ciclo. Wife's Golf MK7.5 Ready2Go 1.0 TSI 6MT 200Nm/l 115HP. 🧙‍♂️
Locked
Re: ciclo. Wife's Golf MK7.5 Ready2Go 1.0 TSI 6MT 200Nm/l 115HP. First and Last pages UPDATED !!!
While getting parts for my upcoming 2022-2023 project (DCC)😊, I discovered a gift in the form of leaks and stains in the engine bay.
There is an Oil leak by the AC compressor shaft.
Due to the natural movement of the Poly-V belt, the oil from the A/C compressor is spreading everywhere, surrounding pipes, A/C condenser, noise insulation (bottom cover), etc... Poly-V belt is impregnated with the AC Compressor oil.
The air conditioning system cools, it does what it has to do, seizing of the AC compressor is not appreciated, nor has any type of fault been diagnosed in the air conditioning system.
The oil leak started last week, I cleaned the noise insulation to observe the behavior of the oil leak. Yesterday I removed the noise insulation to take pictures and make the following video in which it is clearly seen that the AC compressor shaft seal has suffered excessive heating.
💎💎💎Original Video :arrow: :arrow: :arrow: : https://www.youtube.com/embed/FnXirlPCo ... autoplay=1 ... 🦈🤭
My wife's Golf is still under VW warranty, I will request the replacement of the AC compressor, the Poly-V belt, and other possible damaged parts depending on the result of the inspection for possible metal chips inside the AC compressor.
I will continue to report 'in detail' (with many pics) on the solution/decision taken by my regular VW dealer to fix this issue.🤐
If necessary, I will contact the customer service of VW Spain and 'Germany' to inform them with precision and 'accuracy' of everything that happens.
I would be very grateful if my regular VW dealer would fix this problem this time without breaking other parts of the car and treating me with the utmost respect.🤷‍♂️
Post dedicated to the followers of this thread (a little info):
Before continuing with the project 2022/2023 (Dynamic Chassis Control - DCC) the leak from the A/C compressor must be solved/repaired, which opens another new process and leaves the DCC project on standby.
Regardless of the solution/decision the VW dealer makes next week about oil/refrigerant or refrigerant oil leaking from the A/C compressor shaft, I have been purchasing an original A/C compressor, and 140A alternator at excellent condition from a 'new vehicle' -donor car, 1400km- with engine DKRF.
According to ETKA, they are fully up to date for my wife's golf. Logically, I verified that both/this parts, and the equipment of our Golf meet ALL the specifications indicated by the manufacturer (PR codes, wiring thickness, etc).
I will keep this new A/C compressor saved for a quick solution in case of any inconvenience or bad decisions/repairs by third parties to solve the current A/C compresor leak.
The 140A Alternator/Generator is just to check differences with respect to the 110A alternator that my wife's Golf 7.5 currently has installed.
It's simple curiosity in order to verify that both alternators show similar or identical load values. Supposedly the 140A will make the charge a bit faster.
(this 140A alternator was a real bargain that I couldn't pass up, just that).
As you all know, these types of alternators are colloquially called 'smart alternators', which with the help of the battery voltage monitor and the GW, supply exactly the amount of voltage that the battery needs for its optimal charge level, but not the maximum, as was the case with vehicles without battery monitoring (for example my 6R with a factory 140A alternator). In this way it is possible to slightly reduce fuel consumption and extend the useful life of the Battery (EU6, etc).
On my 6R the load voltage is always between 13.8-14.1 V (on the retrofitted voltmeter). In the Golf the charging voltage, even with almost all consumers connected, rarely exceeds 12.7V.
Aclaratory Note:
I don't have the need to change the Alternator from 110A to 140A even with all the retrofits I have done on my wife's Golf. I have always verified with the multimeter that the 110A Alternator charges the AGM Battery 'Perfectly' and fulfills its function with total correctness after install new units/parts.
https://www.youtube.com/shorts/mo5ItOIiBb8
VCDS Autoscan
Monday,03,October,2022,12:57:00:32438
VCDS Version: 22.9.0.0 (x64)  HEX-V2 CB: 0.4623.4
Data version: 20220830 DS341.0
www.Ross-Tech.com
VIN: WVWZZZAUZKPCICLOW   License Plate: NEW RLHS C, NEW FRONT DOOR MODULES HW-P, MINOR CHANGES BVWD ... OK!
