Locked
Ugabista, it is a totally different problem that you says.
Your problem is with the Chinese module, and his problem "was" the BCM.
Ugabista
Drives: Vw Polo 6R 1.6TDI 90CV CAYB
Post by Ugabista »
ciclo wrote:Ugabista, it is a totally different problem that you says.
Ahh ok, thanks :)
sambir
Drives: Polo 6R GTD (140HP 300NM)
Post by sambir »
Alright...next step is to buy a gtd emblem to fit on oem gti grill. I decided to just leave the led brightness as is...only a new bcm will fix this...
The chinese set makes the fogs start I guess it only starts the fog lights and this is just how the set works...would be nice to see the drls go on also. It does give the possibility to make the headlights start instead of fogs but this is not advised for xenon headlights...but only the drl leds and fogs would look neat.
Again thank you dude this small coding change made the ch and lh look like oem and I also got auto light now...what else could I ask for..
sambir
Post by sambir »
Aah would also be nice to fit the facelift taillights. Are you willing to build and sell me a pair of adapter cables?
Thank you very much for your confidence.
Long ago I have no parts to make wirings taillights. I am sorry sincerely.Image
However, you can buy here: https://www.x2car.de/Adapter-fuer-VW-Po ... 1-Facelift
Now 10% cheaper, last units.
http://www.uk-polos.net/view ... 09#p478298
VCDS coding
DRL OFF with handbrake up.
Address 09: Cent. Elect. (J519)
Byte23 mark bit4
Remember, your binary or hexadecimal need not match those shown here.
I guess only be possible for xenon or BlueMotion. :)
A good friend told me (by reviewing his BCM), but still I have to check. Image
Works on BM
Perfect. :D
jobbercete
Drives: Polo 6R 1.2 TSI 90cv Sport
Post by jobbercete »
Need to check that las vcds trick on my car, why do you think it will only work on BM or Polo's with Xenon? :roll: . There's another byte/bit with that option but it's not working for me...
Ah, still pending the mod you sent me the parts...I'm looking for a drill you know... :roll: :lol:
Because they are the only ones with DRLs controlled by the BCM.
Do not worry, I have another "new" encoding for BCM that might work for all POLO.
I will post soon... when I solve some small problems with VCDS.
Snap a photo when you install my gift ...Image
VCDS coding
The two static cornering lights turn on with reverse
Light switch must be low beam. (or AUTO :) )
Byte21 mark bit3
Thanks to wamba. :wink:
Also works om BM :p
:) Thanks for sharing your experience with BlueMotion and the best xenon retrofit (with all functions working perfectly), not OEM. :)
The coding for static cornering lights should work on all VW POLO 6R with them.
Locked
