Big Turbo GTI build Redine mag front cover DYNO VID
- KennyPOLO_Gti
Re: my GTI build / updated 01/04/09 now booked for the turbo
So whats your current spec as you have been driving it???
- Sponsor
all mods from when i got it or engine modsKennyPOLO_Gti wrote:So whats your current spec as you have been driving it???
- KennyPOLO_Gti
engine mods
Just so you can make me see them and get jealous!!!
- Sponsor
forged conrods
JE forged pistons
supertec inlet and exhaust valves
gas flowed cylinder head
inlet manifold Phenolic Insulator Gasket
solid flywheel
spec stage 3+ clutch
Peloquin LSD
JE forged pistons
solid flywheel
Peloquin LSD
eye that bit pipe was just a bit i had lying about when i built it, never give it another thought till it poppedgreat stuff shame about the pipe but looks like its the cheap stuff not sure how the 5 speed will cope with the power but will be finding out soon
i have some proper stuff on now along with some heat sheild which stinks when its hot (smells like a old kebab )
- Sponsor
the new pipe looks alot better what psi of boost are you running
it boosts canny high according to the graph my boost gauge only goes upto 1.5baryorks GT TDI wrote:the new pipe looks alot better what psi of boost are you running
- whitegtipolo
- Sponsor
if you go by the graph that ihi will not thank you for it but looks very nice power
turbo is a mitsubushi td05/18gyorks GT TDI wrote:if you go by the graph that ihi will not thank you for it but looks very nice power
- Sponsor
ihi fitment stillceedubya wrote:turbo is a mitsubushi td05/18gyorks GT TDI wrote:if you go by the graph that ihi will not thank you for it but looks very nice power
mate runs one on his s3 goes well
- Sponsor
its been a while my manifold is now fully made after changing my mind im now going to run external waste gated and now im having an inletmanifold too
more updates once the work starts
Re: my GTI build / updated 05/06/09
The build looks immense. You say you had a Gt tdi, I've not long ago got one myself. Is there a similar build thread for your old car? I'm curious to see what you did to that.
Im excited for you. It must put a huge smile on your face as you get closer to getting it on the road.
- Sponsor
youll have to do a serch think i did one still have some pics of the old motorDeepM1989 wrote:The build looks immense. You say you had a Gt tdi, I've not long ago got one myself. Is there a similar build thread for your old car? I'm curious to see what you did to that.
- Sponsor
yorks GT TDI wrote:its been a while my manifold is now fully made after changing my mind im now going to run external waste gated and now im having an inletmanifold too
with the turbo