Mileage: 47959km-29800mi   Repair Order:
Chassis Type: AU-VW37 (3Q0)
Scan: 01 03 08 09 10 13 15 17 19 29 39 3C 42 44 4B 52 5F 65 6C A5
          A9 D6 D7
VIN: WVWZZZAUZKPCICLOW   Mileage: 47959km-29800miles
29-Left Light -- Status: OK 0000
39-Right Light -- Status: OK 0000
42-Door Elect, Driver -- Status: OK 0000
4B-Multifunc. Module -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
A5-Frt Sens. Drv. Assist -- Status: OK 0000
A9-Struct. Borne Sound -- Status: OK 0000
D6-Light Ctrl Left 2 -- Status: OK 0000
D7-Light Ctrl Right 2 -- Status: OK 0000
Address 01: Engine (J623-DKRF)       Labels:. 04E-907-309-V1.clb
   Part No SW: 04C 906 025 L    HW: 04C 907 309 BB
   Component: R3 1.0l TFS   H20 6198
   Revision: D7H20000    CVN: 92B19492
   Coding: 01190032234415082000
   Shop #: WSC 00046 123 12345
   ASAM Dataset: EV_ECM10TFS01104C906025L 002003
   ROD: EV_ECM10TFS01104C906025L_002.rod
   VCID: 290F00D8897EC92390D-807C
   VINID: 9E69EAAAA465A9B8000041051C011774D2
Readiness: 0000 0000
Address 03: ABS Brakes (J104)       Labels: 5Q0-907-379-IPB-V1.clb
   Part No SW: 5Q0 614 517 DD    HW: 5Q0 614 517 AC
   Component: ESC           H25 0424
   Revision: 00000000    Serial number: 51998000000173
   Coding: 01FA6AA114202170477B060560CA2580562884E26006A4733420F00A40AA430B00000012121212B835351919323200
   ASAM Dataset: EV_Brake1UDSContiMK100IPB 037009
   ROD: EV_Brake1UDSContiMK100IPB_037_VW37.rod
   VCID: 76B51BA40840D6DBCDF-8022
Address 08: Auto HVAC (J255)       Labels:| 5G0-907-044.clb
   Part No SW: 5G0 907 044 CF    HW: 5G0 907 044 CF
   Component: Climatronic   H04 1801
   Revision: 00001K08
   Coding: 000200032001100D1105004C0018542A
   Shop #: WSC 00028 028 00068
   ASAM Dataset: EV_ACClimaBHBVW37X 006145
   ROD: EV_ACClimaBHBVW37X_006_VW37.rod
   VCID: 6D8734C87D1615033C5-8038
   Fresh air blower control module (front):
   A/C pressure/coolant temperature sensor:
   Air quality sensor:
Address 09: Cent. Elect. (J519)       Labels:. 5Q0-937-08X-V2.clb
   Part No SW: 5Q0 937 084 EC    HW: 5Q0 937 084 CG
   Component: BCM MQBAB H   H40 0511
   Serial number: 72007150025702
   Coding: 000000000000000000000000000000000000000000000000000000000000
   ASAM Dataset: EV_BCMMQB 022001
   ROD: EV_BCMBOSCH_022_VW27.rod
   VCID: 7DA704882D7685838C5-8028
   Wiper motor control module:
   Subsystem 1 - Part No SW: 5G1 955 119 A    HW: 5G1 955 119 A  Labels: 5QX-955-119-V1.CLB
   Component: WWS    180621  043 0551
   Serial number:         180705074106
   Coding: 0F4DFD
   Rain/Light Recognition Sensor:
   Subsystem 2 - Part No SW: 5Q0 955 547 C    HW: 5Q0 955 547 C  Labels: 5Q0-955-547.CLB
   Component: RLHS  054 0206
   Serial number: SBY22M01D06H23M07S44
   Coding: 00A8DD
