Page 6 of 15
Re: Introducing my Lightning McQueen LM95
Posted: Tue Dec 24, 2019 10:57 am
by ag69
A Pillar Tweeters and Parking Ticket Holders -- > Edited and Added photos on 14 Dec 2021
After getting few cuts on most of fingers and using enormous forces, finally could get A pillars off. Thanks to some long plastic pry tools it became less hard :D. Not forgetting to mention Ciclo and antardaksh04
"V" shaped metal clips remain in car metal body. Removing "metal clips" also needs force. Don't be surprised if clips fly from one side of car to another.
Here is how it looks after removing A pillar. Metal clips are still in the metal body.
A-pillar Left
A-pillar right
A-pillar left with parking ticket holders
A-pillar right with parking ticket holder Bottom
A-pillar right with parking ticket holder Top
A-pillar tweeter wiring
A-pillar left with tweeter
A-pillar Right with tweeter
Parts used :
    • Wire used -- 0.5 sq mm
    • Soldering Gun for soldering Joints
    • Sleeve to cover the soldered joints
    • Insulating Tape wrapped for all joints
    • Applied loom tape for whole wires.
    • A) 3V0867333 -- Parking Ticket Holder
    • B) 6R6867234 -- A-pilalr Right
    • C) 6R6867233 -- A-pillar Left
    I don't know in which (trans) state I live but I was expecting ticket holder to get nice hole alignment so I can put rubber grommet. But .. it was far from that...
    so a handy useful double sided tape with multiple layers helped me.
    A pillar with tweeters come with a connector 1J0 971 972. So either you can use a appropriate connector (3B0 972 712) or splice wire and use it connect to appropriate wires.
    Also long plastic tools are handy while putting in new A pillar, they help in aligning clips (which are in A pillar NOW) in body
    Posted: Wed Feb 05, 2020 6:42 am
    by ag69
    Dome Light LED --> Added photos
    Recently got a Sylvania LED Cool White
    Replaced factory fitted dome light (N 017723) which had 10W consumption with this, which is rated at 0.5W
    Sylvania has two models 578 fits 6411 and 6411 fits 578. But I could not locate difference.
    Here are images of the product:
    Front
    Rear
    Here is how it looks:
    [youtube]https://youtu.be/kBrdrmVOs7s[/youtube]
    Posted: Wed Feb 05, 2020 7:06 am
    by ciclo
    Posted: Wed Feb 05, 2020 7:17 am
    by ag69
    Thank you Ciclo
    Posted: Sat Mar 07, 2020 7:07 am
    by ag69
    Though, I have not made any changes here is latest scan.
    Even after clearing both Door Control Module, they reappear.
    Saturday,07,March,2020,06:35:28:47040
    VCDS Version: 19.6.2.0 (x64) HEX-V2 CB: 0.4508.4
    Data version: 20190930 DS308.0
    www.Ross-Tech.com
    VIN: WVWL14601FT043293 License Plate: MH12LM0095
    Mileage: 280km-902mi Repair Order:
    Chassis Type: 60-VW25 (6N0)
    Scan: 01 02 03 04 08 09 15 17 19 25 44
    VIN: WVWL14601FT043293 Mileage: 280km-902miles
    Address 01: Engine (J623-CBZB) Labels:. 03F-906-070-CBZ.clb
    Part No SW: 03F 906 070 KC HW: 03F 907 309 AJ
    Component: SIMOS10.22AH10 6270
    Revision: --H10--- Serial number:
    Coding: 00250056230400080000
    Shop #: WSC 00793 648 00255
    ASAM Dataset: EV_ECM12TFS02103F906070KC 004006
    VCID: 6D84C0DFDD1A826F121-8038
    Readiness: 0000 0000
    Part No SW: 0AM 300 065 N HW: 0AM 927 769 D
    Component: GSG DSG AG7 431 6561
    Revision: 00043014 Serial number: CU501407085037
    Coding: 0000020
    Shop #: WSC 63002 002 1048576
    VCID: 3A2E3B83D054E5D7C73-806E
    Part No SW: 6R0 907 379 BH HW: 6R0 907 379 AS
    Component: ESP9.0i front H03 0001
    Serial number: --------------
    Coding: 62DD2463422703C3461624724254C0800904
    Shop #: WSC 00788 648 00255
    ASAM Dataset: EV_Brake1ESP90iBOSCH 003020
    VCID: 0554987FE5AA5A2FFA1-8050
    Serial number: 14081404650280
    Coding: 01
    Shop #: WSC 00000 000 00000
    ROD: EV_LWSKLOVW25X.rod
    VCID: 7EA6F793807C09F7BBB-802A
    Part No SW: 6R0 907 044 P HW: 6R0 907 044 P
    Component: Climatronic H12 0614
    Revision: V0000000
    VCID: 40DA496BBA88BF07897-8014
    Part No SW: 6R0 937 087 R HW: 6R0 937 087
    Component: BCM PQ25 H+4 H34 0424
    Revision: BF034001 Serial number: 0681 233141094
    Coding: 3AB82BBF08B30000003800006C2B04900040414F608C0000200000000000
    Shop #: WSC 124697 483 00190
