Polo Genesis & GT Engines
PHATBOYDAVE
Post by PHATBOYDAVE »
appart from the obvious can anyone tell me if there are any differences such as the cam, compresion, gearbox atuff like that. i just need some advice really because i have a GT engine and box and i also have the engine and box out of my genesis and im wondering which dirrection to go in.
will be glad of any info
cheers.
Dodgy Dave
metz
Moderator
Post by metz »
the genesis (if its 1.3) will be single point injection and 55bhp i would have thought whereas the gt will be multipoint injection and 75bhp...go GT 8)
pete69zx
Post by pete69zx »
I did once go to view a 1.3 Genesis, which had the GT engine in.
They guy selling told me that was the original engine for that car :?
Krupa
Post by Krupa »
Might have been an NZ engine, they look the same.
I've seen a black K plate Genesis with an NZ engine.
pete69zx
Post by pete69zx »
Krupa wrote:Might have been an NZ engine, they look the same.
Ah right... this was a L plate Genesis, IIRC
DanW
Post by DanW »
Krupa wrote: I've seen a black K plate Genesis with an NZ engine.
argh wtf?! Thought they decided to go SPI after 1991? :lol:
PHATBOYDAVE
engine differences
my polo is an L reg genesis 1272 ive had two of them but they both been single point fuel inection, some genesis polo's have the multipoint fuel injection but ive only seen it in the squareback shape which say Genesis Catalyst on the back.
does anyone know if the gearboxes are different (GT - Genesis)
(Cams Cylinder heads) are there any differences?
wiring looms are they different? does the whole lot have to be swapped over if you either do an engine swap or just the fuel injection system? i could go on for ages lol
cheers for the help though fellers!
P.S how do i get a pic of me darkhorse motor onto the site or signature?
amstrange1
Post by amstrange1 »
The Genesis will be an AAV-code SPI 55bhp 1272cc motor, with a 9.5:1 compression ratio, mild cam (204 degrees) and the same cylinder head and port/valve sizes as a GT. It'll more than likely use the 8P gearbox - which is quite high ratios compared to a GT.
The 3F GT is MPI 75bhp 1272cc, with 10:1 compression ratio, slightly hotter cam (219 degrees) and a close ratio gearbox.
The wiring looms are different on account of the different injection systems.
PHATBOYDAVE
WICKED
Thats the kinda sh*t im tryin to find out!!! cheers mate! Can you just swap the heads over do you know? you see my genesis engine is knocking its balls off (bottom end going big time) just waitin for the conrods to come flying out the case lol.
the GT engine i have was known to be smokin the last time it was running, so looking to try and somehow bodge meself a half decent sowin machine out the lot!
Krupa
Post by Krupa »
Just entered the reg of the Genesis I knew into RAC.
Manufacturer Volkswagen
Model POLO COUPE GENESIS
Body type coupe
Colour Black
Fuel type Petrol
Date manufactured 30 December 1992
Number of previous owners 3
Last owner change 20 September 2004
K335 MEJ if you want to look it up.
Definately had an NZ engine as I remember looking it up on his boot sticker.
Probably old stock left over from 1991.
Gareth_GT_Hatch
Post by Gareth_GT_Hatch »
its probably just an engine that was left over from old stock. They used NZ engines in mk2 golfs you see so when the golfs stopped being made maybe they had a few spare so they ended up in a load of polos.
DanW
Post by DanW »
Gareth_GT_Hatch wrote:its probably just an engine that was left over from old stock. They used NZ engines in mk2 golfs you see so when the golfs stopped being made maybe they had a few spare so they ended up in a load of polos.
Yeah my parents used to have an NZ Golf, pitty I chose red (fadded really quickly), but then again I was only 7 or 8 (if that) at the time.
amstrange1
Re: WICKED
PHATBOYDAVE wrote:Thats the kinda sh*t im tryin to find out!!! cheers mate! Can you just swap the heads over do you know? you see my genesis engine is knocking its balls off (bottom end going big time) just waitin for the conrods to come flying out the case lol.
The heads can be swapped over - but obviously use the GT cam in the Genesis head if you're putting it on the GT.
PHATBOYDAVE
Valve springs
Cheers for this info mate! will i have to swap all the valve springs and what ava ya from the GT head to the genesis head when i swap the cam or are they the same?
amstrange1
Just whack the cam in. If you're feeling keen you could put new hydraulic tappets in though.