   Anti-theft alarm system sensor:
   Subsystem 3 - Part No SW: 5Q0 951 172     HW: 5Q0 951 172
   Component: Sensor, DWA  005 0316
   Serial number: 000000000ZY191251XZQ
   Alarm horn:
   Subsystem 4 - Part No SW: 5QD 951 605     HW: 5QD 951 605
   Component: Sirene, DWA  005 0313
   Serial number: 00002854456462182207
   Steering Column Switch:
   Subsystem 5 - Part No SW: 5Q1 953 507 GB    HW: 5Q1 953 549 F
   Component: J527 SMLS MQB  005 0080
   Serial number: 00000023032104400679
Address 10: Park/Steer Assist (J791)       Labels:| 5Q0-919-298.clb
   Part No SW: 5QA 919 298 K    HW: 5QA 919 298 A
   Component: PLA 3.0 12K   H07 0073
   Serial number: 000308417318277
   Coding: 8271567841
   Shop #: WSC 00046 000 00000
   ASAM Dataset: EV_EPHVA2CAU3700000 009055
   ROD: EV_EPHVA2CAU3700000.rod
   VCID: 58E9751CE29480ABFF3-800C
Address 13: Auto Dist. Reg (J428)       Labels:| 5Q0-907-572-V2.clb
   Part No SW: 5Q0 907 572 S    HW: 3QF 907 572 A
   Component: ACC BOSCH MQB H11 0780
   Coding: 2B0D7FE35DFFC728979F81A4614006800000000000B9C00024
   ASAM Dataset: EV_ACCBOSCHVW416 003015
   ROD: EV_ACCBOSCHVW416_003_VW37.rod
   VCID: 47CBA6603F2A1F53669-8012
Address 15: Airbags (J234)       Labels:| 5Q0-959-655.clb
   Part No SW: 5Q0 959 655 BJ    HW: 5Q0 959 655 BJ
   Component: AirbagVW21    006 0339
   Serial number: 003VWR4F1CUQ
   Coding: 98CCC000000000005C0000CF000800000065
   Shop #: WSC 00028 028 00064
   ASAM Dataset: EV_AirbaVW20SMEVW37X 002160
   ROD: EV_AirbaVW20SMEVW37X_VW37.rod
   VCID: 094F605869BEA923B0D-805C
   Left seat belt tensioner:
   Subsystem 1 - Part No SW: 5G0 980 945 B    HW: 5G0 980 945 B
   Component: BeltPretRevFL  H37 0350
   Serial number: 34169667E30071820325
   Coding: 333135
   Right seat belt tensioner:
   Subsystem 2 - Part No SW: 5G0 980 946 B    HW: 5G0 980 946 B
   Component: BeltPretRevFR  H37 0350
   Serial number: 34169668E31071830145
   Coding: 333135
   Subsystem 3 - Part No SW: -----------    HW: 480 002 307 18
   Component: SideSensor_Df  001 0887
   Serial number: 35700000000F8745C23S
   Coding: 2D2D2D
   Subsystem 4 - Part No SW: -----------    HW: 480 002 807 18
   Component: SideSensor_Pf  001 0887
   Serial number: 358000000000EC18233G
   Coding: 2D2D2D
   Subsystem 5 - Part No SW: -----------    HW: 480 403 107 18
   Component: SideSensor_Dr  003 6149
   Serial number: 3510001A729FD154210-
   Coding: 2D2D2D
   Subsystem 6 - Part No SW: -----------    HW: 480 403 107 18
   Component: SideSensor_Pr  003 6149
   Serial number: 3520001A929FD1515577
   Coding: 2D2D2D
   Subsystem 7 - Part No SW: -----------    HW: 480 402 306 18
   Component: FrontSensor_D  003 6149
   Serial number: 3550001A326704A3C63.
