Page 1 of 2
Cambelt change
Posted: Thu Jul 07, 2005 8:38 pm
by ][=][anson
looking through the history of my car there doesn't seem to be any record of a cambelt change and this is slightly worrying me. the cart has just done 74k and i am worried if it hasn't been changed that my car may soon die
is there any way i can tell if it has been changed?? if not i guess it would be advisable to get it done, yes? if so how much am i looking at to have it done???
Posted: Thu Jul 07, 2005 9:47 pm
by helios1
Try removing the cambelt and giving it an inspection. If your not sure what your looking for in the wear and tear then ask a local dealer or someone who knows cars.
Its pretty simple to remove i think - get a Haynes manual. Its the best thing i ever bought for my polo!
Posted: Thu Jul 07, 2005 9:56 pm
by ][=][anson
dont have a clue where to start tbh. and cant find a haynes manual for my car as the n - s reg manual does not cover the 16v
Posted: Thu Jul 07, 2005 10:04 pm
by helios1
Ah crap yeah, forgot about that. Try getting a polo one from the library anyways - theres a possibilty of some similarities - although the 16v is DOHC so i guess thered be 2 cam belts? I dont know a lot about DOHCs.
Posted: Fri Jul 08, 2005 12:21 am
by bstardchild
helios1 wrote:Try removing the cambelt and giving it an inspection. If your not sure what your looking for in the wear and tear then ask a local dealer or someone who knows cars.
Noooooooo - don't do that if it's still intact leave well alone untill you have all the bits to replace it!!!
Posted: Fri Jul 08, 2005 12:22 am
by bstardchild
helios1 wrote:the 16v is DOHC so i guess thered be 2 cam belts? I dont know a lot about DOHCs.
You are right - you don't know a lot about DOHC engines
They still have one belt but it's longer to go round two cams
Posted: Fri Jul 08, 2005 9:42 am
by ][=][anson
is it easy enough to check?? if so how can i??
Posted: Fri Jul 08, 2005 11:15 am
by bstardchild
][=][anson wrote:is it easy enough to check?? if so how can i??
Well you need to get enough of the timing belt cover off to enable you too look at the belt - small section and then turn the engine over by hand to look at the whole of the belt bit by bit.....
What are you looking for? Basically......
- Smooth clean edge both sides of the belt so you know it hasn't been rubbing
- All teeth present and correct
- No cracks in the rubber between the teeth
- No cracks or frays on the outside of the belt
- Belt tension correct (twist the belt in a free section should twist 90 deg any more and either tensioner is fubar or the belt is overstretched and the tensioner can't adjust anymore
BUT and it's a big BUT
- None of the above even if all perfect will save you from the belt failing
- they have a service life and once past their replacement mileage of age it is a really big risk to continue with the same belt
IF it snaps you can say goodbye to all the valves and probably the pistons too so you then will need to find a 2nd hand engine to replace it with.
Much better just to replace it and have 3 years or 60,000 miles of worry free motoring.
Posted: Fri Jul 08, 2005 12:19 pm
by ][=][anson
bstardchild wrote:Much better just to replace it and have 3 years or 60,000 miles of worry free motoring.
thats what i was thinking really.
i've phoned VW this morning and been quoted £295 inc VAT & Labour to have the belt changed. Does this seem "reasonable"??
Posted: Fri Jul 08, 2005 1:00 pm
by bstardchild
][=][anson wrote:bstardchild wrote:Much better just to replace it and have 3 years or 60,000 miles of worry free motoring.
Hmmm depends on their labour rate - it's about 2 hrs to do - the really important thing is the tensioners - I don't know if this applies to the 16V MKIV but on a lot of cars they now replace the tensioners as well as the belt as it's often teh tensioner that breaks up and leads to the belt failing - someone with a 16V must be able to advise you
Posted: Fri Jul 08, 2005 1:59 pm
by ][=][anson
yeah that price includes the tensioners. can anyone with a 16v offer there thoughts????
Posted: Fri Jul 08, 2005 4:05 pm
by Ajit_mk2_16v
][=][anson wrote:yeah that price includes the tensioners. can anyone with a 16v offer there thoughts????
rough guide
belt £15
tensior £25
my garage in london (independent) charged 2 hours labour at £100
Posted: Fri Jul 08, 2005 4:13 pm
by ][=][anson
shame i dont live in London as i'd be round in a jiffy!!! haha. i'm gunna check the local garages and see what prices i can get! cheers for the guide though
Posted: Fri Jul 08, 2005 4:17 pm
by bstardchild
Ajit_mk2_16v wrote:rough guide
belt £15
tensior £25
Labour rate at a reputable independant compared to a VW garage makes a big difference
take the VAT off = £250
Say VW parts are a tad dearer £25 and £35 for belt and tensioner respectively
leaves £190 labour or £95 per hour - sounds bout right for a dealership - damned if I'd pay it tho!!!
Posted: Fri Jul 08, 2005 4:32 pm
by ][=][anson
a lad i work withs Dad has a garage so i'll ask him on monday 4 a quote. hopefully will be a little more bank balance friendly than VW!!!!
