Greek tdi bluemotion
Rocco-85
Drives: 1.2 tdi bluemotion
Re: Greek tdi bluemotion
Post by Rocco-85 »
After finishing rear pdc i had this fault
its about the fault golf 6 control unit?
because polo doesnt has j527?
Mittwoch,21,Marz,2018,16:23:21:12669
VCDS Version: PCI 17.8.0 lauft auf Windows 7 x86
www.VCDSpro.de
Adresse 10: Einparkhilfe 2 Labeldatei: DRV\1T0-919-475.clb
Steuergerat-Teilenummer: 1T0 919 475 H HW: 1T0 919 475
Bauteil und/oder Version: PARKHILFE PLA H07 0110
Codierung: 100205
Betriebsnummer: WSC 00028 028 00001
VCID: 408B123BD3B2BE46CA-8014
2 Fehlercodes gefunden:
02069 - Geber für Einparkhilfe vorne
011 - Unterbrechung
Umgebungsbedingungen:
Fehlerstatus: 01101011
Fehlerprioritat: 3
Fehlerhaufigkeit: 1
Verlernzahler: 237
Kilometerstand: 110611 km
Zeitangabe: 0
Datum: 2004.14.10
Zeit: 16:11:27
Temperatur: 18.0°C
00466 - Steuergerät für Lenksäulenelektronik (J527)
004 - kein Signal/Kommunikation
Fehlerstatus: 01100100
Fehlerprioritat: 6
Fehlerhaufigkeit: 1
Verlernzahler: 237
Zeitangabe: 0
Datum: 2004.14.10
Zeit: 16:11:27
Temperatur: 18.0°C
ciclo wrote: Wed Mar 07, 2018 10:30 am Note: That control unit for Golf 6 will not work for the PDC system on your 6R.
Rocco-85
Post by Rocco-85 »
ok, and which will work?
any 7e0 ?
7e0 919 475 J sure will work, which other i can take
i found a 7e0 919 475 L on ebay for 55euro
7E0 is for front and rear PDC on PQ25.
Rocco-85
Post by Rocco-85 »
yes, i am adding front too, i have all the wirings i need allready installed, i am waiting the new front R20 bumper to install the sensors.
Rocco-85
Post by Rocco-85 »
I add footwell light front and rear and connect the red to A65 in bcm, it was right??? Because they don’t switch off when driving, only if I lock the car.
It depends. The red and black wire is the so called terminal 30G.
It is live when the car is unlocked. This means, if you power a light by this wire, it will be on when the car is unlocked (with a certain time out).
So if you connected the minus to the normal GND, they will be always on when the car is unlocked.
If you want them to function as a footwell light the same way it operates as the interior light:
Connect one wire of the footwell light to the 30G (like you did)
Connect the other wire of the footwell light to the brown and black wire of the interior light.
Rocco-85
Post by Rocco-85 »
Can I find the wire at the bcm connector?
T73a4 as i See Right?
PDC unit
7E0919475AA
Footwell lights = Dome lights, etc...
+ve = T73a/65
-ve = T73a/4 (managed by the BCM)
viewtopic.php?f=56&t=58703&start=3810#p527085
Rocco-85
Post by Rocco-85 »
i allready order 7E0919475L
its ok?
Yes
Rocco-85
Post by Rocco-85 »
Today i installed the RLS, mirror and the automatic light wirng
but i dont have lights..
i dont have the bixenons installed (wirings too)!! maybe i need other coding
06302DDonnerstag,05,April,2018,17:27:59:12669
VCDS -- Windows-basierter VAG/VAS-Emulator lauft auf Windows 7 x86
VCDS Version: PCI 17.8.0.1
Datenstand: 20170809 DS276.3
www.VCDSpro.de
Fahrzeug-Ident.-Nr.: WVWZZZ6RZCY234732 KFZ-Kennzeichen: SIXTH
Kilometerstand: 111430km Reparaturauftrag:
Fahrzeugtyp: 6R-VW25 (7E0)
Scan: 01 03 04 08 09 10 15 17 19 25 2E 37 44 56 61 77 0B
Fahrzeug-Ident.-Nr.: WVWZZZ6RZCY234732 Kilometerstand: 111430km
01-Motorelektronik -- Status: i.O. 0000
03-Bremsenelektronik -- Status: i.O. 0000
04-Lenkwinkelsensor -- Status: i.O. 0000
08-Klima-/Heizungsel. -- Status: i.O. 0000
09-Zentralelektrik -- Status: i.O. 0000
10-Einparkhilfe 2 -- Status: i.O. 0000
15-Airbag -- Status: i.O. 0000
17-Schalttafeleinsatz -- Status: i.O. 0000
19-Diagnoseinterface -- Status: i.O. 0000
25-Wegfahrsperre -- Status: i.O. 0000
2E-Media Player 3 -- Status: i.O. 0000
37-Navigation -- Status: i.O. 0000
44-Lenkhilfe -- Status: i.O. 0000
56-Radio -- Status: i.O. 0000
61-Batterieregelung -- Status: i.O. 0000
77-Telefon -- Status: i.O. 0000
Adresse 01: Motorelektronik (J000-CFWA) Labeldatei:. DRV\03P-906-021-CFW.clb
Teilenummer SW: 03P 906 021 B HW: 03P 907 425
Bauteil: R3 1.2l TDI H07 9978
Revision: 12005001 Seriennummer:
Codierung: 00114014032401080000
Betriebsnr.: WSC 46471 001 1048576
ASAM Datensatz: EV_ECM12TDI03103P906021B 001041
ROD: EV_ECM12TDI03103P906021AA.rod
VCID: 2759A9A75EDC697EEB-8072
Kein(e) Fehlercode(s) gefunden.