   Coding: 2D2D2D
Address 17: Instruments (J285)       Labels:| 5G0-920-XXX-17.clb-SRI3
   Part No SW: 5G1 920 791 B    HW: 5G1 920 791 B
   Component: KOMBI         404 4191
   Coding: 07A532806E8C000801887A0F5401000080000000
   ASAM Dataset: EV_DashBoardVDDMQBAB 009058
   ROD: EV_DashBoardVDDMQBAB_009_VW26.rod
   VCID: 2B03FAD08382DB33621-807E
Address 19: CAN Gateway (J533)       Labels:| 3Q0-907-530-V1.clb
   Part No SW: 3Q0 907 530 AR    HW: 3Q0 907 530 C
   Component: GW MQB High   521 5502
   Serial number: 09012020001767
   Coding: 030900047F085700FB0002FE080F00010001070000000000000000000000
   GVL: 014E3C100000000040CC80000002480000000000000200000000000000000000
   ASAM Dataset: EV_GatewNF 013026
   ROD: EV_GatewNF_VW37.rod
   VCID: 7F5BFE80277A97939E9-802A
   Generator:
   Component: 4-01-02-01-04
   Multifunction steering wheel control module:
   Subsystem 2 - Part No SW: 1EA 959 442 F    HW: 1EA 959 442 F
   Component: MFL  H50 0420
   Serial number: 17044958021162102894
   Coding: AE2B00
   Subsystem 3 - Part No SW: 5Q0 915 181 K    HW: 5Q0 915 181 K
   Component: J367-BDMHella  H10 9070
   Serial number: 9353818504
Address 29: Left Light (J1018)       Labels: 8V0-907-399.clb
   Part No SW: 8V0 907 399 D    HW: 8V0 907 399 D
   Component: LCM_MLBevoH08 0014
   ASAM Dataset: EV_LCMLeftHELLAAU736 001012
   ROD: EV_LCMLeftHELLAAU736_VW37.rod
Address 39: Right Light (J1023)       Labels: 8V0-907-399.clb
   ASAM Dataset: EV_LCMRightHELLAAU736 001012
Address 3C: Lane Change (J1086)       Labels:* None
   Part No SW: 2Q0 907 686 B    HW: 2Q0 907 686 B
   Component: HRE3_Kl15_Mst H07 0150
   Serial number: 00000587514012
   Coding: 52A54640
   ASAM Dataset: EV_HREntryHellaGen3Kl15 002001
   ROD: EV_HREntryHellaGen3Kl15_002_VW27.rod
   VCID: 392FD09879DE79A3E0D-806C
   Lane change assistance control module 2:
   Subsystem 1 - Part No SW: 2Q0 907 685 B    HW: 2Q0 907 685 B
   Component: HRE3_Kl15_Slv  H07 0150
   Serial number: 00000587481913
Address 42: Door Elect, Driver (J386)       Labels:| 5QX-959-X93-42.clb
   Part No SW: 5Q4 959 593 P    HW: 5Q4 959 593 P
   Component: TSG FS        011 0912
   Serial number: 0000417322781
   Coding: 00150220D000048000001000
   Shop #: WSC 00030 935 00052
   ASAM Dataset: EV_DCU2DriveSideMAXHCONT 001005
   ROD: EV_DCU2DriveSideMAXHCONT_VW37.rod
   VCID: 52FD8734C468AAFB017-8006
   Rear Driver Side Door Control Module:
   Subsystem 1 - Part No SW: 5Q4 959 811 F    HW: 5Q4 959 811 F  Labels: 5QX-959-81X-V1.CLB
   Component: Fond FHSG DRV  010 0004
   Serial number: 00000000000009798407
   Coding: 010000
Address 44: Steering Assist (J500)       Labels:| 5Q0-909-144.clb
   Part No SW: 5Q0 909 144 AA    HW: 5Q0 909 144 AA
   Component: EPS_MQB_ZFLS  131 1081
   Coding: 931F0000
   Shop #: WSC 12345 102 209715
   ASAM Dataset: EV_SteerAssisMQB 015157
   ROD: EV_SteerAssisMQB_015.rod
   VCID: 73B322B01B32C3F3EA1-8026
Address 4B: Multifunc. Module (J745)       Labels:| 3Q0-907-338-V2.clb
   Part No SW: 3Q0 907 338 E    HW: 3Q0 907 338 E
   Component: FCM MQB Low   003 0371
   Serial number: 01081930001280
   Coding: 00000005090016C200207F07620000000000000000000000000000000000
   Shop #: WSC 12345 123 12345
   ASAM Dataset: EV_MultiModulContiVW48X 003003
   ROD: EV_MultiModulContiVW48X_003.rod