    VCID: 4CC26D5B86C06B6765F-8018
    Subsystem 1 - Part No SW: 6R0 959 802 AL HW: 6R0 959 802 AL Labels: 6R0-959-802.CLB
    Component: ------------- 006 5550
    Serial number: 13102576140821120301
    Coding: 010000
    Subsystem 2 - Part No SW: 6R0 959 801 AH HW: 6R0 959 801 AH Labels: 6R0-959-801.CLB
    Serial number: 13202579140804112607
    Coding: 010000
    Subsystem 3 - Part No SW: 6C0 959 442 HW: 6C0 959 442
    Component: E221__MFL-TAT H04 0019
    Serial number: 2181400090300021AB1B
    Coding: 240000
    Subsystem 4 - Part No SW: 6R0 959 811 L HW: 6R0 959 811 L
    Serial number: 13102580140812095241
    Coding: 020000
    Subsystem 5 - Part No SW: 6R0 959 812 L HW: 6R0 959 812 L
    Serial number: 13202581140821150004
    Coding: 020000
    2 Faults Found:
    01332 - Door Control Module; Passenger Side (J387)
    Fault Status: 00100100
    Fault Priority: 2
    Fault Frequency: 1
    Reset counter: 248
    Mileage: 6143 km
    Time Indication: 0
    Date: 2017.03.01
    Time: 13:39:26
    01331 - Door Control Module; Driver Side (J386)
    Fault Priority: 2
    Fault Frequency: 1
    Reset counter: 248
    Mileage: 6143 km
    Time Indication: 0
    Date: 2017.03.01
    Time: 13:53:46
    Part No SW: 6R0 959 655 J HW: 6R0 959 655 J
    Revision: -------- Serial number: 003GW00VFBN2
    Coding: 003036
    ROD: EV_AirbaVW10BPAVW250.rod
    VCID: 49CC544F89327E4F5E9-801C
    Part No SW: 6RF 920 860 Q HW: 6RF 920 860 Q
    Component: KOMBI H02 0152
    Coding: 140800
    ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A04719
    VCID: 58EA810B429817C7D17-800C
    Address 19: CAN Gateway (J533) Labels:. 6N0-909-901-6R.clb
    Part No SW: 6N0 909 901 HW: 6R0 937 087
    Component: GW-K-CAN TP20 H34 0424
    Revision: BF034001
    Coding: 002300
    VCID: 70BAD9ABCAA86F87397-8024
    Component: IMMO H02 0152
    Serial number:
    ROD: EV_Immo_UDS_VDD_RM09.rod
    VCID: 6A8ECBC3ECF49557773-803E
    Address 44: Steering Assist (J792) Labels:* 6Rx-909-144-V1.clb
    Part No SW: 6RF 909 144 K HW: 6RF 909 144 J
    Component: EPS_ECU H44 0401
    Coding: 0000
    ASAM Dataset: EV_SteerAssisUDSNSK 005005
    ROD: EV_SteerAssisUDSNSK.rod
    VCID: 54F2753B5E7033A73DF-8000
    End----(Elapsed Time: 01:05, VBatt start/end: 11.8V/11.8V. VIgn 11.8V)-----
    Posted: Mon Mar 09, 2020 5:41 pm
    by patil
    ag69 wrote: Sat Mar 07, 2020 7:07 am Though, I have not made any changes here is latest scan.
    With those error codes..
    Does your window glasses go all the way up and down normally with master control switch ?
    Also comfort window function is working normal with key fob?
    Posted: Tue Mar 10, 2020 4:35 am
    by ciclo
    Maybe the battery was not at its best when making the diagnosis.
    Try to make a new Autoscan with the engine started.
    Another, less likely, possibility is that the new door switches you installed are not 100%. (wires, etc)
    Posted: Tue Mar 10, 2020 8:21 am
    by ag69
    thanks patil and ciclo.
    -- yes
    -- yes
    ciclo, I will try and update you once I get all parts assembled.
    sorry to trouble but SOS
    viewtopic.php?f=62&t=70394&p=567179#p567179
    there are two same color coded wires white with black. they are marked 26 and 29
    so how can I find which is which?
    Posted: Tue Mar 10, 2020 8:52 am
    by ciclo
    My dear friend ag69,
    viewtopic.php?f=62&t=70394&p=567182#p567182
    Namaste🙏
    Posted: Tue Mar 10, 2020 9:03 am
    by ciclo
    Posted: Tue Mar 10, 2020 9:42 am
    by ag69
    Thank you Ciclo.
    Posted: Tue Mar 10, 2020 10:25 am
    by ciclo
    Thanks to you!
    Happy to help you.
    Posted: Tue Mar 10, 2020 12:42 pm
    by ag69
    ciclo wrote: Tue Mar 10, 2020 4:35 am Maybe the battery was not at its best when making the diagnosis.
    Bingo, with car powered on and carried clear code and codes have disappeared.
    Thanks ciclo again :)
    Posted: Tue Mar 10, 2020 4:23 pm
    by patil
    Ok problem solved :D
    I knew that the window motors are power hungry devices, but never thought that they hang errors with low voltage.
    Something new I learnt.. thank you Master and ag69. 8)
    Posted: Wed Mar 11, 2020 5:33 am
    by ciclo
    Excellent. In this case, the appropriate conditions for the diagnostic tool were simply provided.
