get angry:
The manufacturing process shown in the french forum (as you already know) is not with original parts, however, it is much appreciated by me that people show their work with the intention of sharing.
Justice: Diagram owned by Master2b already existed elsewhere but in a better way... It was enough to look at the Elsawin in the right place...
Nonetheless, everyone should thank Master2b his work, was the beginning of the automatic lights for Polo 6R...
If you want a perfect wiring (only wiring)... contact me by PM. «I'm going to make you an offer you can't refuse» :)
AS I said: you will save lots of time and especially money.
Show us a picture of the plastic connector 17-pin female you've made.
sanderb
Drives: 6r
Post by sanderb »
hello ciclo,
i have polo 6r 1.4 highline (no bluemotion) manua garebox an bcm 6R0 937 087 D right now polo 6r highline, fog lights, cruise control, climate control.
I have no rainsensor and no automatic mirror that dims and no automatich lighting offcourse.
Can the rainsor and automatic mirror can be installed with my current bcm? I found a new window of a polo bluemotion 6r with rainsensor will this fit on my polo (i don't have a bluemotion).
Which bcm i need for the the automatic lights precisely? I found one on the internet 7H0937089F from a seat ibiza 2011 will that work? http://www.onderdelenlijn.nl/upload/onl ... SR20-1.jpg
i like to order your kit offcourse but first i want to make the new BCM to work before i start with the wirring.
greetings,
Sander
Mart!n-GTI-DK
Drives: '14 Polo BlueGT
Post by Mart!n-GTI-DK »
It's a bit sad that Ciclo's excellent build thread has been turned into a "questions to ciclo thread".
Maybe there could be a seperate thread for that (If ciclo is interested of course) so this thread could be a normal build thread.
Hi sanderb,
sanderb wrote:Which bcm i need for the the automatic lights precisely? I found one on the internet 7H0937089F from a seat ibiza 2011 will that work? http://www.onderdelenlijn.nl/upload/onl ... SR20-1.jpg
Upgrade BCM Polo 6R:
Beware, this is a very delicate process !!
My experience: I have a BCM High 7H0937089F from factory on my R-line for xenon headlights, but I tried to install a "used" BCM Max 7H0937090 from a Skoda Rapid.
After encode everything correctly, basics settings (not sure if this was necessary), adaptation of keys, etc ... I was not able to make will work properly the instrument cluster, consequently there were detected faults in other units for this reason. These units were working properly.
VCDS autoscan with this BCM Max:
Chassis Type: 6R (6N0)
Scan: 01 03 08 09 10 15 17 19 25 2E 37 44 55 56 77
VIN: WVWZZZ6RZDY-ciclo
2E-Media Player 3 -- Status: Malfunction 0010
37-Navigation -- Status: Not registered 0001
55-Xenon Range -- Status: OK 0000
56-Radio -- Status: OK 0000
77-Telephone -- Status: Malfunction 0010
Address 01: Engine (J623-CBZC)       Labels: 03F-906-070-CBZ.clb
   Part No SW: 03F 906 070 GD    HW: 03F 907 309 AJ
   Component: SIMOS10.22AH10 2686
   Revision: --H10---    Serial number: 00000000000000
   Coding: 001100D6202400080000
   Shop #: WSC 00788 648 00255
   ASAM Dataset: EV_ECM12TFS02103F906070GD 004004
   ROD: EV_ECM12TFS02103F906070GD.rod
   VCID: 6AD1DC718D64C89
Readiness: 0110 0101
Address 03: ABS Brakes (J104)       Labels: 6R0-907-37x-ESP82.clb
   Part No SW: 6R0 907 379 BE    HW: 6R0 907 379 AF
   Revision: --------
   Coding: 210228E3216D00B5842814EA84D300401700
   VCID: 8201124819F1500E027-80D7
   Part No SW: 6R0 907 044 H    HW: 6R0 907 044 H
   Component: Climatronic   H11 0711
   Revision: V0000000