   VCID: 372BD6A04FCA6FD3169-8062
Address 52: Door Elect, Pass. (J387)       Labels:| 5QX-959-X92-52.clb
   Part No SW: 5Q4 959 592 P    HW: 5Q4 959 592 P
   Component: TSG BFS       011 0912
   Serial number: 0000423015792
   Coding: 00150220DE00048000001000
   Shop #: WSC 00030 935 00034
   ASAM Dataset: EV_DCU2PasseSideMAXHCONT 001005
   ROD: EV_DCU2PasseSideMAXHCONT_VW37.rod
   VCID: 51FF8838C16ED1E338D-8004
   Rear Passenger Door Control Module:
   Subsystem 1 - Part No SW: 5Q4 959 812 F    HW: 5Q4 959 812 F  Labels: 5QX-959-81X-V1.CLB
   Component: Fond FHSG PSG  010 0004
   Serial number: 00000000000009846262
   Coding: 090000
   Part No SW: 3Q0 035 874 C    HW: 3Q0 035 874 C
   Component: MU-S-ND-ER    853 0879
   Serial number:
   Coding: 02731001FF0000004111010140880A231F0507E401200400CF
   ASAM Dataset: EV_MUStd4CDELP 001001
   ROD: EV_MUStd4CDELP_VW26.rod
   VCID: 323DE7B4A4A88AFB217-8066
   Display and control head 1 for information electronics:
   Subsystem 1 - Part No SW: 5G6 919 605 B    HW: 5G6 919 605 B
   Component: ABT_Std-2_Nav  H52 8130
   Serial number: VWZ6ZHV2691212
   Data carrier:
   Subsystem 2 - Part No SW: 5NA 919 866 CA    HW: -----------
   Component: ECE AS 22/23  --- 1810
   Part No SW: 5Q0 907 273 F    HW: 5Q0 907 273
   Serial number: 30000000250801
   ASAM Dataset: EV_RDKBERU30 006001
   ROD: EV_RDKBERU30_006_VW37.rod
   VCID: 3829D59C42D460AB1F3-806C
Address 6C: Back-up Cam. (J772)       Labels:| 5Q0-980-556.clb
   Part No SW: 5Q0 980 556 B    HW: 5Q0 980 556 B
   Component: RVC Compact   H18 0231
   Coding: 01040201C600201F000060
   ASAM Dataset: EV_CamSysRVRVCPANAMQBAB 006009
   ROD: EV_CamSysRVRVCPANAMQBAB_006_VW37.rod
Address A5: Frt Sens. Drv. Assist (R242)       Labels:* None
   Part No SW: 2Q0 980 653 C    HW: 2Q0 980 653
   Component: MQB MFK 3.0   H16 1302
   Serial number: E80320004213340
   Coding: 0000018811EEC028889F2C801030004400438000000000000000000000000000
   ASAM Dataset: EV_MFK3ValeoMQB 007042
   ROD: EV_MFK3ValeoMQB_007_VW27.rod
   VCID: 3537DCA855C69DC3045-8060
Address A9: Struct. Borne Sound (J869)       Labels: 4H0-907-159.clb
   Part No SW: 5F0 907 159     HW: 4H0 907 159 A
   Component: SAS-GEN 2     H07 Z001
   Serial number: 181027201414
   ASAM Dataset: EV_SoundActuaGen2AU64X 003010
   ROD: EV_SoundActuaGen2AU64X.rod
   VCID: 6A8D3FD44CF8023B597-803E
Address D6: Light Ctrl Left 2 (A31)       Labels: 7PP-941-572.clb
   Part No SW: 7P5 941 572 A    HW: 7P5 941 572 A
   Component: LED1L         H06 0002
   ASAM Dataset: EV_LEDMinMaxL_KEBODAVW481 001003
   ROD: EV_LEDMinMaxL_KEBODAVW481.rod
Address D7: Light Ctrl Right 2 (A27)       Labels: 7PP-941-572.clb
   Component: LED1R         H06 0002
   ASAM Dataset: EV_LEDMinMaxR_KEBODAVW481 001003
End----------(Elapsed Time: 01:39, VBatt start/end: 12.6V/12.6V)-----------
🤭 https://www.youtube.com/embed/2PlgL5xiU ... autoplay=1
https://www.youtube.com/watch?v=8p4lYNCJvAM&t=487s
My regular VW dealer fixed the oil leak from the A/C compressor shaft.
The original Mahle AC compressor was changed for a new Denso brand, as well as the poly-v belt, the O-rings of the high and low lines, the guide rings, and the corresponding bolts.
The technician neatly cleaned the bottom engine noise insulation, which is a great indicator of a job very well done.
