Vento ~ Polo Sedan 1.5 Tdi RHD
Re: BCM Max upgrade in Vento IND manual transmission
sshakthi123 wrote: Sat Feb 23, 2019 4:32 am
Saturday,23,February,2019,09:17:33:00006
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 8.1 x64
VCDS Version: 18.2.0.3 (x64)
Data version: 20180212 DS287.0
www.Ross-Tech.com
VIN: MEXJ1760XJT075118   License Plate: 88
Mileage: 18080km-11234mi   Repair Order:
Chassis Type: 60-VW25 (7E0)
Scan: 01 03 04 08 09 10 15 17 19 25 44 56
VIN: MEXJ1760XJT075118   Mileage: 18080km-11234miles
56-Radio -- Status: OK 0000
Address 01: Engine (J623-CWXC)       Labels: None
   Part No SW: 03L 906 023 RS    HW: 03L 907 425 B
   Component: R4 1.5l TDI   H33 9977
   Revision: --H33---    Serial number:
   Coding: 00110116032500080000
   Shop #: WSC 00000 000 08192
   ASAM Dataset: EV_ECM15TDI02103L906023RS 001002
   ROD: EV_ECM15TDI02103L906023QT.rod
   VCID: 081F2E22B3333D0450-805C
Readiness: 0 0 0 0 0
Address 03: ABS Brakes (J104)       Labels: None
   Part No SW: 6R0 907 379 CA    HW: 6R0 907 379 AQ
   Component: ABS9.0 front  H01 0004
   Serial number: --------------
   Coding: 60DD2F63212A04C50615F46A845920020000
   ASAM Dataset: EV_Brake1ABS90BOSCH 003017
   ROD: EV_Brake1ABS90BOSCH_VW25.rod
   VCID: 7F0DB5FEE6FD7ABC61-802A
   Serial number: 03111813470922
   Coding: 01
   Shop #: WSC 00000 000 00000
   ROD: EV_LWSKLOVW25X.rod
   VCID: 7EF348FAE1F773B46A-802A
1 Fault Found:
1140738 - Steering angle sensor
          B1168 54 [009] - Missing Calibration / Basic Setting
                    Fault Status: 00000001
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 5
                    Mileage: 18085 km
                    Date: 2015.06.03
                    Time: 21:03:42
                    Voltage terminal 15: 13.30 V
                    Voltage terminal 30: 13.85 V
                    Terminal 15 status: On
   Part No SW: 6R0 907 044 Q    HW: 6R0 907 044 Q
   Component: Climatronic   H12 0615
   Revision: V0000000
   VCID: 4189F306D889CC4C57-8014
   Part No SW: 7E0 937 090 D    HW: 7E0 937 090 D
   Component: BCM PQ25 Max4 H82 0762
   Revision: B9082001    Serial number: 8601 222180856
   Coding: 3A904BFF48A10000013806407CEB96904980630F608C2141220000030000
   Shop #: WSC 12345 123 12345
   VCID: 2C57B2B24F0B312494-8078
   Subsystem 1 - Part No: 5K7 955 559 C  Labels: 5K7-955-559.CLB
   Component: RLS 290617 04  42  0106
   Coding: 0714DD
   Subsystem 2 - Part No SW: 6R0 959 802 EF    HW: 6R0 959 802 EF  Labels: 6R0-959-802.CLB
   Component: J386__TSG_FT  023 2521
   Serial number: 13202848170704050535
   Coding: 350000
   Subsystem 3 - Part No SW: 6R0 959 801 ED    HW: 6R0 959 801 ED  Labels: 6R0-959-801.CLB
   Component: J387__TSG_BT  023 2521
   Serial number: 13102849170705002249
   Coding: 040000
   Subsystem 4 - Part No SW: 6C0 959 442     HW: 6C0 959 442
   Serial number: 1811713320101504AB1B
   Coding: 240000
   Subsystem 5 - Part No SW: 6R0 959 811 S    HW: 6R0 959 811 S
   Component: J388__TSG_HL  022 1522
   Serial number: 13102728170704212031
   Subsystem 6 - Part No SW: 6R0 959 812 S    HW: 6R0 959 812 S
   Component: J389__TSG_HR  022 1522
   Serial number: 13102729170630002341
3 Faults Found:
00901 - Back-Up Lamps
            010 - Open or Short to Plus
                    Fault Status: 01101010
                    Fault Priority: 3
                    Fault Frequency: 1
                    Reset counter: 4
                    Mileage: 18081 km
                    Time Indication: 0
                    Date: 2015.06.03
                    Time: 20:13:11
02745 - Bulb for Daytime Running Light; Left
                    Fault Priority: 3
                    Fault Frequency: 1
                    Reset counter: 4
                    Mileage: 18081 km
                    Time Indication: 0
                    Date: 2015.06.02
                    Time: 20:26:19
02746 - Bulb for Daytime Running Light; Right
                    Fault Priority: 3