   VCID: 387530A08BAD4ADE6C3-806D
1 Fault Found:
01317 - Control Module in Instrument Cluster (J285)
            004 - No Signal/Communication
                    Fault Status: 01100100
                    Fault Priority: 6
                    Fault Frequency: 1
                    Reset counter: 253
                    Time Indication: 0
Address 09: Cent. Elect. (J519)       Labels: 7H0-937-08x-09.clb
   Part No SW: 7H0 937 090     HW: 7H0 937 090
   Component: BCM PQ25 Max4 H72 0708
   Revision: B9072001    Serial number: 0531 022130666
   Coding: 3CB02FBF48E1240093380FD17EEB9FD8FAC067FF600530C1200000010000
   Shop #: WSC 00000 960 03736
   VCID: EBDF5FEC0A7BB146D11-80BE
   Subsystem 1 - Part No: 1K0 955 559 AH  Labels: 1K0-955-559-AG.CLB
   Component: RLS 050512 05  54  0403
   Coding: 0F302D
   Subsystem 2 - Part No SW: 6R0 959 801 BD    HW: 6R0 959 801 BD  Labels: 6R0-959-801.CLB
   Component: J386__TSG_FT  003 8612
   Coding: 0200A3
   Subsystem 3 - Part No SW: 6R0 959 802 BF    HW: 6R0 959 802 BF
   Component: J387__TSG_BT  003 8612
   Coding: 1000AB
   Subsystem 5 - Part No: 1K8 951 605 B
   Component: LIN BACKUP HO  H11 9005
   Subsystem 7 - Part No SW: 5K0 959 542 A    HW: 5K0 959 542 A
   Component: E221__MFL-TAS  H09 0013
   Coding: 820000
   Subsystem 8 - Part No SW: 6R0 959 811 G    HW: 6R0 959 811 G
   Component: J388__TSG_HL  008 1611
   Coding: 18BC32
   Subsystem 9 - Part No SW: 6R0 959 812 G    HW: 6R0 959 812 G
   Component: J389__TSG_HR  008 1611
   Coding: 18BC32
Address 10: Park/Steer Assist (J446)       Labels: 6R0-919-475.clb
   Part No SW: 6R0 919 475 C    HW: 7E0 919 475
   Component: PARKHILFE 4K  H11 0013
   Revision: --------    Serial number: 47361212601014
   Coding: 308001
   ROD: EV_VW250ParkiAssis2.rod
   VCID: 3E7926B8A18974EEA6F-806B
   Component: VW10Airbag01M H10 0020
   Revision: --------    Serial number: 003GX01JKVVP
   Coding: 00314D
   Shop #: WSC 01383 785 00200
   ROD: EV_AirbaVW10BPAVW250_VW24.rod
   VCID: 4A917A68ED41C84E0A7-801F
   Crash sensor for side airbag; driver side:
   Serial number: 3575HRB405N1C4LI7929
   Crash sensor for side airbag; passenger side:
   Serial number: 3585HRB405B1D5MS8GS2
   Crash sensor for side airbag; rear driver side:
   Serial number: 3515RRB405B17ABS901.
   Crash sensor for side airbag; rear passenger side:
   Serial number: 3525RRB405B181TUDPKC
   Part No SW: 6R0 920 870 C    HW: 6R0 920 870 C
   Component: KOMBI         H05 0607
   Coding: 140E01
   Shop #: WSC 00233 572 91226
   ROD: EV_Kombi_UDS_VDD_RM09_SE35.rod
   VCID: 356B399494BFB7B6775-8060
1 Fault Found:
12664832 - Function Restricted due to Missing Message(s)
          U1111 00 [009] - -
                    Fault Status: 00000001
                    Fault Priority: 6
                    Fault Frequency: 1
                    Reset counter: 253
                    Mileage: 0 km
                    Date: 2000.00.00
                    Time: 00:00:00
Address 19: CAN Gateway (J533)       Labels: 6N0-909-901-19.lbl
   Part No SW: 6N0 909 901     HW: 7H0 937 090
   Component: GW-K-CAN TP20 H72 0708
   Revision: B9072001
   Coding: 002200
   Shop #: WSC 73430 790 00216
   VCID: F0E54880235D529EE43-80A5
1 Fault Found:
00381 - Databus Instrument Cluster
                    Fault Priority: 1
                    Fault Frequency: 1
                    Reset counter: 252
                    Time Indication: 0
   Component: IMMO          H05 0607
   Shop #: WSC 00000 000 00000
   ROD: EV_Immo_UDS_VDD_RM09_VN35.rod
   VCID: EAD15AE80D81A84EAA7-80BF
Address 2E: Media Player 3 (J650)       Labels: 5N0-035-342.lbl
