Locked
Images of lights with xenon headlight. (for those who ask me)
Andrea 6r
Drives: 6r
Post by Andrea 6r »
hi ciclo,
I have a question for you. When I close the car close mirrors automatically,but after 10/15 minutes,open again .. is this normal?
I use ACC in pin 10 and the positive where the radio
I used the pin 20 for "windows line"
pin 10, from T28 connector? This is not a good place to catch ACC signal (+15), this wire is for side airbag crash sensor.
Do you have the installation instructions?
Andrea 6r
Drives: 6r
Post by Andrea 6r »
hello, unfortunately the pin 15 there is no electricity and for this I used the 10 (I speak the fuse box). I have no instructions, I "made" I based on information that I gave the seller and your
Fuse 10 and 15 have the same strip of power supply, so no problem by this part of installatión.
What is the function of "windows line" that you say?
Andrea 6r
Drives: 6r
Post by Andrea 6r »
the pin 20 in t28
If you have connected the wires according as indicated by the seller and the kit not working properly you should return the kit.
Mart!n-GTI-DK wrote:
ciclo wrote:I'll do, Mart!n-GTI-DK. I have to find a good painter.
Make sure the painter smooths everything to get rid of the textured surface. It will look much better. :)
Thanks for the advice, I'll keep in mind. :wink:
About the plastic parts marked in the following images, what would you do?
Mart!n-GTI-DK
Drives: '14 Polo BlueGT
Post by Mart!n-GTI-DK »
I have just handed my front spoiler/splitter of to the painter this morning. So I would paint it on yours aswell.
I haven't painted the bases of the side mirrors. I just think it would be too much with my gloss black mirrorcaps.
personally i always liked the black accents on a white polo.
but if you do the front splitter you also should consider the rear splitter in glossy black ;)
(and whilst we're at it, black mirrors and glossy black background of the rear logo and black wrapped roof :-) )
Thank you very much to you both for your advice, your opinion is very helpful for me. Image
but remember, in the end it is still your (masterpiece) car and colors are all about taste. and your taste should decide ;)
Andrea 6r
Drives: 6r
Post by Andrea 6r »
ciclo wrote:If you have connected the wires according as indicated by the seller and the kit not working properly you should return the kit.
The problem is this: I can not understand the problem is the kit or the connection. The seller, does not understand what I'm saying, and connections appear well made.
I have not the foggiest idea what to do
Andrea 6r, it's very easy, you have to tell to the seller:
Please, send me a wiring diagram with the connections of wires that I must do. Thanks.
After, show wiring diagram here. :wink:
Andrea 6r
Drives: 6r
Post by Andrea 6r »
I try, thanks :D
Locked