Readiness: 0 0 0 0 1
Adresse 03: Bremsenelektronik (J104) Labeldatei:. DRV\6R0-907-37x-ESP82.clb
Teilenummer SW: 6R0 907 379 BC HW: 6R0 907 379 AF
Bauteil: ESP8.2i front H05 0002
Revision: --------
Codierung: 210224E3417000B6842C24E582D300521300
Betriebsnr.: WSC 00788 648 00255
VCID: 000BD23B97327E468A-8054
Adresse 08: Klima-/Heizungsel. (J255) Labeldatei: 6R0-907-044.clb
Teilenummer SW: 6R0 907 044 H HW: 6R0 907 044 H
Bauteil: Climatronic H11 0711
Revision: V0000000
VCID: 387B7ADB8B62F68672-806C
Adresse 09: Zentralelektrik (J519) Labeldatei:. DRV\7E0-937-BCM-V1.clb
Teilenummer SW: 7E0 937 090 HW: 7E0 937 090
Bauteil: BCM PQ25 Max4 H80 0733
Revision: B9080001 Seriennummer: 0771 220150189
Codierung: 3AB02BBF08FB2400B3380F916CEB0ED05A80672F6005304D200000030000
Betriebsnr.: WSC 12345 123 12345
VCID: 68DBEA9B9B42A60622-803C
Subsystem 1 - Teilenummer: 1K0 955 559 AH Labeldatei: DRV\1K0-955-559-AG.CLB
Bauteil: RLS 030409 05 54 0402
Codierung: 06302D
Subsystem 2 - Teilenummer SW: 6R0 959 801 AB HW: 6R0 959 801 AB Labeldatei: 6R0-959-801.CLB
Bauteil: J386__TSG_FT 008 1611
Seriennummer: KU0KU002031200013631
Codierung: 58BC30
Subsystem 3 - Teilenummer SW: 6R0 959 802 AD HW: 6R0 959 802 AD Labeldatei: 6R0-959-802.CLB
Bauteil: J387__TSG_BT 008 1611
Seriennummer: KU0KU001031200013755
Codierung: 58BC30
Subsystem 4 - Teilenummer: 1K8 951 171 A
Bauteil: DWA-Sensor 00 001 0103
Codierung: 000000
Subsystem 5 - Teilenummer: 1K8 951 605 B
Bauteil: LIN BACKUP HO H11 9005
Codierung: 000000
Subsystem 6 - Teilenummer: 1K8 951 171 A
Codierung: 000000
Subsystem 7 - Teilenummer SW: 1K8 959 442 HW: 1K8 959 442
Bauteil: E221__MFL-DC1 H04 0103
Seriennummer: 29170000778570077135
Codierung: A4FFFF
Subsystem 8 - Teilenummer SW: 6R0 959 811 G HW: 6R0 959 811 G
Bauteil: J388__TSG_HL 008 1611
Seriennummer: KU0KU028021200012587
Codierung: 58BC32
Subsystem 9 - Teilenummer SW: 6R0 959 812 G HW: 6R0 959 812 G
Bauteil: J389__TSG_HR 008 1611
Seriennummer: KU0KU029021200015174
Codierung: 58BC32
Adresse 10: Einparkhilfe 2 (J446) Labeldatei:| DRV\7E0-919-475.clb
Teilenummer SW: 7E0 919 475 L HW: 7N0 919 475
Bauteil: PARKHILFE 8K H06 0106
Revision: -------- Seriennummer: 28261301103289
Codierung: 100004
Betriebsnr.: WSC 02756 790 50316
ASAM Datensatz: EV_VW75XParkAssis8K 001003
ROD: EV_EPHVA18VW250GPCS.rod
VCID: 3B7165D7B254DD9E9F-806E
Adresse 15: Airbag (J234) Labeldatei:| DRV\5K0-959-655.clb
Teilenummer SW: 6R0 959 655 K HW: 6R0 959 655 K
Bauteil: VW10Airbag01M H10 0020
Revision: -------- Seriennummer: 003GX014SRK3
Codierung: 00314D
Betriebsnr.: WSC 01383 785 00200
ASAM Datensatz: EV_AirbaVW10BPAVW250 A01001
VCID: 4A9F3013ED8E741614-801E
Crashsensor fόr Seitenairbag Fahrerseite:
Seriennummer: 3575HRB404T150GSBHT4
Crashsensor fόr Seitenairbag Beifahrerseite:
Seriennummer: 3585HRB405115IRSA0KN
Crashsensor fόr Seitenairbag hinten Fahrerseite:
Seriennummer: 3515RRB405T134DQKP71
