UK-POLOS.NET - THE VW Polo Forum • will it go SPROIIIIIING? :)
Posted: Fri Oct 21, 2005 5:42 pm
by Tahrey1043
i need to seek the advice of anyone who's ever reconned or re-cased a gearbox here... don't worry, i have absolutely no intent of reconning the 4-speed or replacing the bearing, as i know i haven't the tools or fine motor neurone control to do it...
anyhow, thanks to crap weather and a general feeling of fatigue and malaise on getting home from work/college (bleurrgh) i haven't had chance to do anything much with the pair of boxes lying around my house, save clear some of the inch-thick coating of road grime and degraded waxoyl from the new one.
which is good because it gave my brain time to hit me with this realisation about my plan to open the case on the 4-speed and investigate the differential (after draining the oil of course)
are there any parts in there that are held in place by the casing? or any that will block it coming apart?
i'm thinking for the first part, the shafts themselves, any "loose" bits of the diff etc
for the second, the right-hand shaft hub, release bearing parts, the outer spline of the input shaft
especially anything that's going to fall out or will fly across the room/into my eye ;) under spring tension! (spreading ultra-smellerific gearbox oil as it goes)