   Part No SW: 5N0 035 342 F    HW: 5N0 035 342 F
   Component: SG EXT.PLAYER H18 0530
   Revision: A1001003    Serial number: 7662584630
   Coding: 010100
   VCID: 2A511AE84501E84EEA7-807F
1 Fault Found:
                    Fault Priority: 6
                    Fault Frequency: 1
                    Reset counter: 253
                    Mileage: 0 km
                    Time Indication: 0
Address 37: Navigation (J0506)       Labels: 1T0-035-680.clb
   Part No SW: 1T0 035 680 L    HW: 1T0 035 680 C
   Component: RNS-MID       H06 5218
   Revision: AB001001    Serial number: VWZ6Z7L7654213
   Coding: 04000442040000A10001
   Shop #: WSC 12345 123 12345
   VCID: 3777339C86B345A6659-8062
   Subsystem 1 - Part No: 1T0 919 859 B
   Component: EU West V9  7918
   Part No: 6R0 423 156 B
   Coding: 11250
   Shop #: WSC 00788
   VCID: 2F670BFCEAE38D663D9-807A
Address 55: Xenon Range (J431)       Labels: 6R0-907-357.clb
   Revision: --------    Serial number: --------------
   Coding: 0112000001000000
   ROD: EV_HeadlRegulVWLWRPt.rod
   VCID: F7F7739C4E3305A6259-80A2
Address 56: Radio (J0506)       Labels: 1T0-035-680.clb
Address 77: Telephone (J412)       Labels: 7P6-035-730.clb
   Part No SW: 7P6 035 730 L    HW: 7P6 035 730 L
   Component: TELEFON       H15 3200
   Revision: 1B001001    Serial number: 00007664158506
   Coding: 0501000000010110
   ASAM Dataset: EV_UHVNA 002720
   ROD: EV_UHVNA.rod
   VCID: 3B7F2FACB29B61C6811-806E
1 Fault Found:
12670208 - No Communication with Instrument Cluster
          U0155 00 [009] - -
                    Fault Priority: 6
                    Fault Frequency: 1
                    Reset counter: 207
End   ---------------------------------------------------------------------
I went to the VW dealer to adapt this BCM Max in my R-line. With its New diagnostic tool (not VAS 5054) and via online with factory (told me them) they were unable adapt this BCM in my R-line.
SOLUTION :arrow: http://www.uk-polos.net/view ... 00#p497844
sanderb wrote: bcm 6R0 937 087 D
Yes, no problem. Just consider installing the wires correctly.
Please, click here http://www.uk-polos.net/view ... 97#p483697
Ugabista
Drives: Vw Polo 6R 1.6TDI 90CV CAYB
Re: New Member. R-line 1.2 TSI 90hp 119gr.
Post by Ugabista »
[quote="ciclo"]
New Mod:
Volmeter
Wonderful mod :)
Mart!n-GTI-DK wrote:It's a bit sad that Ciclo's excellent build thread has been turned into a "questions to ciclo thread".
You're absolutely right my good friend Martin, I would have a better organized thread.
In any case, I'm guilty of this. Image
I take this opportunity to tell you I bought a pair of LEDs for indicators and one for reverse gear. Just to test how they work.
Also I have another mod to test, but it will take a month of tests. After I will upload some pictures in my thread, but I will not say I've done. :lol:
Just like last year: Glædelig jul og Godt Nytår 2015
"Happy New Year 2015 to all".Image
Ugabista wrote:
ciclo wrote:New Mod:
-Voltmeter
Hi friend,
Which the outer size of the voltmeter box?
Alloys up to the car cigarette lighter?
What are the characteristics voltmeter, DC 0-100V?
The links do not work ... :(
Hug
Ugabista, I tell you the right links if you edit and delete the pictures from your "quote" like I just did. :lol:
My finger scroll will thank you.
EDIT: Thank you 8)
Please thoroughly read description.
http://www.ebay.com/itm/DC-3-00-32V-Dig ... 20f2f70d37
http://www.ebay.com/itm/5-PCS-LOT-0-36- ... 1e96eb8a70
Store: http://stores.ebay.com/jennyear
lighter: http://www.uk-polos.net/view ... 95#p465295
Ugabista
Post by Ugabista »
Voltmeter discreet and very helpful :)
Locked