Crashsensor fόr Seitenairbag hinten Beifahrerseite:
Seriennummer: 3525RRB4067134DQD8C5
Adresse 17: Schalttafeleinsatz (J285) Labeldatei:| DRV\5K0-920-xxx-17.clb
Teilenummer SW: 6R0 920 861 H HW: 6R0 920 861 H
Bauteil: KOMBI H04 0206
Seriennummer: 00000010513275
Codierung: 140801
ASAM Datensatz: EV_DashBoardUDSJCIPQ25 A01015
ROD: EV_DashBoardUDSJCIPQ25_A01_VW25.rod
VCID: 3A7F60D3BD6EE49684-806E
Adresse 19: Diagnoseinterface (J533) Labeldatei:. DRV\7E0-909-901.clb
Teilenummer SW: 7E0 909 901 HW: 7E0 937 090
Bauteil: GW-K-CAN TP20 H80 0733
Revision: B9080001
Codierung: 002200
Adresse 25: Wegfahrsperre (J285) Labeldatei:. DRV\5K0-920-xxx-25.clb
Bauteil: IMMO H04 0014
Seriennummer:
ASAM Datensatz: EV_ImmobUDSJCIPQ25 A01001
ROD: EV_ImmobUDSJCIPQ25.rod
Adresse 2E: Media Player 3 (J650) Labeldatei:. DRV\5N0-035-342.lbl
Teilenummer SW: 5N0 035 342 E HW: 5N0 035 342 E
Bauteil: SG EXT.PLAYER H13 0240
Revision: A1001003 Seriennummer: 7662028739
Codierung: 020000
VCID: 295DAF9F40C85F0EFD-807C
Adresse 37: Navigation (J794) Labeldatei:| DRV\3C0-035-270.clb
Teilenummer SW: 3C0 035 270 B HW: 3C0 035 270
Bauteil: RNS310 H20 0357
Revision: 11000000 Seriennummer: VWZ1Z2M8462982
Codierung: 040004010200000000000000
ASAM Datensatz: VW_RNS310 A02007
ROD: EV_VWRNS310UDS.rod
VCID: 193D9F5F18A8CF8E6D-804C
Adresse 44: Lenkhilfe Labeldatei: DRV\6Q0-423-156.clb
Teilenummer: 6R0 423 156 B
Bauteil: LenkhilfeTRW V277
Codierung: 11230
VCID: 2F694187EA2C313E23-807A
Adresse 61: Batterieregelung (J840) Labeldatei:. DRV\1K0-907-534.clb
Teilenummer SW: 7E0 907 534 HW: 7E0 937 090
Bauteil: Batt.regelung H80 0733
Codierung: 030B1A59
Subsystem 1 - Teilenummer SW: 6R0 915 181 E HW: 6R0 915 181 E
Bauteil: J367-BDM H08 0181
Seriennummer: 00000000004970247327
Adresse 77: Telefon (J412) Labeldatei:| DRV\7P6-035-730.clb
Teilenummer SW: 5K0 035 730 F HW: 5K0 035 730 F
Bauteil: TELEFON H09 2902
Revision: 1B001001 Seriennummer: 00007662017862
Codierung: 0100000000000210
ASAM Datensatz: EV_UHVNA A01719
ROD: UHVNA.rod
VCID: 285BAA9B53C26606E2-807C
Ende----------------------------(Dauer: 03:30)-----------------------------
Rocco-85
Post by Rocco-85 »
ok i found why.. i try the switch from my scirocco and it works...
LOL!
When you install the Bixenon headlights this will be the coding :arrow: viewtopic.php?f=56&t=70442&start=45#p530481
I wonder why you have not installed them yet.
I also wonder why you have been permanently trying to install parts that would not work in your 6R. No problem for this, at least it has been fun. :lol:
The last autoscan means that all the wiring you bought me works perfectly (Auto lights and RLS/Auto dimming mirror). Thanks for the report. 8)
Rocco-85
Post by Rocco-85 »
Yes all working perfectly!
I had the bixenons installed, but one of them get water inside and damaged the ballast.. two month now I have the xenons for opening by a guy but he is busy..
Time will come to reinstall them again.. I hope lol 😂
