HELP!
Posted: Tue Nov 15, 2005 10:40 pm
by owenjt
I've just been round to a mates to try and fix my horn - hasn't worked for a few weeks and can't pass my MOT without it. Anyway i knew it wasn't the actual horn that was the problem so we ended up removing the steering wheel and fixing the problem, only to find once back together that the airbag light stays on after the 3 second test!
We checked the wiring and it seems ok - has anyone had this problem before or know what's wrong? It says in the manual to take it to a vw dealer at the nearest opportunity!
Posted: Wed Nov 16, 2005 10:02 am
by david burton
I think (from memory) you have to take it to VW to get it reset
Posted: Wed Nov 16, 2005 12:22 pm
by owenjt
Yeah found out its got to be reset - vw charge £61 to do this! However phoned up a local vw specialist and he said it takes 5 mins and charges only £15 - sorted! :D
Posted: Sun Nov 27, 2005 11:40 pm
by JTLondon
So... the other night I put my headlights on and the beam lasted a split second and they suddenly went off.
Both headlights dont work now, so I'm suspecting the fuse went.
So were do I locate the fuse for the headlights? :?
The only fuses I've found are 4 fuses in a box on top of my battery. :roll:
Posted: Mon Nov 28, 2005 9:47 am
by david burton
under the steering wheel in the little cubby box......
Posted: Mon Nov 28, 2005 1:08 pm
by Noddy
I had to replace my horn's fuse recently..
Like David said, you pop open the drivers side cubby box, unhook it from its mountings by sliding it forwards and upwards, then (I found it much easier this way) undo the two large screws on the left and right underside of the fuse area - giving you perfect access to the row of smaller fuses on the bottom.
If you just pop the cubby box out you might find it hard to get at the smaller fuses since the lip of the lower piece of plastic bends up and restricts access.
Good luck.
Posted: Tue Nov 29, 2005 7:54 pm
by JTLondon
Thanks Noddy.
So now I've managed to get access to the fuses and located the 2 fuses for the low beam headlights.
The fuses dont look broken, how can I tell? and I've pulled out the left and right fuses and cant remember which goes where :oops:
Is the Right low beam the 10amp and the Left the 15amp?
So, how can I tell whether its the bulbs that have blown or the fuses?
Any help would be much appreciated. Thanks
Posted: Tue Nov 29, 2005 9:48 pm
by david burton
er - they should both be the same rating!
Posted: Tue Nov 29, 2005 11:31 pm
by suby786
lol at different fuse ratings...they should certainly be the same...
about the airbag light... mine is on due to a faulty contact i think that i cant seem to find.. anyway its past 2 MOT's with this light on...either the MOT station i use is blind or its not required as not all cars have airbags...so hence mite not be tested but then again not all cars have ABS, mine does and that would fail if the light was on...weird heh
Posted: Wed Nov 30, 2005 10:04 am
by JTLondon
david burton wrote:er - they should both be the same rating!
I just found them like that :?
So if I was to get new ones should I get 15 or 10amp?
Also any way to tell whether its the fuses or the bulbs that are faulty?
Posted: Wed Nov 30, 2005 10:56 am
by david burton
you need a mutimeter to check the continuity of the fuse.
that should tell you which one has gone. It could be the relay too though, as the headlights will use a relay too.
what are the symptoms?
edit: just buy new fuses and test these. If they look ok, then the bulbs have probably gone
Posted: Wed Nov 30, 2005 10:31 pm
by JTLondon
Need to get the fuses tomorrow, should I get 10A or 15A?
Parents bought be a bulb when I got back, only £6 they said. Only one of my bulbs had gone, but both didnt work.
Is it the relay that makes them both not work in the event of one of them blowing?
Symptons: I got in the car the other night, turned on the car and switched the headlights on, they flashed for a very split second and went out. Now only the parking lights come on when I switch it to low beam headlights.
I hope this new bulb is bright.