Images:
After a first inspection, there are no strange/weird sounds, the movement of the pulleys/poly-v belt is smooth, and the air conditioning system works correctly, ... inspiring full confidence. 8)
I received 'exceptional' treatment from all the staff at the VW dealership.
My deepest thanks to VW, ... AWESOME!
(sun rising, 08:30 am)
https://www.youtube.com/embed/3UUdLm2Tf ... autoplay=1
Notes:
It took one morning to perform this repair, from breakfast 08:30 am to lunch 13:30 pm.
The repair was covered by the VW Guarantee, but I would like to say that although this is a priority for many people, which I deeply respect, it is not for me.
My priority is harmony in actions, a long time ago I understood that money enslaves thoughts.
Diagnosis with the new A/C compressor.
etc...
VCDS Autoscan.
Thursday,20,October,2022,09:40:46:32438
www.Ross-Tech.com
VIN: WVWZZZAUZKPCICLOW   License Plate: AFTER VWD OK!
Mileage: 48149km-29918mi   Repair Order:
          A9 D6 D7
VIN: WVWZZZAUZKPCICLOW   Mileage: 48149km-29918miles
Address 08: Auto HVAC (E87)       Labels:| 5G0-907-044.clb
   Part No SW: 5NA 907 044 AJ    HW: 5NA 907 044 AJ
   Component: AC Automat    H50 1301
   Revision: 20K03000    Serial number: 00000A00202735
   Coding: 000200032001100D1115004C0018542A
   ASAM Dataset: EV_ACTouchPrehVW37X 001010
   ROD: EV_ACTouchPrehVW37X_VW37.rod
   VCID: 074B66607FAADF53A69-8052
   Air quality sensor:
   Humidity sensor: exterior:
   Subsystem 2 - Part No SW: 4H0 907 658 D    HW: 4H0 907 658 D
   Component: G935 MuFu  H05 0010
   Serial number: AAE88B8400PAG0MUFU05
   Coding: 0F4DFD
   Coding: 00A8DD
   Alarm horn:
   Coding: 8271567841
   Coding: 333135
   Coding: 333135
   Coding: 2D2D2D
   Coding: 2D2D2D
   Coding: 2D2D2D
   Coding: 2D2D2D
   Coding: 2D2D2D
   Generator:
   Coding: AE2B00
   Coding: 52A54640
   Coding: 010000
   Coding: 931F0000
   Coding: 090000
   Serial number:
   Data carrier:
End----------(Elapsed Time: 01:40, VBatt start/end: 14.2V/14.1V)-----------
https://www.youtube.com/watch?v=HIqA5EZNGn8
... continuing the 2022/2023 project. (receiving necessary parts, in my case)
https://www.youtube.com/watch?v=_K4wsMyHwqc 😊
Golf 7.5 Brake pedal depressor VAG 1869/2. Broom handle.🤭
Original.
Similar.
Original Video :arrow: :arrow: :arrow: : https://www.youtube.com/embed/rkO1QfMKG ... autoplay=1
Warning:
After a pilgrimage through the local stores in my city and checking the grip between the tubes of several broom/handles/sticks, this was the only one that met my expectations.
Golf 7.5 1.0 TSI Checking alternator 110A operation. Activating consumers from essential to MAX.
Test conditions:
Once I have traveled 7km and without waiting for the stabilization of the charging system (Alt/Gen-voltage regulator, Battery monitoring module, GW-ECU) I activate consumers with the engine idling:
Original Video :arrow: :arrow: :arrow: : https://www.youtube.com/embed/vTABiRiQ3 ... autoplay=1
It went roughly like this:
Essential, Radio-Nav, Lights, Climate ON - A/C OFF, A/C ON - MAX, Heated rear window, Heated seats, Heated steering wheel, and something else...
Amps consumption values can vary considerably depending on various factors (temperatures, battery condition, test conditions, etc).
While and after reaching the Maximum load the system began to stabilize and the values began to decrease slowly (logically).
Correct operation that will serve as a comparison when I install the new 140A alternator.
https://www.youtube.com/watch?v=N9yvcDYo3N4
Golf 7.5 Voltage regulator -C1-. Basic setting - Adaption (test bench).