                    Fault Frequency: 1
                    Reset counter: 4
                    Mileage: 18081 km
                    Time Indication: 0
                    Date: 2015.06.02
                    Time: 20:26:19
   Part No SW: 7E0 919 475 K    HW: 7N0 919 475
   Component: PARKHILFE 8K  H06 0106
   Revision: --------    Serial number: 28231325304021
   Coding: 308002
   ASAM Dataset: EV_VW75XParkAssis4K 001004
   ROD: EV_VW75XParkAssis4K_001.rod
   VCID: 3A7B84EABD5F9F9416-806E
   Revision: --------    Serial number: 003GW01BGFS-
   Coding: 003036
   ROD: EV_AirbaVW10BPAVW250.rod
   VCID: 4999EB26E8B9040C8F-801C
   Part No SW: 6RF 920 862 B    HW: 6RF 920 862 B
   Component: KOMBI         H01 0217
   Coding: 1208000000
   ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A05729
   VCID: 4B95D12EE2C5161CBD-801E
   Part No SW: 7E0 909 901     HW: 7E0 937 090 D
   Component: GW-K-CAN TP20 H82 0762
   Revision: B9082001
   Coding: 002300
   VCID: 68DF0EA29B73DD04B0-803C
   Component: IMMO          H01 0217
   Serial number:
   ROD: EV_Immo_UDS_VDD_RM09.rod
   VCID: 6ADB74AA8D7FEF14A6-803E
   Part No SW: 1S2 909 144 P    HW: 1S2 909 144 P
   Component: EPS_ECU       H61 1702
   Coding: 0001000000000000
   ROD: EV_SteerAssisNSK_014.rod
   VCID: 4189F306D089CC4C57-8014
Address 56: Radio (J503)       Labels: None
   Part No SW: 6RF 035 187 C    HW: 6RF 035 187 C
   Component: Radio         557 5515
   Revision: --------    Serial number: VWZ7Z2R8103103
   Coding: 0E000440000010
   Shop #: WSC 12345 123 08192
   VCID: 4999EB26E0B9040C8F-801C
End-------------------------(Elapsed Time: 02:26)--------------------------
here are the images,
Image Image
Thanks for the report and the images.
I will send you the new wire that I told you previously to solve this issue of the reversing light.
All you have to do is install it and the problems are over, regardless BCM coding.
clue
The same but at address 03.
In the right dialog box you can do a search by the steering ring angle.
Nikhil wrote: Sat Feb 23, 2019 6:03 am T73b/48 is input signal to Bcm for Backup light from gear selector. It dosent give any output to reverse light.
Wrong. It depends on the type of BCM.
Please do not waste my time. I'm looking forward to finishing this installation. Thanks.
Nikhil
Drives: 1.6 tdi
Post by Nikhil »
It true that disabling Backup lamp diagnostics is not working in 090D Bcm.
Now remaing option is to give output to the Backup Lamp from T73b/12, like its present in automatic transmissions.
I respect your experience with wiring diagrams. But diagnosing Lamp by input signal given from a gear shifter it dosent sound correct to me.
Just trying to help sakthi to solve the error in his car with basic diagnostics procedures we use.
God knows how BCM gone know backup lamp is working
or not without its being connected to BCM.
No one is wasting your time here. The comments i do also read by other users. Not mandatory to give reply to my comments. Its FORUM.
He already has the best possible help. He doesn't need the help from someone who is monetarily benefiting from the knowledge extracted from the FORUMS.. :wink:
https://imgur.com/u8JPfA4
7,5m
Sakthi, I'll send it on Monday (absolutely free) and only the masters of the universe will know when it'll arrive to your address. (15-30 days, SP-IND)
Nikhil
Drives: 1.6 tdi
Post by Nikhil »
ciclo wrote: Sat Feb 23, 2019 7:24 am He already has the best possible help. He doesn't need the help from someone who is monetarily benefiting from the knowledge extracted from the FORUMS.. :wink:
I been helping him from before you even know him :lol:
Just to cover up your mistake that you forgot to send wiring for backup lamp adatpation you were trying to disable Backup lamp diagnostics via coding and mentioned that its not really needed to put new wire for Backup lamp. You know it very well that wire is needed so you sent it with other kits for manual transmission cars in past.
