Sony MDX-690 (as requested by 2K)
Posted: Sun Jun 15, 2003 3:40 pm
by KarlM
Heres all the information i could find, sorry its not much...
Features:
Mechanism: 1 x MiniDisc®
Tuner RDS EON
ABC (Automatic Bandwidth Control)
MDLP
EQ-7 (7 Band Equalizer)
Max. Output Power (1kHz, 4 ohm) 4x52 W
Removable Front Panel
Tech Spec
Tuner / ABC (Automatic Bandwidth Control)
DAB Control
Station Presets: FM / MW / LW
RDS EON
AMS (Automatic Music Sensor) -
Dolby NR
Integrated MD, CD Player
MD: MDLP
MD: Shock Resistant Memory 4 Mbit, 10 sec
MD: Wide Bit Stream
MD: Data Compression ATRAC, ATRAC3
CD: CD-R / CD-RW Playback capability
CD: MP3 Playback capability
CD: ID3 Tag (Track-, Artist-, Album name)
CD: Electronic Shock Protection
CD: CD Text
Frequency Response 10 - 20000 Hz
Signal to Noise Ratio 90 dB
Repeat / Shuffle
Amplifier
Output Power (DIN 45324, 4 ohm) 4x 27 W
Max. Output Power (1kHz, 4 ohm) 4x 52 W
My Best sound Position:
Separate Bass, Treble Control
Loudness / D-Bass (Dynamic Bass)
Pre-amp Output: Front / Rear
5.5 Volt Pre-amp Output
Sub Output / Switchable Low Pass Filter
Sub Volume Control
AUX Input
Key Illumination: Amber, Green, Red (switchable)
Removable Front Panel & Security Code
Integrated Clock: 24 h / 12 h
Telephone Attenuator
ISO Connector supplied
Dimensions (WxHxD in mm) approx. 178x50x182
Supplied Remote Control
Optional Accessories
Safety Commander RM-X5S, RM-X4S
IR Card Commander -
PS i'm being sarcastic :P
Posted: Sun Jun 15, 2003 4:39 pm
by polo2k
hmm have you got any more info to sway me cos im not convinced :P
now will it suit my application?
i want 3 rca outs and 4x high leval outs
and 1 rca input
sorry but i dont want to spend christmas reading that list :P
Posted: Sun Jun 15, 2003 4:57 pm
by KarlM
There is one 5.5volt pre amp output and one sub output - as well as 4 x 52w speaker outputs.
I would run your sub amps from the sub out, and get a Y lead to create 3 outputs in total.
It also has 1 input for a changer and 1 AUX input.
Drop a line if you need anymore input.
Karl
Posted: Sun Jun 15, 2003 4:59 pm
by KarlM
If anybody else would like info about thier headunit, please let me know by PM