Original Video :arrow: :arrow: :arrow: : https://www.youtube.com/embed/IV2fPn4c- ... autoplay=1
... some tests before installing the 140A Alternator.🤷‍♂️
These little posts that I am doing are related to the 2022/2023 project (DCC).😊
Golf 7.5 1.0 TSI. New set of wheels. From Lyon 15" to Linas 16".
Yesterday I installed a new complete set of wheels (rims and tires) as I needed to change the current tires (3mm deep).
From.
To.
:arrow: Premiun Wheels.👌
My main reason for buying 16" rims is because I am going to install bigger front brakes on my wife's golf, at first I thought from 270mm to 288mm discs, but I changed my mind and it will be 312mm discs. On the other hand, it is specified in erWin that the Golf 7-7.5 with DCC are equipped with brake systems for 16" wheels (or larger).
:arrow: 16" Brake caliper... :arrow: https://www.vwgolf.org/front_brakes-2060.html :arrow: https://www.vwgolf.org/front_brakes-2057.html 1)
312mm, OEM.
eBay, from Germany. (Blue 🤭)
I have never installed All season tires, so these new tires will expand my knowledge.
'Currently' I prefer tires with a larger 'balloon' (sidewall), which as you know offers more comfort.
Tomorrow I have an appointment to install the tire pressure sensors at the usual trusted Michelin workshop, which has a machine and a worker that balances the wheels impeccably.😍
I received the new Linas wheels excellently well balanced, but when installing the new sensors/valves they will have to be rebalanced.
https://youtube.com/clip/UgkxBEoBZ_zhT6 ... GEAzplP7XA
Visual inspection of the 'new' 140A alternator. (before installing)
Remove the plastic cover "carefully" (erWin).
With a flat screwdriver, slightly pry the edge of the cover at various points (circularly) so that it is released from its three fastening points. It is not necessary to bend the body of the plastic cover (try to keep the plastic cover parallel to the alternator body).
The diode rectifier plate, the three phases, and the voltage regulator can be seen.
The screws/bolts and solders indicate how the different elements are electrically connected.
New as a toddler.👶✅
TSI (1.4, 1.0)
Golf 7.5 Installation of new sensors for the TPMS. Optimized wheel balancing. New dataset for TPMS.
:arrow: Previous info: viewtopic.php?p=594170#p594170
-Installation.
(same as other times, checking for air bubbles underwater)
-Balancing.
A laser indicates the exact point for the placement of the wheel weights.
-New dataset.
Generated with💎TinyQ program💎for Odis. 🤗Ty.
W at ... :mrgreen:
VCDS Autoscan.
Tuesday,08,November,2022,12:00:11:32438
www.Ross-Tech.com
VIN: WVWZZZAUZKPCICLOW   License Plate: NEW TPM SENSORS OK!
Mileage: 48410km-30080mi   Repair Order:
          A9 D6 D7
VIN: WVWZZZAUZKPCICLOW   Mileage: 48410km-30080miles
Readiness: 0110 0001
   Air quality sensor:
   Coding: 0F4DFD
   Coding: 00A8DD
   Alarm horn:
   Coding: 8271567841
   Coding: 333135
   Coding: 333135
   Coding: 2D2D2D
   Coding: 2D2D2D
   Coding: 2D2D2D
   Coding: 2D2D2D
   Coding: 2D2D2D
   Generator:
   Coding: AE2B00
   Coding: 52A54640
   Coding: 010000
   Coding: 931F0000
   Coding: 090000
   Serial number:
   Data carrier:
End----------(Elapsed Time: 01:41, VBatt start/end: 13.3V/13.3V)-----------
https://www.youtube.com/watch?v=oRi5psbm8JY
Golf 7.5 1.0TSI Factory running gear, before DCC and other previous adaptations (inspection 🧐).
Original Video :arrow: :arrow: :arrow: : https://www.youtube.com/embed/V8bho7Asw ... autoplay=1
I took these pictures a few years ago, when I installed the tire pressure sensors on the 15" rims.😉😄
Then these parts were installed:
... which I recently inspected and continue in perfect condition. ✅
I think I already have all the parts (mechanical part of the DCC project), and specific tools, to start installing them together with the new blue brakes, although it will not be something immediate due to some natural family circumstances of the law of life.
Update 02/2023:
Until spring I will not be able to continue with the DCC project.🌼
https://www.youtube.com/watch?v=aEPx0Qpq3Kw
VCDS update 03/2023
Locked
