Phono(RCA) wire grounding?
Posted: Sat Aug 13, 2005 11:32 am
by jackal42
Hi, new here.
Installing sub into my polo at the mo. When i came across the phono cable from my autoleads amp wiring kit, i noticed an extra wire on it. I guess this is an earth cable.
However, this small wire is about 5mm too short to connect to my hu. does this really need to be connected?
I do have another phono cable for amp wiring, but this one has no earth wire?!
Posted: Sat Aug 13, 2005 11:47 am
by polocoupcl
doesnt have to be connected but it would get rid of any interfearance from your rca lead. I used mine for my remote wire ;)
Posted: Sat Aug 13, 2005 12:11 pm
by ModifiedMadness
I thought that's usually what they are for, to be used as a remote wire, however if it doesn't fit, all you have to do is use another one, like I had to, just because the actual wires were so thin they were not making a good enough connection
Posted: Sat Aug 13, 2005 12:20 pm
by jackal42
i will try without it connected first, and see if i get any interferance.
thanks.
Posted: Sat Aug 13, 2005 12:28 pm
by ModifiedMadness
How thick is the other wire? About 2-3mm?
Posted: Sat Aug 13, 2005 1:41 pm
by wul3er
I too thought this was a Remote cable. :oops:
Posted: Sat Aug 13, 2005 3:15 pm
by jackal42
It is actually moulded into the phono cable, so im thinking this is an earth wire. In the wiring kit there was a seperate remote wire.
The wiring diagram shows the power and remote down one side of the car and the Phono(RCA) down the other.
Posted: Sat Aug 13, 2005 3:43 pm
by ModifiedMadness
Mine was as well, there was a thin cable in between the 2 RCA's which is a remote lead, but as I say there just wasn't enough wire in there to make a connection - Didn't know they had earth leads?
Posted: Sat Aug 13, 2005 4:18 pm
by polocoupcl
its to earth the rca to get rid of static in the rca's. All good quality Rca leads have them :) origionally used it as a remote lead but soon changed it.
Posted: Sun Aug 14, 2005 9:07 am
by inder
It's defo an earth lead, but as mentioned - it's very useful to use it as the remote wire, saves running another cable :lol:
