Heaters/ac only working on Speed 4 On Gti
Posted: Fri Oct 21, 2005 11:05 pm
by dom596
my Heaters only working on Speed 4 On my polo Gti 2000 model. 1,2,3 are dead been told its a resistor pack? anyone ever fitted one? where do they go? vw want 40 for the part!!!
Posted: Wed Nov 02, 2005 10:01 am
by JWC
If you go into the passenger footwell, peal back the foam gently, and then you will see a few screws on the far left, take them out and the bottom of the fan unit comes off. The pack is in there its a green coily resistor type thingy about 2 inch long. You unscrew it, pull the leads off and then reverse what you just did after bunging the new one on.
Bet you can't get the foam back in a fashion where it stays back!!! :)
Posted: Wed Nov 02, 2005 10:25 am
by inder
That foam stuff takes the p*** sometimes, did you know, its meant to be held in place with plastic screws with large heads on them, PLUS a large re-useable strap/cable tie - this strap is nearly £20, mine did not come with it :roll:
Posted: Wed Nov 02, 2005 1:52 pm
by JWC
Re-usable my arse. They are about as re-usuable as a firework. Mine has the AC and stuff and this makes the whole thing worse. The other models are less of a pain.
Posted: Wed Nov 02, 2005 2:05 pm
by inder
Its the cost of one that is annoying for me, ahh well, I don't see in that seat :)
Posted: Wed Nov 02, 2005 3:52 pm
by JWC
couldn't you use some tie-wraps? Besides, how did you get it off? You don't need to get it off to get to the resistor pack, just fold it back over it the blower is on the car left next to the A pilar.
Posted: Wed Nov 02, 2005 4:09 pm
by inder
I never took it off, if you talking to me? Was never there in first place. Ive got the black screws holding it up in place, works fine
Posted: Wed Nov 02, 2005 5:00 pm
by JWC
Yours has AC?
Posted: Wed Nov 02, 2005 6:04 pm
by inder
Oh no, just the normal air controls, no AC or Climatronic
by inder
Posted: Wed Nov 02, 2005 8:25 pm
by JWC
Oh no an echo echo!
Posted: Thu Nov 03, 2005 12:22 am
by inder
how odd, I only posted it once :D