I am laughing on floor that still you post that non Bcm max gives output in mt cars to reverse lamp from T73b/48. Its input signal in non bcm max and bcm max. If we remove and isolate T73b/48 bcm wont understand that car is in reverse gear. Even in diagram you have posted, you can see the switch at gear shifter which giving input to T73b/48. Tell more lies to cover up your mistake. This one is not enough.
Its not your thread to tell someone to offer help or not. Have some sense to accept your mistake rather than blaming other things. Everyone do mistakes. I wish you had said same thing to hmthakur, when i offered him help to give the terminal pins which was sent wrong by you.
Don't wan talk more. Everyone knows about your great attitude. Please dont waste you precious time for replying to my comment. And if you dont want me to comment in these thread, please start your own forum which will allow only two people to write in thread.
I accept i leaned a lot from the knowledge you have shared on forum. Thanks for it.
The great satisfaction of absolute truth
Study here viewtopic.php?f=56&t=70736#p528319 + viewtopic.php?f=56&t=70736&start=75#p533244
or
here viewtopic.php?f=56&t=70902&start=30#p530329
None of these PQ25 vehicles (BCM Max adaptation) have the new wire for the reverse light installed. (VCDS = no fault code found)
Ask Sakthi or whoever you want who forces their authors to create these threads. None of them will tell you that they were created by their own will.
You're being ridiculous at its maximum expression, slightly retarded if you haven't understood the diagram, and you seem somewhat resentful because of my words related to monetary issues.
sshakthi123
Drives: Vento 1.5 TDI MT and Polo 6R 1.2 Tsi Dsg
Post by sshakthi123 »
ciclo wrote: Sat Feb 23, 2019 8:45 am Image
7,5m
Ciclo,
Can you add a cloth tape and the pin terminal removal tool with this?
Also it will be great if you can few BCM pins of different sizes? for my future upgrades any.
peter_dk25
Drives: Blue GT
Post by peter_dk25 »
ciclo wrote: Sat Feb 23, 2019 4:31 pm The great satisfaction of absolute truth
or
Fernando: I think that you are to good for this discussion - do not waste your time on such behavior :-)
sshakthi123 wrote: Sat Feb 23, 2019 5:20 pm Ciclo,
I can't do it, I made the shipment yesterday. 🚀✅
I send you the tracking number by email so you can verify that it's absolutely true.🤷‍♂️ so sorry.
peter_dk25 wrote: Sat Feb 23, 2019 5:58 pm Fernando: I think that you are to good for this discussion - do not waste your time on such behavior :-)
Sure Peter, absolutely agree. Many thanks for your advice.
I could have banned him, but even if I don't like what this user writes, I can't deny the right to other users to read what he writes ... :lol:
An example of how signals can be manipulated.
Magnifico...ooo....ooo...ooo...ooo.ooo.oo. 😂
sshakthi123
ciclo wrote: Sun Feb 24, 2019 3:14 am I can't do it, I made the shipment yesterday. 🚀✅
Okay 8)
sshakthi123
Re: BCM Max upgrade in Polo Sedan (Vento in india) manual highline
sshakthi123 wrote: Thu Feb 21, 2019 1:47 pm 1. ignition on -> windows down -> locked the car -> pour water immediately -> and it rolled up the windows
2. ignition on -> windows down -> DIDN't LOCK the car -> pour water immediately -> and it rolled up the windows
3. followed same procedure of #1 and #2 but pour the water after 5 to 10 mins -> THIS DIDN'T ROLL THE WINDOWS
Ciclo, I would really like to get the rain closing (point 3 above) working. I checked with other users (antardaksh and govindsharma) and they have it working.
here is an update on my observation,
lets say windows are down and car is locked. On pouring the water after sometime (after 15 mins) it has NO action. BUT but as soon as pouring the water, if we press car LOCK button then the windows are ROLLING UP. So my guess is the rain sensor is not connected with +30 (OR direct positive) hence it is not working.
Please provide me your expertise help fixing this.
edited by ciclo
Rain sensor is (from factory) connected to +30 (permanent 12v)
sshakthi123
iichel wrote: Mon Feb 25, 2019 1:03 pm Rain sensor is (from factory) connected to +30 (permanent 12v)
Thanks iichel, any guess what would be the issue then? how can we fix this.
