UK-POLOS.NET - THE VW Polo Forum • Internal light switch removal
Posted: Wed Jul 20, 2005 8:08 pm
by KITT
The dial on my 16v that turns the lights on/off has a problem. It seems to intermittantly work. Does anyone know how you get behind the dashboard to see if the wires are loose?
cheers
Posted: Wed Jul 20, 2005 8:11 pm
by AKs_SlickPolo
is it the knurled wheel thingy that adjusts the dash lights wot u mean? if so ull notice its connected with the headlight switch as a single unit. that whole unit usually prises off when a small flathead screwdriver is poked on the side. Then just gently pull it out to expose the wires at the back of it.
Posted: Wed Jul 20, 2005 8:16 pm
by KITT
Not the knurled wheel thingy, but the actual main light rotary knob. All the lights do seem to work (except the passenger, rear cluster), but the dash lights don't :( If you fiddle with the switch, I can get the dash ones to light but they soon stop again.
I'll have a play at the weekend :)
